CompleteOCL parser problem [message #1001801] |
Thu, 17 January 2013 06:51 |
Hi all,
I try to use to atl query to generate a very simple text form a parsed OCL document
conforms to CompleteOCLCST metamodel proposed by OCL MDT community.
I use this Java Parser
package Parser;
import java.io.IOException;
import org.eclipse.emf.common.util.URI;
import org.eclipse.emf.ecore.resource.Resource;
import org.eclipse.emf.ecore.resource.ResourceSet;
import org.eclipse.emf.ecore.resource.impl.ResourceSetImpl;
import org.eclipse.emf.ecore.util.EcoreUtil;
import org.eclipse.ocl.examples.pivot.model.OCLstdlib;
import org.eclipse.ocl.examples.xtext.completeocl.CompleteOCLStandaloneSetup;
import org.eclipse.ocl.examples.xtext.oclinecore.OCLinEcoreStandaloneSetup;
public class Parser {
public static void main(String[] args) throws IOException {
CompleteOCLStandaloneSetup.doSetup();
OCLinEcoreStandaloneSetup.doSetup();
OCLstdlib.install();
ResourceSet resourceSet = new ResourceSetImpl();
Resource resource = resourceSet.createResource(URI.createURI(args[0]));
resource.load(null);
EcoreUtil.resolveAll(resource);
Resource resourceAsXmi = resourceSet.createResource(URI.createURI(args[0]+".xmi"));
resourceAsXmi.getContents().addAll(resource.getContents());
resourceAsXmi.save(null);
an XMI file is generated.
when I use ATL transformation, An error is generated which is
Error loading platform:/resource/CompleteOCL/Test.xmi: The class 'VisitableCS' is not a valid classifier
Note: the problem is in the java parser, and I don't find how can I extend it to generate an appropriate xmi file.
if someone wants to help me, I am truly grateful because I spent a lot of time to try to extend this parser but I don't find anything
Fy Za
FUDForum. Page generated in 0.02894 seconds
