Home » Archived » Hudson » [Solved] Configure job loading screen hangs. Groovy plugin exception.
[Solved] Configure job loading screen hangs. Groovy plugin exception. [message #1000805] Tue, 15 January 2013 08:02 Go to next message
Hi!
After upgrading to 3.0.0 from 2.2.1 and installing all recommended plugins plus the "groovy support plugin", I can't configure jobs anymore.
The loading screen hangs and I get an exception that I think is related to the groovy plugin. Jobs executing groovyscripts seem to run just fine it's just when configuring (or for that matter creating new jobs) that I get this exception.
Any ideas? Any more info needed?
Relnah
2013-01-15 13:46:31.606:WARN:oejs.ServletHandler:/job/Z_test/configure
org.apache.commons.jelly.JellyTagException: jar:file:/C:/hudson/war/webapp/WEB-INF/lib/hudson-core-3.0.0.jar!/lib/form/block.jelly:25:22: <d:invokeBody> hudson.model.Hudson.getAuthentication()Lorg/acegisecurity/Authentication;
	at org.apache.commons.jelly.impl.TagScript.handleException(TagScript.java:728)
	at org.apache.commons.jelly.impl.TagScript.run(TagScript.java:290)
	at org.kohsuke.stapler.jelly.ReallyStaticTagLibrary$1.run(ReallyStaticTagLibrary.java:91)
	at org.apache.commons.jelly.impl.ScriptBlock.run(ScriptBlock.java:95)
	at org.apache.commons.jelly.tags.core.CoreTagLibrary$2.run(CoreTagLibrary.java:105)
	at org.kohsuke.stapler.jelly.CallTagLibScript.run(CallTagLibScript.java:111)
	at org.kohsuke.stapler.jelly.JellyViewScript.run(JellyViewScript.java:55)
	at org.kohsuke.stapler.jelly.IncludeTag.doTag(IncludeTag.java:138)
	at org.apache.commons.jelly.impl.TagScript.run(TagScript.java:270)
	at org.kohsuke.stapler.jelly.CallTagLibScript$1.run(CallTagLibScript.java:90)
	at org.apache.commons.jelly.tags.define.InvokeBodyTag.doTag(InvokeBodyTag.java:91)
	at org.apache.commons.jelly.TagSupport.invokeBody(TagSupport.java:186)
	at org.apache.commons.jelly.tags.core.ForEachTag.doTag(ForEachTag.java:150)
	at org.apache.commons.jelly.tags.core.WhenTag.doTag(WhenTag.java:46)
	at org.apache.commons.jelly.tags.core.ChooseTag.doTag(ChooseTag.java:38)
	at org.apache.commons.jelly.tags.core.CoreTagLibrary$1.run(CoreTagLibrary.java:98)
	at org.kohsuke.stapler.jelly.DefaultScriptInvoker.invokeScript(DefaultScriptInvoker.java:55)
	at org.kohsuke.stapler.jelly.DefaultScriptInvoker.invokeScript(DefaultScriptInvoker.java:45)
	at org.kohsuke.stapler.jelly.JellyFacet$1.dispatch(JellyFacet.java:82)
	at org.kohsuke.stapler.Stapler.tryInvoke(Stapler.java:565)
	at org.kohsuke.stapler.Stapler.invoke(Stapler.java:650)
	at org.kohsuke.stapler.MetaClass$6.doDispatch(MetaClass.java:225)
	at org.kohsuke.stapler.NameBasedDispatcher.dispatch(NameBasedDispatcher.java:45)
	at org.kohsuke.stapler.Stapler.invoke(Stapler.java:481)
	at org.kohsuke.stapler.Stapler.service(Stapler.java:152)
	at javax.servlet.http.HttpServlet.service(HttpServlet.java:848)
	at org.eclipse.jetty.servlet.ServletHolder.handle(ServletHolder.java:648)
	at org.eclipse.jetty.servlet.ServletHandler$CachedChain.doFilter(ServletHandler.java:1336)
	at hudson.util.PluginServletFilter$1.doFilter(PluginServletFilter.java:86)
	at org.hudsonci.servlets.internal.ServletRegistrationFilterAdapter.doFilter(ServletRegistrationFilterAdapter.java:162)
	at org.hudsonci.servlets.internal.ServletRegistrationFilterAdapter.doFilter(ServletRegistrationFilterAdapter.java:134)
	at hudson.util.PluginServletFilter$1.doFilter(PluginServletFilter.java:89)
	at hudson.plugins.greenballs.GreenBallFilter.doFilter(GreenBallFilter.java:52)
	at hudson.util.PluginServletFilter.doFilter(PluginServletFilter.java:78)
	at org.eclipse.jetty.servlet.ServletHandler$CachedChain.doFilter(ServletHandler.java:1307)
	at hudson.security.ChainedServletFilter$1.doFilter(ChainedServletFilter.java:81)
	at hudson.security.ChainedServletFilter.doFilter(ChainedServletFilter.java:73)
	at hudson.security.HudsonFilter.doFilter(HudsonFilter.java:157)
	at hudson.util.CharacterEncodingFilter.doFilter(CharacterEncodingFilter.java:70)
	at org.eclipse.jetty.servlet.ServletHandler.doHandle(ServletHandler.java:453)
	at org.eclipse.jetty.server.handler.ScopedHandler.handle(ScopedHandler.java:137)
	at org.eclipse.jetty.security.SecurityHandler.handle(SecurityHandler.java:534)
	at org.eclipse.jetty.server.session.SessionHandler.doHandle(SessionHandler.java:231)
	at org.eclipse.jetty.server.handler.ContextHandler.doHandle(ContextHandler.java:1072)
	at org.eclipse.jetty.servlet.ServletHandler.doScope(ServletHandler.java:382)
	at org.eclipse.jetty.server.session.SessionHandler.doScope(SessionHandler.java:193)
	at org.eclipse.jetty.server.handler.ContextHandler.doScope(ContextHandler.java:1006)
	at org.eclipse.jetty.server.handler.ScopedHandler.handle(ScopedHandler.java:135)
	at org.eclipse.jetty.server.handler.HandlerWrapper.handle(HandlerWrapper.java:116)
	at org.eclipse.jetty.server.Server.handle(Server.java:365)
	at org.eclipse.jetty.server.AbstractHttpConnection.handleRequest(AbstractHttpConnection.java:485)
	at org.eclipse.jetty.server.AbstractHttpConnection.headerComplete(AbstractHttpConnection.java:926)
	at org.eclipse.jetty.server.AbstractHttpConnection$RequestHandler.headerComplete(AbstractHttpConnection.java:988)
	at org.eclipse.jetty.http.HttpParser.parseNext(HttpParser.java:635)
	at org.eclipse.jetty.http.HttpParser.parseAvailable(HttpParser.java:235)
	at org.eclipse.jetty.server.AsyncHttpConnection.handle(AsyncHttpConnection.java:82)
	at org.eclipse.jetty.io.nio.SelectChannelEndPoint.handle(SelectChannelEndPoint.java:627)
	at org.eclipse.jetty.io.nio.SelectChannelEndPoint$1.run(SelectChannelEndPoint.java:51)
	at org.eclipse.jetty.util.thread.QueuedThreadPool.runJob(QueuedThreadPool.java:608)
	at org.eclipse.jetty.util.thread.QueuedThreadPool$3.run(QueuedThreadPool.java:543)
Caused by:
java.lang.NoSuchMethodError: hudson.model.Hudson.getAuthentication()Lorg/acegisecurity/Authentication;
	at hudson.plugins.groovy.SystemGroovy$DescriptorImpl.isApplicable(SystemGroovy.java:95)
	at hudson.tasks.BuildStepDescriptor.filter(BuildStepDescriptor.java:79)
	at hudson.Functions.getBuilderDescriptors(Functions.java:691)
	at org.apache.commons.jexl.util.introspection.UberspectImpl$VelMethodImpl.invoke(UberspectImpl.java:258)
	at org.apache.commons.jexl.parser.ASTMethod.execute(ASTMethod.java:104)
	at org.apache.commons.jexl.parser.ASTReference.execute(ASTReference.java:83)
	at org.apache.commons.jexl.parser.ASTReference.value(ASTReference.java:57)
	at org.apache.commons.jexl.parser.ASTReferenceExpression.value(ASTReferenceExpression.java:51)
	at org.apache.commons.jexl.ExpressionImpl.evaluate(ExpressionImpl.java:80)
	at org.eclipse.hudson.ExpressionFactory2$JexlExpression.evaluate(ExpressionFactory2.java:89)
	at org.kohsuke.stapler.jelly.CallTagLibScript.run(CallTagLibScript.java:50)
[Updated on: Thu, 17 January 2013 02:18] by Moderator
Re: Configure job loading screen hangs. Groovy plugin exception. [message #1000884 is a reply to message #1000805] Tue, 15 January 2013 10:58 Go to previous messageGo to next message
Would you mind me asking if you could do a fresh install of hudson, install all the necessary plugins, and then port all the jobs/configuration over? Something might have gone wrong in the upgrade. We had actually removed all references to org/acegisecurity/Authentication which leads me to believe that some old references are there after the upgrade.
Steve.
Re: Configure job loading screen hangs. Groovy plugin exception. [message #1000952 is a reply to message #1000884] Tue, 15 January 2013 14:09 Go to previous messageGo to next message
I will try that first thing tomorrow at work.
I'll post back with the result.
Thanks for the swift reply Smile
/Relnah
Re: Configure job loading screen hangs. Groovy plugin exception. [message #1001171 is a reply to message #1000952] Wed, 16 January 2013 02:37 Go to previous messageGo to next message
No luck with new install :/
I started the hudson 3.0.0 war with java -jar and then through hudson installed as a service after installing the three important plugins at first load.
After installed as a service I got a ChartException. (Will post all exceptions below and all plugins with version)
I continued to install all plugins I had before, a couple more were installed automatically.
After restarting hudson I tried to create a new project but the config loading hangs like before with what seems to be the same exception as before.
Is there anything I should try with this new install to correct the problem. Or can I go back to my old one?
/Relnah
ChartException:
Jan 16, 2013 8:21:46 AM org.hudsonci.inject.internal.extension.SmoothieExtensionLocator locate
WARNING: Failed to create extension
com.google.inject.ProvisionException: Guice provision errors:
1) Error injecting constructor, java.lang.NoClassDefFoundError: org/eclipse/birt/chart/exception/ChartException
  at org.hudsonci.plugins.birtcharts.BirtChartSupport$DescriptorImpl.<init>(Unknown Source)
  at org.hudsonci.inject.internal.extension.SezPozExtensionModule.bindItem(SezPozExtensionModule.java:110)
  while locating org.hudsonci.plugins.birtcharts.BirtChartSupport$DescriptorImpl
  while locating hudson.model.Descriptor annotated with @com.google.inject.name.Named(value=org.hudsonci.plugins.birtcharts.BirtChartSupport$DescriptorImpl)
1 error
	at com.google.inject.internal.InjectorImpl$4.get(InjectorImpl.java:987)
	at org.sonatype.guice.bean.locators.LazyBeanEntry.getValue(LazyBeanEntry.java:79)
	at org.hudsonci.inject.internal.extension.SmoothieComponent.<init>(SmoothieComponent.java:45)
	at org.hudsonci.inject.internal.extension.SmoothieExtensionLocator.locate(SmoothieExtensionLocator.java:72)
	at org.hudsonci.inject.internal.plugin.SmoothiePluginStrategy.findComponents(SmoothiePluginStrategy.java:235)
	at org.hudsonci.inject.internal.plugin.DelegatingPluginStrategy.findComponents(DelegatingPluginStrategy.java:74)
	at hudson.ExtensionList.load(ExtensionList.java:246)
	at hudson.ExtensionList.ensureLoaded(ExtensionList.java:214)
	at hudson.ExtensionList.getComponents(ExtensionList.java:122)
	at hudson.DescriptorExtensionList.load(DescriptorExtensionList.java:149)
	at hudson.ExtensionList.size(ExtensionList.java:130)
	at java.util.AbstractCollection.isEmpty(Unknown Source)
	at hudson.model.labels.LabelAtom.updateTransientActions(LabelAtom.java:95)
	at hudson.model.labels.LabelAtom.load(LabelAtom.java:171)
	at hudson.model.Hudson.getLabelAtom(Hudson.java:1463)
	at hudson.model.Hudson.getSelfLabel(Hudson.java:2221)
	at hudson.model.Node.getAssignedLabels(Node.java:223)
	at hudson.model.Hudson$13.run(Hudson.java:2285)
	at org.jvnet.hudson.reactor.TaskGraphBuilder$TaskImpl.run(TaskGraphBuilder.java:146)
	at org.jvnet.hudson.reactor.Reactor.runTask(Reactor.java:259)
	at hudson.model.Hudson$4.runTask(Hudson.java:647)
	at org.jvnet.hudson.reactor.Reactor$2.run(Reactor.java:187)
	at org.jvnet.hudson.reactor.Reactor$Node.run(Reactor.java:94)
	at java.util.concurrent.ThreadPoolExecutor$Worker.runTask(Unknown Source)
	at java.util.concurrent.ThreadPoolExecutor$Worker.run(Unknown Source)
Caused by: java.lang.NoClassDefFoundError: org/eclipse/birt/chart/exception/ChartException
	at java.lang.Class.getDeclaredMethods0(Native Method)
	at java.lang.Class.privateGetDeclaredMethods(Unknown Source)
	at java.lang.Class.getMethod0(Unknown Source)
	at java.lang.Class.getMethod(Unknown Source)
	at hudson.model.Descriptor.<init>(Descriptor.java:240)
	at org.eclipse.hudson.graph.GraphSupportDescriptor.<init>(GraphSupportDescriptor.java:27)
	at org.hudsonci.plugins.birtcharts.BirtChartSupport$DescriptorImpl.<init>(BirtChartSupport.java:154)
	at sun.reflect.NativeConstructorAccessorImpl.newInstance0(Native Method)
	at sun.reflect.NativeConstructorAccessorImpl.newInstance(Unknown Source)
	at sun.reflect.DelegatingConstructorAccessorImpl.newInstance(Unknown Source)
	at java.lang.reflect.Constructor.newInstance(Unknown Source)
	at com.google.inject.internal.DefaultConstructionProxyFactory$1.newInstance(DefaultConstructionProxyFactory.java:85)
	at com.google.inject.internal.ConstructorInjector.construct(ConstructorInjector.java:85)
	at com.google.inject.internal.ConstructorBindingImpl$Factory.get(ConstructorBindingImpl.java:254)
	at com.google.inject.internal.ProviderToInternalFactoryAdapter$1.call(ProviderToInternalFactoryAdapter.java:46)
	at com.google.inject.internal.InjectorImpl.callInContext(InjectorImpl.java:1031)
	at com.google.inject.internal.ProviderToInternalFactoryAdapter.get(ProviderToInternalFactoryAdapter.java:40)
	at com.google.inject.Scopes$1$1.get(Scopes.java:59)
	at com.google.inject.internal.InternalFactoryToProviderAdapter.get(InternalFactoryToProviderAdapter.java:40)
	at com.google.inject.internal.FactoryProxy.get(FactoryProxy.java:54)
	at com.google.inject.internal.InjectorImpl$4$1.call(InjectorImpl.java:978)
	at com.google.inject.internal.InjectorImpl.callInContext(InjectorImpl.java:1024)
	at com.google.inject.internal.InjectorImpl$4.get(InjectorImpl.java:974)
	... 26 more
Caused by: java.lang.ClassNotFoundException: org.eclipse.birt.chart.exception.ChartException
	at org.aspectj.weaver.bcel.ExtensibleURLClassLoader.findClass(ExtensibleURLClassLoader.java:54)
	... 49 more
Installed plugins
Groovy plugin
	1.9
Hudson Translation Assistance plugin
	1.10-h-1
Dashboard View
	2.3-h-2
The Continuous Integration Game plugin
	1.17
Hudson REST Plugin
	2.1.2
Hudson Deploy Plugin
	1.8
XPath Provider Plugin
	1.0.1
Maven 2 job type plugin
	2.2.1
Groovy Support Plugin
	3.0.3
JNA Native Support Plugin
	3.0.2
Email-ext plugin
	2.10
Hudson JIRA plugin
	1.36-h-1
Hudson Subversion Plug-in
	2.3.6-h-1
Hudson BIRT Charts Plugin
	3.0.3
Checkstyle Plug-in
	3.28-h-1
Static Analysis Collector Plug-in
	1.28-h-1
Green Balls
	1.10
JFreeChart Plugin
	1.4
Warnings Plug-in
	4.6-h-1
Release Plugin
	2.3-h-1
Static Analysis Utilities
	1.42-h-1
Exception on job config load
2013-01-16 08:23:06.807:WARN:oejs.ServletHandler:/job/Z_test/configure
Caused by:
Re: Configure job loading screen hangs. Groovy plugin exception. [message #1001476 is a reply to message #1001171] Wed, 16 January 2013 14:47 Go to previous messageGo to next message
I believe I fixed this issue. The tests I have conducted locally looks like it fix the issue, would you mind testing to verify they are fixed? I have a .hpi file for you if you could email me at schristou88@gmail.com.
Steve.
Re: Configure job loading screen hangs. Groovy plugin exception. [message #1001634 is a reply to message #1001476] Thu, 17 January 2013 00:06 Go to previous messageGo to next message
Ah, Steven, with out looking at this forum topic, I went ahead and released groovy plugin 1.13-h-1 after fixing the exception. I kept the sources at Github hudon3-plugins. If my changes are different than yours, please go ahead and release 1.1.3-h2
Re: Configure job loading screen hangs. Groovy plugin exception. [message #1001672 is a reply to message #1001634] Thu, 17 January 2013 02:18 Go to previous messageGo to next message
I applied Stevens fix to my original install that I upgraded to 3.0.0 and it fixed my issue. You two can duke it out what code to release Wink
Thanks again Steven for such quick help!
/Relnah
Re: Configure job loading screen hangs. Groovy plugin exception. [message #1001962 is a reply to message #1001672] Thu, 17 January 2013 11:06 Go to previous message
Winston released the latest version of the groovy-plugin with the exact code changes I made. Rel Nah, you can upgrade to the official version of the groovy-plugin 1.13-h-1.
Previous Topic:tagging
Next Topic:package org.hudsonci.maven.plugin.builder does not exist
Current Time: Sat Jul 26 11:54:50 EDT 2025
Powered by FUDForum. Page generated in 0.08694 seconds
