Home » Eclipse Projects » Eclipse 4 » Menu shows only with -clearPersistedState
Menu shows only with -clearPersistedState [message #997140] Thu, 03 January 2013 17:37 Go to next message
when I run my application with compatibility layer with the argument -clearPersistedState it shows the menu, without the menu is no more shown.
I use a TrimmedWindow with Main Menu.
When I look at the
.metadata\.plugins\org.eclipse.e4.workbench\workbench.xmi the "mainMenu" element is missing.
I am using Eclipse 4.2.1 and e4 tools 0.12.
Is this a bug or is there something that I missed?
thanks
Frank
Re: Menu shows only with -clearPersistedState [message #997304 is a reply to message #997140] Sat, 05 January 2013 08:40 Go to previous messageGo to next message
I tried the same now with eclipse 4.3M4 and e4 tools I20130103-2200
For running on 4.3M4 I added the HandlerProcessingAddon as suggested by Lars Vogel.
This is how the app look with 4.2
index.php/fa/12880/0/
4.3M4, the quickaccess is strange
index.php/fa/12881/0/
4.3M4, this is the resize needed to make the quick access flip so the upper line
index.php/fa/12882/0/
And again without -clearPersistedState the menu disapears
index.php/fa/12883/0/
Any ideas why the UI changes?
Any ideas what I can do about the clerarPersistedState?
thanks Frank
  • Attachment: cv-4.2.PNG
    (Size: 34.73KB, Downloaded 2905 times)
  • Attachment: cv-4.3.PNG
    (Size: 46.54KB, Downloaded 2903 times)
  • Attachment: cv-4.3-2.PNG
    (Size: 49.07KB, Downloaded 2906 times)
  • Attachment: cv-4.3-noarg.PNG
    (Size: 48.43KB, Downloaded 2830 times)
Re: Menu shows only with -clearPersistedState [message #1002382 is a reply to message #997304] Fri, 18 January 2013 08:38 Go to previous messageGo to next message
Try inspecting the model with the live editor and see what happens when you run it. Is it any different from your Application.e4xmi?
Re: Menu shows only with -clearPersistedState [message #1002830 is a reply to message #1002382] Sat, 19 January 2013 10:10 Go to previous messageGo to next message
Hi Sopot,
when I inspect the live editor (now with 4.2.1), I run the appl with -clearPersistedState. Then I see the mainMenu in the model. When the application is ended, I examine the .metadata\.plugins\org.eclipse.e4.workbench\workbench.xmi, which I guess is the persisted model. Here the mainMenu is not contained. This is the reason, why a new start without -clearPersitedState is not working.
Frank
Re: Menu shows only with -clearPersistedState [message #1002832 is a reply to message #1002830] Sat, 19 January 2013 10:17 Go to previous messageGo to next message
... when I do the same with the wizard generaed e4 app, this works. How can I find the reason, it is not working in my application?
Re: Menu shows only with -clearPersistedState [message #1002932 is a reply to message #1002832] Sat, 19 January 2013 17:14 Go to previous messageGo to next message
Are you providing lifecycle hooks to your application? Maybe you are messing something with the lifecycle annotations which are meant to manipulate the model on app shutdown.
Re: Menu shows only with -clearPersistedState [message #1002959 is a reply to message #1002932] Sat, 19 January 2013 19:01 Go to previous messageGo to next message
Thanks for the suggestion.
Indeed, I had a live cycle hook installed for testing purpose, there hooks where not doing anything. But I remove it from the plugin.xml now. Still the mainMenu is missing from the saved workbench.xmi.
Re: Menu shows only with -clearPersistedState [message #1003179 is a reply to message #1002959] Sun, 20 January 2013 08:55 Go to previous messageGo to next message
Well try putting a breakpoint in the MWindow.setMainMenu method and examine the call stack to see who calls it with the null argument when the workbench closes. If no one calls than it is not in the model at startup in the first place. If so you have to examine the model merging code and see where it is left out.
This may get a bit deep but you will get at it eventually.
Re: Menu shows only with -clearPersistedState [message #1003939 is a reply to message #1003179] Tue, 22 January 2013 04:32 Go to previous messageGo to next message
Hi Sopot,
thanks for the hints. So far I did insert the breakpoint and find that the application break at close.
The MWindowImpl.setMainMenu is called with null, and the workbench.xmi is written afterwards without the main menu element.
At that time, this is the call stack:
Thread [main] (Suspended (breakpoint at line 511 in WindowImpl))
	TrimmedWindowImpl(WindowImpl).setMainMenu(MMenu) line: 511
	WorkbenchWindow$1.handleEvent(Event) line: 286
	UIEventHandler$1.run() line: 41
	UISynchronizer(Synchronizer).syncExec(Runnable) line: 180
	UISynchronizer.syncExec(Runnable) line: 150
	Display.syncExec(Runnable) line: 4687
	E4Application$1.syncExec(Runnable) line: 187
	UIEventHandler.handleEvent(Event) line: 38
	EventHandlerWrapper.handleEvent(Event, Permission) line: 197
	EventHandlerTracker.dispatchEvent(EventHandlerWrapper, Permission, int, Event) line: 197
	EventHandlerTracker.dispatchEvent(Object, Object, int, Object) line: 1
	EventManager.dispatchEvent(Set, EventDispatcher, int, Object) line: 230
	ListenerQueue.dispatchEventSynchronous(int, Object) line: 148
	EventAdminImpl.dispatchEvent(Event, boolean) line: 135
	EventAdminImpl.sendEvent(Event) line: 78
	EventComponent.sendEvent(Event) line: 39
	EventBroker.send(String, Object) line: 81
	UIEventPublisher.notifyChanged(Notification) line: 58
	TrimmedWindowImpl(BasicNotifierImpl).eNotify(Notification) line: 374
	TrimmedWindowImpl(UIElementImpl).setWidget(Object) line: 248
	WBWRenderer(SWTPartRenderer).unbindWidget(MUIElement) line: 114
	WBWRenderer(SWTPartRenderer).disposeWidget(MUIElement) line: 135
	PartRenderingEngine.safeRemoveGui(MUIElement) line: 847
	PartRenderingEngine.access$3(PartRenderingEngine, MUIElement) line: 775
	PartRenderingEngine$8.run() line: 770
	SafeRunner.run(ISafeRunnable) line: 42
	PartRenderingEngine.removeGui(MUIElement) line: 755
	PartRenderingEngine.stop() line: 1081
	Workbench.busyClose(boolean) line: 1121
	Workbench.access$16(Workbench, boolean) line: 1001
	Workbench$17.run() line: 1182
	BusyIndicator.showWhile(Display, Runnable) line: 70
	Workbench.close(int, boolean) line: 1180
	Workbench.close() line: 1153
	WorkbenchWindow.busyClose(boolean) line: 1164
	WorkbenchWindow.access$14(WorkbenchWindow, boolean) line: 1137
	WorkbenchWindow$10.run() line: 1193
	WorkbenchWindow.close(boolean) line: 1191
	WorkbenchWindow.close() line: 1203
	WorkbenchWindow$6.close(MWindow) line: 446
	WBWRenderer$11.shellClosed(ShellEvent) line: 575
	TypedListener.handleEvent(Event) line: 98
	EventTable.sendEvent(Event) line: 84
	Shell(Widget).sendEvent(Event) line: 1053
	Shell(Widget).sendEvent(int, Event, boolean) line: 1077
	Shell(Widget).sendEvent(int, Event) line: 1062
	Shell(Decorations).closeWidget() line: 309
	Shell(Decorations).WM_CLOSE(int, int) line: 1694
	Shell(Control).windowProc(int, int, int, int) line: 4530
	Shell(Canvas).windowProc(int, int, int, int) line: 341
	Shell(Decorations).windowProc(int, int, int, int) line: 1627
	Shell.windowProc(int, int, int, int) line: 2069
	Display.windowProc(int, int, int, int) line: 4976
	OS.DefWindowProcW(int, int, int, int) line: not available [native method]
	OS.DefWindowProc(int, int, int, int) line: 2541
	Shell.callWindowProc(int, int, int, int) line: 498
	Shell(Control).windowProc(int, int, int, int) line: 4623
	OS.DispatchMessageW(MSG) line: not available [native method]
	OS.DispatchMessage(MSG) line: 2546
	Display.readAndDispatch() line: 3756
	PartRenderingEngine$9.run() line: 1029
	Realm.runWithDefault(Realm, Runnable) line: 332
	PartRenderingEngine.run(MApplicationElement, IEclipseContext) line: 923
	E4Workbench.createAndRunUI(MApplicationElement) line: 86
	Workbench$5.run() line: 588
	Workbench.createAndRunWorkbench(Display, WorkbenchAdvisor) line: 543
	PlatformUI.createAndRunWorkbench(Display, WorkbenchAdvisor) line: 149
	Application.start(IApplicationContext) line: 48
	EclipseAppHandle.run(Object) line: 196
	EclipseAppLauncher.runApplication(Object) line: 110
	EclipseAppLauncher.start(Object) line: 79
	EclipseStarter.run(Object) line: 353
	EclipseStarter.run(String[], Runnable) line: 180
	NativeMethodAccessorImpl.invoke0(Method, Object, Object[]) line: not available [native method]
	NativeMethodAccessorImpl.invoke(Object, Object[]) line: not available
	DelegatingMethodAccessorImpl.invoke(Object, Object[]) line: not available
	Method.invoke(Object, Object...) line: not available
	Main.invokeFramework(String[], URL[]) line: 629
	Main.basicRun(String[]) line: 584
	Main.run(String[]) line: 1438
	Main.main(String[]) line: 1414
The direct calling code in WorkbenchWindow$1.handleEvent(Event) line: 286 looks like this:
MMenu menu = model.getMainMenu();
if (menu != null) {
	engine.removeGui(menu);
	model.setMainMenu(null);
In the debugger, I changed the passed argument (null) to have the value of the existing menu. The result is a workbench.xmi which contains the main menu.
Any further hint how I can make the workbench not to remove the main menu.
Frank
Re: Menu shows only with -clearPersistedState [message #1003970 is a reply to message #1003939] Tue, 22 January 2013 05:41 Go to previous messageGo to next message
Thanks for digging into this. It truly looks like an issue with the code as this deliberately removing the menu if it exists doesn't make sense to me. However I'm not familiar with the specific use case so please file a bug at https://bugs.eclipse.org/bugs/enter_bug.cgi?product=Platform&component=UI and reference this bug here also.
Re: Menu shows only with -clearPersistedState [message #1004258 is a reply to message #1003970] Tue, 22 January 2013 16:53 Go to previous messageGo to next message
The bug: https://bugs.eclipse.org/bugs/show_bug.cgi?id=398847
Re: Menu shows only with -clearPersistedState [message #1100752 is a reply to message #997140] Tue, 03 September 2013 10:46 Go to previous messageGo to next message
I am also running into this issue - has there been any development? Comment #10 in the bug report does not really help. The main menu stays invisible, even with a new Application.e4xmi that was started from Legacy.e4xmi.
Thanks for any hints or workarounds!
Wernke
Re: Menu shows only with -clearPersistedState [message #1110364 is a reply to message #1100752] Mon, 16 September 2013 15:46 Go to previous messageGo to next message
For reference here's the comment that helped with this issue:
"Frank, perhaps it's just a case of starting with a cut-down copy of the LegacyIDE.xmi ? For example the compatibility code has expectations like the main menu having the elementId "org.eclipse.ui.main.menu"...
You might try by creating a new starting model for your app from an initial copy of the LegacyIDE and cutting out some stuff (but leaving the ids in place).."
Basically, we're reliant on the ids of trim bars and such for the compat layer to work.
Re: Menu shows only with -clearPersistedState [message #1413327 is a reply to message #1110364] Thu, 28 August 2014 05:27 Go to previous message
This is still a bug! The main menu is removed before the application model is persisted to disk. Next time you start without the -clearPersistedState option the main menu is missing. I use the following workaround.
1. Use a model processor to create an empty main menu and set the apply option in the extension point to "always".
public class MainMenuModelProcessor {
  @Inject
  MApplication application;
  @Inject
  EModelService modelService;
  @Execute
  public void execute() {
    MTrimmedWindow window = (MTrimmedWindow)this.modelService.find("window.main", this.application);
    if (window == null || window.getMainMenu() != null) {
      return;
    window.setMainMenu(createEmptyMainMenu());
  private MMenu createEmptyMainMenu() {
    final MMenu mainMenu = this.modelService.createModelElement(MMenu.class);
    mainMenu.setElementId("org.eclipse.ui.main.menu");
    return mainMenu;
2. Add an empty main menu to your base application model with ID=org.eclipse.ui.main.menu (you need this for referencing in model fragments).
3. Create an application model fragment and set the apply option in the extension point to "always".
4. In the fragment create a model fragment for your main menu with feature=children and add all your main menu elements.
This way the main menu will always be added to the application model.
Previous Topic:Nothing to merge for "platform:/plugin/org.eclipse.e4.tools.emf.ui/fragment.e4xmi"???
Next Topic:[SOLVED] RCP: Part stack is removed when last part was closed
Current Time: Wed Jul 23 04:16:48 EDT 2025
Powered by FUDForum. Page generated in 0.09476 seconds
