Home » Modeling » EMF » Mapping eType of reference to eType of attribute(Mapping eTypes)
Mapping eType of reference to eType of attribute [message #1001891] Thu, 17 January 2013 09:15 Go to next message
I define an ecore model with Java interfaces:
import java.net.InetAddress;
 * @model
public interface net {
     * @model dataType="java.net.InetAddress"
    InetAddress getAddress();
and
import java.util.List;
 * @model
public interface nic {
     * @model containment="true" required="false" type="java.net.InetAddress"
    List<InetAddress> getAddresses();
Now, I would expect that ecore uses the same eType for the attribute net.address and the reference nic.addresses. However, it uses two different eTypes: InetAddress for the attribute and InetAddress_1 for the reference.
How can I enforce that the same eType is used? And why is that happening anyways?
I'm using Eclispe Juno.
Martin
[Updated on: Thu, 24 January 2013 06:56] by Moderator
Re: Mapping eType of reference to eType of attribute [message #1002083 is a reply to message #1001891] Thu, 17 January 2013 17:32 Go to previous messageGo to next message
The eType of an attribute must be a DataType, while the eType of a
Reference must be an EClass, hence it generates and uses another type
for the reference.
Hallvard
On 17.01.13 07.57, Martin C. wrote:
> and
> the reference.
> anyways?
> Martin
Re: Mapping eType of reference to eType of attribute [message #1002237 is a reply to message #1001891] Fri, 18 January 2013 03:22 Go to previous messageGo to next message
Martin,
You might want to consider using Xcore instead. The syntax is simpler
and there's much more in the way of immediate error checking and feedback:
http://wiki.eclipse.org/Xcore
On 17/01/2013 4:57 PM, Martin C. wrote:
> and
> the reference.
> happening anyways?
> Martin
Re: Mapping eType of reference to eType of attribute [message #1005064 is a reply to message #1002237] Thu, 24 January 2013 07:07 Go to previous messageGo to next message
Let's use a list:
  • Thanks Hallvard, that explained what happens.
  • Also thanks Ed for the pointer to Xcore. However, I'm not quite sure if I want to use Xcore. It looks already so similar to Java that I could also model with Java classes themselves.
  • Is there a way to specify the name of the EClass/eType? So I could get rid of the annoying "_1" name.
  • BTW: I pasted the annotations to the wrong statements in my code examples, because I simplified the code to what the problem is. But it's fixed now.
Re: Mapping eType of reference to eType of attribute [message #1005084 is a reply to message #1005064] Thu, 24 January 2013 08:02 Go to previous messageGo to next message
Martin,
Comments below.
On 24/01/2013 1:07 PM, Martin C. wrote:
> Let's use a list:
Yes, but as I said, there is little in the way of feedback on what's
wrong with your @model annotations. In your example, not a single one
of the attributes you've specified was sensible in that location.
Have a look at the generated XyzPackage implementation's @model
annotations to see what data types you've ended up with. Once they're
their and they're marked @model, you have to delete them to get rid of them.
> it's fixed now.
What does it look like now?
Re: Mapping eType of reference to eType of attribute [message #1005693 is a reply to message #1005084] Mon, 28 January 2013 05:08 Go to previous message
Hi Ed,
the annotations were in the wrong place, because I pasted them to the wrong statement. It's now fixed in my first posting. If that should still be wrong, I really got something wrong.
Martin
Previous Topic:[CDO] 4.1 transaction rollback after a commit
Next Topic:[CDO] Unmonitored fail-over example
Current Time: Fri Jul 25 22:20:49 EDT 2025
Powered by FUDForum. Page generated in 0.05895 seconds
