Home » Eclipse Projects » Equinox » javax.annotation package
javax.annotation package [message #1004995] Thu, 24 January 2013 04:29 Go to next message
Hi all,
As I'm trying to work on some API Tools for Tycho build, I'm hitting an
OSGi issue: Equinox can't load org.eclipse.e4.core.di bundle because of
missing javax.annotation package, whereas I use Java 6, which provide
this package:
$ java -jar plugins/org.eclipse.osgi_3.7.2.v20120110-1415.jar -console
osgi> packages
javax.annotation; version="0.0.0"<org.eclipse.osgi_3.7.2.v20120110-1415 [0]>
osgi> install
file:/home/mistria/git/apitooling/maven-plugins/apitools-plugin/src/test/resources/org.eclipse.e4.core.di_1.1.0.v20120627-124443.jar
Bundle id is 1
osgi> start org.eclipse.e4.core.di
org.osgi.framework.BundleException: The bundle
"org.eclipse.e4.core.di_1.1.0.v20120627-124443 [1]" could not be
resolved. Reason: Missing Constraint: Import-Package: javax.annotation;
version="1.0.0"
at
org.eclipse.osgi.framework.internal.core.AbstractBundle.getResolverError(AbstractBundle.java:1327)
I thought this Import-Package could resolve to the JRE/System bundle. It
seems that it's not the case.
Is the only (good) way to get this bundle started to install also the
javax.annotation bunde?
Mickael Istria
JBoss, by Red Hat
My blog: http://mickaelistria.wordpress.com
My Tweets: http://twitter.com/mickaelistria
Re: javax.annotation package [message #1005083 is a reply to message #1004995] Thu, 24 January 2013 08:05 Go to previous message
The package versions don't match. The system bundle exports at version 0 while you import at version 1. Since there are no standards for the package versions for the JRE packages, they are exported by the system bundle without version (which is version 0).
Previous Topic:Installable Unit Version - feature of plugin?
Next Topic:Equinox Issue and Question
Current Time: Sun Jul 27 09:19:10 EDT 2025
Powered by FUDForum. Page generated in 0.27057 seconds
