Home » Modeling » EMF "Technology" (Ecore Tools, EMFatic, etc)  » Log4j Dependency
Log4j Dependency [message #100048] Tue, 23 October 2007 07:36 Go to next message
Using Teneo 0.8 we set up Log4j logging in our application.
After the teneo plugin org.eclipse.emf.teneo.eclipse
is started our log4j configuration is ignored.
From the source we can see that Teneo loads
its own log4j configuration in the start method of
org.eclipse.emf.teneo.eclipse.StorePlugin
I removed the log4j configuration in teneo's source and recompiled
and setting the log4j.configuration variable to point to our own
log4j.properties file solves the problem. Both our own logs and teneos
are written to the same file.
In future releases can Teneo's dependency on Log4j and how its congifured
be removed??
Shane
Re: Log4j Dependency [message #100063 is a reply to message #100048] Tue, 23 October 2007 08:34 Go to previous messageGo to next message
Hi Shane,
Can you enter a call for this in bugzilla? Then I will solve this in the next build.
gr. Martin
Shane Coughlan wrote:
> From the source we can see that Teneo loads its own log4j configuration
> in the start method of org.eclipse.emf.teneo.eclipse.StorePlugin
> congifured be removed??
> Shane
With Regards, Martin Taal
Springsite/Elver.org
The Netherlands
Tel: +31 (0)84 420 2397
Fax: +31 (0)84 225 9307
Re: Log4j Dependency [message #100100 is a reply to message #100063] Tue, 23 October 2007 10:54 Go to previous message
Hi Martin,
I have submitted a request. Bug 207170.
Thanks for the help.
Shane
Re: Log4j Dependency [message #610127 is a reply to message #100048] Tue, 23 October 2007 08:34 Go to previous message
Hi Shane,
gr. Martin
> Shane
The Netherlands
Re: Log4j Dependency [message #610133 is a reply to message #100063] Tue, 23 October 2007 10:54 Go to previous message
Hi Martin,
Shane
Previous Topic:Log4j Dependency
Next Topic:[Compare] Non-eclipse context
Current Time: Sat Nov 01 11:56:01 EDT 2025
Powered by FUDForum. Page generated in 0.03825 seconds
