Home » Eclipse Projects » Rich Client Platform (RCP) » How to view sources of internal plugins
How to view sources of internal plugins [message #998547] Thu, 10 January 2013 03:08 Go to next message
I am using a target platform from another party.
My problem is that they have recently started using x-internal true in their exported packages. What this means to me is that I can't view the source codes anymore. I have the source jars and it is of course possible to unzip the source jars and view the source manually that way. It would be easier if I could just open the classes in Eclipse.
I know the dangers of using relying on packages that are marked as internal. But it would be quite important to see what is happening in the classes.
Is it possible to somehow view these classes in Eclipse?
Re: How to view sources of internal plugins [message #998750 is a reply to message #998547] Thu, 10 January 2013 11:09 Go to previous messageGo to next message
> the classes.
Marking the stuff x-internal is probably not the issue but rather that
they no longer provide the source plug-ins (correctly). If you have the
source then you can e.g. import the bundles from the target and then
manually attach the source. After that you will be able to see the
source when opening a type.
Dani
Re: How to view sources of internal plugins [message #1000807 is a reply to message #998750] Tue, 15 January 2013 08:04 Go to previous messageGo to next message
Thanks, that helps a bit.
I wish there was a way to allow opening the types without importing though. There are nearly 600 plugins, so importing them all is not really that convenient and importing them one by one when I need them seems a bit inconvenient too.
What confuses me is that the packages without x-internal open without importing them.
Re: How to view sources of internal plugins [message #1002338 is a reply to message #1000807] Fri, 18 January 2013 07:25 Go to previous message
From bundle_manifest
The x-internal Directive
The x-internal directive can be used in an Export-Package header to specify whether the package is an internal package. The Plug-in Development Environment will discourage other bundles from using an internal package. If the x-internal directive is not specified then a default value of 'false' is used. The x-internal directive must use the following syntax:
x-internal ::= ( 'true' | 'false' )
The following is an example of the x-internal directive:
Export-Package: org.eclipse.foo.internal; x-internal:=true
Previous Topic:Add the Console to an Eclipse 4 RCP Application
Next Topic:table cell editor does not deactivate and commit the value when save command is invoked
Current Time: Sat Jul 26 08:11:04 EDT 2025
Powered by FUDForum. Page generated in 0.04899 seconds
