Home » Archived » BIRT » Dynamic sql(Dynamic sql)
Dynamic sql [message #992062] Thu, 20 December 2012 14:28 Go to next message
I have two views, which has multiple versions. Each version is dynamically created, which is as part of design.
For the report design I need to union all the 2 views,all the versions that are available at the time of report execution.
Please find the attached report design. Here in this report I am able to exceute union all on one view.
Please suggest how to execute the same on multiple views.
Amarnath A
[Updated on: Wed, 16 January 2013 16:11] by Moderator
Re: Dynamic sql [message #992085 is a reply to message #992062] Thu, 20 December 2012 15:47 Go to previous messageGo to next message
Can you point me to where I'm looking for the issue, in the design? Is the one dataSet one view and the other dataSet the other, then the LatestRequirement dataSet is where you're trying to combine them? Let me know.
Re: Dynamic sql [message #996686 is a reply to message #992085] Wed, 02 January 2013 12:11 Go to previous messageGo to next message
Hello Williams Thanks !
I need to combine both the datasets in LatestRequirement.
AR
Re: Dynamic sql [message #996687 is a reply to message #992085] Wed, 02 January 2013 12:11 Go to previous messageGo to next message
Hello Williams Thanks for the response !
AR
Re: Dynamic sql [message #997110 is a reply to message #996687] Thu, 03 January 2013 13:17 Go to previous messageGo to next message
And the script you're currently using in LatestRequirement doesn't get you what you're wanting? What is the issue? Are you getting an error? Are you only getting part of the data you want? Let me know.
Re: Dynamic sql [message #997134 is a reply to message #997110] Thu, 03 January 2013 16:15 Go to previous messageGo to next message
I am not the getting the data when I am use the script for two views. I am only getting the data for one view.
I am getting the following error, when I try to modify the script.
A BIRT exception occurred.
Plug-in Provider:Eclipse.org
Plug-in Name:BIRT Data Engine
Plug-in ID:org.eclipse.birt.data
Version:2.6.1.v20100915
Error Code:odaconsumer.CannotGetResultSetMetaData
Error Message:Cannot get the result set metadata.
org.eclipse.birt.report.data.oda.jdbc.JDBCException: SQL statement does not return a ResultSet object.
SQL error #1: ORA-00942: table or view does not exist
java.sql.SQLException: ORA-00942: table or view does not exist
Williams can you please let me know is the script I am using right?
Amarnath
Re: Dynamic sql [message #997144 is a reply to message #997134] Thu, 03 January 2013 18:00 Go to previous messageGo to next message
To add to the above details,
When I am trying to check the list of tables that are return in view are working fine. I don't see any issue in working with those tables.
AR
Re: Dynamic sql [message #997274 is a reply to message #997144] Fri, 04 January 2013 16:26 Go to previous messageGo to next message
What if you just returned the data from your two views separately, then used a joint dataSet to merge the two together?, rather than making even more complicated script? Or will that not work?
Re: Dynamic sql [message #997481 is a reply to message #997274] Mon, 07 January 2013 12:51 Go to previous messageGo to next message
Yes Williams,
It will not work for my requirement as I need to use the data details from the views I need to use in where condition only. Going further I need to use the 3rd view from which I need to use union all on all the views that are in database.
AR
Re: Dynamic sql [message #997521 is a reply to message #997481] Mon, 07 January 2013 20:38 Go to previous messageGo to next message
So, if I create an example taking the data from more than one other dataSet to use in the main dataSet's where condition, it would help you with your issue?
Re: Dynamic sql [message #997784 is a reply to message #997521] Tue, 08 January 2013 13:38 Go to previous messageGo to next message
yes it will help
Re: Dynamic sql [message #997888 is a reply to message #997521] Tue, 08 January 2013 18:29 Go to previous messageGo to next message
In where coindition i need the unionl results for the tables that are resulted in the both datasets.
Please let me know if I am not clear.
AR
Re: Dynamic sql [message #998256 is a reply to message #997888] Wed, 09 January 2013 12:09 Go to previous messageGo to next message
I'm pretty sure I understand. I'll be working on an example for you, sometime this afternoon! Smile
Re: Dynamic sql [message #998295 is a reply to message #998256] Wed, 09 January 2013 13:39 Go to previous messageGo to next message
I am working on the previous example provided by you. I will come up with my questions before that Smile
Thank you sir !
Re: Dynamic sql [message #998300 is a reply to message #998295] Wed, 09 January 2013 13:49 Go to previous messageGo to next message
Hi Williams ,
This is the script you have give me some time back. Please let me know how I can include one more union all in the same script for the dataset.
myTables = reportContext.getPersistentGlobalVariable("myTables");
if(myTables[0] != "blah"){
numTables = myTables.length;
qt = "select * from " + myTables[0];
i=1;
while(i<numTables){
qt = qt + " UNION ALL select * from " + myTables[i];
i++;
else{
qt = "select * from RPT_ASSET_REQUEST_29";
this.queryText = this.queryText.replace("scriptSelect",qt).replace("scriptSelect",qt);
Re: Dynamic sql [message #998301 is a reply to message #998256] Wed, 09 January 2013 13:49 Go to previous messageGo to next message
Hi Williams ,
i=1;
while(i<numTables){
i++;
else{
Re: Dynamic sql [message #998347 is a reply to message #992062] Wed, 09 January 2013 16:10 Go to previous messageGo to next message
Take a look at this report. It should give you an idea of how to complete your report. It takes the values from Data Set and Data Set 1 and stores them into arrays. In the Data Set 2 where clause, I left a marker to replace, though you could simply build the entire query, instead. I then union this result set with another query that uses the other marker. In the beforeOpen script, I replace the markers to give me the data I want. Hope this helps.
Re: Dynamic sql [message #998368 is a reply to message #998347] Wed, 09 January 2013 16:42 Go to previous messageGo to next message
Thanks for the example report Williams.
Can you please correct me if I am wrong in the attahed report.
In the attached report:
- REQUEST & PROPERTY are datasets that return the list of views that are available in schema.
- scriptselect & scriptselect1 datasets are returning the union all result for the tables that are return in the REQUEST & PROPERTY views.
- *ISSUE* dataset is the one where I am trying to fetch the data from both the views.
AR
[Updated on: Wed, 16 January 2013 16:12] by Moderator
Re: Dynamic sql [message #998779 is a reply to message #998368] Thu, 10 January 2013 12:29 Go to previous messageGo to next message
Hello Williams ,
Did you get a chance to look into this issue....
AR
Re: Dynamic sql [message #998951 is a reply to message #998779] Thu, 10 January 2013 21:59 Go to previous messageGo to next message
Can you post what the data looks like from your two dataSets and what the final query looks like in your main dataSet, when the data from your two original dataSets is added in?
Re: Dynamic sql [message #1000405 is a reply to message #998951] Mon, 14 January 2013 12:20 Go to previous messageGo to next message
results for Property dataset:
Re: Dynamic sql [message #1000414 is a reply to message #998951] Mon, 14 January 2013 12:46 Go to previous messageGo to next message
[Updated on: Wed, 16 January 2013 16:13] by Moderator
Re: Dynamic sql [message #1000443 is a reply to message #998951] Mon, 14 January 2013 14:36 Go to previous messageGo to next message
Williams , it seems we cannot able to call multiple queries through the script.
I tried the folowing cases:
====in script 'beforeOpen'======
qt = "select * from RPT_ASSET_REQUEST_36";
qt1 = "select * from RPT_ASSET_REQUEST_36 ";
this.queryText = this.queryText.replace("scriptSelect1",qt1).replace("scriptSelect1",qt1);
=====in dataset Sql Query Text ===========
Case 1:
scriptSelect --> Working
Case 2:
scriptSelect UNION ALL scriptSelect --> Working
Case 3:
scriptSelect UNION ALL scriptSelect1 -- Not Working
The .rptdesign file is attached.
please correct me if I am wrong.
AR
Re: Dynamic sql [message #1000936 is a reply to message #1000443] Tue, 15 January 2013 13:12 Go to previous messageGo to next message
I tried with
Case 4 :
Replace both "scriptSelect" and "scriptSelect1" replaced by qt?
this.queryText = this.queryText.replace("scriptSelect1",qt).replace("scriptSelect1",qt);
It throws the error : table or view does not exist
Case 5: "scriptSelect1" and "scriptSelect2" as placeholders
this.queryText = this.queryText.replace("scriptSelect2",qt).replace("scriptSelect2",qt);
This is working for
But throwing the error "table doesn't exist " when I tried the below:
qt1 = "select * from RPT_ASSET_REQUEST_PROPERTY_36 ";
Re: Dynamic sql [message #1001014 is a reply to message #992062] Tue, 15 January 2013 16:22 Go to previous messageGo to next message
Try this out. Look in the requirement dataSet's beforeOpen script.
Re: Dynamic sql [message #1005831 is a reply to message #1001014] Mon, 28 January 2013 16:54 Go to previous messageGo to next message
Hi Williams - Sorry for the delay in reposne.
I tried the attachment , it is giving the error table doesn't exist.
Error Description:
thanks
AR
Re: Dynamic sql [message #1006041 is a reply to message #1005831] Tue, 29 January 2013 10:45 Go to previous messageGo to next message
Double check the returned values in the two dataSets we're pulling data from and make sure that all of the tables exist, in your database. I remember us having this problem the first time we set this up because your data had extra tables that weren't in your DB. Let me know.
Re: Dynamic sql [message #1006558 is a reply to message #992062] Thu, 31 January 2013 12:52 Go to previous messageGo to next message
Hi Williams - issue resolved Smile
It is because of the place holders, appending 1 to one table name.
Thank you so much for ur support thru this issue.
AR
Re: Dynamic sql [message #1006785 is a reply to message #1006558] Fri, 01 February 2013 15:18 Go to previous message
Awesome! Glad it's finally working! You're welcome for the help! Smile
Previous Topic:How to add an editable text field ?
Next Topic:How to localize currency symbols in BIRT in the web application?
Current Time: Sat Jul 19 11:44:46 EDT 2025
Powered by FUDForum. Page generated in 0.08405 seconds
