Home » Eclipse Projects » Equinox » How to load class with its bundle's classloader ?
How to load class with its bundle's classloader ? [message #100073] Fri, 19 October 2007 06:38 Go to next message
Originally posted by: sf.tragwerk-dresden.de
please imagine the following situation:
Plugin A
Plugin C |
Plugin B
1. Plugin B depends on A and C where A knows nothing about C.
2. Plugin B contributes a Classname via an extension point to A.
3. This class is located inside Plugin C.
How can I load this class from Plugin A with its own BundleClassLoader (
C ) ?
I only know that Bundle B must know about the class.
Sebastian
Re: How to load class with its bundle's classloader ? [message #100088 is a reply to message #100073] Fri, 19 October 2007 07:15 Go to previous messageGo to next message
It should be enough to just import the package where the class resides
from Plugin C.
Sebastian Fuchs wrote:
> Plugin A
> Plugin C |
> Plugin B
> C ) ?
> Sebastian
Re: How to load class with its bundle's classloader ? [message #100102 is a reply to message #100088] Fri, 19 October 2007 09:59 Go to previous messageGo to next message
Hi Danial,
you are right.
Calling
bundleB.loadClass(hidden.in.bundle_c.ClassName);
from A works.
Don't know what went wrong the last time.
Thank you.
Sebastian
Danail Nachev schrieb:
> from Plugin C.
>> Hi,
>> Plugin A
>> Plugin C |
>> Plugin B
>> C ) ?
>> Sebastian
Re: How to load class with its bundle's classloader ? [message #100147 is a reply to message #100073] Mon, 22 October 2007 02:48 Go to previous messageGo to next message
Did you try #createExecutableExtension?
http://help.eclipse.org/help33/topic/org.eclipse.platform.do c.isv/reference/api/org/eclipse/core/runtime/IConfigurationE lement.html#createExecutableExtension(java.lang.String)
-Gunnar
Gunnar Wagenknecht
gunnar@wagenknecht.org
http://wagenknecht.org/
Re: How to load class with its bundle's classloader ? [message #100162 is a reply to message #100147] Mon, 22 October 2007 03:52 Go to previous message
Thank you Gunnar,
I know about creatExecutableExtension, but this is not exactly what I
need. I need more control over time and circumstances when a class is
loaded.
Sebastian
> -Gunnar
Previous Topic:AdapterHooks: BundleFileWrapperFactoryHook is ignored
Next Topic:Commons logging / log4j : ClassNotFound in JSP when using embedded Jetty/Jasper
Current Time: Tue Nov 04 16:14:14 EST 2025
Powered by FUDForum. Page generated in 0.21653 seconds
