Home » Modeling » TMF (Xtext) » Problem running xtext workflow in Plugin Environment(Running user-specified xtext workflow files.)
Problem running xtext workflow in Plugin Environment [message #1004590] Wed, 23 January 2013 09:05 Go to next message
Problem Description:
In Eclipse Plugin Environment, Mwe2StandaloneSetup fails to run xtext workflow.
We need to run xtext workflow using some user-specified, external workflow(.mwe2) and grammar(.xtext) files. This is achieved by creating an eclipse plugin and running a workflow from a new "Context Menu". The location of .mwe2 and .xtext files is specified by the user.
In the attachment, the sample plugin is used to re-create this problem.
PS: To demonstrate the problem, location of .mwe2 and .xtext files is hard-coded to be User's Home directory("user.home") in NewAction.java
Steps to reproduce
1. Import this zip file in eclipse as an existing project:
File -> Import -> Existing Projects into workspace
2. Copy "grammar.xtext" and "GenerateGrammar.mwe2" into your "Home" directory(directory path returned by System.getProperty("user.home")) and Edit the following in "GenerateGrammar.mwe2" file to specify this directory :
var grammarURI = "file:///<your-home-directory>/grammar.xtext"
3. Launch this plugin as an eclipse application
4. In the new workbench, Right click on any file and choose "New SubMenu -> New Action"
Step 3 should run the workflow successfully, but it fails with the following exception even when all the dependencies are satisfied:
"org.eclipse.core.internal.resources.ResourceException:
Resource '/org.eclipse.xtext.xbase/model/Xbase.genmodel' does not exist"
=================code snippet===============
		Injector inj = new Mwe2StandaloneSetup().createInjectorAndDoEMFRegistration();
		Mwe2Runner runner3 = inj.getInstance(Mwe2Runner.class);
		String wfFile3str = System.getProperty("user.home")+File.separator+"GenerateGrammar.mwe2";//"GenerateTutorial";
		File wfFile3 = new File(wfFile3str);
		org.eclipse.emf.common.util.URI wfuri = org.eclipse.emf.common.util.URI.createFileURI(wfFile3.getAbsolutePath());
				// Class path of the xtext generator
		runner3.run(wfuri, new HashMap<String, String>());
Any pointers to solve such problem would be highly appreciated..
Thanks in advance..
[Updated on: Wed, 23 January 2013 09:17] by Moderator
Re: Problem running xtext workflow programmatically in Plugin Environment [message #1004603 is a reply to message #1004590] Wed, 23 January 2013 09:30 Go to previous messageGo to next message
Never ever call a stanalonesetup from an eclipse context
Need training, onsite consulting or any other kind of help for Xtext?
Go visit http://xtext.itemis.com or send a mail to xtext at itemis dot de
Re: Problem running xtext workflow programmatically in Plugin Environment [message #1004695 is a reply to message #1004603] Wed, 23 January 2013 12:26 Go to previous messageGo to next message
Hi Christian
Thank you for your response. Could you please point me out then how could I realize such case i.e. invoking xtext workflow for some user-specified workflow and grammar files from within the eclipse plugin environment.
Thanks again.
[Updated on: Wed, 23 January 2013 12:27] by Moderator
Re: Problem running xtext workflow programmatically in Plugin Environment [message #1004705 is a reply to message #1004695] Wed, 23 January 2013 12:44 Go to previous message
Hi you may have a look what workflow runner/launcher do
Previous Topic:Null pointer through customizing outline view
Next Topic:createReferenceUpdate failed in rename/refactor
Current Time: Fri Jul 25 19:12:57 EDT 2025
Powered by FUDForum. Page generated in 0.06093 seconds
