Home » Modeling » EMF » [GWT] Server-side XMLResource
[GWT] Server-side XMLResource [message #1001378] |
Wed, 16 January 2013 10:40  |
the scenario I'm evaluating is a follows.
The service has a method that returns the root of a data structure
modelled with EMF.
On the server side this method reads the XML file and turns it into the
data structure like so:
----- 8< --------------
ResourceSet resourceSet = new ResourceSetImpl();
Resource.Factory resourceFactory = new XYResourceFactoryImpl();
Map<String, Object> extensionToFactory = resourceSet
.getResourceFactoryRegistry().getExtensionToFactoryMap();
extensionToFactory.put("xml", resourceFactory);
// Dummy call just to register the package
GenLegacyRenderingPackage.eINSTANCE.eClass();
Resource resource =
resourceSet.createResource(URI.createFileURI("DUMMY.xml"));
Map<String, Object> options = new HashMap<String, Object>();
options.put(XMLResource.OPTION_DEFER_IDREF_RESOLUTION, Boolean.TRUE);
options.put(XMLResource.OPTION_DEFER_ATTACHMENT, Boolean.TRUE);
options.put(XMLResource.OPTION_DISABLE_NOTIFY, Boolean.TRUE);
options.put(XMLResource.OPTION_RECORD_UNKNOWN_FEATURE, Boolean.TRUE);
resource.load(inputStream, options);
----- >8 -------------------
Well the problem is that there seems to be no XMLResource class in the
emf.gwt packages.
Actually I even do not need that because on the server side there is no
need for JavaScript. My first idea was to simply let the project depend
on org.eclipse.emf.ecore.xmi but will it be a good idea to mix non-GWT
with GWT EMF packages?
I started off with the default GWT Web Application project which creates
the client as well as the server side inside the same project. So how
could I use regular EMF runtime jars on the server side and GWT EMF on
the client side and allow both to share the same data model and to
interchange data based on this model?
Are two projects where each has its own .genmodel an option?
Thanks and Regards,
Dirk
Re: [GWT] Server-side XMLResource [message #1001384 is a reply to message #1001378] |
Wed, 16 January 2013 10:46   |
Another question along the same lines:
What if I wanted to send the XML file over the wire and parse it into a
data structure on the client. Is there an equivalent of
for the GWT client.
Dirk
Am 16.01.2013 16:40, schrieb Dirk Hoffmann:
> modelled with EMF.
> Resource resource =
> emf.gwt packages.
> Thanks and Regards,
> Dirk
Re: [GWT] Server-side XMLResource [message #1001405 is a reply to message #1001378] |
Wed, 16 January 2013 11:40   |
Dirk,
Comments below.
On 16/01/2013 4:40 PM, Dirk Hoffmann wrote:
> modelled with EMF.
> the data structure like so:
> Resource resource =
> emf.gwt packages.
Nor much in the way of something equivalent to SAX in the GWT runtime.
> no need for JavaScript. My first idea was to simply let the project
> depend on org.eclipse.emf.ecore.xmi but will it be a good idea to mix
> non-GWT with GWT EMF packages?
Probably not. I have no experience with that...
> creates the client as well as the server side inside the same project.
> So how could I use regular EMF runtime jars on the server side and GWT
> EMF on the client side and allow both to share the same data model and
> to interchange data based on this model?
Not sure. The binary serialization that's produced by the standard
runtime should be consumable by the GWT client.
I'm not sure I understand this question... If you want to use the
standard runtime on the server, then I think you'll need a separated
generated model for that environment verses the generated model you use
in the GWT client.
> Thanks and Regards,
> Dirk
Re: [GWT] Server-side XMLResource [message #1001408 is a reply to message #1001384] |
Wed, 16 January 2013 11:41   |
Dirk,
No, there's not even an equivalent of an input stream on the client...
> a data structure on the client. Is there an equivalent of
> for the GWT client.
> Dirk
>> Hi,
>> modelled with EMF.
>> Resource resource =
>> emf.gwt packages.
>> Thanks and Regards,
>> Dirk
Re: [GWT] Server-side XMLResource [message #1001690 is a reply to message #1001408] |
Thu, 17 January 2013 03:11   |
Hi Ed,
see below...
Am 16.01.2013 17:41, schrieb Ed Merks:
> Dirk,
Well, maybe not. I'm just looking for a way to deserialize some XML
serialized model into a data structure whose classes are generated from
an Ecore meta model.
I assume quite some code of the EMF/GWT projects was derived from the
regular EMF code. How difficult was that?
Do you think it would be achievable without too much effort to turn
org.eclipse.emf.ecore.xmi into its GWT counterpart, of course replacing
input stream with string?
Answering myself I think the biggest problem would be to replace the SAX
parser as browsers do not provide that natively. It would have to use
the dom returned by the browser's XMLParser.
After all deserialize some XML serialized model into a data structure
whose classes are generated from an Ecore meta model doesn't seem to be
an option, so I have to find a way to do this on the server or go
without EMF.
Dirk
(Why did they add this Followup button?)
>> for the GWT client.
>> Dirk
>>> Hi,
>>> modelled with EMF.
>>> Resource resource =
>>> emf.gwt packages.
>>> Thanks and Regards,
>>> Dirk
Re: [GWT] Server-side XMLResource [message #1001723 is a reply to message #1001690] |
Thu, 17 January 2013 04:29   |
Dirk,
Comments below.
On 17/01/2013 9:11 AM, Dirk Hoffmann wrote:
> Hi Ed,
> see below...
>> Dirk,
> from an Ecore meta model.
Yes, all of it. Most was quite straight forward. In normal generated
models, there's actually almost nothing to do. I've been told that
solve folks use stubs for the GWT dependencies to make the same
generated model work in the standard runtime...
> replacing input stream with string?
I looked at that a bit. Deserialization is quite heavily driven by SAX
events, so if there's a way to produce those, it should be relatively
straight forward. Serialization should be quite easily; it's heavily
focused on producing an efficient in-memory serialization using standard
Java libraries that should work well with GWT.
> SAX parser as browsers do not provide that natively. It would have to
> use the dom returned by the browser's XMLParser.
Yes, exactly.
> be an option, so I have to find a way to do this on the server or go
> without EMF.
If you can do all the work on the server, exchanging binary between the
client and the server is fast and effective.
> Dirk
Good question. :-P
>>> for the GWT client.
>>> Dirk
>>>> Hi,
>>>> modelled with EMF.
>>>> the
>>>> Resource resource =
>>>> emf.gwt packages.
>>>> is no
>>>> depend
>>>> creates
>>>> Thanks and Regards,
>>>> Dirk
Re: [GWT] Server-side XMLResource [message #1001742 is a reply to message #1001405] |
Thu, 17 January 2013 05:11   |
Hi Ed,
the approach is now to deserialize on the server using standard EMF and
return that to the client somehow.
I just added the standard ecore.xmi package to the dependencies to see
what happens. That gets me an Exception, more below...
Am 16.01.2013 17:40, schrieb Ed Merks:
> Dirk,
> Comments below.
>> Hi,
>> modelled with EMF.
>> Resource resource =
Up to here all went through
This comes back with an InvocationTargetException with target pointing
to a SecurityException saying
class "org.eclipse.emf.ecore.xml.type.internal.QName"'s signer
information does not match signer information of other classes in the
same package.
Not too surprising that it went wrong. This looks like if I had to
create a GWT version of the exore.xmi package (and maybe dependencies as
well) not to be run on the client but on the server just to make it
compatible with the emf.gwt jars.
Any other ideas?
What is the easiest way today to download the sources of the EMF projects?
Dirk
>> emf.gwt packages.
> in the GWT client.
>> Thanks and Regards,
>> Dirk
Re: [GWT] Server-side XMLResource [message #1001778 is a reply to message #1001690] |
Thu, 17 January 2013 05:59   |
Hi Dirk, Ed,
I don't want to break into the thread but still wanted to mention another direction. The EMFT Texo project supports JSON
serialization with a server side solution also. There is also a EMF JSON resource which can be used in a RCP client.
Would it be an idea to consider using Texo on the server side and EMF GWT on the client side?
See these blogs with further links to the docs inside:
http://martintaal.wordpress.com/2012/04/05/emf-texo-json-rest-web-service-support-connecting-your-client-to-an-emf-supporting-web-server/
http://martintaal.wordpress.com/2012/08/30/taking-emf-to-the-third-tier-the-texo-json-resource/
http://martintaal.wordpress.com/2012/05/09/emft-texo-model-driven-rcp-using-texo-generated-jpa-entities/
gr. Martin
On 01/17/2013 09:11 AM, Dirk Hoffmann wrote:
> Hi Ed,
> see below...
>> Dirk,
> Well, maybe not. I'm just looking for a way to deserialize some XML serialized model into a data structure whose classes
> are generated from an Ecore meta model.
> I assume quite some code of the EMF/GWT projects was derived from the regular EMF code. How difficult was that?
> Do you think it would be achievable without too much effort to turn org.eclipse.emf.ecore.xmi into its GWT counterpart,
> of course replacing input stream with string?
> Answering myself I think the biggest problem would be to replace the SAX parser as browsers do not provide that
> natively. It would have to use the dom returned by the browser's XMLParser.
> After all deserialize some XML serialized model into a data structure whose classes are generated from an Ecore meta
> model doesn't seem to be an option, so I have to find a way to do this on the server or go without EMF.
> Dirk
>>> for the GWT client.
>>> Dirk
>>>> Hi,
>>>> modelled with EMF.
>>>> Resource resource =
>>>> emf.gwt packages.
>>>> Thanks and Regards,
>>>> Dirk
With Regards, Martin Taal
Springsite/Elver.org
The Netherlands
Cell: +31 (0)6 288 48 943
Tel: +31 (0)84 420 2397
Fax: +31 (0)84 225 9307
Mail: mtaal@xxxxxxxx - mtaal@xxxxxxxx
Re: [GWT] Server-side XMLResource [message #1001789 is a reply to message #1001778] |
Thu, 17 January 2013 06:23   |
Hi Martin,
thanks for the hint. Looks interesting. I've come across Texo recently
but thought that it would not solve my problem. I have to use GWT for
the code executed on the browser so I wonder how Texo is to be used in
conjunction with GWT.
I want to use EMF for the client and server side because I already used
it for an Eclipse based application and hope to reuse as much of the
code I've written for it. The task basically is to port the application
from Eclipse to the GWT client.
Dirk
Am 17.01.2013 11:59, schrieb Martin Taal:
> Hi Dirk, Ed,
> another direction. The EMFT Texo project supports JSON serialization
> which can be used in a RCP client. Would it be an idea to consider using
> gr. Martin
>> Hi Ed,
>> see below...
>>> Dirk,
>> XMLParser.
>> Dirk
>>>> for the GWT client.
>>>> Dirk
>>>>> Hi,
>>>>> modelled with EMF.
>>>>> the
>>>>> Resource resource =
>>>>> emf.gwt packages.
>>>>> is no
>>>>> depend
>>>>> creates
>>>>> Thanks and Regards,
>>>>> Dirk
Re: [GWT] Server-side XMLResource [message #1001825 is a reply to message #1001789] |
Thu, 17 January 2013 07:23   |
Hi Dirk,
I haven't tried it but maybe the EMFJSONResource can be used in a EMF GWT client. Then on the server you can run Texo in
a webserver environment. The EMFJSONResource works out-of-the-box with a Texo EMF webserver.
Another option is to use another GWT solution, many GWT solutions (exjs/sencha, smartclient) use json as the
communication data format, then on the server you can use Texo also.
gr. Martin
On 01/17/2013 12:23 PM, Dirk Hoffmann wrote:
> Hi Martin,
> thanks for the hint. Looks interesting. I've come across Texo recently but thought that it would not solve my problem. I
> have to use GWT for the code executed on the browser so I wonder how Texo is to be used in conjunction with GWT.
> I want to use EMF for the client and server side because I already used it for an Eclipse based application and hope to
> reuse as much of the code I've written for it. The task basically is to port the application from Eclipse to the GWT
> client.
> Regards,
> Dirk
>> Hi Dirk, Ed,
>> gr. Martin
>>> Hi Ed,
>>> see below...
>>>> Dirk,
>>> XMLParser.
>>> Dirk
>>>>> for the GWT client.
>>>>> Dirk
>>>>>> Hi,
>>>>>> modelled with EMF.
>>>>>> the
>>>>>> Resource resource =
>>>>>> emf.gwt packages.
>>>>>> is no
>>>>>> depend
>>>>>> creates
>>>>>> Thanks and Regards,
>>>>>> Dirk
The Netherlands
Re: [GWT] Server-side XMLResource [message #1001845 is a reply to message #1001742] |
Thu, 17 January 2013 07:48   |
Dirk,
Comments below.
On 17/01/2013 11:11 AM, Dirk Hoffmann wrote:
> Hi Ed,
> and return that to the client somehow.
BinaryResourceImpl should do the trick for the "somehow."
>> Dirk,
>> Comments below.
>>> Hi,
>>> modelled with EMF.
>>> Resource resource =
> same package.
XMI depends on the standard EMF runtime, so you can't just mix that into
the GWT compatible runtime...
> as well) not to be run on the client but on the server just to make it
Yes, I suppose so. Differences in the Resource APIs (because of lack of
support for Streams) is going to cause a problem...
> Any other ideas?
Perhaps some kind of compatibility layer for the models you want to use
in both contexts would work. I.e., something that depends on the
standard *.emf.ecore and *.emf.common, but has the GWT bundle names and
also include stubs for the GWT-specific things generated in the models
would do the trick. Or maybe hand modify the generated manifest to use
package imports rather than bundle imports so they can resolve
differently depending on what's in your target platform. Then you'd
only need some stubs to keep the compiler happy.
So imagine that you have the same generated model in two different
workspaces, one with the GWT runtime in the target platform and the
other with the standard runtime in the target platform. It should be
possible that the same generated model code could compile properly in
both those workspace. All sharing of data between client and server
could be accomplished with binary. Note that there's
XMLResource.OPTION_BINARY which can be used to produce binary from an
XMLResource.
> projects?
From http://git.eclipse.org/c/emf/org.eclipse.emf.git
> Dirk
>>> emf.gwt packages.
>> in the GWT client.
>>> Thanks and Regards,
>>> Dirk
Re: [GWT] Server-side XMLResource [message #1001950 is a reply to message #1001845] |
Thu, 17 January 2013 10:45   |
Wow, a lot to chew.
So on the server side (compiled with standard EMF) the XMLResource would
do load(inputStream, options) and then save(outputStream, options) to a
ByteArrayOutputStream with OPTION_BINARY set to true. The byte array
from the ByteArrayOutputStream would then be returned to the client. On
the client side (compiled with EMF for GWT) the byte array would be fed
into a ByteArrayInputStream which would then be passed to the
load(inputStream, options) method of a newly created BinaryResourceImpl.
I'm curious if this will be debuggable in GWT's hosted mode.
Dirk
(Sorry for spamming your mail folder, Ed; never getting used to the
Followup button)
Am 17.01.2013 13:48, schrieb Ed Merks:
> Dirk,
> Comments below.
>> Hi Ed,
>>> Dirk,
>>> Comments below.
>>>> Hi,
>>>> modelled with EMF.
>>>> Resource resource =
>> same package.
>> Any other ideas?
> XMLResource.
>> projects?
>> Dirk
>>>> emf.gwt packages.
>>> in the GWT client.
>>>> Thanks and Regards,
>>>> Dirk
Re: [GWT] Server-side XMLResource [message #1002234 is a reply to message #1001950] |
Fri, 18 January 2013 03:16   |
<html>
<head>
<meta content="text/html; charset=ISO-8859-15"
http-equiv="Content-Type">
</head>
<body text="#000000" bgcolor="#FFFFFF">
Dirk,<br>
<br>
Comments below.<br>
<br>
<div class="moz-cite-prefix">On 17/01/2013 4:45 PM, Dirk Hoffmann
wrote:<br>
</div>
<blockquote cite="mid:kd96a0$c7o$1@xxxxxxxxe.org" type="cite">Wow,
a lot to chew.
<br>
<br>
would do load(inputStream, options) and then save(outputStream,
options) to a ByteArrayOutputStream with OPTION_BINARY set to
true. The byte array from the ByteArrayOutputStream would then be
returned to the client. On the client side (compiled with EMF for
GWT) the byte array would be fed into a ByteArrayInputStream which
would then be passed to the load(inputStream, options) method of a
<br>
</blockquote>
Yes, exactly.<br>
<br>
<br>
</blockquote>
Yes, you should be able to debug the client and server code.<br>
<br>
Dirk
<br>
<br>
the Followup button)
<br>
</blockquote>
Somehow I configured something (probably via the account
preferences) so I have a follow up button as the default like this:<br>
<blockquote><img src="http://www.eclipse.org/forums/index.php?t=getfile&id=13012" alt=""><br>
</blockquote>
<blockquote cite="mid:kd96a0$c7o$1@xxxxxxxxe.org" type="cite">Am
<br>
<blockquote type="cite">Dirk,
<br>
<br>
Comments below.
<br>
<br>
<br>
<blockquote type="cite">Hi Ed,
<br>
<br>
standard EMF
<br>
<br>
</blockquote>
<br>
<br>
dependencies to see
<br>
<br>
<br>
<br>
<br>
<br>
Comments below.
<br>
<br>
<br>
<blockquote type="cite">Hi,
<br>
<br>
<br>
<br>
structure
<br>
modelled with EMF.
<br>
<br>
turns it into
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
Resource resource =
<br>
<br>
<br>
Object>();
<br>
<br>
Boolean.TRUE);
<br>
Boolean.TRUE);
<br>
Boolean.TRUE);
<br>
Boolean.TRUE);
<br>
Boolean.TRUE);
<br>
<br>
</blockquote>
</blockquote>
<br>
<blockquote type="cite">resource.load(inputStream, options);
<br>
</blockquote>
</blockquote>
pointing
<br>
<br>
<br>
in the
<br>
same package.
<br>
</blockquote>
that into
<br>
<br>
<br>
had to
<br>
dependencies
<br>
make it
<br>
<br>
</blockquote>
lack of
<br>
<br>
<br>
Any other ideas?
<br>
</blockquote>
to use
<br>
the
<br>
names and
<br>
models
<br>
manifest to use
<br>
<br>
you'd
<br>
<br>
<br>
different
<br>
the
<br>
should be
<br>
properly in
<br>
server
<br>
<br>
from an
<br>
XMLResource.
<br>
<br>
EMF
<br>
projects?
<br>
</blockquote>
From <a class="moz-txt-link-freetext" href="http://git.eclipse.org/c/emf/org.eclipse.emf.git">http://git.eclipse.org/c/emf/org.eclipse.emf.git</a>
<br>
<br>
Dirk
<br>
<br>
<blockquote type="cite">----- >8 -------------------
<br>
<br>
class in the
<br>
emf.gwt packages.
<br>
</blockquote>
GWT runtime.
<br>
<br>
side there is
<br>
the project
<br>
idea to mix
<br>
<br>
</blockquote>
<br>
<br>
which
<br>
same project.
<br>
side and GWT
<br>
data model and
<br>
<br>
</blockquote>
standard
<br>
<br>
<br>
option?
<br>
</blockquote>
use the
<br>
separated
<br>
model you use
<br>
in the GWT client.
<br>
<br>
Thanks and Regards,
<br>
Dirk
<br>
<br>
</blockquote>
<br>
</blockquote>
<br>
</blockquote>
<br>
</blockquote>
<br>
</blockquote>
<br>
</body>
</html>
Attachment: gfaifdha.png
(Size: 7.03KB, Downloaded 251 times)
Re: [GWT] Server-side XMLResource [message #1003498 is a reply to message #1002234] |
Mon, 21 January 2013 06:20  |
Hi Ed,
this is how it went on:
I started creating a "DomResource" interface and its implementation
before I realized that DOM is already supported through XMLResource.
So I tried to convert ecore.xmi into its GWT counterpart. I managed to
remove all compile problems and finally got it running.
I had to modify the source code of EFactoryImpl in the gwt.ecore package
so it can run on the server as well as on the client. I have attached
the piece of code I modified. It is in the static initializer at the
bottom of the file.
I've chosen the DOM approach for the server just to see how it would go
if I moved the loading of the model from the XML contents to the server.
I could have done it with SAX as well I believe. If I really want to use
my new gwt.ecore.xmi package on the client I need to create a variation
of it because on the client the DOM classes are not located under
org.w3c.dom but under com.google.gwt.dom.client.
Should I find the time to try the BinaryResourceImpl approach I will let
you know.
Thanks so far,
Dirk
Am 18.01.2013 09:16, schrieb Ed Merks:
> Dirk,
> Comments below.
> On 17/01/2013 4:45 PM, Dirk Hoffmann wrote:
>> Wow, a lot to chew.
>> options) to a ByteArrayOutputStream with OPTION_BINARY set to true.
>> The byte array from the ByteArrayOutputStream would then be returned
>> to the client. On the client side (compiled with EMF for GWT) the byte
>> array would be fed into a ByteArrayInputStream which would then be
>> passed to the load(inputStream, options) method of a newly created
>> BinaryResourceImpl.
> Yes, exactly.
>> Dirk
>> Followup button)
> Somehow I configured something (probably via the account preferences) so
>>> Dirk,
>>> Comments below.
>>>> Hi Ed,
>>>>> Dirk,
>>>>> Comments below.
>>>>>> Hi,
>>>>>> modelled with EMF.
>>>>>> Resource resource =
>>>> same package.
>>>> Any other ideas?
>>> XMLResource.
>>>> projects?
>>>> Dirk
>>>>>> the
>>>>>> emf.gwt packages.
>>>>>> project.
>>>>>> GWT
>>>>>> and
>>>>> use
>>>>> in the GWT client.
>>>>>> Thanks and Regards,
>>>>>> Dirk
static {
try {
if (GWT.isClient()) {
// This only works on the client.
class ClientInternalEDateTimeFormat implements
InternalEDateTimeFormat {
DateTimeFormat dateTimeFormat;
ClientInternalEDateTimeFormat(DateTimeFormat dateTimeFormat) {
this.dateTimeFormat = dateTimeFormat;
public Date parse(String value) {
return dateTimeFormat.parse(value);
public String format(Date value) {
return dateTimeFormat.format(value);
EDATE_FORMATS = new InternalEDateTimeFormat[] {
new ClientInternalEDateTimeFormat(
DateTimeFormat
.getFormat("yyyy-MM-dd'T'HH:mm:ss'.'SSSZ")),
DateTimeFormat
.getFormat("yyyy-MM-dd'T'HH:mm:ss'.'SSS")),
DateTimeFormat
.getFormat("yyyy-MM-dd'T'HH:mm:ss")),
DateTimeFormat.getFormat("yyyy-MM-dd'T'HH:mm")),
DateTimeFormat.getFormat("yyyy-MM-dd")) };
} else {
class ServerInternalEDateTimeFormat implements
DateFormat dateFormat;
ServerInternalEDateTimeFormat(DateFormat dateFormat) {
this.dateFormat = dateFormat;
try {
return dateFormat.parse(value);
} catch (ParseException e) {
throw new RuntimeException(e);
return dateFormat.format(value);
new ServerInternalEDateTimeFormat(new SimpleDateFormat(
"yyyy-MM-dd")) };
} catch (Throwable exception) {
// Ignore.
Current Time: Fri Jul 25 11:06:18 EDT 2025
Powered by FUDForum. Page generated in 0.08467 seconds
