Home » Archived » EMF-IncQuery » Unable to install EMF IncQuery(Unable to install EMF IncQuery from the update site.)
Unable to install EMF IncQuery [message #987329] Mon, 26 November 2012 02:40 Go to next message
Hi Team
I want to try the EMF IncQuery for my application. The installation is not happening from the update site.
update site: viatra.inf.mit.bme.hu/update/incquery/
The below message is thrown when the update site is hit
HTTP Server 'Bad Gateway' : viatra.inf.mit.bme.hu/update/incquery/content.xml
General connection error with response code=502
Please guide on this.
Re: Unable to install EMF IncQuery [message #1004065 is a reply to message #987329] Tue, 22 January 2013 09:14 Go to previous message
Zoltán Ujhelyi has already answered this question:
"Hi Kiren,
the content.xml files are not available in our repository, but that should not cause any issues, as they are not used in the p2-based update mechanism.
However, if you are using the 'Classic update' mechanism, disabled by default in the Preferences (General/Capabilities), that might be the source of the problem. Can you confirm, that Classic update is turned off (and then your Eclipse instance is restarted)?
Zoltán"
Previous Topic:Welcome to eclipse.incquery
Next Topic:Finding all elements of an association in a subtree
Current Time: Fri Jul 25 19:42:50 EDT 2025
Powered by FUDForum. Page generated in 0.03763 seconds
