Home » Eclipse Projects » Equinox » Question on starting Equinox from Java Application
Question on starting Equinox from Java Application [message #100312] Thu, 25 October 2007 03:33 Go to next message
Hi all,
I've followed tutorial
http://www.eclipsezone.com/eclipse/forums/t93976.rhtml to enable me to
start Equinox programmatically (Thanks Alex). I have the following
questions :
1. One of my bundles (Jetty) needs a parameter that tells it to open at
the specified port. When I launch Equinox from Eclipse I only have to put
"-Dorg.osgi.service.http.port=8080" at the VM arguments section. How do I
pass the parameter through code ?
2. One of my bundles actually points to an Eclipse plugin project that's
not jarred yet. Since installBundle method apparently expects url that
points to jar files, how do I tell Equinox to install this bundle ?
3. Since starting this Equinox takes place on startup method of a TestCase
class, do I have to call each bundle's stop method on teardown method or
is just calling EclipseStarter.shutdown enough ?
Any help would be greatly appreciated.
Best Regards,
Setya
Re: Question on starting Equinox from Java Application [message #100327 is a reply to message #100312] Thu, 25 October 2007 06:38 Go to previous messageGo to next message
Hi all,
For question #2 I've tried the following code:
bundle = context.installBundle("reference:file:<path to my project>")
but then it throws ClassNotFoundException exception stating that it can
not find my activator class.
Any ideas ?
Setya
Re: Question on starting Equinox from Java Application [message #100375 is a reply to message #100327] Fri, 26 October 2007 08:54 Go to previous messageGo to next message
Well, anybody ?
Setya
Re: Question on starting Equinox from Java Application [message #100385 is a reply to message #100375] Fri, 26 October 2007 09:23 Go to previous messageGo to next message
That would indicate that it installed correctly and found the Manifest fine
but it couldn't find your Activator's class.
I'd check your bundle classpath and double check the location of your class
files.
The other possibility is that you're getting a misleading CNF exception
because a dependency of your Activator is not being found. In that case I
would attach a debugger.
HTH
-Simon
"Setya" <jsetya@gmail.com> wrote in message
news:2211f170fe62382ea2aafdeb596a1916$1@www.eclipse.org...
> Well, anybody ?
> Regards,
> Setya
Re: Question on starting Equinox from Java Application [message #100411 is a reply to message #100385] Fri, 26 October 2007 09:47 Go to previous messageGo to next message
Thanks for your response.
> files.
This is weird, I have no problem running it from PDE and all dependencies
are satisfied.
From the stacktrace it's clearly trying to load my bundle activator and
failed.
org.osgi.framework.BundleException: The activator
com.farbeyond.core.rap.CorePlugin for bundle com.farbeyond.core is invalid
at
org.eclipse.osgi.framework.internal.core.AbstractBundle.load BundleActivator(AbstractBundle.java:141)
at
org.eclipse.osgi.framework.internal.core.BundleContextImpl.s tart(BundleContextImpl.java:962)
at
org.eclipse.osgi.framework.internal.core.BundleHost.startWor ker(BundleHost.java:317)
at
org.eclipse.osgi.framework.internal.core.AbstractBundle.star t(AbstractBundle.java:256)
at com.farbeyond.core.test.TestCore.startTest(TestCore.java:83)
Caused by: java.lang.ClassNotFoundException:
at
org.eclipse.osgi.framework.internal.core.BundleLoader.findCl ass(BundleLoader.java:402)
at
org.eclipse.osgi.framework.internal.core.BundleLoader.findCl ass(BundleLoader.java:347)
at
org.eclipse.osgi.internal.baseadaptor.DefaultClassLoader.loa dClass(DefaultClassLoader.java:83)
at java.lang.ClassLoader.loadClass(ClassLoader.java:251)
at
org.eclipse.osgi.framework.internal.core.BundleLoader.loadCl ass(BundleLoader.java:278)
at
org.eclipse.osgi.framework.internal.core.BundleHost.loadClas s(BundleHost.java:227)
at
org.eclipse.osgi.framework.internal.core.AbstractBundle.load BundleActivator(AbstractBundle.java:134)
... 26 more
... Removed 22 stack frames
Any ideas ?
Setya
Re: Question on starting Equinox from Java Application [message #100424 is a reply to message #100411] Fri, 26 October 2007 14:12 Go to previous messageGo to next message
Hmm... if I had to guess.
Did you export your bundle?
When you run under PDE /bin is automagically added to your bundle-classpath.
HTH
-Simon
news:19c3542aef947b127da8e07fc295d1ed$1@www.eclipse.org...
>> fine but it couldn't find your Activator's class.
>> class files.
> are satisfied.
> failed.
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> ... 26 more
> Any ideas ?
> Regards,
> Setya
Re: Question on starting Equinox from Java Application [message #100484 is a reply to message #100424] Sun, 28 October 2007 22:59 Go to previous messageGo to next message
Yes, you guess right.
After I add 'Bundle-ClassPath: bin/' in the MANIFEST.MF through PDE it
works as expected.
Thank you very much for your help.
Setya
Re: Question on starting Equinox from Java Application [message #100622 is a reply to message #100484] Tue, 30 October 2007 08:44 Go to previous message
> works as expected.
I want to go deeper here. How to do above programmatically ?
Setya
Previous Topic:OSGI-server/JSP integration : missing org.eclipse.equinox.http.helper bundle
Next Topic:basic jetty configuration question
Current Time: Fri Jul 18 21:18:07 EDT 2025
Powered by FUDForum. Page generated in 0.04889 seconds
