Home » Archived » Buckminster » Problem with Target Platform Definition(using ${git_work_tree} variable)
Problem with Target Platform Definition [message #1002374] |
Fri, 18 January 2013 08:30  |
Hello Bucky Team
I am currently trying to setup an rcp build using buckminster. During the process I came over the following issue with the target definition.
We use a target definition which only uses plugins (jar files) which are placed in a general eclipse project. This project is placed in a git repository. Therefor the target definition itself looks like this, so it is identical for every developer regardless of the location of his git repository.
<?xml version="1.0" encoding="UTF-8" standalone="no"?>
<?pde version="3.8"?>
<target name="GO§A Target" sequenceNumber="280">
<locations>
<location path="${git_work_tree}/lib/Target/test" type="Directory"/>
<location path="${git_work_tree}/lib/Target/eclipse" type="Directory"/>
<location path="${git_work_tree}/lib/Target/extensions" type="Directory"/>
</locations>
... skipped ...
</target>
This works in PDE but does not get resolved correctly by buckminster. If I use full path names instead of the ${git_work_tree} property everything works fine.
Is there a way I can let buckminster know where to look for ${git_work_tree}?
Version: Juno Service Release 1
Build id: 20121004-1855
Buckminster Core 1.5.0.v20121128-1508
Greetings
Christoph
Re: Problem with Target Platform Definition [message #1003108 is a reply to message #1002411] |
Sun, 20 January 2013 03:58   |
Hi Christoph
I'm not sure I understand what you are doing: you have a standard PDE
..target definition file right? and what are your steps to make
Buckminster resolve that target in the IDE?
As far as I know, Buckminster headless has commands to use a .target
file, but inside the IDE you have to set the target platform based on a
..target file with standard PDE tools. At least, that's how I understood
(Thomas?)
When does it happen that it "does not get resolved correctly by
buckminster"? During an headless build? Or here we're not talking
about headless build at all?
Placing the line "git_work_tree=D:/GitRepos/gosa" in
buckminster-win-32.properties, for instance, would work during a
headless build if you pass this properties file to buckminster headless
when resolving the CQUERY; but if you are using this properties file
from the IDE for running an action, like site.p2, this will not work,
since those actions assume that target platform resolution has already
been resolved.
Or probably I missed some details :)
P.S. my tutorial does not use .target definition files at all: it
defines the target platform with standard Buckminster components
dependencies.
cheers
Lorenzo
On 01/18/2013 03:25 PM, Christoph Keimel wrote:
> Hi Lorenzo
> Thanks for your input! I am working inside the IDE. I am not quite sure
> where ${git_work_tree} is defined. Maybe it gets defined as part of the
> EGit feature ... ?
> Thanks for your blog on building an rcp application! I followed the
> tutorial succesfully and am now trying to use the concept for our
> application. Speaking in the context of your blog. Where would you put
> the definition in relation to the
> org.eclipse.buckminster.examples.rcp.mail.product.site project?
> I tried placing the line "git_work_tree=D:/GitRepos/gosa" in
> buckminster-win-32.properties, but this doesn't work.
> A global solution would be better anyway, so that the target platform is
> available for all buckminster components (i.e. the Component Explorer).
> To achieve this I tried to start the IDE itself with
> "-Dgit_work_tree=D:/GitRepos/gosa", but that doesn't work either :(.
> Greetings
> Christoph
HOME: http://www.lorenzobettini.it
Re: Problem with Target Platform Definition [message #1003455 is a reply to message #1003108] |
Mon, 21 January 2013 04:28   |
Yes, the target platform is defined in a .target file. Afaik no steps are
needed for Buckminster to know about the target platform. Looking at the view
"Component Explorer", you can see the "Target Platform Components".
> (Thomas?)
Good to know, as I will be working on a headless build in the future. Right
know I am happy to get it working within the IDE.
I am talking about a build from the IDE.
The problem depends on how the target is defined in the .target file.
This works:
<target name="GO§A Target for Build" sequenceNumber="294">
<locations>
<location path="D:/GitRepos/gosa/lib/Target/eclipse" type="Directory"/>
<location path="D:/GitRepos/gosa/lib/Target/test" type="Directory"/>
<location path="D:/GitRepos/gosa/lib/Target/extensions" type="Directory"/>
</locations>
... skipped ...
</target> The bundles are listed in the PDE view "Target Platform State" and in the Buckinster view "Target Platform Components".
This does not work:
<locations>
</locations>
... skipped ...
</target> The bundles are listed in the PDE view "Target Platform State" but NOT in the Buckinster view "Target Platform Components".
> been resolved.
Thanks for the explanation. That explains why my efforts have been fruitless
Is there a way to customize the target platform resolution?
Smile,
Christoph
Re: Problem with Target Platform Definition [message #1003946 is a reply to message #1003455] |
Tue, 22 January 2013 04:51   |
Hi Christoph
comments inline
> view "Component Explorer", you can see the "Target Platform Components".
Yes, you resolve and set the target platform with PDE.
> I am talking about a build from the IDE. The problem depends on how the
> This works:
> <locations>
> type="Directory"/>
> type="Directory"/>
> type="Directory"/>
> </locations>
> ... skipped ...
> </target>The bundles are listed in the PDE view "Target Platform State"
> This does not work:
> <locations>
> type="Directory"/>
> type="Directory"/>
> type="Directory"/>
> </locations>
> ... skipped ...
but all the projects compile fine anyway, don't they?
you're able, for instance, to run site.p2 action in the IDE anyway,
aren't you?
As for the Buckminster View I don't know why it does not show that...
let's hear from Buckminster developers :)
>> been resolved.
> fruitless :)
you mean in the IDE again, right?
If the projects compile fine, and it is only a matter of the Buckminster
View not showing that it might be only a problem in that view... but
again, Buckminster developers should confirm this :)
cheers
Lorenzo
Current Time: Sun Jul 20 22:35:36 EDT 2025
Powered by FUDForum. Page generated in 0.27620 seconds
