Home » Modeling » TMF (Xtext) » xtext check annotation issue(xtext check annotation issue)
xtext check annotation issue [message #1000278] Mon, 14 January 2013 07:30 Go to next message
I'm using the @Check annotation in order to validate my dsl. my dsl is for json.
at first the method was invoked for a specific object and once per change
but it suddenly doesn't work in the same way anymore (and i'm not sure what i've done that effected it)
the method signature is:
@Check
public void validateJson(ObjectValue object) {...}
now its entering this method for each node in the gui although i'm editing only one node
Re: xtext check annotation issue [message #1000665 is a reply to message #1000278] Tue, 15 January 2013 02:58 Go to previous messageGo to next message
what Xtext (partially) Parses/Constructs while Editing depends on the Grammar. Did you change the Grammar?
~Christian
Re: xtext check annotation issue [message #1000676 is a reply to message #1000665] Tue, 15 January 2013 03:28 Go to previous messageGo to next message
no :\
Re: xtext check annotation issue [message #1000759 is a reply to message #1000676] Tue, 15 January 2013 06:43 Go to previous messageGo to next message
Btw why is this a problem?
Re: xtext check annotation issue [message #1000761 is a reply to message #1000759] Tue, 15 January 2013 06:48 Go to previous messageGo to next message
cause when i'm changing one object it runs the validation on all of them, but they other were already validated.
it's a waste of time for something that already calculated and some of my files that need to be check are very big and each change takes too much time
Re: xtext check annotation issue [message #1000763 is a reply to message #1000761] Tue, 15 January 2013 06:52 Go to previous messageGo to next message
You may try a @Check(CheckType.NORMAL)
Re: xtext check annotation issue [message #1000777 is a reply to message #1000763] Tue, 15 January 2013 07:23 Go to previous messageGo to next message
thank you, but it still validating each object in any change.
Re: xtext check annotation issue [message #1000784 is a reply to message #1000777] Tue, 15 January 2013 07:38 Go to previous messageGo to next message
but it will only validate when saving
Re: xtext check annotation issue [message #1000837 is a reply to message #1000784] Tue, 15 January 2013 09:02 Go to previous messageGo to next message
i noticed, but it still validate each object in the file
Re: xtext check annotation issue [message #1000867 is a reply to message #1000837] Tue, 15 January 2013 10:10 Go to previous messageGo to next message
do you know what can cause this kind of change?
cause it used to work fine, validate only the object which was changed in the gui.
Re: xtext check annotation issue [message #1000869 is a reply to message #1000867] Tue, 15 January 2013 10:13 Go to previous messageGo to next message
no,
i guess you have to look what you have changed - e.g. by starting a new grammar and copy&paste add your changes
Re: xtext check annotation issue [message #1000871 is a reply to message #1000869] Tue, 15 January 2013 10:19 Go to previous message
ok thank you and thank you for the patience! Smile
Previous Topic:What is best way to get reference of JvmAnnotationType in inference?
Next Topic:IJvmModelInferrer invoked for invalid model
Current Time: Fri Jul 25 06:47:27 EDT 2025
Powered by FUDForum. Page generated in 0.07936 seconds
