Home » Newcomers » Newcomers » "Task List Indexer" error when opening Eclipse
"Task List Indexer" error when opening Eclipse [message #987399] Mon, 26 November 2012 08:30 Go to next message
Hello
I have installed and used Eclipse in the past, but this is a fresh installation with the Android sdk plugin.
Whenever I open Eclipse, I get this message:
An internal error occurred during: "Task List Indexer".
For input string: "1-Guy-PC"
While Guy-PC is the name of my computer.
After that the program seems to continue normally, but I would like to fix the issue anyway.
Googling the error message retrieved very few and irrelevant results.
Does anyone here know what that means and how to fix it ?
Guy
Re: "Task List Indexer" error when opening Eclipse [message #1000368 is a reply to message #987399] Mon, 14 January 2013 10:57 Go to previous messageGo to next message
Helo I have similar problem when I start eclipse.
For input string: "Kama-Pc conflicted copy"
I fix it in folder C:\Users\"User"\Documents\workspace\.metadata\.mylyn\.taskListIndex
I find file "Kama-Pc conflicted copy" and I delete it.
You can find file 1-Guy-PC in folder .metadata in workspace where are all settings for eclipse workspace and you can remove it from this folder.-better is only move file to other folder for back up Smile
Re: "Task List Indexer" error when opening Eclipse [message #1470727 is a reply to message #1000368] Wed, 12 November 2014 10:28 Go to previous messageGo to next message
Thank you for the message. It helped.
I had the same issue, but I had no 'conflicting copy'. I just renamed the file and it worked. Mylyn is still functioning, it just recreated the folder.
Re: "Task List Indexer" error when opening Eclipse [message #1758011 is a reply to message #1470727] Wed, 22 March 2017 14:09 Go to previous messageGo to next message
I don't have .metadata\.mylyn\.taskListIndex on my kepler system.
I can no longer do searches in task list find field.
I get:
'Refresh Filter' has encountered a problem.
An internal error has occurred.
For input string: "My MacBook Pro.gen"
help please.
[Updated on: Wed, 22 March 2017 14:47] by Moderator
Re: "Task List Indexer" error when opening Eclipse [message #1758033 is a reply to message #1758011] Wed, 22 March 2017 16:21 Go to previous message
I fixed this by changing mylyn task lists folder location in preferences and imported old task lists.
This worked , got rid of error messages for both start up and find field in Task Lists, so I copied folder back to my original location, whew! back to normal.
[Updated on: Wed, 22 March 2017 16:22] by Moderator
Previous Topic:Installation Error
Next Topic:Marketplace
Current Time: Fri Jul 18 06:43:14 EDT 2025
Powered by FUDForum. Page generated in 0.12255 seconds
