Unable to run Eclipse Helios on windows 7 with jdk [message #550346] |
Thu, 29 July 2010 21:56  |
I am attempting to run Eclipse Helios on windows 7 32-bit. I have 32 bit Helios and 32 bit JDK.
I previously asked about this issue on the newcomers forum and it was suggested I ask here.
my original post: http://www.eclipse.org/forums/index.php?t=msg&th=172802& amp;start=0&
when I try to run Eclipse it will always crash by exiting without an error message. It will also hang if I try to interact with the workspace setting window.
I reverted to JDK 6 update 20 in case it was an issue with update 21 but it made no difference. Specifying the VM directly in the ini also makes no difference.
Here is the log:
!SESSION 2010-07-28 21:29:57.439 -----------------------------------------------
eclipse.buildId=I20100608-0911
java.version=1.6.0_20
BootLoader constants: OS=win32, ARCH=x86, WS=win32, NL=en_AU
Framework arguments: -product org.eclipse.epp.package.java.product
Command-line arguments: -os win32 -ws win32 -arch x86 -product org.eclipse.epp.package.java.product -data c:\temp\ws -debug
!ENTRY org.eclipse.osgi 4 0 2010-07-28 21:29:59.756
!MESSAGE Application error
!STACK 1
org.eclipse.swt.SWTError: Cannot initialize Drop
at org.eclipse.swt.dnd.DND.error(DND.java:266)
at org.eclipse.swt.dnd.DND.error(DND.java:227)
at org.eclipse.swt.dnd.DropTarget.<init>(DropTarget.java:144)
at org.eclipse.ui.internal.EditorSashContainer.addDropSupport(E ditorSashContainer.java:542)
at org.eclipse.ui.internal.EditorSashContainer.createControl(Ed itorSashContainer.java:534)
at org.eclipse.ui.internal.EditorAreaHelper.<init>(EditorAreaHelper.java:41)
at org.eclipse.ui.internal.WorkbenchPage.init(WorkbenchPage.jav a:2425)
at org.eclipse.ui.internal.WorkbenchPage.<init>(WorkbenchPage.java:563)
at org.eclipse.ui.internal.tweaklets.Workbench3xImplementation. createWorkbenchPage(Workbench3xImplementation.java:39)
at org.eclipse.ui.internal.WorkbenchWindow.busyOpenPage(Workben chWindow.java:768)
at org.eclipse.ui.internal.Workbench$23.runWithException(Workbe nch.java:1220)
at org.eclipse.ui.internal.StartupThreading$StartupRunnable.run (StartupThreading.java:31)
at org.eclipse.swt.widgets.RunnableLock.run(RunnableLock.java:3 5)
at org.eclipse.swt.widgets.Synchronizer.runAsyncMessages(Synchr onizer.java:134)
at org.eclipse.swt.widgets.Display.runAsyncMessages(Display.jav a:4041)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :3660)
at org.eclipse.ui.application.WorkbenchAdvisor.openWindows(Work benchAdvisor.java:803)
at org.eclipse.ui.internal.Workbench$31.runWithException(Workbe nch.java:1566)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:2537)
at org.eclipse.ui.internal.Workbench.access$4(Workbench.java:24 27)
at org.eclipse.ui.internal.Workbench$7.run(Workbench.java:670)
at org.eclipse.core.databinding.observable.Realm.runWithDefault (Realm.java:332)
at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Work bench.java:663)
at org.eclipse.ui.internal.ide.application.IDEApplication.start (IDEApplication.java:115)
at org.eclipse.equinox.internal.app.EclipseAppHandle.run(Eclips eAppHandle.java:196)
at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .runApplication(EclipseAppLauncher.java:110)
at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .start(EclipseAppLauncher.java:79)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:369)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:179)
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAcce ssorImpl.java:39)
at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMe thodAccessorImpl.java:25)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java: 619)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:574)
at org.eclipse.equinox.launcher.Main.run(Main.java:1407)
at org.eclipse.equinox.launcher.Main.main(Main.java:1383)
any help would be much appreciated.
FUDForum. Page generated in 0.25322 seconds
