Home » Archived » BIRT » Html reports without charts(Html reports without charts)
Html reports without charts [message #998335] Wed, 09 January 2013 15:31 Go to next message
am i using birt with rcp and i can't generate a html report with charts embeded. Tables work fine but charts (images) are not renderized
My code:
EngineConfig config = new EngineConfig();
config.setEngineHome("C:/Users/Junger/Desktop/birt-runtime-4_2_1/ReportEngine");
IReportEngineFactory factory = (IReportEngineFactory) Platform.createFactoryObject( IReportEngineFactory.EXTENSION_REPORT_ENGINE_FACTORY );
IReportEngine engine = factory.createReportEngine( config );
engine.changeLogLevel( Level.WARNING );
IReportRunnable design = null;
try {
design = engine.openReportDesign(rpt);
} catch (EngineException e) {
e.printStackTrace();
IRunAndRenderTask task = engine.createRunAndRenderTask(design);
//Set parameter values and validate
task.setParameterValue("pAcc", account);
task.validateParameters();
//Setup rendering to HTML
HTMLRenderOption options = new HTMLRenderOption();
options.setOutputFileName("output.html");
options.setOutputFormat("html");
options.setImageDirectory("output");
options.setEmbeddable(false);
options.setImageHandler(new HTMLServerImageHandler());
options.setSupportedImageFormats("PNG;GIF;JPG;BMP;SWF;SVG");
task.setRenderOption(options);
//run and render report
try {
task.run();
browser.setUrl("...strategy.html");
It seems like a missing library, on eclipse's Report Designer works fine. What i'm doing wrong?
Re: Html reports without charts [message #998657 is a reply to message #998335] Thu, 10 January 2013 07:54 Go to previous messageGo to next message
Someone?
Re: Html reports without charts [message #998949 is a reply to message #998657] Thu, 10 January 2013 21:54 Go to previous messageGo to next message
There are no errors? What do the logs say?
Re: Html reports without charts [message #999143 is a reply to message #998949] Fri, 11 January 2013 07:46 Go to previous messageGo to next message
I solved. The problem was the bundle org.eclipse.birt.chart.reportitem wasn't included.
Thanks anyway.
Re: Html reports without charts [message #1000900 is a reply to message #999143] Tue, 15 January 2013 11:44 Go to previous message
Ah. Thanks for updating the thread. Glad you found out what was wrong!
Previous Topic:Best Practice of How to Manage reports from different Environments? Dev, QA and Prod?
Next Topic:Problem with scripted Dataset
Current Time: Sat Jul 26 09:01:19 EDT 2025
Powered by FUDForum. Page generated in 0.06071 seconds
