Home » Eclipse Projects » EclipseLink » I need to capture database warnings, which log level to use?(I'm debugging triggers, and I need to capture PostgreSQL warnings to get there)
I need to capture database warnings, which log level to use? [message #1001515] Wed, 16 January 2013 16:20 Go to next message
Hi!
I've a bunch of triggers in my PostgreSQL database, and I need to capture SQL Warnings issues to check the result of "RAISE NOTICE" statements inside the trigger.
I've tried even:
<property name="eclipselink.logging.level" value="ALL"/>
<property name="eclipselink.logging.level.sql" value="ALL"/>
<property name="eclipselink.logging.parameters" value="true"/>
<property name="eclipselink.logging.timestamp" value="true"/>
How can I achieve this when using Eclipse Link 2.4.1?
Edson
Re: I need to capture database warnings, which log level to use? [message #1001881 is a reply to message #1001515] Thu, 17 January 2013 09:07 Go to previous messageGo to next message
EclipseLink prints warning on finest/all if they are returned by JDBC. Seems like your driver is not returning the warnings.
Re: I need to capture database warnings, which log level to use? [message #1058114 is a reply to message #1001881] Sat, 11 May 2013 11:14 Go to previous message
You are right!
I had to change PostgreSQL driver to get warnings from it.
Edson.
Previous Topic:eclipseLink inheritance joined and oneToMany
Next Topic:Sorting by Date , I can't solve it
Current Time: Wed Jul 23 07:34:52 EDT 2025
Powered by FUDForum. Page generated in 0.04167 seconds
