Eclipse PDE compatibility layer 3.3 to 4.2 migration [message #989487] |
Thu, 06 December 2012 08:10  |
I'm trying to find some step-by-step/beginners guides to migrating features/plugins from Eclipse 3.3 to 4.2 Juno with the compatibility layer. I found some notes from Lars Vogel (unable to link - stupid error message) but right from the start I get stuck because I have no product configuration file (.product) and when it starts suggesting installing new plugins I've no idea where to get them from (i.e. org.eclipse.equinox.ds).
We're all stuck on 3.3 until I can get this package migrated, so any help much appreciated. If 3.3 to 4.2 is too much of a leap then any help for 3.7 to 4.2 and/or 3.3 to 3.7 would be extremely helpful.
Regards.
Brendan.
link error was: You can only use links to eclipse.org sites while you have fewer than 5 messages.
[Updated on: Wed, 09 January 2013 09:27] by Moderator
Re: Eclipse PDE compatibility layer 3.3 to 4.2 migration [message #998181 is a reply to message #990237] |
Wed, 09 January 2013 09:10   |
Thomas & Dani, thanks for your replies. Apologies for my sporadic posting on here, I had some time off over the festive period.
I tried simply copying over the plugins and features from the old installation into Juno, and then when I start eclipse I get the following stack trace in the workspace/.../.log file:
!SESSION 2013-01-09 14:02:16.134 -----------------------------------------------
eclipse.buildId=M20120914-1800
java.version=1.7.0_09
BootLoader constants: OS=win32, ARCH=x86, WS=win32, NL=en_GB
Framework arguments: -product org.eclipse.epp.package.java.product
Command-line arguments: -os win32 -ws win32 -arch x86 -product org.eclipse.epp.package.java.product
!ENTRY org.eclipse.jface 4 0 2013-01-09 14:02:20.400
!MESSAGE Undefined context while filtering dialog/window contexts
!STACK 0
org.eclipse.core.commands.common.NotDefinedException: Cannot get the parent identifier from an undefined context. org.eclipse.jst.j2ee.J2eeMainActionSet4
at org.eclipse.core.commands.contexts.Context.getParentId(Context.java:201)
at org.eclipse.jface.bindings.BindingManager.createFilteredContextTreeFor(BindingManager.java:825)
at org.eclipse.jface.bindings.BindingManager.recomputeBindings(BindingManager.java:1721)
at org.eclipse.jface.bindings.BindingManager.contextManagerChanged(BindingManager.java:689)
at org.eclipse.core.commands.contexts.ContextManager.fireContextManagerChanged(ContextManager.java:165)
at org.eclipse.core.commands.contexts.ContextManager.setActiveContextIds(ContextManager.java:295)
at org.eclipse.e4.ui.bindings.internal.BindingServiceImpl.setContextIds(BindingServiceImpl.java:237)
I get the same exception for J2eeMainActionSet3, J2eeMainActionSet2 & J2eeMainActionSet, one after the other starting with J2eeMainActionSet4, then the messages:
!ENTRY org.eclipse.ui 4 4 2013-01-09 14:02:20.513
!MESSAGE Unable to find Action Set: org.eclipse.jst.j2ee.J2eeMainActionSet
!MESSAGE Unable to find Action Set: org.eclipse.jst.j2ee.J2eeMainActionSet2
!ENTRY org.eclipse.ui 4 4 2013-01-09 14:02:20.514
!MESSAGE Unable to find Action Set: org.eclipse.jst.j2ee.J2eeMainActionSet3
!MESSAGE Unable to find Action Set: org.eclipse.jst.j2ee.J2eeMainActionSet4
I think the decompiler idea is a good one, but I think I need to address the above issues first.
Brendan.
Re: Eclipse PDE compatibility layer 3.3 to 4.2 migration [message #998259 is a reply to message #998181] |
Wed, 09 January 2013 12:14   |
This is not supported and is expected to cause trouble (as you can see).
You have to download the build you need and install it into an empty folder.
Dani
> java.vendor=Oracle Corporation
> !STACK 0
> at
> at
> at
> at
> at
> at
> at
> Brendan.
Re: Eclipse PDE compatibility layer 3.3 to 4.2 migration [message #1004996 is a reply to message #999051] |
Thu, 24 January 2013 04:32  |
Hi, I wanted to clarify that I only copied files from the plugins and features directory
that were bundled with the package I'm trying to "port" over to Juno, I did not overwrite
any of the eclipse or other files.
I tried again with a freshly downloaded Eclipse Classic and this is what I'm seeing in the
log file...
This is looking to me like I probably need to decompile the code and rebuild in the Juno
PDK environment, does this seem reasonable or could I be missing something?
Thanks.
!SESSION 2013-01-24 09:26:24.713 -----------------------------------------------
!ENTRY org.eclipse.core.resources 2 10035 2013-01-24 09:26:25.868
!MESSAGE The workspace exited with unsaved changes in the previous session; refreshing workspace to recover changes.
!ENTRY org.eclipse.jface 4 0 2013-01-24 09:26:28.324
!STACK 0
at org.eclipse.e4.core.internal.di.MethodRequestor.execute(MethodRequestor.java:56)
at org.eclipse.e4.core.internal.di.InjectorImpl.inject(InjectorImpl.java:105)
at org.eclipse.e4.core.internal.di.InjectorImpl.internalMake(InjectorImpl.java:319)
at org.eclipse.e4.core.internal.di.InjectorImpl.make(InjectorImpl.java:240)
at org.eclipse.e4.core.contexts.ContextInjectionFactory.make(ContextInjectionFactory.java:161)
at org.eclipse.e4.ui.bindings.internal.BindingServiceCreationFunction.compute(BindingServiceCreationFunction.java:32)
at org.eclipse.e4.core.internal.contexts.ValueComputation.get(ValueComputation.java:60)
at org.eclipse.e4.core.internal.contexts.EclipseContext.internalGet(EclipseContext.java:229)
at org.eclipse.e4.core.internal.contexts.EclipseContext.internalGet(EclipseContext.java:238)
at org.eclipse.e4.core.internal.contexts.EclipseContext.get(EclipseContext.java:200)
at org.eclipse.e4.core.internal.contexts.ContextObjectSupplier$ContextInjectionListener.update(ContextObjectSupplier.java:68)
at org.eclipse.e4.core.internal.contexts.TrackableComputationExt.update(TrackableComputationExt.java:107)
at org.eclipse.e4.core.internal.contexts.EclipseContext.runAndTrack(EclipseContext.java:299)
at org.eclipse.e4.core.internal.contexts.ContextObjectSupplier.get(ContextObjectSupplier.java:167)
at org.eclipse.e4.core.internal.di.InjectorImpl.resolveArgs(InjectorImpl.java:428)
at org.eclipse.e4.core.internal.di.InjectorImpl.resolveRequestorArgs(InjectorImpl.java:375)
at org.eclipse.e4.core.internal.di.InjectorImpl.inject(InjectorImpl.java:100)
at org.eclipse.e4.ui.workbench.renderers.swt.ToolBarManagerRenderer.processHandledItem(ToolBarManagerRenderer.java:675)
at org.eclipse.e4.ui.workbench.renderers.swt.ToolBarManagerRenderer.modelProcessSwitch(ToolBarManagerRenderer.java:586)
at org.eclipse.e4.ui.workbench.renderers.swt.ToolBarManagerRenderer.processContents(ToolBarManagerRenderer.java:473)
at org.eclipse.e4.ui.workbench.renderers.swt.ToolBarManagerRenderer$5.handleEvent(ToolBarManagerRenderer.java:221)
at org.eclipse.e4.ui.services.internal.events.UIEventHandler$1.run(UIEventHandler.java:41)
at org.eclipse.swt.widgets.Synchronizer.syncExec(Synchronizer.java:180)
at org.eclipse.ui.internal.UISynchronizer.syncExec(UISynchronizer.java:150)
at org.eclipse.swt.widgets.Display.syncExec(Display.java:4687)
at org.eclipse.e4.ui.internal.workbench.swt.E4Application$1.syncExec(E4Application.java:187)
at org.eclipse.e4.ui.services.internal.events.UIEventHandler.handleEvent(UIEventHandler.java:38)
at org.eclipse.equinox.internal.event.EventHandlerWrapper.handleEvent(EventHandlerWrapper.java:197)
at org.eclipse.equinox.internal.event.EventHandlerTracker.dispatchEvent(EventHandlerTracker.java:197)
at org.eclipse.equinox.internal.event.EventHandlerTracker.dispatchEvent(EventHandlerTracker.java:1)
at org.eclipse.osgi.framework.eventmgr.EventManager.dispatchEvent(EventManager.java:230)
at org.eclipse.osgi.framework.eventmgr.ListenerQueue.dispatchEventSynchronous(ListenerQueue.java:148)
at org.eclipse.equinox.internal.event.EventAdminImpl.dispatchEvent(EventAdminImpl.java:135)
at org.eclipse.equinox.internal.event.EventAdminImpl.sendEvent(EventAdminImpl.java:78)
at org.eclipse.equinox.internal.event.EventComponent.sendEvent(EventComponent.java:39)
at org.eclipse.e4.ui.services.internal.events.EventBroker.send(EventBroker.java:81)
at org.eclipse.e4.ui.internal.workbench.UIEventPublisher.notifyChanged(UIEventPublisher.java:58)
at org.eclipse.emf.common.notify.impl.BasicNotifierImpl.eNotify(BasicNotifierImpl.java:374)
at org.eclipse.emf.ecore.util.EcoreEList.dispatchNotification(EcoreEList.java:249)
at org.eclipse.emf.common.notify.impl.NotifyingListImpl.addUnique(NotifyingListImpl.java:294)
at org.eclipse.emf.common.util.AbstractEList.add(AbstractEList.java:301)
at org.eclipse.ui.internal.CoolBarToTrimManager.fill(CoolBarToTrimManager.java:728)
at org.eclipse.ui.internal.CoolBarToTrimManager.update(CoolBarToTrimManager.java:663)
at org.eclipse.ui.internal.WorkbenchWindow.updateActionBars(WorkbenchWindow.java:1807)
at org.eclipse.ui.internal.WorkbenchWindow.largeUpdateEnd(WorkbenchWindow.java:1860)
at org.eclipse.ui.internal.Workbench.largeUpdateEnd(Workbench.java:3105)
at org.eclipse.ui.internal.WorkbenchWindow.fillActionBars(WorkbenchWindow.java:2072)
at org.eclipse.ui.internal.WorkbenchWindow.setup(WorkbenchWindow.java:533)
at org.eclipse.e4.core.internal.di.InjectorImpl.processAnnotated(InjectorImpl.java:859)
at org.eclipse.e4.core.internal.di.InjectorImpl.inject(InjectorImpl.java:111)
at org.eclipse.e4.core.internal.di.InjectorImpl.inject(InjectorImpl.java:81)
at org.eclipse.e4.core.contexts.ContextInjectionFactory.inject(ContextInjectionFactory.java:72)
at org.eclipse.ui.internal.Workbench.createWorkbenchWindow(Workbench.java:1252)
at org.eclipse.ui.internal.Workbench.openWorkbenchWindow(Workbench.java:2324)
at org.eclipse.ui.internal.Workbench.getWorkbenchPage(Workbench.java:1737)
at org.eclipse.ui.internal.Workbench.setReference(Workbench.java:1756)
at org.eclipse.ui.internal.Workbench.access$22(Workbench.java:1753)
at org.eclipse.ui.internal.Workbench$33.handleEvent(Workbench.java:1693)
at org.eclipse.e4.ui.model.application.ui.basic.impl.PartImpl.setContext(PartImpl.java:399)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.safeCreateGui(PartRenderingEngine.java:609)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine$6.run(PartRenderingEngine.java:518)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.createGui(PartRenderingEngine.java:503)
at org.eclipse.e4.ui.workbench.renderers.swt.ElementReferenceRenderer.createWidget(ElementReferenceRenderer.java:74)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.createWidget(PartRenderingEngine.java:896)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.safeCreateGui(PartRenderingEngine.java:630)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.safeCreateGui(PartRenderingEngine.java:732)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.access$2(PartRenderingEngine.java:703)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine$7.run(PartRenderingEngine.java:697)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.createGui(PartRenderingEngine.java:682)
at org.eclipse.e4.ui.workbench.renderers.swt.StackRenderer.showTab(StackRenderer.java:1114)
at org.eclipse.e4.ui.workbench.renderers.swt.LazyStackRenderer.postProcess(LazyStackRenderer.java:98)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.safeCreateGui(PartRenderingEngine.java:646)
at org.eclipse.e4.ui.workbench.renderers.swt.SWTPartRenderer.processContents(SWTPartRenderer.java:59)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.safeCreateGui(PartRenderingEngine.java:642)
at org.eclipse.e4.ui.workbench.renderers.swt.PerspectiveRenderer.processContents(PerspectiveRenderer.java:59)
at org.eclipse.e4.ui.workbench.renderers.swt.PerspectiveStackRenderer.showTab(PerspectiveStackRenderer.java:103)
at org.eclipse.e4.ui.workbench.renderers.swt.PerspectiveStackRenderer.postProcess(PerspectiveStackRenderer.java:77)
at org.eclipse.e4.ui.workbench.renderers.swt.WBWRenderer.processContents(WBWRenderer.java:639)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine$9.run(PartRenderingEngine.java:968)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.run(PartRenderingEngine.java:923)
at org.eclipse.e4.ui.internal.workbench.E4Workbench.createAndRunUI(E4Workbench.java:86)
at org.eclipse.ui.internal.Workbench$5.run(Workbench.java:588)
at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.java:543)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:353)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:180)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:629)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:584)
at org.eclipse.equinox.launcher.Main.run(Main.java:1438)
!ENTRY org.eclipse.jface 4 0 2013-01-24 09:26:28.327
!STACK 0
org.eclipse.core.commands.common.NotDefinedException: Cannot get the parent identifier from an undefined context. org.eclipse.jst.j2ee.J2eeMainActionSet3
!ENTRY org.eclipse.jface 4 0 2013-01-24 09:26:28.328
!STACK 0
org.eclipse.core.commands.common.NotDefinedException: Cannot get the parent identifier from an undefined context. org.eclipse.jst.j2ee.J2eeMainActionSet2
!ENTRY org.eclipse.jface 4 0 2013-01-24 09:26:28.329
!STACK 0
FUDForum. Page generated in 0.04225 seconds
