SVN externals no longer trigger SCM Polling builds [message #987113] |
Fri, 23 November 2012 10:03  |
I have a c# solution which includes several projects that get brought into the solution folder using svn:externals.
My Hudson job is configured to build from the latest SVN sources which includes the externals. The build trigger is set to SCM polling.
When I commit a change in one of the externals projects I expect Hudson to trigger a build on my job. This was working fine a couple of months ago but does not work now. Changes to non-external code trigger as expected.
The only changes I can recall are:
- Hudson upgraded from 2.2 to 2.2.1
- SVN upgraded to 1.7.6 on build server. In Hudson, Subversion Workspace Version changed from "1.6 (svn:external to file)" to "1.7"
- SVN plug-in upgraded to 2.3.4 from 2.3.2 that was bundled with Hudson 2.2.1 (Same behaviour with either version)
As far as I can gather the SVNKit within the SVN plug-in is responsible for checking for changes to svn:externals because SVN itself does not do it. Has this been broken during the recent changes listed above?
Is anyone else seeing this problem - there does not seem to be enough mention of it the internet which makes me think it is just my system!
FUDForum. Page generated in 0.06854 seconds
