Home » Modeling » EMF » [CDO] Different object was registered for OID:http://example.com#MyType#c09f11a0-
[CDO] Different object was registered for OID:http://example.com#MyType#c09f11a0- [message #1003591] Mon, 21 January 2013 10:17 Go to next message
I am getting the following exception...
- Hibernate store
- Latest CDO 4.2 git sources
java.lang.IllegalStateException: Different object was registered for OID:http://example.com#MyType#c09f11a0-d68a-4570-9cfb-dd310f5d545d
	at org.eclipse.emf.internal.cdo.view.AbstractCDOView.registerObject(AbstractCDOView.java:1302)
	at org.eclipse.emf.internal.cdo.view.AbstractCDOView.getObject(AbstractCDOView.java:916)
	at org.eclipse.emf.internal.cdo.transaction.CDOTransactionImpl.getObject(CDOTransactionImpl.java:1140)
	at org.eclipse.emf.internal.cdo.view.AbstractCDOView.convertIDToObject(AbstractCDOView.java:1237)
	at org.eclipse.emf.internal.cdo.view.CDOStoreImpl.convertIDToObject(CDOStoreImpl.java:686)
	at org.eclipse.emf.internal.cdo.view.CDOStoreImpl.convertToEMF(CDOStoreImpl.java:654)
	at org.eclipse.emf.internal.cdo.view.CDOStoreImpl.get(CDOStoreImpl.java:190)
	at org.eclipse.emf.internal.cdo.CDOObjectImpl.dynamicGet(CDOObjectImpl.java:527)
	at org.eclipse.emf.ecore.impl.EStructuralFeatureImpl$InternalSettingDelegateSingleEObject.dynamicGet(EStructuralFeatureImpl.java:2324)
	at org.eclipse.emf.ecore.impl.BasicEObjectImpl.eGet(BasicEObjectImpl.java:1027)
	at org.eclipse.emf.ecore.impl.BasicEObjectImpl.eGet(BasicEObjectImpl.java:1011)
	at org.eclipse.emf.ecore.impl.BasicEObjectImpl.eGet(BasicEObjectImpl.java:1003)
	at com.example.model.impl.MyTypeContainerImpl.getMyType(MyTypeContainerImpl.java:110)
Any hints what to look for?
Re: [CDO] Different object was registered for OID:http://example.com#MyType#c09f11a0- [message #1003621 is a reply to message #1003591] Mon, 21 January 2013 11:17 Go to previous messageGo to next message
Hi Erdal,
This can happen when there are references to a parent class/type while the actual instance is a subclass type.
Would this be the case here? So MyTypeContainer refers to a parent type of MyType?
gr. Martin
> - Hibernate store
> at
With Regards, Martin Taal
Springsite/Elver.org
The Netherlands
Cell: +31 (0)6 288 48 943
Tel: +31 (0)84 420 2397
Fax: +31 (0)84 225 9307
Mail: mtaal@xxxxxxxx - mtaal@xxxxxxxx
Re: [CDO] Different object was registered for OID:http://example.com#MyType#c09f11a0- [message #1003623 is a reply to message #1003621] Mon, 21 January 2013 11:24 Go to previous messageGo to next message
Yes, that is the case!
MyTypeContainer has a reference to MyType's parent.
The parent has its inheritance type set to SINGLE_TABLE.
How to resolve this?
Martin taal wrote on Mon, 21 January 2013 17:17
Hi Erdal,
gr. Martin
> - Hibernate store
> at
The Netherlands
Re: [CDO] Different object was registered for OID:http://example.com#MyType#c09f11a0- [message #1003639 is a reply to message #1003623] Mon, 21 January 2013 12:03 Go to previous messageGo to next message
Hi Erdal,
I solved this earlier for abstract classes. Can you make this parent class abstract and see if it helps?
gr. Martin
>> Hi Erdal,
>> gr. Martin
>> > - Hibernate store
>> > at
>> The Netherlands
The Netherlands
Re: [CDO] Different object was registered for OID:http://example.com#MyType#c09f11a0- [message #1003878 is a reply to message #1003639] Tue, 22 January 2013 02:12 Go to previous message
That was it, thanks!
Martin taal wrote on Mon, 21 January 2013 18:03
Hi Erdal,
gr. Martin
Previous Topic:[CDO] Get negative version objects in CDOQuery
Next Topic:Manually creating and firing events from inside another listener
Current Time: Wed Jul 23 10:08:51 EDT 2025
Powered by FUDForum. Page generated in 0.03491 seconds
