Home » Language IDEs » C / C++ IDE (CDT) » Remote Build
Remote Build [message #100175] Mon, 19 April 2004 08:34 Go to next message
Originally posted by: wayneglanfield.hotmail.com
I am currently running eclipse v3.0 M8 and the CDT plugin on windows NT,
however, the primary target platforms are a cluster running Linux and
Intel IA32 chips and an IBM SP. I would prefer only to use a single dev.
environment rather than have a separate environment running on each target
platform.
I would like to know if it is possible to set up the build environment so
that the project is built using the specified compiler on the target
platform.
Is this possible?
Re: Remote Build [message #100189 is a reply to message #100175] Mon, 19 April 2004 08:53 Go to previous message
I provided this info already here on the list two or three times.
Anyway, you can try to put your workspace on your NT host. The remote
targets could mount this workspace into their home e.g. using samba.
Next install SSH on the remote machines, and set them up to login per
public/private keypair and ssh-agent forwarding.
In your build configuration, change the default command to do a remote
shell-command call, something like:
ssh <your remote target> "cd $HOME/workspace/<project> && make"
This should log into the remote machine and execute the commands. The
output should still appear in the build console view in Eclipse.
Debugging is a more tricky thing, since this only works, where GDB has
GDB-Server support for remote targets (which is not true for windows
machines). Though, as long as your remote machine is not Windows, you
can use the GDB-Server settings in the Run/Debug-configuration.
Hope, this helps you getting started.
> platform.
> platform.
> Is this possible?
> Thanks
Previous Topic:parsing / indexing
Next Topic:Problem solved...
Current Time: Wed Nov 05 01:42:22 EST 2025
Powered by FUDForum. Page generated in 0.07517 seconds
