Home » Language IDEs » Java Development Tools (JDT) » problem with JVM
problem with JVM [message #99995] Tue, 30 September 2003 09:10 Go to next message
hi,
i am tring to run eclipse 2.1.1 with IBM 1.4.1 JVM and when i try to open
a plugin.xml file i get an error:
!MESSAGE org.apache.xerces.parsers.DOMBuilderImpl: method
setFeature(Ljava/lang/String;Z)V not found
!STACK 0
java.lang.NoSuchMethodError: org.apache.xerces.parsers.DOMBuilderImpl:
method setFeature(Ljava/lang/String;Z)V not found
at
org.eclipse.pde.internal.core.plugin.XMLDocumentModelBuilder .initialize(XMLDocumentModelBuilder.java:71)
at
org.eclipse.pde.internal.core.plugin.XMLDocumentModelBuilder . <init>(XMLDocumentModelBuilder.java:67)
what can i do?? (i want to use this JVM and this eclipse version)
thanks Asaf:)
Re: problem with JVM [message #100027 is a reply to message #99995] Tue, 30 September 2003 09:33 Go to previous messageGo to next message
Originally posted by: olivier_thomann.ca.ibm.comNOSPAM
Le Tue, 30 Sep 2003 13:10:29 +0000 (UTC), asafbe@il.ibm.com (Asaf) a
écrit :
>!STACK 0
> at
> at
You have a vesion of xerces on your classpath that collides with the
one used by Eclipse. Remove the xml.jar from your classpath.
Olivier
Re: problem with JVM [message #100193 is a reply to message #100027] Wed, 01 October 2003 02:28 Go to previous message
> écrit :
> >!STACK 0
> > at
> > at
> Olivier
i removed the xml.jar from my classpath and now the eclipse cann't start..
i got this message in the log file:
org.apache.xerces.util.ObjectFactory$ConfigurationError: Provider
org.apache.xerces.parsers.IntegratedParserConfiguration not found
at
org.apache.xerces.util.ObjectFactory.newInstance(ObjectFacto ry.java:252)
at
org.apache.xerces.util.ObjectFactory.createObject(ObjectFact ory.java:182)
at
org.apache.xerces.util.ObjectFactory.createObject(ObjectFact ory.java:123)
at org.apache.xerces.parsers.SAXParser.<init>(SAXParser.java:95)
at
org.eclipse.core.internal.resources.ProjectDescriptionReader .read(ProjectDescriptionReader.java:439)
at
org.eclipse.core.internal.resources.ProjectDescriptionReader .read(ProjectDescriptionReader.java:475)
at
org.eclipse.core.internal.localstore.FileSystemResourceManag er.read(FileSystemResourceManager.java:450)
at
org.eclipse.core.internal.resources.SaveManager.restoreMetaI nfo(SaveManager.java:582)
at
org.eclipse.core.internal.resources.SaveManager.restoreMetaI nfo(SaveManager.java:623)
at
org.eclipse.core.internal.resources.SaveManager.restore(Save Manager.java:504)
at
org.eclipse.core.internal.resources.SaveManager.startup(Save Manager.java:1033)
at
org.eclipse.core.internal.resources.Workspace.startup(Worksp ace.java:1734)
at org.eclipse.core.internal.resources.Workspace.open(Workspace .java:1537)
at
org.eclipse.core.resources.ResourcesPlugin.startup(Resources Plugin.java:268)
at
org.eclipse.core.internal.plugins.PluginDescriptor$1.run(Plu ginDescriptor.java:736)
at
org.eclipse.core.internal.runtime.InternalPlatform.run(Inter nalPlatform.java:1006)
at
org.eclipse.core.internal.plugins.PluginDescriptor.internalD oPluginActivation(PluginDescriptor.java:748)
at
org.eclipse.core.internal.plugins.PluginDescriptor.doPluginA ctivation(PluginDescriptor.java:188)
at
org.eclipse.core.internal.plugins.PluginClassLoader.activate Plugin(PluginClassLoader.java:112)
at
org.eclipse.core.internal.plugins.PluginClassLoader.internal FindClassParentsSelf(PluginClassLoader.java:185)
at
org.eclipse.core.internal.boot.DelegatingURLClassLoader.find ClassParentsSelf(DelegatingURLClassLoader.java:490)
at
org.eclipse.core.internal.boot.DelegatingURLClassLoader.load Class(DelegatingURLClassLoader.java:882)
at
org.eclipse.core.internal.boot.DelegatingURLClassLoader.acce ss$0(DelegatingURLClassLoader.java:876)
at
org.eclipse.core.internal.boot.DelegatingURLClassLoader$Dele gateLoader.loadClass(DelegatingURLClassLoader.java:90)
at
org.eclipse.core.internal.boot.DelegatingURLClassLoader.find ClassPrerequisites(DelegatingURLClassLoader.java:554)
at
org.eclipse.core.internal.boot.DelegatingURLClassLoader.load Class(DelegatingURLClassLoader.java:890)
at
org.eclipse.core.internal.boot.DelegatingURLClassLoader.load Class(DelegatingURLClassLoader.java:862)
at java.lang.ClassLoader.loadClass(ClassLoader.java:484)
at java.lang.Class.getDeclaredConstructors0(Native Method)
at java.lang.Class.privateGetDeclaredConstructors(Class.java:16 57)
at java.lang.Class.getConstructor0(Class.java:1835)
at java.lang.Class.newInstance0(Class.java:316)
at java.lang.Class.newInstance(Class.java:295)
at
org.eclipse.core.internal.plugins.PluginDescriptor.createExe cutableExtension(PluginDescriptor.java:138)
at
org.eclipse.core.internal.plugins.PluginDescriptor.createExe cutableExtension(PluginDescriptor.java:167)
at
org.eclipse.core.internal.plugins.ConfigurationElement.creat eExecutableExtension(ConfigurationElement.java:103)
at
org.eclipse.core.internal.runtime.InternalPlatform.loaderGet Runnable(InternalPlatform.java:578)
at
sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAcce ssorImpl.java:79)
at
sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMe thodAccessorImpl.java:41)
at java.lang.reflect.Method.invoke(Method.java:371)
at
org.eclipse.core.internal.boot.InternalBootLoader.getRunnabl e(InternalBootLoader.java:471)
at
org.eclipse.core.internal.boot.InternalBootLoader.run(Intern alBootLoader.java:854)
at org.eclipse.core.boot.BootLoader.run(BootLoader.java:461)
at
at
at org.eclipse.core.launcher.Main.basicRun(Main.java:291)
at org.eclipse.core.launcher.Main.run(Main.java:747)
at org.eclipse.core.launcher.Main.main(Main.java:583)
Previous Topic:Error: source locator does not exist
Next Topic:Popup Menu Actions on custom IFolder
Current Time: Fri Jul 18 10:02:16 EDT 2025
Powered by FUDForum. Page generated in 0.03540 seconds
