Hudson jobs can not send mail after upgrading to version 3.0.0 and JDK 7.0 [message #1004550] |
Wed, 23 January 2013 07:44  |
I've just upgraded to from Hudson 2.2.1 to 3.0.0. In that upgrade I also updated to JDK 7, due to a bug in the SubVersion plugin (see Jenkins issue JENKINS-11985 and http://jespertejlgaard.blogspot.dk/2013/01/solved-badrecordmac-error-for.html).
My jobs are no longer able to send mails. They fail with the following error:
ERROR: 535 5.7.8 Error: authentication failed: UGFzc3dvcmQ6
javax.mail.AuthenticationFailedException: 535 5.7.8 Error: authentication failed: UGFzc3dvcmQ6
at com.sun.mail.smtp.SMTPTransport$Authenticator.authenticate(SMTPTransport.java:809)
at com.sun.mail.smtp.SMTPTransport.authenticate(SMTPTransport.java:752)
at com.sun.mail.smtp.SMTPTransport.protocolConnect(SMTPTransport.java:669)
at javax.mail.Service.connect(Service.java:295)
at hudson.tasks.Mailer$DescriptorImpl.send(Mailer.java:505)
at hudson.tasks.Mailer$DescriptorImpl.send(Mailer.java:476)
at hudson.tasks.MailSender.execute(MailSender.java:91)
at hudson.maven.MavenModuleSetBuild$RunnerImpl.cleanUp(MavenModuleSetBuild.java:829)
at hudson.model.Run.run(Run.java:1433)
at hudson.maven.MavenModuleSetBuild.run(MavenModuleSetBuild.java:414)
at hudson.model.ResourceController.execute(ResourceController.java:81)
at hudson.model.Executor.run(Executor.java:137)
I first thought I had the same issue as http://www.eclipse.org/forums/index.php?t=rview&goto=1004249#msg_1004249, but I know see the stacktraces are different. The issues might be related though.
Any clues on how to solve the problem?
[Updated on: Thu, 24 January 2013 04:34] by Moderator
FUDForum. Page generated in 0.06807 seconds
