Greater than (>) does not work at filter using regular expression? [message #1000896] |
Tue, 15 January 2013 11:38  |
I have an integer in a column and I want to filter it with the options greater than less than etc. I found out that I could do that with the:
configRegistry.registerConfigAttribute(
FilterRowConfigAttributes.TEXT_MATCHING_MODE,
TextMatchingMode.REGULAR_EXPRESSION,
DisplayMode.NORMAL,
FilterRowDataLayer.FILTER_ROW_COLUMN_LABEL_PREFIX + 6);
If I do that, the less than (<), less than or equals (<=), greater than or equals (>=) works, but the greater than (>) does not work.
After some investigation I found out that in the examples this also does not work!!!
I am using NatTable version 0.9.0.
And Glazedlists 1.8.0 (java15).
I followed the code and it looks like the correct matcher is build: ThresholdMatcherEditor with the correct match operation: ThresholdMatcherEditor.GREATER_THAN
So maybe it is a problem at glazedlist.
I could not find a bug report on it.
Does anybody know what the problem is?
And how I can fix it?
[Updated on: Tue, 15 January 2013 11:46] by Moderator
FUDForum. Page generated in 0.05089 seconds
