Home » Modeling » QVT-OML » Unsettable attribute, intrinsic defaults
Unsettable attribute, intrinsic defaults [message #1001994] Thu, 17 January 2013 12:18 Go to next message
given the following simple assignment:
result.floatval := self.floatval;
Both models define "floatval" as an unsettable, lowerBound=0 attribute
of type EFloat. The input model actually is an ecore model as generated
by the XSDEcoreBuilder.
Here's the problem I'm facing: if the input value is unset, then the QVT
engine still ends up in assigning the intrinsic default value of float,
which is defined in
org.eclipse.emf.ecore.impl.EDataTypeImpl.getDefaultValue(). The expected
result would have been that the lvalue remains unset.
Note this special handling is only done for primitive types. For
example, for all xs:integer based types in our XSD model it works,
because those are mapped to java.lang.BigInteger.
I'm not sure yet if this is a missunderstanding on my part, an EMF bug,
or a QVT bug. I traced
QvtOperationalEvaluationVisitorImpl.visitAssignExp() in the debugger bug
could not identify that QVT even cares for unset input attributes.
TIA for any insights!
Marius
Re: Unsettable attribute, intrinsic defaults [message #1002036 is a reply to message #1001994] Thu, 17 January 2013 14:52 Go to previous messageGo to next message
My expectation is that if some output is unSettable, it should not be
set, so specifying a QVTo assignment should be a compiler error; please
raise a Bugzilla.
If you omit the QVTo assignment, the only 'set' should be EMF's default
initialization. If QVTo zaps it please raise a Bugzilla. I'm not sure
this is even possible. If it's unsettable, any eSet should barf.
On the input side, I would not expect QVTo to take any notice of
isSettable. It's just a value source that happens to have a frozen default.
Ed Willink
On 17/01/2013 17:18, Marius Gröger wrote:
> Hello,
> which is defined in
> Marius
Re: Unsettable attribute, intrinsic defaults [message #1002217 is a reply to message #1002036] Fri, 18 January 2013 02:41 Go to previous messageGo to next message
Hi Ed,
thanks for your answer. Reading it made me realize that I misunderstood
the meaning of "unsettable". I was under the impression that it means
"can be unset", but it really means "cannot be set".
This misunderstanding led me to a false description of the issue. So
here I go again with the corrected description:
Given the following simple assignment:
Both models define "floatval" as a settable, lowerBound=0 attribute
which is defined in
result would have been that the lvalue remains unset, because the rvalue
is unset as well.
TIA
Marius
On 17.01.2013 20:52, Ed Willink wrote:
> Hi
> raise a Bugzilla.
> Regards
> Ed Willink
>> Hello,
>> which is defined in
>> Marius
Re: Unsettable attribute, intrinsic defaults [message #1002232 is a reply to message #1002217] Fri, 18 January 2013 03:17 Go to previous messageGo to next message
No. Unset, means that it has not been explicitly set and so retains its
initial value. It does not mean that it contains a distinct out-of-band
value. So a transformation should indeed transfer this value. Just
possibly in an Eclipse tool if the transferred value is identical to the
default value the transfer could be done without actually setting the
default explicitly.
However unset is an Ecore rather than EMOF concept, so there is no OMG
specification for this in OCL or QVT.
If unset was supported, one would need to define whether an update
transformation sets the unchanged values, in which case there could be
an inconsistency between a created output and an unchanged refreshed
output. Would need some careful study.
So no bug. QVTo like many tools is free to perform redundant sets when
creating EObjects.
Ed Willink
On 18/01/2013 07:41, Marius Gröger wrote:
> Hi Ed,
> which is defined in
> is unset as well.
> TIA
> Marius
>> Hi
>> raise a Bugzilla.
>> Regards
>> Ed Willink
>>> Hello,
>>> which is defined in
>>> Marius
Re: Unsettable attribute, intrinsic defaults [message #1002255 is a reply to message #1002232] Fri, 18 January 2013 03:58 Go to previous messageGo to next message
Hello Ed,
thanks for your explanation. In the meantime I have done some reading
and found that my initial understanding "unset" was correct after all:
it means the value has not been assigned a value.
So my issue boils down to the fact that EMF, for primitive type, always
has an intrinsic default value. It is this value that QVT will then
transfer. For non-primitive types, the value is also transfered, but
that value is null and so the output attribute remains being unset.
I think I will take it to the EMF group to find out how to best handle this.
Thanks again
Marius
On 18.01.2013 09:17, Ed Willink wrote:
> Hi
> default explicitly.
> creating EObjects.
> Regards
> Ed Willink
>> Hi Ed,
>> which is defined in
>> is unset as well.
>> TIA
>> Marius
>>> Hi
>>> raise a Bugzilla.
>>> default.
>>> Regards
>>> Ed Willink
>>>> Hello,
>>>> QVT
>>>> which is defined in
>>>> expected
>>>> bug
>>>> Marius
Re: Unsettable attribute, intrinsic defaults [message #1002280 is a reply to message #1002255] Fri, 18 January 2013 04:55 Go to previous messageGo to next message
It is not the type that is unset; it is the reference to the type that
is unset, so there should be no difference for primitive types. EMF
maintains a distinct out-of-band is_set eFlags bit for the case where
there is no in-band value that can be used.
QVTo has no specification for this bit.
If explicit-set/default is so important to you, I suggest that you model
it explicitly rather than rely on under-specified implementation details.
Ed Willink
On 18/01/2013 08:58, Marius Gröger wrote:
> Hello Ed,
> Thanks again
> Marius
>> Hi
>> default explicitly.
>> creating EObjects.
>> Regards
>> Ed Willink
>>> Hi Ed,
>>> which is defined in
>>> is unset as well.
>>> TIA
>>> Marius
>>>> Hi
>>>> raise a Bugzilla.
>>>> default.
>>>> Regards
>>>> Ed Willink
>>>>> Hello,
>>>>> QVT
>>>>> which is defined in
>>>>> expected
>>>>> bug
>>>>> Marius
Re: Unsettable attribute, intrinsic defaults [message #1002347 is a reply to message #1002280] Fri, 18 January 2013 07:36 Go to previous messageGo to next message
I'm afraid explicitly modeling set/unset would be overly complicate the
XSD model. The XML instance is perfectly able to represent the unset
case, and so is my internal EMF model. It's just a shame that during the
QVT conversion, EMF sneaks in an intrinsic default for all primitive
types. I'm currently looking into changing this behavior in EMF's
XSDEcoreBuilder, but it doesn't look very promising.
Marius
On 18.01.2013 10:55, Ed Willink wrote:
> Hi
> Regards
> Ed Willink
>> Hello Ed,
>> this.
>> Thanks again
>> Marius
>>> Hi
>>> default explicitly.
>>> creating EObjects.
>>> Regards
>>> Ed Willink
>>>> Hi Ed,
>>>> QVT
>>>> which is defined in
>>>> expected
>>>> rvalue
>>>> is unset as well.
>>>> TIA
>>>> Marius
>>>>> Hi
>>>>> please
>>>>> raise a Bugzilla.
>>>>> default
>>>>> default.
>>>>> Regards
>>>>> Ed Willink
>>>>>> Hello,
>>>>>> attribute
>>>>>> generated
>>>>>> QVT
>>>>>> float,
>>>>>> which is defined in
>>>>>> expected
>>>>>> bug,
>>>>>> bug
>>>>>> Marius
Re: Unsettable attribute, intrinsic defaults [message #1002357 is a reply to message #1002347] Fri, 18 January 2013 08:00 Go to previous messageGo to next message
I can see a QVTo change on efficiency grounds to the effect that every
eSet to the output model is guarded by an if-necessary test.
This would avoid numerous redundant notifications for the in-place
update usage.
This would also solve your immediate problem, but probably then provoke
the opposite; output values that just happen to be right by default
would not be explicitly set.
If so then QVTo may be needs four eSet modes:
- always eSet
- always eSet unless value is correct and source is explictly unset
- only eSet if necessary to change a value
- only eSet if necessary to change a value or source is explicitly set
Since the source is an arbitrary OCL expression, special casing the
trivial PropertyCallExp makes me uncomfortable, and why can't you
control unset for more complex cases?
Surely you can control unset on the output by wrapping the assignment in
an imperative if? Then you just need a helper function to allow you to
test whether a source value is unset.
Ed Willink
On 18/01/2013 12:36, Marius Gröger wrote:
> Hello,
> Marius
>> Hi
>> Regards
>> Ed Willink
>>> Hello Ed,
>>> this.
>>> Thanks again
>>> Marius
>>>> Hi
>>>> default explicitly.
>>>> creating EObjects.
>>>> Regards
>>>> Ed Willink
>>>>> Hi Ed,
>>>>> QVT
>>>>> which is defined in
>>>>> expected
>>>>> rvalue
>>>>> is unset as well.
>>>>> TIA
>>>>> Marius
>>>>>> Hi
>>>>>> please
>>>>>> raise a Bugzilla.
>>>>>> default
>>>>>> default.
>>>>>> Regards
>>>>>> Ed Willink
>>>>>>> Hello,
>>>>>>> attribute
>>>>>>> generated
>>>>>>> QVT
>>>>>>> float,
>>>>>>> which is defined in
>>>>>>> expected
>>>>>>> bug,
>>>>>>> bug
>>>>>>> Marius
Re: Unsettable attribute, intrinsic defaults [message #1002385 is a reply to message #1002357] Fri, 18 January 2013 08:39 Go to previous messageGo to next message
Meaning to analyse the source as an EObject and checking eIsSet()?
Probably, but it would really mess up the QVT code a lot. And I really
only see this issue with primitive floats.
I just posted a work-around on e.t.emf in the thread 'Annoying intrinsic
default values for primitive types'. That solution concerns XSD models.
Regular Ecore models won't be affected by this as long as all values are
put into custom EDataTypes, ie. if EInt, EFloat etc are avoided.
Marius
Re: Unsettable attribute, intrinsic defaults [message #1002426 is a reply to message #1002385] Fri, 18 January 2013 09:55 Go to previous messageGo to next message
<!DOCTYPE html PUBLIC "-//W3C//DTD HTML 4.01//EN" "http://www.w3.org/TR/html4/strict.dtd">
<html>
<head>
<meta http-equiv="Content-Type" content="text/html; charset=iso-8859-1">
<meta http-equiv="Content-Style-Type" content="text/css">
<title></title>
<meta name="Generator" content="Cocoa HTML Writer">
<meta name="CocoaVersion" content="1138.51">
<style type="text/css">
p.p1 {margin: 0.0px 0.0px 0.0px 0.0px; line-height: 15.0px; font: 12.0px Helvetica}
p.p2 {margin: 0.0px 0.0px 0.0px 0.0px; line-height: 15.0px; font: 12.0px Helvetica; min-height: 14.0px}
p.p3 {margin: 0.0px 0.0px 0.0px 0.0px; font: 11.0px Monaco; color: #3344fc}
p.p4 {margin: 0.0px 0.0px 0.0px 0.0px; font: 11.0px Monaco; color: #921e67; min-height: 15.0px}
p.p5 {margin: 0.0px 0.0px 0.0px 0.0px; font: 11.0px Monaco}
p.p6 {margin: 0.0px 0.0px 0.0px 0.0px; font: 11.0px Monaco; color: #921e67}
p.p7 {margin: 0.0px 0.0px 0.0px 0.0px; font: 11.0px Monaco; color: #0034c9}
p.p8 {margin: 0.0px 0.0px 0.0px 0.0px; font: 12.0px Helvetica; min-height: 14.0px}
p.p9 {margin: 0.0px 0.0px 0.0px 12.0px; line-height: 14.0px; font: 12.0px Helvetica; color: #002390}
p.p10 {margin: 0.0px 0.0px 0.0px 24.0px; font: 12.0px Helvetica; color: #008d12}
p.p11 {margin: 0.0px 0.0px 0.0px 12.0px; font: 12.0px Helvetica; color: #002390; min-height: 14.0px}
p.p12 {margin: 0.0px 0.0px 0.0px 12.0px; font: 12.0px Helvetica; color: #002390}
p.p13 {margin: 0.0px 0.0px 0.0px 0.0px; font: 12.0px Helvetica; color: #000000; min-height: 14.0px}
span.s1 {color: #921e67}
span.s2 {color: #000000}
span.s3 {color: #83195c}
span.s4 {color: #002cae}
span.s5 {color: #0034c9}
span.s6 {color: #3344fc}
span.Apple-tab-span {white-space:pre}
</style>
</head>
<body>
<p class="p1">I ran into this problem and my solution is to sort of cheat a bit and add a Helper method:</p>
<p class="p2"><br></p>
<p class="p3"><span class="s1">modeltype</span><span class="s2"> ECORE </span><span class="s1">uses</span><span class="s2"> </span>'http://www.eclipse.org/emf/2002/Ecore'<span class="s2">;</span></p>
<p class="p4"><br></p>
<p class="p5"><span class="s1">helper</span> OclAny::<span class="s3">isSet</span>(feature : String) : Boolean{</p>
<p class="p5"><span class="Apple-tab-span"> </span><span class="s1">var</span> value : Boolean := <span class="s1">false</span>;</p>
<p class="p5"><span class="Apple-tab-span"> </span><span class="s1">if</span> (<span class="s4">self</span>.oclAsType(<span class="s5">ECORE</span>::<span class="s5">EObject</span>).eIsSet(<span class="s4">self</span>.oclAsType(<span class="s5">ECORE</span>::<span class="s5">EObject</span>).eClass().getEStructuralFeature(feature))) <span class="s1">then</span>{</p>
<p class="p5"><span class="Apple-tab-span"> </span><span class="Apple-tab-span"> </span>value := <span class="s1">true</span>;</p>
<p class="p6"><span class="s2"><span class="Apple-tab-span"> </span>}</span>endif<span class="s2">;</span></p>
<p class="p5"><span class="Apple-tab-span"> </span><span class="s1">return</span> value;</p>
<p class="p5">}</p>
<p class="p1">I can then call this from within the code as something like:</p>
<p class="p7"><span class="s1">if</span><span class="s2"> (</span><span class="s4">self</span><span class="s2">.</span><span class="s3">isSet</span><span class="s2">(</span><span class="s6">"pTolerance"</span><span class="s2">)) </span><span class="s1">then</span><span class="s2">{ </span><span class="s4">result</span><span class="s2">.</span>tolerance<span class="s2"> := </span><span class="s4">self</span><span class="s2">.</span>pTolerance<span class="s2">;}</span><span class="s1">endif</span><span class="s2">;</span></p>
<p class="p8"><br></p>
<p class="p1">Obviously the main problem here is that you're referring to the attribute as a string so there's the risk you mistype it and you won't get auto-correction, but I only use it for the primitive types where the default vs unset case is required. This was a simpler approach than trying to modify the underlying QVT engine</p>
<p class="p1">Alan</p>
<p class="p1">On 2013-01-18 13:39:09 +0000, Marius Gröger said:</p>
<p class="p9">On 18.01.2013 14:00, Ed Willink wrote:</p>
<p class="p10">Surely you can control unset on the output by wrapping the assignment in</p>
<p class="p10">an imperative if? Then you just need a helper function to allow you to</p>
<p class="p10">test whether a source value is unset.</p>
<p class="p11"><br></p>
<p class="p12">Meaning to analyse the source as an EObject and checking eIsSet()?</p>
<p class="p12">Probably, but it would really mess up the QVT code a lot. And I really</p>
<p class="p12">only see this issue with primitive floats.</p>
<p class="p12">I just posted a work-around on e.t.emf in the thread 'Annoying intrinsic</p>
<p class="p12">default values for primitive types'. That solution concerns XSD models.</p>
<p class="p12">Regular Ecore models won't be affected by this as long as all values are</p>
<p class="p12">put into custom EDataTypes, ie. if EInt, EFloat etc are avoided.</p>
<p class="p12">Regards</p>
<p class="p12">Marius</p>
<p class="p13"><br></p>
</body>
</html>
Re: Unsettable attribute, intrinsic defaults [message #1002438 is a reply to message #1002426] Fri, 18 January 2013 10:19 Go to previous messageGo to next message
<html>
<head>
<meta content="text/html; charset=ISO-8859-1"
http-equiv="Content-Type">
</head>
Hi<br>
<br>
It should be possible for OCL to provide an
OclElement::oclIsSet(Property) method that might then allow<br>
<br>
class="s4">self</span><span class="s2">.</span><span class="s3">oclsSet</span><span
class="s2">(</span><span class="s6">pTolerance</span><span
<br>
but there might be a syntax ambiguity requiring<br>
<br>
class="s2">(MyClass::</span><span class="s6">pTolerance</span><span
<br>
&nbsp;&nbsp;&nbsp; Regards<br>
<br>
&nbsp;&nbsp;&nbsp; &nbsp;&nbsp;&nbsp; Ed Willink<br>
<br>
<br>
<br>
On 18/01/2013 14:55, Alan McMorran wrote:
<blockquote cite="mid:kdbnor$lfd$1@xxxxxxxxe.org" type="cite">
charset=ISO-8859-1">
<title></title>
</style>
<p class="p2"><br>
</p>
ECORE </span><span class="s1">uses</span><span class="s2"> </span>'<a class="moz-txt-link-freetext" href="http://www.eclipse.org/emf/2002/Ecore">http://www.eclipse.org/emf/2002/Ecore</a>'<span
<p class="p4"><br>
</p>
<p class="p5">}</p>
<p class="p2"><br>
</p>
something like:</p>
<p class="p2"><br>
</p>
<p class="p8"><br>
</p>
<p class="p2"><br>
</p>
<p class="p2"><br>
</p>
<p class="p2"><br>
</p>
<p class="p2"><br>
</p>
<p class="p1">On 2013-01-18 13:39:09 +0000, Marius Gr&ouml;ger said:</p>
<p class="p2"><br>
</p>
<p class="p11"><br>
</p>
<p class="p11"><br>
</p>
are avoided.</p>
<p class="p11"><br>
</p>
<p class="p13"><br>
</p>
</blockquote>
<br>
</body>
</html>
Re: Unsettable attribute, intrinsic defaults [message #1002523 is a reply to message #1002438] Fri, 18 January 2013 14:01 Go to previous messageGo to next message
<html>
<head>
<title></title>
p.p3 {margin: 0.0px 0.0px 0.0px 0.0px; font: 11.0px Monaco}
p.p4 {margin: 0.0px 0.0px 0.0px 12.0px; font: 16.0px Helvetica; color: #002390}
p.p5 {margin: 0.0px 0.0px 0.0px 12.0px; font: 16.0px Helvetica; color: #002390; min-height: 19.0px}
p.p6 {margin: 0.0px 0.0px 0.0px 12.0px; font: 12.0px Helvetica; color: #002390}
p.p7 {margin: 0.0px 0.0px 0.0px 12.0px; font: 12.0px Helvetica; color: #002390; min-height: 14.0px}
p.p8 {margin: 0.0px 0.0px 0.0px 24.0px; font: 12.0px Helvetica; color: #008d12}
p.p9 {margin: 0.0px 0.0px 0.0px 36.0px; font: 12.0px Helvetica; color: #930f04}
p.p10 {margin: 0.0px 0.0px 0.0px 24.0px; font: 12.0px Helvetica; color: #008d12; min-height: 14.0px}
p.p11 {margin: 0.0px 0.0px 0.0px 0.0px; line-height: 14.0px; font: 12.0px Helvetica; min-height: 14.0px}
span.s2 {color: #83195c}
span.s3 {text-decoration: underline}
</style>
</head>
<body>
<p class="p1">Ed,</p>
<p class="p1">That would be nice, right now the problem I get if I try to reference MyClass::pTolerance in QVT is that it complains about:</p>
<p class="p1"><span class="Apple-tab-span"> </span>'static reference to non-static attribute "pTolerance"'</p>
<p class="p1">So even doing a method of:</p>
<p class="p3"><span class="s1"><span class="Apple-tab-span"> </span>helper</span> OclAny::<span class="s2">isSetOcl</span>(feature : OclAny) : Boolean{</p>
<p class="p1">Would not work as we can't reference the property in the QVT code in the first place.</p>
<p class="p1">As I said, the string passing method isn't the cleanest but it works and the implementation below doesn't even require a black-box :-)</p>
<p class="p1">On 2013-01-18 15:19:21 +0000, Ed Willink said:</p>
<p class="p4">Hi</p>
<p class="p5"><br></p>
<p class="p4">It should be possible for OCL to provide an OclElement::oclIsSet(Property) method that might then allow</p>
<p class="p6">if (self.oclsSet(pTolerance)) then{ result.tolerance := self.pTolerance;}endif;</p>
<p class="p4">but there might be a syntax ambiguity requiring</p>
<p class="p6">if (self.oclsSet(MyClass::pTolerance)) then{ result.tolerance := self.pTolerance;}endif;</p>
<p class="p4">    Regards</p>
<p class="p4">        Ed Willink</p>
<p class="p4">On 18/01/2013 14:55, Alan McMorran wrote:</p>
<p class="p6">I ran into this problem and my solution is to sort of cheat a bit and add a Helper method:</p>
<p class="p7"><br></p>
<p class="p6">modeltype ECORE uses '<a href="http://www.eclipse.org/emf/2002/Ecore"><span class="s3">http://www.eclipse.org/emf/2002/Ecore</span></a>';</p>
<p class="p6">helper OclAny::isSet(feature : String) : Boolean{</p>
<p class="p6"><span class="Apple-converted-space"> </span>var value : Boolean := false;</p>
<p class="p6"><span class="Apple-converted-space"> </span>if (self.oclAsType(ECORE::EObject).eIsSet(self.oclAsType(ECORE::EObject).eClass().getEStructuralFeature(feature))) then{</p>
<p class="p6"><span class="Apple-converted-space">  </span>value := true;</p>
<p class="p6"><span class="Apple-converted-space"> </span>}endif;</p>
<p class="p6"><span class="Apple-converted-space"> </span>return value;</p>
<p class="p6">}</p>
<p class="p6">I can then call this from within the code as something like:</p>
<p class="p6">if (self.isSet("pTolerance")) then{ result.tolerance := self.pTolerance;}endif;</p>
<p class="p6">Obviously the main problem here is that you're referring to the attribute as a string so there's the risk you mistype it and you won't get auto-correction, but I only use it for the primitive types where the default vs unset case is required. This was a simpler approach than trying to modify the underlying QVT engine</p>
<p class="p6">Alan</p>
<p class="p6">On 2013-01-18 13:39:09 +0000, Marius Gröger said:</p>
<p class="p8">On 18.01.2013 14:00, Ed Willink wrote:</p>
<p class="p9">Surely you can control unset on the output by wrapping the assignment in</p>
<p class="p9">an imperative if? Then you just need a helper function to allow you to</p>
<p class="p9">test whether a source value is unset.</p>
<p class="p10"><br></p>
<p class="p8">Meaning to analyse the source as an EObject and checking eIsSet()?</p>
<p class="p8">Probably, but it would really mess up the QVT code a lot. And I really</p>
<p class="p8">only see this issue with primitive floats.</p>
<p class="p8">I just posted a work-around on e.t.emf in the thread 'Annoying intrinsic</p>
<p class="p8">default values for primitive types'. That solution concerns XSD models.</p>
<p class="p8">Regular Ecore models won't be affected by this as long as all values are</p>
<p class="p8">put into custom EDataTypes, ie. if EInt, EFloat etc are avoided.</p>
<p class="p8">Regards</p>
<p class="p8">Marius</p>
</body>
</html>
Re: Unsettable attribute, intrinsic defaults [message #1002529 is a reply to message #1002523] Fri, 18 January 2013 14:11 Go to previous messageGo to next message
<html>
<head>
</head>
Hi Alan<br>
<br>
That's why oclIsSet(pTolerance) might not work; is 'pTolerance' a
VariableExp or a PropertyLiteralExp?<br>
<br>
oclIsSet(MyClass::pTolerance) might be more tractably a
<br>
NB. OCL's support for Element Literals is patchy at present; types
for oclAsType and expressions for iterator bodies.<br>
<br>
I have yet to decide quite what form of ElementLiteralExp
could/should be added.<br>
<br>
<br>
<br>
On 18/01/2013 19:01, Alan McMorran wrote:
<blockquote cite="mid:kdc666$i0e$1@xxxxxxxxe.org" type="cite">
<title></title>
</style>
<p class="p2"><br>
</p>
about:</p>
<p class="p2"><br>
</p>
Boolean{</p>
<p class="p2"><br>
</p>
<p class="p2"><br>
</p>
<p class="p2"><br>
</p>
<p class="p2"><br>
</p>
<p class="p2"><br>
</p>
<p class="p2"><br>
</p>
<p class="p5"><br>
</p>
<p class="p5"><br>
</p>
<p class="p5"><br>
</p>
<p class="p5"><br>
</p>
<p class="p5"><br>
</p>
<p class="p4">&nbsp;&nbsp;&nbsp; Regards</p>
<p class="p5"><br>
</p>
<p class="p4">&nbsp;&nbsp;&nbsp; &nbsp;&nbsp;&nbsp; Ed Willink</p>
<p class="p5"><br>
</p>
<p class="p5"><br>
</p>
<p class="p5"><br>
</p>
<p class="p7"><br>
</p>
<p class="p6">modeltype ECORE uses '<a moz-do-not-send="true"
<p class="p7"><br>
</p>
<p class="p6"><span class="Apple-converted-space">&nbsp;</span>var
<p class="p6"><span class="Apple-converted-space">&nbsp;</span>if
then{</p>
<p class="p6"><span class="Apple-converted-space">&nbsp; </span>value
:= true;</p>
<p class="p6"><span class="Apple-converted-space">&nbsp;</span>}endif;</p>
<p class="p6"><span class="Apple-converted-space">&nbsp;</span>return
value;</p>
<p class="p6">}</p>
<p class="p7"><br>
</p>
something like:</p>
<p class="p7"><br>
</p>
<p class="p7"><br>
</p>
<p class="p7"><br>
</p>
<p class="p7"><br>
</p>
<p class="p7"><br>
</p>
<p class="p7"><br>
</p>
<p class="p6">On 2013-01-18 13:39:09 +0000, Marius Gr&ouml;ger said:</p>
<p class="p7"><br>
</p>
<p class="p10"><br>
</p>
<p class="p10"><br>
</p>
are avoided.</p>
<p class="p10"><br>
</p>
<p class="p11"><br>
</p>
</blockquote>
<br>
</body>
</html>
Re: Unsettable attribute, intrinsic defaults [message #1003937 is a reply to message #1002426] Tue, 22 January 2013 04:25 Go to previous messageGo to next message
Alan,
Thanks for sharing this. TBH, I was aware that this can be solved like
this, but I don't really like having to actively remember writing that
if-isSet-then-set-endif clause everytime I assign such a value. What's
more, we are working on those transformations in a team so everybody has
to remember.
To recap: if you use custom datatypes in your EMF models that point to
java.lang.Float etc., then attributes with these types can very well be
unset and will deliver "null" when QVT calls eGet(). No problem here,
because when QVT subsequently eSet()s this "null" value to the output
variable, everything behaves as expected.
It's _only_ primitive types (EFloat etc. and --in my case-- xs:float
from an originating XSD) which will magically deliver the intrinsic
default even when they were never explicitly assigned. While I
understand Ed Merck's argument that intrinsic values just always have a
default, I like my models to be truely unsettable and returning "null"
if so.
Over in http://www.eclipse.org/forums/index.php/m/1002492/ I shared how
I now import my XML instances by enforcing xs:float to be mapped to Float.
Marius
Re: Unsettable attribute, intrinsic defaults [message #1004032 is a reply to message #1003937] Tue, 22 January 2013 08:29 Go to previous messageGo to next message
Hi Marius,
Remember that apart from the Ecore EDataTypes for java primitive types
(EFloat, EInt, ...) you also have Ecore EDataTypes counterparts for true
java Objects: EFloatObject, EIntegerObject, ... so, if desired, you
don't need to create custom datatypes at all.
Adolfo.
Re: Unsettable attribute, intrinsic defaults [message #1004085 is a reply to message #1004032] Tue, 22 January 2013 09:49 Go to previous message
> Hi Marius,
Thanks for this hint, I was indeed not really aware of this. In our
project however we need custom datatypes anyway because we add a number
of custom annotations that further refine allowed content.
Marius
Previous Topic:Errors running builder 'QVT Operational Builder'
Next Topic:Constant rebuilds
Current Time: Sun Jul 27 07:32:25 EDT 2025
Powered by FUDForum. Page generated in 0.06725 seconds
