Home » Eclipse Projects » EclipseLink » get sequence number through Eclipselink
get sequence number through Eclipselink [message #998157] Wed, 09 January 2013 08:09 Go to next message
I have read the wiki so i know that for getting a sequence value i should be able to do this
long id = em.unwrap(Session.class).getNextSequenceNumberValue(Employee.class).longValue();
However when i try this i get a NPE
Caused by: java.lang.NullPointerException: null
        at org.eclipse.persistence.internal.sequencing.SequencingManager.getNextValue(SequencingManager.java:1067) ~[eclipselink-2.4.1.jar:2.4.1.v20121003-ad44345]
        at org.eclipse.persistence.internal.sequencing.SequencingManager.getNextValue(SequencingManager.java:266) ~[eclipselink-2.4.1.jar:2.4.1.v20121003-ad44345]
        at org.eclipse.persistence.internal.sessions.AbstractSession.getNextSequenceNumberValue(AbstractSession.java:2457) ~[eclipselink-2.4.1.jar:2.4.1.v20121003-ad44345]
Our sequence is just defined like this
@SequenceGenerator(name = "AppId", sequenceName = "SEQ_APP", allocationSize = 500)
Reason i'm asking is that we have mixed jpa en jdbc inserts and i would like them to pull numbers from the same sequence number pool, otherwise the jdbc inserts will have ids that are 500 apart each time which is not desired.
Any thoughts ?
Jorg
Re: get sequence number through Eclipselink [message #998362 is a reply to message #998157] Wed, 09 January 2013 16:34 Go to previous messageGo to next message
Are you able to insert a new Employee instance using JPA and have the sequence generated? For example em.persist(new Employee());
If not, then I believe you might be missing the @GeneratedValue annotation on the ID that ties the defined SequenceGenerator to the Employee class, and might result in the NPE you see when trying to get it through native API.
Best Regards,
Chris
Re: get sequence number through Eclipselink [message #998506 is a reply to message #998157] Thu, 10 January 2013 01:06 Go to previous messageGo to next message
Not sure why your call is failing, but I do about the same and that works great. So this should work.
Tom
Re: get sequence number through Eclipselink [message #998559 is a reply to message #998506] Thu, 10 January 2013 03:35 Go to previous messageGo to next message
Yes @GeneratedValue is not present on the @Id because it works fine without. This is our setup:
- the @SequenceGenerator is defined on a @MappedSuperclass that all our entities extend from. So we use one sequence for all entities.
@MappedSuperclass
@SequenceGenerator(name = "AppIdentity", sequenceName = "SEQ_APP", allocationSize = 500)
public abstract class AbstractDatabaseEntity {
- each entity extends this mapped superclass and defines its @Id with something like this:
    @Id
    @Column(name = "ID")
    private String id;
Apparently there is no need for @GeneratedValue on each @Id definition, it defaults to the defined sequencegenerator in the base class.
So when i then explicitly add an @GeneratedValue annotation to the entity
    @Id
    @GeneratedValue(generator="AppIdentity")
    private String id;
then the NPE disappears. Is this a bug then ? I can add it everywhere no problem, but perhaps EL should take into account the mappedsuperclass when searching for the sequencegenerator.
Thanks!
Re: get sequence number through Eclipselink [message #998709 is a reply to message #998559] Thu, 10 January 2013 09:39 Go to previous messageGo to next message
If you don't use @GeneratedValue, then tere is no generated value, the id will be null, and you cannot get the sequence generator for the class, as it has none.
To generate an id you need to use @GeneratedValue.
Re: get sequence number through Eclipselink [message #1004062 is a reply to message #998157] Tue, 22 January 2013 09:09 Go to previous messageGo to next message
Hello, I have another question on the same subject.
EclipseLink does support custom sequence generators, as explained here:
http://wiki.eclipse.org/EclipseLink/Examples/JPA/CustomSequencing#Using_the_Sequence
When using a sequence generator that returns a sequence value that is not a number (for example an UUID, or any other string), the above method is not applicable because it forces the returned sequence value to be a subtype of Number.
I found an alternative path:
entityManager.unwrap(org.eclipse.persistence.jpa.JpaEntityManager.class).getServerSession().getSequencing().getNextValue(domainClass);
and it seems to work properly, however it is using the org.eclipse.persistence.internal.sequencing.Sequencing interface which belongs to an internal package. Is there a safer way of obtaining the next sequence value when a custom generator is used and the data type is not a number?
Thanks in advance
Giamma.
Re: get sequence number through Eclipselink [message #1004104 is a reply to message #1004062] Tue, 22 January 2013 10:27 Go to previous messageGo to next message
Please log a bug to have the API return Object (probably a new API, getNextSequenceValue()).
Your workaround is fine.
Re: get sequence number through Eclipselink [message #1004119 is a reply to message #1004104] Tue, 22 January 2013 11:04 Go to previous message
Done, 398764
Giamma.
Previous Topic:tenant property not found on cascading delete
Next Topic:Eclipselink and oderby does not work on criteria fetch query
Current Time: Thu Jul 24 21:24:26 EDT 2025
Powered by FUDForum. Page generated in 0.07084 seconds
