Home » Modeling » TMF (Xtext) » Use xmi elements inside the dsl
Use xmi elements inside the dsl [message #1000691] Tue, 15 January 2013 04:12 Go to next message
Hello everyone!
I've got a complex situation in my hands. I've got an ecore project where I can define some "Functions". From this ecore I've generated an .xmi file with a sample function definition.
My DSL uses that ecore:
import "http://www.eclipse.org/xtext/common/JavaVMTypes" as jvmTypes
import "http://www.eclipse.org/xtext/xbase/Xbase" as xbase
import "platform:/resource/com.egicon.ats.sequence.model/model/AtsSequenceEdit.ecore" as coreSequence
RealFunction:
	'REAL_FUNCTION'
	function=[coreSequence :: Function]
What I want is this: user can call sample function (xmi file) from RealFunction rule.
Is the cross reference correct? How can I import the xmi file (need to have scope for defined functions)?
Thanks for your tips!
Re: Use xmi elements inside the dsl [message #1000700 is a reply to message #1000691] Tue, 15 January 2013 04:35 Go to previous messageGo to next message
I can't edit last message, so here are the update:
I think I can resolve that cross reference with a global scope, but I can't find an useful example of it.
Re: Use xmi elements inside the dsl [message #1000757 is a reply to message #1000700] Tue, 15 January 2013 06:40 Go to previous messageGo to next message
am not quite sure what you want to do. xmi is a very generic term.
do you mine you have a test.mystuff file which is an xmi persited ecore based model and you want to reference it?
something like http://christiandietrich.wordpress.com/2011/07/17/xtext-2-0-and-uml/
~Christian
Re: Use xmi elements inside the dsl [message #1000783 is a reply to message #1000757] Tue, 15 January 2013 07:37 Go to previous messageGo to next message
Exactly
Re: Use xmi elements inside the dsl [message #1000785 is a reply to message #1000783] Tue, 15 January 2013 07:38 Go to previous messageGo to next message
so the solution is in the blog
Re: Use xmi elements inside the dsl [message #1000820 is a reply to message #1000691] Tue, 15 January 2013 08:24 Go to previous messageGo to next message
But I need to menage import of xmi files,
user could write some imports and use objects inside those.
Re: Use xmi elements inside the dsl [message #1000833 is a reply to message #1000820] Tue, 15 January 2013 08:52 Go to previous message
What about a complete real world example!
Previous Topic:Line break after multi-line comments using serialization
Next Topic:What is best way to get reference of JvmAnnotationType in inference?
Current Time: Fri Jul 25 20:43:19 EDT 2025
Powered by FUDForum. Page generated in 0.06026 seconds
