Home » Eclipse Projects » Eclipse 4 » Where to find the IServiceConstants?
Where to find the IServiceConstants? [message #1004630] Wed, 23 January 2013 10:14 Go to next message
in almost each tutorial the annotation
@Named(IServiceConstants.ACTIVE_SELECTION) Some thing is described. But
where can I find the IServiceConstants? Which plugin contains this
interface and what feature to install?
best regards,
Gilbert
Re: Where to find the IServiceConstants? [message #1004639 is a reply to message #1004630] Wed, 23 January 2013 10:24 Go to previous messageGo to next message
Try using the Open Type dialog (CTRL + SHFT + T)
Re: Where to find the IServiceConstants? [message #1004640 is a reply to message #1004630] Wed, 23 January 2013 10:25 Go to previous messageGo to next message
Hi Gilbert,
IServiceConstants is in the org.eclipse.e4.ui.services plugin.
But I don't know which feature to use for a pure e4 application ... but would also be interessted in the answer Smile.
Hope that helps.
Christoph
Re: Where to find the IServiceConstants? [message #1004647 is a reply to message #1004640] Wed, 23 January 2013 10:32 Go to previous messageGo to next message
Right now there is only one feature for everything e4 and that is org.eclipse.e4.rcp, including all org.eclipse.e4.core.* plugins.
JD
Re: Where to find the IServiceConstants? [message #1004683 is a reply to message #1004639] Wed, 23 January 2013 11:56 Go to previous messageGo to next message
I tried this with an empty result set :(
Re: Where to find the IServiceConstants? [message #1004939 is a reply to message #1004683] Thu, 24 January 2013 02:15 Go to previous messageGo to next message
Please check the following: Open the "Preferences" dialog and select the
node "Plug-in Development": Ensure that the option "Include all plug-ins
from target in Java search" is checked. If it wasn't this might be the
reason that Ctrl+Shift+T wasn't working.
HTH & Greetings from Bremen,
- Daniel
Re: Where to find the IServiceConstants? [message #1004981 is a reply to message #1004640] Thu, 24 January 2013 04:03 Go to previous messageGo to next message
Ok, I added the dependency to org.eclipse.e4.ui.services and now I can
access the IServiceConstants. More interesting, after adding the
dependency the IServiceConstants are listed when pressing CTRL + SHFT +
T. Thanks to all.
best regards,
Gilbert
Christoph Keimel wrote:
> Hi Gilbert,
> IServiceConstants is in the org.eclipse.e4.ui.services plugin. But I
> also be interessted in the answer :).
> Hope that helps.
> Christoph
Re: Where to find the IServiceConstants? [message #1004988 is a reply to message #1004981] Thu, 24 January 2013 04:11 Go to previous messageGo to next message
One last question: how do I inject the active selection when
right-clicking in the Ecore diagram editor (or in an GMF editor in
general)? I tried this what always results in an null object:
@Execute
public void execute(@Optional @Named(IServiceConstants.ACTIVE_SELECTION)
IGraphicalEditPart editPart){
// do something)
Re: Where to find the IServiceConstants? [message #1004999 is a reply to message #1004988] Thu, 24 January 2013 04:39 Go to previous message
Ok I got it:
@Execute
StructuredSelection structuredSelection){
// do something)
if(!structuredSelection.isEmpty()){
Object selectedElement = structuredSelection.getFirstElement();
if(selectedElement instanceof IGraphicalEditPart){
// do something
Previous Topic:Model Menu replaced by 3.x contributed menu
Next Topic:How to contribute a new menu item in an existing menu via a fragment?
Current Time: Wed Jul 23 12:41:40 EDT 2025
Powered by FUDForum. Page generated in 0.11760 seconds
