Can't get Eclipse to run anymore. [message #738793] |
Sun, 16 October 2011 15:15  |
So I'm using this program for my Java class and it has been working fine for weeks. I think I screwed something up but I can't figure out what I did or why it isn't working anymore. It just doesn't start after I choose the workspace (which is on my flash drive) and says to check the log. log here:
!SESSION 2011-10-16 14:54:31.510 -----------------------------------------------
eclipse.buildId=I20110613-1736
java.version=1.6.0_27
Command-line arguments: -os win32 -ws win32 -arch x86
!ENTRY org.eclipse.core.resources 2 10035 2011-10-16 14:54:33.631
!MESSAGE The workspace exited with unsaved changes in the previous session; refreshing workspace to recover changes.
!ENTRY org.eclipse.osgi 4 0 2011-10-16 14:54:33.672
!MESSAGE An error occurred while automatically activating bundle org.eclipse.core.resources (36).
!STACK 0
org.osgi.framework.BundleException: Exception in org.eclipse.core.resources.ResourcesPlugin.start() of bundle org.eclipse.core.resources.
at org.eclipse.osgi.framework.internal.core.BundleContextImpl.startActivator(BundleContextImpl.java:734)
at org.eclipse.osgi.framework.internal.core.BundleContextImpl.start(BundleContextImpl.java:683)
at org.eclipse.osgi.framework.internal.core.BundleHost.startWorker(BundleHost.java:381)
at org.eclipse.osgi.framework.internal.core.AbstractBundle.start(AbstractBundle.java:299)
at org.eclipse.osgi.framework.util.SecureAction.start(SecureAction.java:440)
at org.eclipse.osgi.internal.loader.BundleLoader.setLazyTrigger(BundleLoader.java:268)
at org.eclipse.core.runtime.internal.adaptor.EclipseLazyStarter.postFindLocalClass(EclipseLazyStarter.java:107)
at org.eclipse.osgi.baseadaptor.loader.ClasspathManager.findLocalClass(ClasspathManager.java:462)
at org.eclipse.osgi.internal.baseadaptor.DefaultClassLoader.findLocalClass(DefaultClassLoader.java:216)
at org.eclipse.osgi.internal.loader.BundleLoader.findLocalClass(BundleLoader.java:400)
at org.eclipse.osgi.internal.loader.SingleSourcePackage.loadClass(SingleSourcePackage.java:35)
at org.eclipse.osgi.internal.loader.BundleLoader.findClassInternal(BundleLoader.java:473)
at org.eclipse.osgi.internal.loader.BundleLoader.findClass(BundleLoader.java:429)
at org.eclipse.osgi.internal.loader.BundleLoader.findClass(BundleLoader.java:417)
at org.eclipse.osgi.internal.baseadaptor.DefaultClassLoader.loadClass(DefaultClassLoader.java:107)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:344)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:622)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:577)
at org.eclipse.equinox.launcher.Main.run(Main.java:1410)
Caused by: org.eclipse.core.internal.dtree.ObjectNotFoundException: Tree element '/lab5' not found.
at org.eclipse.core.internal.dtree.AbstractDataTree.handleNotFound(AbstractDataTree.java:257)
at org.eclipse.core.internal.dtree.DeltaDataTree.getData(DeltaDataTree.java:585)
at org.eclipse.core.internal.dtree.DataDeltaNode.asBackwardDelta(DataDeltaNode.java:50)
at org.eclipse.core.internal.dtree.DataDeltaNode.asBackwardDelta(DataDeltaNode.java:47)
at org.eclipse.core.internal.dtree.DeltaDataTree.asBackwardDelta(DeltaDataTree.java:88)
at org.eclipse.core.internal.dtree.DeltaDataTree.reroot(DeltaDataTree.java:816)
at org.eclipse.core.internal.dtree.DeltaDataTree.reroot(DeltaDataTree.java:815)
at org.eclipse.core.internal.dtree.DeltaDataTree.reroot(DeltaDataTree.java:792)
at org.eclipse.core.internal.watson.ElementTree.immutable(ElementTree.java:518)
at org.eclipse.core.internal.resources.SaveManager.restore(SaveManager.java:709)
at org.eclipse.core.internal.resources.SaveManager.startup(SaveManager.java:1527)
at org.eclipse.core.internal.resources.Workspace.startup(Workspace.java:2503)
at org.eclipse.core.internal.resources.Workspace.open(Workspace.java:2251)
at org.eclipse.core.resources.ResourcesPlugin.start(ResourcesPlugin.java:439)
at org.eclipse.osgi.framework.internal.core.BundleContextImpl$1.run(BundleContextImpl.java:711)
at org.eclipse.osgi.framework.internal.core.BundleContextImpl.startActivator(BundleContextImpl.java:702)
... 28 more
Root exception:
!ENTRY org.eclipse.osgi 4 0 2011-10-16 14:54:33.695
!MESSAGE Application error
!STACK 1
java.lang.NoClassDefFoundError: org/eclipse/core/resources/IContainer
Caused by: org.eclipse.core.runtime.internal.adaptor.EclipseLazyStarter$TerminatingClassNotFoundException: An error occurred while automatically activating bundle org.eclipse.core.resources (36).
at org.eclipse.core.runtime.internal.adaptor.EclipseLazyStarter.postFindLocalClass(EclipseLazyStarter.java:122)
... 13 more
Caused by: org.osgi.framework.BundleException: Exception in org.eclipse.core.resources.ResourcesPlugin.start() of bundle org.eclipse.core.resources.
... 22 more
... 28 more
Can anyone tell what went wrong and how to fix it from this? I can't make any sense of this at all. Sorry for sounding like I don't know anything at all. It's probably because I don't.
Re: Can't get Eclipse to run anymore. [message #1138066 is a reply to message #738793] |
Mon, 14 October 2013 19:20  |
I have the exact same issue right now. (The links above are a different issue!)
I don't understand why it says it can't find a file that exists!
This bug if often triggered by a bug in Dropbox, because I use Dropbox to sync my project folder, and usually I have another PC around with a backup... but due to another Dropbox "feature" it started syncing without informing me and I lost my backup.
Fail Deleting .snap fixes it, but all my projects are gone, and I'm not planning on importing all my projects again, there are just too many.
Fail Deleting all other *.snap files didn't fix that.
I FIXED IT by also restoring an older version of .metadata\.plugins\org.eclipse.core.resources\.safetable
[Updated on: Tue, 15 October 2013 07:21] by Moderator
FUDForum. Page generated in 0.15158 seconds
