Home » Modeling » EMF » [CDO][EMF Command] problems with SetCommand.redo from empty List(Problems with redo of SetCommand on CDO model when current value is empty List)
[CDO][EMF Command] problems with SetCommand.redo from empty List [message #1001717] |
Thu, 17 January 2013 04:16  |
I'm using EMF Commands to enable undo/redo of modifications on a CDO model, and am now experiencing an issue with redoing SetCommand when it has set an empty List.
My test case:
@Test
public void setCommand_emptyListInHistory_isNotRedoable(){
assertEquals(ImmutableList.of(createIntervall(10, 20)), selectionLine.getEmployees());
SetCommand setCommand = new SetCommand(editDomain, selectionLine, SELECTION_EMPLOYEES, new BasicEList<Intervall>());
commandStack.execute(setCommand);
assertEquals(new BasicEList<Intervall>(),selectionLine.getEmployees());
SetCommand setCommand2 = new SetCommand(editDomain, selectionLine, SELECTION_EMPLOYEES, ImmutableList.of(createIntervall(20, 30)));
commandStack.execute(setCommand2);
assertEquals(ImmutableList.of(createIntervall(20, 30)),selectionLine.getEmployees());
commandStack.undo();
commandStack.redo();
//This is what happens
//This is what I expected
//assertEquals(ImmutableList.of(createIntervall(20, 30)),selectionLine.getEmployees());
Basically the first redo after an empty List has been set, it is not able to execute correctly.
What seems to be happening is that SetCommand.prepare does if(owner.eIsSet(feature)) oldValue = UNSET_VALUE , since eIsSet is false for emptyList, then doUndo() does if(oldValue == UNSET_VALUE) owner.eUnset(feature); however doRedo goes into else in if (value == UNSET_VALUE){owner.eUnset(feature);} else {owner.eSet(feature, value);} as I originally expected, but doesn't set anything when redoing to the second (non empty) value.
Does anyone have any experience with this issue, or is there something obvious I'm doing wrong?
I can add that if I add the following into doUndo (before else if (oldValue == UNSET_VALUE)) of an overridden SetCommand it works:
else if (oldValue == UNSET_VALUE && feature.isMany())
//Hack to get setting of list with empty List working with redo
oldValue = new BasicEList<Object>();
owner.eSet(feature, oldValue);
Re: [CDO][EMF Command] problems with SetCommand.redo from empty List [message #1003085 is a reply to message #1001717] |
Sun, 20 January 2013 02:20  |
Mads,
Comments below.
> model,
Is it a CDO-specific problem?
> set an empty List.
> My test case:
> @Test
> if(owner.eIsSet(feature)) oldValue = UNSET_VALUE, since eIsSet is
So it sounds like the command is doing the right thing... It should
have a copy of the old value it (which you say it does) so eSet should
result in that value ending up being the the contents of the list
owner's list for that feature, but you say with CDO it doesn't...
It looks correct what you're doing.
It certainly sounds like something is wrong. If it's reproducible
without CDO then it's something wrong in SetCommand, otherwise something
wrong with CDO.
Could you create a self contained test case that doesn't depend on a CDO
generated model and open a bugzilla (assuming it's reproducible that
way)? Then I'll have a close look and fix whatever the problem is.
I should note that your workaround doesn't look exactly correct: even
multi-valued features can be unsettable, so it makes a difference to the
final state (for unsettable lists) to call eUnset verses calling eSet to
an empty list.
Current Time: Wed Jul 23 03:10:03 EDT 2025
Powered by FUDForum. Page generated in 0.06140 seconds
