Home » Modeling » EMF » [CDO] Raw writes in DB (MySQL)
[CDO] Raw writes in DB (MySQL) [message #989763] Fri, 07 December 2012 11:08 Go to next message
I first want to apologize to re-open this discussion that I posted one year ago:
I wanted to load large amount of data when initializing the database (150.000 rows), but now we added about 400.000 rows at the initialization process.
I thought about some workarounds, but don't know which one make sense, and which one is safe:
- Make an SQL dump of the concerned tables: should be quick, but annoying to maintain imho (since data are updated monthly...), and doesn't handle nicely the meta model changes (maybe more a feeling than reality).
- Insert directly data in the SQL base, but seems quite risky. Even if we start understanding the CDO data model, we still can miss some subtilities, and we have to ensure that CDO don't use any cache, etc....
- The initialization code runs into the same VM as the CDO Server: isn't it some ways to use directly CDO raw layer classes to initialize the base properly without using the Net4j/Network communication overhead ? For the moment I create a CDO Client into the CDO Server process to initialize the database, but I don't think it is optimal...
- Other ideas... ?
The thing is that my C++ co workers laugh at us because our initialization process takes about 10 minutes, and their takes about 10 sec....
I really hope I could reach some descent performance. I would appreciate some shared experiences.
Thank a lot in advance,
Christophe.
Nota: thank you for the automatic migration of the meta model when adding features and tables like Teneo/Hibernate does, this is just great Wink
Re: [CDO] Raw writes in DB (MySQL) [message #989905 is a reply to message #989763] Sun, 09 December 2012 14:10 Go to previous messageGo to next message
Sorry to mention "competitor" solution, but should I try something like http://code.google.com/p/emf-fragments/ instead ?
Re: [CDO] Raw writes in DB (MySQL) [message #989949 is a reply to message #989763] Mon, 10 December 2012 03:44 Go to previous messageGo to next message
Hi Christophe, (Nice name BTW Smile
I have to deal with the same challenge.
On the MM migration, this is unfortunately not possible, there is a bug on the topic, it requires
funding. I think, Eike mentioned the way to migrate now, is to setup a parallel repo, with the new EPackages, and then one-by-one copy the tables over. (With potential customized ECore Util Copier).
On skipping network layer, you can use a JVMConnector. It works like this:
// Prepare container
		final IManagedContainer container = IPluginContainer.INSTANCE;
		acceptor = JVMUtil.getAcceptor(container, "default");
		connector = JVMUtil.getConnector(container, "default");
		// Create configuration
		final CDOSessionConfiguration sessionConfiguration = CDONet4jUtil
				.createSessionConfiguration();
		sessionConfiguration.setConnector(connector);
		sessionConfiguration.setRepositoryName(REPO_NAME);
Note, this was created for 4.0, and the API changed, but this works with 4.2.
Now on the C++ guys, ok they should have some speed advantage on running the code, but the I/O towards the DB, should be roughly equivalent, so you sure you comparing Pineapples here?
Cheers Christophe
Re: [CDO] Raw writes in DB (MySQL) [message #989960 is a reply to message #989763] Mon, 10 December 2012 04:28 Go to previous messageGo to next message
Am 07.12.2012 17:08, schrieb Christophe MOINE:
> Hello,
> - Other ideas... ?
Perhaps you want to try it with the new LissomeStore which I have developed especially to speed up large commits.
Cheers
/Eike
http://www.esc-net.de
> Regards,
> Christophe.
> does, this is just great ;)
Re: [CDO] Raw writes in DB (MySQL) [message #989961 is a reply to message #989905] Mon, 10 December 2012 04:30 Go to previous messageGo to next message
Am 09.12.2012 20:10, schrieb Christophe MOINE:
I don't know that one. That they call CDO an ORM shows that they did not research correctly (universities are more
interested in making new solutions/attempts than enhancing existing ones).
Cheers
/Eike
Re: [CDO] Raw writes in DB (MySQL) [message #989968 is a reply to message #989949] Mon, 10 December 2012 05:06 Go to previous messageGo to next message
Christophe Bouhier wrote on Mon, 10 December 2012 03:44
I have to deal with the same challenge. ...
Very Happy Thank you very much for the compliment and the hint Christophe Smile
I tried the JVMUtil: very interesting, but it doesn't speed out enough unfortunnatly.
Sound really good Eike: I hope it is not too recent since I need to be compatible with Eclipse 3.7. I'll give it a try right now and let you know.
About EMF Fragment I figured out it is a too recent project, so too risky to adopt for the moment Smile
/Christophe.
Re: [CDO] Raw writes in DB (MySQL) [message #990019 is a reply to message #989968] Mon, 10 December 2012 09:07 Go to previous messageGo to next message
I'm trying LissomeStore, looked at tests.lissome, source code, cdo-light and its cdoperformancetest, and I am a bit confused:
If I understand well the LissomeStore comes in place of the relational "db" store type, but both type are called "db": does rely only on what it is found on the osgi "classpath" ? Or does it behave as a QueryHandler such as executeQuery("lissome", ...) ?
Finally I cannot figure out yet why Lissome deals with a File... ?
Anyway the concept sounds really nice, but I am a bit lost so far Smile
/Christophe.
Re: [CDO] Raw writes in DB (MySQL) [message #990141 is a reply to message #990019] Tue, 11 December 2012 01:37 Go to previous messageGo to next message
Am 10.12.2012 15:07, schrieb Christophe MOINE:
> confused:
Oops, I see there's an inconsistency between code and markup:
public class LissomeStore extends Store implements ILissomeStore, CDOAllRevisionsProvider, IDBConnectionProvider,
NoRawAccess, NoLargeObjects, NoQueryXRefs, NoChangeSets, NoDurableLocking
public static final String TYPE = "lissome"; //$NON-NLS-1$
<extension
point="org.eclipse.emf.cdo.server.storeFactories">
<storeFactory
class="org.eclipse.emf.cdo.server.internal.lissome.LissomeStoreFactory"
storeType="db">
</storeFactory>
</extension>
I've just fixed the latter to "lissome".
You may also want to look at LissomeConfig, which sets up Lissome stores for our tests, see
org.eclipse.emf.cdo.tests.lissome.AllTestsLissome.
No.
No. There's no lissome-specific query handler at all.
The LissomeStore stores data in two random access files, a journal file where the commit change sets are simply appended
and an optimizer file (also random access). The optimizer runs asynchronously (the commit thread doesn't have to wait)
on an in-memory queue of the commit change sets creates new revisions and updates search indexes in the RDB.
Cheers
/Eike
> Anyway the concept sounds really nice, but I am a bit lost so far :)
Re: [CDO] Raw writes in DB (MySQL) [message #990806 is a reply to message #990141] Fri, 14 December 2012 05:38 Go to previous messageGo to next message
I continue testing Lissome Store every now and again Smile
I used also this snippet:
http://code.google.com/a/eclipselabs.org/p/cdo-light/source/browse/trunk/LibraryCreator/src/CDOPerformanceTests.java?spec=svn79&r=79
It seems that the LissomeStore comes from "cdo light" project is that correct ?
I have another question to help my understanding:
does the LissomeStore lives with the DBStore ? if so, is the next CDOID computed correctly between each other store ? I can't see how...
Thanks a lot,
/Christophe.
Re: [CDO] Raw writes in DB (MySQL) [message #990828 is a reply to message #990806] Fri, 14 December 2012 06:18 Go to previous messageGo to next message
Am 14.12.2012 11:38, schrieb Christophe MOINE:
> I continue testing Lissome Store every now and again :)
Interesting ;-)
No, the LissomeStore has been developed by myself. I'm in contact with Andy Rytina, though. I asked him to use his
performance suite on my LissomeStore.
I don't understand this question. Can you elaborate?
Need to understand the first question first :P
Cheers
/Eike
Re: [CDO] Raw writes in DB (MySQL) [message #990855 is a reply to message #990828] Fri, 14 December 2012 09:08 Go to previous messageGo to next message
Sorry Eike. I mean: does the lissome stores can be setup with the DBStore in the same CDO Server instance for instance ? In other words, do I have to configure the store "db" AND "lissome" in the cdo-server.xml ? Or if I configure the lissome store, I have to remove the db store configuration ?
Otherwise I guess I can configure it on another repo name...
So far, I added lissome store in my cdo-server.xml:
<cdoServer>
	<acceptor type="tcp" listenAddr="0.0.0.0" port="2036"/>
	<repository name="repo1">
		<property name="overrideUUID" value=""/>
		<property name="supportingAudits" value="false"/>
		<store type="db">
			<mappingStrategy type="horizontal">
				<property name="qualifiedNames" value="false"/>
				<property name="toManyReferences" value="ONE_TABLE_PER_REFERENCE"/>
				<property name="toOneReferences" value="LIKE_ATTRIBUTES"/>
			</mappingStrategy>
			<dbAdapter name="mysql"/>
			<dataSource class="com.mysql.jdbc.jdbc2.optional.MysqlDataSource"
				url="jdbc:mysql://${db.host}:${db.port}/${db.schema}"
				user="${db.user}" password="${db.password}"/>
		</store>
		<store type="lissome">
		</store>
	</repository>
</cdoServer>
I then configure lissome store on the main container:
final IManagedContainer container=ContainerUtil.createContainer();
Net4jUtil.prepareContainer(container); // Register Net4j factories
TCPUtil.prepareContainer(container); // Register TCP factories
CDONet4jUtil.prepareContainer(container); // Register CDO factories
LissomeStoreUtil.prepareContainer(container);
I cannot see where do I decide to use lissome or db store, but it seems to me more and more clear to configure the lissome store on another repository... But then I'm afraid for the CDOID consistency Smile
Thanks a lot for your quick answers!
/Christophe.
[Updated on: Fri, 14 December 2012 09:09] by Moderator
Re: [CDO] Raw writes in DB (MySQL) [message #990867 is a reply to message #990855] Fri, 14 December 2012 10:15 Go to previous messageGo to next message
I tried with a different repo, and I get:
!ENTRY org.eclipse.osgi 4 0 2012-12-14 16:12:48.388
!MESSAGE Erreur liée à l'application
!STACK 1
java.lang.IllegalStateException: Revision temporality not supported: NONE
	at org.eclipse.net4j.util.CheckUtil.checkState(CheckUtil.java:53)
	at org.eclipse.net4j.util.lifecycle.Lifecycle.checkState(Lifecycle.java:229)
	at org.eclipse.emf.cdo.spi.server.Store.setRevisionTemporality(Store.java:193)
	at org.eclipse.emf.cdo.internal.server.Repository.doActivate(Repository.java:1883)
	at org.eclipse.net4j.util.lifecycle.Lifecycle.internalActivate(Lifecycle.java:76)
	at org.eclipse.net4j.util.lifecycle.ShareableLifecycle.internalActivate(ShareableLifecycle.java:43)
	at org.eclipse.net4j.util.lifecycle.Lifecycle.activate(Lifecycle.java:162)
	at org.eclipse.net4j.util.lifecycle.LifecycleUtil.activate(LifecycleUtil.java:114)
	at org.eclipse.net4j.util.lifecycle.LifecycleUtil.activate(LifecycleUtil.java:104)
	at org.eclipse.emf.cdo.server.CDOServerUtil.addRepository(CDOServerUtil.java:212)
	at org.eclipse.emf.cdo.spi.server.RepositoryConfigurator.configure(RepositoryConfigurator.java:113)
	at org.eclipse.emf.cdo.internal.server.bundle.CDOServerApplication.doStart(CDOServerApplication.java:61)
	at com.robotikdose.importer.ImporterApplication.doStart(ImporterApplication.java:220)
	at org.eclipse.net4j.util.om.OSGiApplication.start(OSGiApplication.java:63)
	at com.robotikdose.app.MLSApplication.start(MLSApplication.java:38)
	at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:353)
	at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:180)
	at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:57)
	at java.lang.reflect.Method.invoke(Method.java:601)
	at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:629)
	at org.eclipse.equinox.launcher.Main.basicRun(Main.java:584)
	at org.eclipse.equinox.launcher.Main.run(Main.java:1438)
	at org.eclipse.equinox.launcher.Main.main(Main.java:1414)
Does that mean that I have to enable versioning with supportingAudits=true ?
Re: [CDO] Raw writes in DB (MySQL) [message #990939 is a reply to message #990855] Sat, 15 December 2012 02:15 Go to previous messageGo to next message
Am 14.12.2012 15:08, schrieb Christophe MOINE:
>> > does the LissomeStore lives with the DBStore ? I don't understand this question. Can you elaborate?
The term "CDO server" is not exactly defined, but it makes most sense to see it like this:
A CDO server is a computer with one or more IRepositories and one or more IAcceptors. One repository must have exactly
one IStore (one of DBStore, MEMStore, LissomeStore, etc.). If the stores of different repositories need access to a
database this database can possibly be shared depending on the capabilities of the database engine, but not the same
tables (although even this is thearetically store dependent (as of now I know of no stores that can do this).
Yes, on a different repository, if you need multiple repos with different store types (less common).
> <cdoServer>
> <store type="db">
> </mappingStrategy>
> </store>
> </store>
Only the first <store> element is used. Others are just ignored to make it easier to play with different store types (at
different times).
> </repository>
> </cdoServer>
The XML-based repository configuration is best supported when OSGi is running. In that case no cutom container has to be
configured/used because the singleton IPluginContainer.INSTANCE is automatically configured through Eclipse's extension
registry.
> lissome store on another repository... But then I'm afraid for the CDOID consistency :)
Yes, referential integrity can only be enforced within a single repository. But you can still create "external
references" between the repos (or other resources with EObjects). Use them with care.
Cheers
/Eike
Re: [CDO] Raw writes in DB (MySQL) [message #990940 is a reply to message #990867] Sat, 15 December 2012 02:16 Go to previous messageGo to next message
Am 14.12.2012 16:15, schrieb Christophe MOINE:
> !STACK 1
Yes, the LissomeStore is in an early development state and does currently not support other repo modes than branching
(IIRC.), which includes auditing.
Cheers
/Eike
> at org.eclipse.equinox.internal.app.EclipseAppHandle.run(EclipseAppHandle.java:196)
> at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.runApplication(EclipseAppLauncher.java:110)
> at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.start(EclipseAppLauncher.java:79)
> at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43)
Re: [CDO] Raw writes in DB (MySQL) [message #991348 is a reply to message #990940] Tue, 18 December 2012 11:11 Go to previous messageGo to next message
It seems - in an SQL point of view - that the fastest way to insert data is LOAD DATA LOCAL INFILE ...
Just to be sure: the lissomestore don't use this statement right ?
I would like to use this only before CDO Server starts, so that there is no potential integrity problem.
/Christophe.
Re: [CDO] Raw writes in DB (MySQL) [message #991365 is a reply to message #991348] Tue, 18 December 2012 13:00 Go to previous messageGo to next message
Hm... does that mean that the LissomeStore uses a DBStore as back-end and it can be switched on/off as needed?
Re: [CDO] Raw writes in DB (MySQL) [message #991377 is a reply to message #991348] Tue, 18 December 2012 15:14 Go to previous messageGo to next message
Am 18.12.2012 17:11, schrieb Christophe MOINE:
I've never heard of that one. Is that vendor-specific?
No.
I don't understand what problem you want to solve and how exactly. Can you please elaborate?
Cheers
/Eike
Re: [CDO] Raw writes in DB (MySQL) [message #991378 is a reply to message #991365] Tue, 18 December 2012 15:15 Go to previous messageGo to next message
Am 18.12.2012 19:00, schrieb Erdal Karaca:
No, they're totally different. But each on their own they use net4j.db for the DDL abstractions.
Cheers
/Eike
Re: [CDO] Raw writes in DB (MySQL) [message #994071 is a reply to message #991377] Wed, 26 December 2012 05:02 Go to previous messageGo to next message
Eike Stepper wrote on Tue, 18 December 2012 15:14
I'm not sure; it might be. I am using MySQL. And it seems to work with Oracle as well.
No.
Well, if I modify MySQL tables directly, I must ensure that CDO Server & Client does not hold any cached data, since they might not be up to date. What I mean is that I know what I do is not "good", but I would like to prevent nightmare issues...
Christophe.
Re: [CDO] Raw writes in DB (MySQL) [message #994399 is a reply to message #994071] Thu, 27 December 2012 02:25 Go to previous messageGo to next message
Am 26.12.2012 11:02, schrieb Christophe MOINE:
>> No.
> nightmare issues...
When the CDO server (i.e., a repository) is running there's most certainly cached data (EPackages and CDORevisions) in it.
Cheers
/Eike
Re: [CDO] Raw writes in DB (MySQL) [message #1000713 is a reply to message #994399] Tue, 15 January 2013 05:05 Go to previous messageGo to next message
Ok, it still under testing, but it seems on the good way: the import took 8 min, and now takes about 3 minutes (not as fast as I hoped, but prevents many timeouts, and other head overflows...).
The prerequisites so far are the following:
- requires Guava library, and maybe others one
- requires a direct JDBC connection (I query it throught a CDO Query Handler...)
- must be called before the CDOServer load any data in its cache....
- all objects passed as parameters must belongs the the same existing CDOResource
- a new CDOTransaction must be created before, and then closed without being commited (a bit ugly I admit)
- all objects must be attached the the CDOResource content of the 'temporary' transaction.
This is subjects to improvements, but not sure I'll have time to 'unpigify' it Smile
/Christophe
Re: [CDO] Raw writes in DB (MySQL) [message #1000735 is a reply to message #1000713] Tue, 15 January 2013 05:52 Go to previous messageGo to next message
Hi Christoph,
Thank you for sharing this! What about sharing your code in the wiki? You could link it from
http://wiki.eclipse.org/CDO/User_Contributed_Documentation#Snippets
Cheers
/Eike
Am 15.01.2013 11:05, schrieb Christophe MOINE:
> This is subjects to improvements, but not sure I'll have time to 'unpigify' it :)
> Cheers,
> /Christophe
Re: [CDO] Raw writes in DB (MySQL) [message #1000859 is a reply to message #1000735] Tue, 15 January 2013 10:00 Go to previous messageGo to next message
Of course, however, I fixed a bug this morning Wink
How do I share this ? You do it for me ? Or can I do it myself ?
Re: [CDO] Raw writes in DB (MySQL) [message #1000912 is a reply to message #1000859] Tue, 15 January 2013 12:07 Go to previous messageGo to next message
Am 15.01.2013 16:00, schrieb Christophe MOINE:
> Of course, however, I fixed a bug this morning ;)
What is "this"? The fix to the bug you just mentioned? What is that bug? Or are you talking about editing the wiki?
Cheers
/Eike
Re: [CDO] Raw writes in DB (MySQL) [message #1000917 is a reply to message #1000912] Tue, 15 January 2013 12:29 Go to previous messageGo to next message
this=the Java file
yes I'm talkign about editing the wiki Smile
/Christophe.
Re: [CDO] Raw writes in DB (MySQL) [message #1000971 is a reply to message #1000917] Tue, 15 January 2013 14:50 Go to previous messageGo to next message
Am 15.01.2013 18:29, schrieb Christophe MOINE:
> this=the Java file
> yes I'm talkign about editing the wiki :)
Of course you're not only allowed but also encouraged to edit it. It's a community resource ;-)
Cheers
/Eike
Re: [CDO] Raw writes in DB (MySQL) [message #1001689 is a reply to message #1000971] Thu, 17 January 2013 03:11 Go to previous message
Eike Stepper wrote on Tue, 15 January 2013 14:50
> this=the Java file
Of course you're not only allowed but also encouraged to edit it. It's a community resource Wink
Cheers
/Eike
Ok Wink
It's done, not sure it is industrialized yet, but it's a first shot.
/Christophe.
Previous Topic:[GWT] SerializationException
Next Topic:[CDO] Exception on commit
Current Time: Wed Jul 23 14:16:25 EDT 2025
Powered by FUDForum. Page generated in 0.30134 seconds
