Home » Modeling » Papyrus » structured datatype(how to create a structured datatype with profiles)
structured datatype [message #999628] Sat, 12 January 2013 12:46 Go to next message
Hello to everyone,
I'm modeling a room with papyrus and profiles. I've created the following types
<<enumeration>> |
 PolygonType    |
rectangle       |
square          |
  <<dataType>>     |
     Shape         |
type: PolygonType  |
area: Real         |
Then I created a class called "room" and I've applied a profile which has the Shape property as tagged value.
Now I want to fulfill the tagged values, but in the Shape field I can write something not defined, for example "circle", and everything goes ok because it is a string to fill and not for example a menu to choose from "rectangle" and "square".
Again what if a type has sub-types, how to manage them?
Thanks in advance,
Claudio
Re: structured datatype [message #1001716 is a reply to message #999628] Thu, 17 January 2013 04:15 Go to previous messageGo to next message
up
Re: structured datatype [message #1001899 is a reply to message #999628] Thu, 17 January 2013 09:21 Go to previous messageGo to next message
Hi, Claudio,
It's not entirely clear to me what the problem is. Are you saying that
in a DataType "room" in your model, having the <<shape>> stereotype
applied, you cal set the 'type' property to "circle"? In my
experience, Papyrus's property sheet presents a pick-list (as you
expected) for enumerated values.
I don't know what this has to do with sub-types.
Can you provide more details of your profile and your model, and in
which UI precisely you're seeing the wrong editing behaviour?
Christian
On 2013-01-12 17:46:44 +0000, Claudio Persico said:
> Hello to everyone,
> <<enumeration>> |
> PolygonType |
> rectangle |
> square |
> <<dataType>> |
> Shape |
> type: PolygonType |
> area: Real |
> Thanks in advance,
> Claudio
Re: structured datatype [message #1003128 is a reply to message #1001899] Sun, 20 January 2013 05:19 Go to previous messageGo to next message
Thanks for the reply and sorry for the confusing example: I was confused too.
I'm using Papyrus Standalone 1.12.3.
I've tried to make a better example (little different from the previous one).
This example is taken from the OMG XMI specification with some modifications
http://www.omg.org/spec/XMI/2.1.1/PDF/index.htm
par. 4.8.7 Datatype representation page 20
Here there's the profile I've made:
http://imageshack.us/a/img819/6519/datatype.jpg
and here the class with profile applied and the stereotypes:
http://imageshack.us/a/img12/8963/aroom.jpg
As you can see the class aRoom has a shape, but I can set whatever I want in the properties value.
Again, what if my two properties "upperLeft" and "lowerRight" were both [0..1] optional? How can I distinguish them in the UML with the notation provided by the standard?
I hope I've made all more clear this time.
Thanks in advance,
Claudio
Re: structured datatype [message #1003475 is a reply to message #999628] Mon, 21 January 2013 05:22 Go to previous messageGo to next message
Hello Claudio,
The Papyrus version from papyrusuml.org is old and deprecated (For about 4 years now). You should really be using the current version of Papyrus, which is available at http://www.eclipse.org/papyrus
Camille
Re: structured datatype [message #1003507 is a reply to message #1003475] Mon, 21 January 2013 06:46 Go to previous message
Thanks for the reply,
I've also installed Eclipse Juno with Papyrus 0.9.1a.
The result is the same, the problem persists as you can see from the UML code produced:
<profile:Room xmi:id="_FU1_gGO_EeKg7d_269-8CQ" base_Classifier="_DdxJIGO_EeKg7d_269-8CQ" shape="whatever, somethingelse, theRest&#xD;&#xA;"/>
Probably it is not a problem but the correct behavior. I would like to know how to handle it.
Thanks in advance,
Claudio
Previous Topic:Timing Information to Sequence Diagrams
Next Topic:Papyrus and SdMetrics
Current Time: Sat Jul 26 11:04:41 EDT 2025
Powered by FUDForum. Page generated in 0.05677 seconds
