Home » Modeling » EMF » Hibernate timeout on connection
Hibernate timeout on connection [message #1004193] Tue, 22 January 2013 14:16 Go to next message
I have a small app that connects on multiple hosts, but sometimes those hosts are down or I can't access by some reasons.
I am connecting like this:
serviceRegistry = new ServiceRegistryBuilder().applySettings(configuration.getProperties()).buildServiceRegistry();
sessionFactory = configuration.buildSessionFactory(serviceRegistry);
Hibernate keeps trying to connect forever on unreachable host. Is there a way to set a timeout on hibernate connection?
Re: Hibernate timeout on connection [message #1004243 is a reply to message #1004193] Tue, 22 January 2013 16:25 Go to previous messageGo to next message
Hi Rafael,
Hmm, I would need to do a google search to reply on this question, I guess it is possible to set a connection timeout,
maybe you have autoReconnect set somehow (this is possible with mysql it seems).
Let me know if you find any specific solutions when searching the net. It would be great if you can post any solutions here.
gr. Martin
With Regards, Martin Taal
Springsite/Elver.org
The Netherlands
Cell: +31 (0)6 288 48 943
Tel: +31 (0)84 420 2397
Fax: +31 (0)84 225 9307
Mail: mtaal@xxxxxxxx - mtaal@xxxxxxxx
Re: Hibernate timeout on connection [message #1005140 is a reply to message #1004193] Thu, 24 January 2013 09:49 Go to previous messageGo to next message
Thanks for replaying Martin. I searched but couldn't find anything.
Re: Hibernate timeout on connection [message #1005435 is a reply to message #1005140] Fri, 25 January 2013 07:38 Go to previous messageGo to next message
Hi Rafael,
Are you using a connection pool mechanism (c3p?)? Which database are you on?
gr. Martin
The Netherlands
Re: Hibernate timeout on connection [message #1005729 is a reply to message #1005435] Mon, 28 January 2013 07:47 Go to previous messageGo to next message
Yes, I am using c3p0, connectinng on MySQl
Here's my hibernate configuration:
<!DOCTYPE hibernate-configuration PUBLIC
"-//Hibernate/Hibernate Configuration DTD 3.0//EN"
"http://hibernate.sourceforge.net/hibernate-configuration-3.0.dtd">
<hibernate-configuration>
<session-factory>
<property name="hibernate.connection.driver_class">com.mysql.jdbc.Driver</property>
<property name="hibernate.connection.password">****</property>
<property name="hibernate.connection.url">jdbc:mysql://localhost:3306/flexadmin</property>
<property name="hibernate.connection.username">***</property>
<property name="hibernate.dialect">org.hibernate.dialect.MySQL5Dialect</property>
<property name="hibernate.show_sql">true</property>
<property name="hibernate.auto">true</property>
<property name="hibernate.connection.autoReconnect">true</property>
<property name="hibernate.connection.provider_class">org.hibernate.service.jdbc.connections.internal.C3P0ConnectionProvider</property>
<property name="hibernate.c3p0.acquire_increment">1</property>
<property name="hibernate.c3p0.validate">true</property>
<property name="hibernate.c3p0.min_size">5</property>
<property name="hibernate.c3p0.max_size">100</property>
<property name="hibernate.c3p0.timeout">1800</property>
<property name="hibernate.c3p0.max_statements">50</property>
<property name="hibernate.c3p0.preferredTestQuery">SELECT 1;</property>
<property name="hibernate.c3p0.testConnectionOnCheckout">true</property>
<property name="hibernate.c3p0.idle_test_period">100</property>
</session-factory>
</hibernate-configuration>
As far as I know, c3p0 timeout refers to the connection's lifetime, not the attempt to connect.
Re: Hibernate timeout on connection [message #1005753 is a reply to message #1005729] Mon, 28 January 2013 09:53 Go to previous messageGo to next message
Have you tried without the autoReconnect option?
In your first post, when say tries to reconnect forever. It means that hibernate tries many times to create a
connection? Or that one connection hangs indefinitely?
gr. Martin
> <session-factory>
> <property name="hibernate.connection.autoReconnect">true</property> <property
> </session-factory>
The Netherlands
Re: Hibernate timeout on connection [message #1005805 is a reply to message #1005753] Mon, 28 January 2013 14:40 Go to previous messageGo to next message
I tried with autoReconnect option false and got the same result.
How can I see if it's trying to make severel connections or just a eternal one?
Re: Hibernate timeout on connection [message #1005810 is a reply to message #1005805] Mon, 28 January 2013 14:52 Go to previous messageGo to next message
Hi Rafael,
Debug in the hibernate code? I mean, when running in eclipse you can pause all threads and check where they are...
Have you asked this on the hibernate forum? They don't always answer but maybe.
gr. Martin
The Netherlands
Re: Hibernate timeout on connection [message #1008003 is a reply to message #1005810] Fri, 08 February 2013 09:59 Go to previous message
Hello Martin, sorry for the delay.
Hibernate was making a eternal attempt to connect indeed. I found a solution on c3p0, using the propertie "checkoutTimeout" and "acquireRetryAttempts". With these, i now can set a timeout on connection.
Thanks for the help anyway.
Previous Topic:[CDO] Offline clone doesn't reload offline branche
Next Topic:EMF-to-XSD Model Transformation
Current Time: Sat Jul 26 11:11:02 EDT 2025
Powered by FUDForum. Page generated in 0.06634 seconds
