Home » Modeling » EMF » EMF Ecore output xmi, can have only text content element ?(How can i model my ecore file which to use only text element on xmi ecore output)
EMF Ecore output xmi, can have only text content element ? [message #1002405] Fri, 18 January 2013 09:17 Go to next message
my ecore model like (simplified);
<eClassifiers xsi:type="ecore:EClass" name="IClafer" eSuperTypes="#//IElement">
<eStructuralFeatures xsi:type="ecore:EAttribute" name="isAbstract" lowerBound="1"
eType="ecore:EDataType ...XMLType#//Boolean"
unsettable="true">
</eStructuralFeatures>
</eClassifiers>
my dynamic instance from this model look like;
<?xml version="1.0" encoding="ASCII"?>
<ir:IModule>
<declaration
xsi:type="ir:IClafer">
<isAbstract
value="true"/>
</declaration>
</ir:IModule>
but i want this xmi file (isAbstract with only text element) like;
<ir:IModule>
<declaration
<isAbstract>false<isAbstract>
</declaration>
</ir:IModule>
So how should I create my eCore file ? (i try all posibility but cant find how can i do)
Re: EMF Ecore output xmi, can have only text content element ? [message #1002480 is a reply to message #1002405] Fri, 18 January 2013 12:00 Go to previous messageGo to next message
Serhat,
Comments below.
> lowerBound="1"
> unsettable="true">
> </eClassifiers>
> <ir:IModule>
> <declaration
> <isAbstract
> value="true"/>
> </declaration>
> </ir:IModule>
I don't think EMF would produce such a serialization. Where's the XMI
declaration? The isAbstract feature would serialize as an attribute, by
default. You must be leaving some details out of your posting...
> <ir:IModule>
> <declaration
> </declaration>
> </ir:IModule>
> find how can i do)
You can influence serialization using extended meta data annotations.
Try creating a schema that specifies the serialization you're expecting
(or look at the Library.xsd from the XML Schema tutorial) and look at
the EAnnotations in the Ecore model generated from it.
Re: EMF Ecore output xmi, can have only text content element ? [message #1003530 is a reply to message #1002480] Mon, 21 January 2013 07:59 Go to previous messageGo to next message
i already create this ecore from XSD file and XSD instance XML is like;
<ir:IModule>
<declaration
</declaration>
</ir:IModule>
as expected for me.
But when i create dynamic instance (xmi) from ecore, <isAbstract> element now become an attribute. but why ? I need isAbstract as element
U can try too
(my xsd file attached)
  • Attachment: library.xsd
    (Size: 14.45KB, Downloaded 217 times)
Re: EMF Ecore output xmi, can have only text content element ? [message #1003551 is a reply to message #1003530] Mon, 21 January 2013 08:52 Go to previous messageGo to next message
Serhat,
The wizard that creates a dynamic instance always creates a resource
that uses an XMI serialization. You shouldn't expect an XMI
serialization to conform to your schema. Even what you show below
doesn't conform to your schema; there's no global element called "IModule".
It's possible to work with dynamic models that conform to the schema,
but you'd need to use GenericXMLResourceFactoryImpl to create resources
for that purpose.
Why aren't you working with the generated model?
> <ir:IModule>
> <declaration
> </declaration>
> </ir:IModule>
> as expected for me.
> U can try too
Re: EMF Ecore output xmi, can have only text content element ? [message #1003571 is a reply to message #1003551] Mon, 21 January 2013 09:38 Go to previous messageGo to next message
ok but i worked with generated model.
i just write these above xmls as an example for the question.
What i have done ?
ir.xsd metamodel of ir.xml
ir.ecore metamodel of IModule.xmi (which created from IModele class with create dynamic instance method)
and when i look the IModule and ir.xml models they are not consistent with eachother.
so i think metamodels not consistent too.
(files attached)
  • Attachment: ir.xml
    (Size: 1.55KB, Downloaded 316 times)
  • Attachment: ir.xsd
    (Size: 10.63KB, Downloaded 266 times)
  • Attachment: ir.ecore
    (Size: 37.30KB, Downloaded 283 times)
  • Attachment: ir.ecorediag
    (Size: 103.76KB, Downloaded 260 times)
  • Attachment: IModule.xmi
    (Size: 0.35KB, Downloaded 281 times)
[Updated on: Mon, 21 January 2013 09:44] by Moderator
Re: EMF Ecore output xmi, can have only text content element ? [message #1003579 is a reply to message #1003571] Mon, 21 January 2013 09:52 Go to previous messageGo to next message
Serhat,
Comments below.
Yes.
> What i have done ?
Well, not of the one you showed...
Any number of serializations are possible. You can use an XMI
serialization and a resource created by XMIResourceFactoryImpl can read
and write that; that's what the reflective editor uses. Or you can use
an XML serialization that conforms to your XML Schema; resources created
by your generated resource factory implementation or by
GenericResourceFactoryImpl can read and write that...
Why do you think that?
> (files attached)
What do you want me to do with those?
Re: EMF Ecore output xmi, can have only text content element ? [message #1003584 is a reply to message #1003579] Mon, 21 January 2013 10:08 Go to previous messageGo to next message
i just say that, java annotations does not work as i expected
Re: EMF Ecore output xmi, can have only text content element ? [message #1003605 is a reply to message #1003584] Mon, 21 January 2013 10:42 Go to previous messageGo to next message
Java annotations?
Note that extended meta data annotations in the model are only respected
when OPTION_EXTENDED_META_DATA is used as a load or save option in the
resource implementation. XMIResourceFactoryImpl doesn't do that by
default. Your generated resource factory does.
Re: EMF Ecore output xmi, can have only text content element ? [message #1003945 is a reply to message #1003605] Tue, 22 January 2013 04:49 Go to previous message
Ahh i understand now. I was forced to understanding u because of my little english Smile
When i run application.editor and create ir Model, i have what i expect
But any way i dont understand why dynamic instance not give that. i think i must re read your replies.
Thanks for help Smile
regards
Serhat
Previous Topic:Manually creating and firing events from inside another listener
Next Topic:[xcore/xbase] Referencing operation parameters from inside lambda expressions
Current Time: Wed Jul 23 13:22:07 EDT 2025
Powered by FUDForum. Page generated in 0.04299 seconds
