Home » Modeling » Papyrus » extending requirement diagram in SysML
extending requirement diagram in SysML [message #997795] Tue, 08 January 2013 13:56 Go to next message
I just started working with Papyrus and I went through tutorial for making UML profiles (with the example of requirement Model). Now I want to extend the Requirement element in SysML. So I want to choose Requirement as my base metaclass. How can I do that?
Thank you so much in advance for your help.
Re: extending requirement diagram in SysML [message #997852 is a reply to message #997795] Tue, 08 January 2013 16:47 Go to previous messageGo to next message
Hi, Jeni,
You should be able to import the SysML profile as an imported package
in your profile. In the Model Explorer, select the root package of
your profile and select "Import Registered Package" (not sure of the
exact label) in the context menu. Can you choose the SysML profile in
this dialog? If so, then you'll end up with that profile imported and
its types available to use in generalization relationships,
associations, etc.
However, I'm not sure that the UML2 implementation of "dynamic
profiles" support these kinds of dependencies between profiles very
well. I think it may copy all of the definitions from the referenced
profiles (SysML in your case) into your profile's Ecore definition, so
that at the EMF level you end up with a distinct copy of SysML that
isn't interoperable with the original SysML profile. Perhaps somebody
in this newsgroup knows better than I how this works with dynamic
profiles. I know that dependencies between profiles work well when the
profiles are statically generated.
HTH,
Christian
On 2013-01-08 18:56:19 +0000, Jeni Martin said:
Re: extending requirement diagram in SysML [message #998727 is a reply to message #997852] Thu, 10 January 2013 10:11 Go to previous messageGo to next message
I think the "Import registered package" menu won't work in this case. It is intended for UML Libraries.
However, the "Import registered profile" menu will work fine.
You cannot choose the SysML Requirement as the "Base Metaclass" of your new Stereotype. Instead, you should create a Generalization between your Stereotype and the SysML Requirement.
Camille
Re: extending requirement diagram in SysML [message #998732 is a reply to message #998727] Thu, 10 January 2013 10:19 Go to previous messageGo to next message
Hi, Camille,
Thanks for the correction of the menu action.
Indeed, stereotypes are not metaclasses and thus cannot be extended by
stereotypes. But the Eclipse UML implementation supports
generalization of stereotypes well (though, as I said, I'm not sure
about how practical it is to have generalization relationships to
stereotypes in another profile when the profiles are dynamically
defined).
cW
On 2013-01-10 15:11:59 +0000, Camille Letavernier said:
> Hello,
> Regards,
> Camille
Re: extending requirement diagram in SysML [message #1000342 is a reply to message #998732] Mon, 14 January 2013 10:04 Go to previous messageGo to next message
Thank yuo so much for all replies and helps.
I imported the SysML as standard profile and made a new stereotype (without any new property)which is the specialization of Stereotype Requirement (from SysML). but when I validate it, it says not all members of namespace Profile are distinguishable within it.
What do you think?
Thanks.
Re: extending requirement diagram in SysML [message #1000588 is a reply to message #1000342] Mon, 14 January 2013 23:00 Go to previous messageGo to next message
Hi, Jeni,
A package import adds members of the imported package (SysML profile)
into the importing namespace (your profile), but only those members
that have names that are distinct from all of the names in the
importing namespace. Thus, a package import shouldn't be able to add
duplicate names, which is what this warning is about.
Which element names are repeated?
cW
On 2013-01-14 15:04:26 +0000, Jeni Martin said:
> What do you think?
> Thanks.
Re: extending requirement diagram in SysML [message #1001498 is a reply to message #1000588] Wed, 16 January 2013 15:41 Go to previous messageGo to next message
yeah, Thank you so much. This is the problem. Smile
Re: extending requirement diagram in SysML [message #1103504 is a reply to message #1001498] Fri, 06 September 2013 18:11 Go to previous messageGo to next message
I am also interested in this subject. I would like to create a profile to create the <<System>> stereotype that you see in the first "System Context" diagram of every textbook. Using the original tutorial and the updated hints above, I was able to get this working almost perfectly but with one small remaining problem. Basically, I created my profile, imported the SysML profile, dragged a copy of the <<Block>> element onto my diagram, and then dragged a new stereotype onto the diagram. After naming the new stereotype <<System>> I added a generalization relationship to <<Block>>
index.php/fa/16131/0/
(See uploaded file: Asatte_SysML_Profile_System_Generalizes_Block.png)
So far, so good. However, when I then create a test model, add a block and apply the new profile (all of which works as described) it shows up nicely in the model explorer, but not in the actual diagram. Like thisL
index.php/fa/16130/0/
(See uploaded file: Not_OK_Diagram_Still_Shows_Block.png)
Looks like a (small) bug to me. Actually, I have a done step-by-step screen captures all the way from zero for this which I could drop into a Word document if that would be helpful... However, I am hoping that it is just something I missed...(?)
[Updated on: Fri, 06 September 2013 18:11] by Moderator
Re: extending requirement diagram in SysML [message #1104038 is a reply to message #1103504] Sat, 07 September 2013 15:28 Go to previous messageGo to next message
Hi, see p.29 of http://www.eclipse.org/papyrus/usersTutorials/resources/PapyrusUserGuideSeries_AboutUMLProfile_v1.0.0_d20120606.pdf
on how to display this graphically...
Re: extending requirement diagram in SysML [message #1105346 is a reply to message #1104038] Mon, 09 September 2013 14:29 Go to previous messageGo to next message
Thanks, that was helpful! I had not noticed the buttons in the upper right hand corner to toggle the appearance. Now, however, it shows both <<system>> (my new stereotype) and <<block>> (the stereotype it is derived from)
index.php/fa/16150/0/
Is there a way to suppress <<block>> and show only <<system>> (?)
In fact, it looks like this behavior has nothing to do with my stereotype.
If I just drag a completely normal SysML block onto my diagram it looks like this:
index.php/fa/16151/0/
If I use the right-hand button, it toggles to this:
index.php/fa/16152/0/
That is, instead of turning the display of <<block>> on and off, it alternates between one and two copies of <<block>>.... (?)
Re: extending requirement diagram in SysML [message #1105742 is a reply to message #997795] Tue, 10 September 2013 04:15 Go to previous messageGo to next message
It seems that the BDD implementation for Blocks automatically displays the <<Block>> label. This is independent from the generic Papyrus mechanism for manipulating stereotypes (Most likely because this is a pure-SysML diagram, not a generic UML one)
It'd probably work as expected in the Class diagram, which is a generic UML diagram.
Camille
Re: extending requirement diagram in SysML [message #1105990 is a reply to message #1105742] Tue, 10 September 2013 10:36 Go to previous messageGo to next message
Ah... this would seem to be a "bug" ...(What I am try to implement is exactly diagrams 17.5 and 17.6 from the SysML specification) Let me read the specification a bit more carefully and then I will submit something on Bugzilla (I will also take a look at making a patch...I haven't looked at the Papyrus source code yet and have no feel for how difficult it might be to get up to speed on making small fixes like this)
Thanks!
David Hetherington
Re: extending requirement diagram in SysML [message #1106894 is a reply to message #1105990] Wed, 11 September 2013 13:36 Go to previous messageGo to next message
A little more information. Instead of creating a Papyrus SysML project, I created a Papyrus UML project and then used "apply registered profile" to apply SysML to it. I then dragged a class (the UML concept) onto the diagram and applied the "Block" profile from SysML to it. After that, the icons to show/hide the <<block>> work perfectly - exactly as expected.
Of course, this approach will work. After all, SysML is simply a profile applied to UML. However, it is less convenient because the diagram editor shows UML constructs rather than SysML constructs. However, using the model explorer and right clicking "New SysML Child" still works. You can create the SysML child and then drag it onto the UML+SysML diagram and that works fine. Relationships are a bit more problematic.
At any rate, the team that implemented the SysML diagram editor seems to have not got this quite right.... the names should not be hard-coded, but rather should be shown based on the profile applied...(?)
Thanks!
David Hetherington
Re: extending requirement diagram in SysML [message #1108447 is a reply to message #1106894] Fri, 13 September 2013 17:51 Go to previous message
Hmmm... So today I downloaded the Papyrus source code tree (which is huge) and spent the day looking at it carefully. This behavior is not so easy to change, at least not for a beginner, and it is deeply embedded in both the UML and SysML side of Papyrus. From what I can see, the <<class>> element is the only element that does NOT hard-code the label to the shape. This behavior is true for both the base UML and also for the SysML. When I found the part that adds or subtracts the stereotype according to the buttons discussed above, it carefully prepends the stereotype list to whatever was there before inserting a comma in the string and then uses the same comma to strip it when you click the button again.
While I still feel that the original intent of UML is that you should be able to elide (hide) anything - including the stereotype - making the change to Papyrus to make this possible would be rather involved. Probably the best way would be to add a new appearance property "Display stereotype = true/false" that handled the basic stereotype. We would then have to rework the logic in AddAppliedQNStereotypeToDisplayCommand.java and RemoveAppliedStereotypePropertiesToDisplayCommand.java to accommodate the more complicated logic. Unfortunately, while I can allocate part of a Friday to reading some source code, I don't have quite enough time to do the work to get fully setup to be able to build and debug Papyrus (it looks pretty complicate) and learn all the ins and outs of the ui and datastructures to make this sort of change. I will submit it as a feature request instead and hope that someone who is already setup and educated on Papyrus building will find the request interesting enough to implement.
Thanks!
David Hetherington
Previous Topic:Change Stereotype display programmatically
Next Topic:Programmatically update diagrams + write transaction
Current Time: Fri Jul 25 08:34:30 EDT 2025
Powered by FUDForum. Page generated in 0.07232 seconds
