Home » Modeling » EMF "Technology" (Ecore Tools, EMFatic, etc)  » Adding/Editing/Deleting Ecore objects programmatically using EditingDomain(How? Any example?)
Adding/Editing/Deleting Ecore objects programmatically using EditingDomain [message #986016] Sat, 17 November 2012 09:00 Go to next message
I am trying to add some annotations, fields and references to an EClass programmatically using EditingDomain. Do we have some examples?
thanks,
Pradeep V.B.
Re: Adding/Editing/Deleting Ecore objects programmatically using EditingDomain [message #986019 is a reply to message #986016] Sat, 17 November 2012 10:00 Go to previous messageGo to next message
You'd use things like AddCommand.create (see the Javadoc) and then use
editingDomain.getCommandStack().execute.
On 17/11/2012 3:00 PM, Pradeep Badiger wrote:
> thanks,
> Pradeep V.B.
Re: Adding/Editing/Deleting Ecore objects programmatically using EditingDomain [message #1001957 is a reply to message #986019] Thu, 17 January 2013 11:00 Go to previous messageGo to next message
Hi Ed,
I was able to create the required EMF features in the model, but the command stack doesnt allow me to save the changes. Is there anything that i have to set to make it save or ask user to save the file when modified programmatically?
Re: Adding/Editing/Deleting Ecore objects programmatically using EditingDomain [message #1002230 is a reply to message #1001957] Fri, 18 January 2013 03:11 Go to previous message
Pradeep,
You can look at the generated editor (or EcoreEditor) to see how things
are saved.
On 17/01/2013 5:00 PM, Pradeep Badiger wrote:
> Hi Ed,
Previous Topic:[Texo] Problems handling ResponseType
Next Topic:[EMFStore] Is it somehow possible to use EMFStore for metamodels?
Current Time: Wed Jul 23 13:27:19 EDT 2025
Powered by FUDForum. Page generated in 0.25485 seconds
