ClassNotFoundException: javax.validation.spi.ValidationProvider after upgrade to Virgo 3.6 [message #998047] |
Wed, 09 January 2013 04:00  |
Hello everyone
We are upgrading Virgo from 3.0.3 to 3.6 and face a ClassNotFoundException we cannot explain. The same setup worked in 3.0.3 though.
[2013-01-09 09:35:45.814] start-signalling-2 <DE0006E> Start failed for bundle 'net.junisphere.eranger.core.config' version '1.0.0.RELEASE'. org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'dbUpdateExecutor' defined in URL [bundleentry://164.fwk1495622108/META-INF/spring/db-update-context.xml]: Cannot create inner bean 'net.junisphere.eranger.domain.internal.neo4j.dbupdate.VersionUpdate#dd63e54' of type [net.junisphere.eranger.domain.internal.neo4j.dbupdate.VersionUpdate] while setting constructor argument with key [0]; nested exception is org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'net.junisphere.eranger.domain.internal.neo4j.dbupdate.VersionUpdate#dd63e54' defined in URL [bundleentry://164.fwk1495622108/META-INF/spring/db-update-context.xml]: Cannot create inner bean 'net.junisphere.eranger.domain.internal.neo4j.dbupdate.task.AddUuidToPropertyValueNodes#2e5b9f90' of type [net.junisphere.eranger.domain.internal.neo4j.dbupdate.task.AddUuidToPropertyValueNodes] while setting constructor argument with key [0]; nested exception is org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'net.junisphere.eranger.domain.internal.neo4j.dbupdate.task.AddUuidToPropertyValueNodes#2e5b9f90': Injection of autowired dependencies failed; nested exception is org.springframework.beans.factory.BeanCreationException: Could not autowire field: private org.springframework.data.neo4j.support.Neo4jTemplate net.junisphere.eranger.domain.internal.neo4j.dbupdate.AbstractTask.neo4j; nested exception is org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'customNeo4jConfiguration': Injection of autowired dependencies failed; nested exception is org.springframework.beans.factory.BeanCreationException: Could not autowire field: private javax.validation.Validator org.springframework.data.neo4j.config.Neo4jConfiguration.validator; nested exception is org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'validator' defined in URL [bundleentry://164.fwk1495622108/META-INF/spring/module-context.xml]: Initialization of bean failed; nested exception is java.lang.TypeNotPresentException: Type javax.validation.spi.ValidationProvider not present
at org.springframework.beans.factory.support.BeanDefinitionValueResolver.resolveInnerBean(BeanDefinitionValueResolver.java:281)
at org.springframework.beans.factory.support.BeanDefinitionValueResolver.resolveValueIfNecessary(BeanDefinitionValueResolver.java:120)
at org.springframework.beans.factory.support.BeanDefinitionValueResolver.resolveManagedList(BeanDefinitionValueResolver.java:353)
at org.springframework.beans.factory.support.BeanDefinitionValueResolver.resolveValueIfNecessary(BeanDefinitionValueResolver.java:153)
at org.springframework.beans.factory.support.ConstructorResolver.resolveConstructorArguments(ConstructorResolver.java:630)
at org.springframework.beans.factory.support.ConstructorResolver.autowireConstructor(ConstructorResolver.java:148)
at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.autowireConstructor(AbstractAutowireCapableBeanFactory.java:1035)
at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.createBeanInstance(AbstractAutowireCapableBeanFactory.java:939)
at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.doCreateBean(AbstractAutowireCapableBeanFactory.java:485)
at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.createBean(AbstractAutowireCapableBeanFactory.java:456)
at org.springframework.beans.factory.support.AbstractBeanFactory$1.getObject(AbstractBeanFactory.java:294)
at org.springframework.beans.factory.support.DefaultSingletonBeanRegistry.getSingleton(DefaultSingletonBeanRegistry.java:225)
at org.springframework.beans.factory.support.AbstractBeanFactory.doGetBean(AbstractBeanFactory.java:291)
at org.springframework.beans.factory.support.AbstractBeanFactory.getBean(AbstractBeanFactory.java:193)
at org.springframework.beans.factory.support.DefaultListableBeanFactory.preInstantiateSingletons(DefaultListableBeanFactory.java:585)
at org.springframework.context.support.AbstractApplicationContext.finishBeanFactoryInitialization(AbstractApplicationContext.java:913)
at org.eclipse.gemini.blueprint.context.support.AbstractDelegatedExecutionApplicationContext.access$1600(AbstractDelegatedExecutionApplicationContext.java:60)
at org.eclipse.gemini.blueprint.context.support.AbstractDelegatedExecutionApplicationContext$4.run(AbstractDelegatedExecutionApplicationContext.java:325)
at org.eclipse.gemini.blueprint.util.internal.PrivilegedUtils.executeWithCustomTCCL(PrivilegedUtils.java:85)
at org.eclipse.gemini.blueprint.context.support.AbstractDelegatedExecutionApplicationContext.completeRefresh(AbstractDelegatedExecutionApplicationContext.java:290)
at org.eclipse.gemini.blueprint.extender.internal.dependencies.startup.DependencyWaiterApplicationContextExecutor$CompleteRefreshTask.run(DependencyWaiterApplicationContextExecutor.java:137)
at org.eclipse.virgo.kernel.agent.dm.ContextPropagatingTaskExecutor$2.run(ContextPropagatingTaskExecutor.java:95)
at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1110)
at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:603)
at java.lang.Thread.run(Thread.java:722)
Caused by: org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'net.junisphere.eranger.domain.internal.neo4j.dbupdate.VersionUpdate#dd63e54' defined in URL [bundleentry://164.fwk1495622108/META-INF/spring/db-update-context.xml]: Cannot create inner bean 'net.junisphere.eranger.domain.internal.neo4j.dbupdate.task.AddUuidToPropertyValueNodes#2e5b9f90' of type [net.junisphere.eranger.domain.internal.neo4j.dbupdate.task.AddUuidToPropertyValueNodes] while setting constructor argument with key [0]; nested exception is org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'net.junisphere.eranger.domain.internal.neo4j.dbupdate.task.AddUuidToPropertyValueNodes#2e5b9f90': Injection of autowired dependencies failed; nested exception is org.springframework.beans.factory.BeanCreationException: Could not autowire field: private org.springframework.data.neo4j.support.Neo4jTemplate net.junisphere.eranger.domain.internal.neo4j.dbupdate.AbstractTask.neo4j; nested exception is org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'customNeo4jConfiguration': Injection of autowired dependencies failed; nested exception is org.springframework.beans.factory.BeanCreationException: Could not autowire field: private javax.validation.Validator org.springframework.data.neo4j.config.Neo4jConfiguration.validator; nested exception is org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'validator' defined in URL [bundleentry://164.fwk1495622108/META-INF/spring/module-context.xml]: Initialization of bean failed; nested exception is java.lang.TypeNotPresentException: Type javax.validation.spi.ValidationProvider not present
at org.springframework.beans.factory.support.BeanDefinitionValueResolver.resolveInnerBean(BeanDefinitionValueResolver.java:270)
... 24 common frames omitted
Caused by: org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'net.junisphere.eranger.domain.internal.neo4j.dbupdate.task.AddUuidToPropertyValueNodes#2e5b9f90': Injection of autowired dependencies failed; nested exception is org.springframework.beans.factory.BeanCreationException: Could not autowire field: private org.springframework.data.neo4j.support.Neo4jTemplate net.junisphere.eranger.domain.internal.neo4j.dbupdate.AbstractTask.neo4j; nested exception is org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'customNeo4jConfiguration': Injection of autowired dependencies failed; nested exception is org.springframework.beans.factory.BeanCreationException: Could not autowire field: private javax.validation.Validator org.springframework.data.neo4j.config.Neo4jConfiguration.validator; nested exception is org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'validator' defined in URL [bundleentry://164.fwk1495622108/META-INF/spring/module-context.xml]: Initialization of bean failed; nested exception is java.lang.TypeNotPresentException: Type javax.validation.spi.ValidationProvider not present
at org.springframework.beans.factory.annotation.AutowiredAnnotationBeanPostProcessor.postProcessPropertyValues(AutowiredAnnotationBeanPostProcessor.java:287)
at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.populateBean(AbstractAutowireCapableBeanFactory.java:1106)
at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.doCreateBean(AbstractAutowireCapableBeanFactory.java:517)
... 34 common frames omitted
Caused by: org.springframework.beans.factory.BeanCreationException: Could not autowire field: private org.springframework.data.neo4j.support.Neo4jTemplate net.junisphere.eranger.domain.internal.neo4j.dbupdate.AbstractTask.neo4j; nested exception is org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'customNeo4jConfiguration': Injection of autowired dependencies failed; nested exception is org.springframework.beans.factory.BeanCreationException: Could not autowire field: private javax.validation.Validator org.springframework.data.neo4j.config.Neo4jConfiguration.validator; nested exception is org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'validator' defined in URL [bundleentry://164.fwk1495622108/META-INF/spring/module-context.xml]: Initialization of bean failed; nested exception is java.lang.TypeNotPresentException: Type javax.validation.spi.ValidationProvider not present
at org.springframework.beans.factory.annotation.AutowiredAnnotationBeanPostProcessor$AutowiredFieldElement.inject(AutowiredAnnotationBeanPostProcessor.java:506)
at org.springframework.beans.factory.annotation.InjectionMetadata.inject(InjectionMetadata.java:87)
at org.springframework.beans.factory.annotation.AutowiredAnnotationBeanPostProcessor.postProcessPropertyValues(AutowiredAnnotationBeanPostProcessor.java:284)
... 38 common frames omitted
Caused by: org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'customNeo4jConfiguration': Injection of autowired dependencies failed; nested exception is org.springframework.beans.factory.BeanCreationException: Could not autowire field: private javax.validation.Validator org.springframework.data.neo4j.config.Neo4jConfiguration.validator; nested exception is org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'validator' defined in URL [bundleentry://164.fwk1495622108/META-INF/spring/module-context.xml]: Initialization of bean failed; nested exception is java.lang.TypeNotPresentException: Type javax.validation.spi.ValidationProvider not present
at org.springframework.beans.factory.support.ConstructorResolver.instantiateUsingFactoryMethod(ConstructorResolver.java:353)
at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.instantiateUsingFactoryMethod(AbstractAutowireCapableBeanFactory.java:1015)
at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.createBeanInstance(AbstractAutowireCapableBeanFactory.java:911)
at org.springframework.beans.factory.support.DefaultListableBeanFactory.findAutowireCandidates(DefaultListableBeanFactory.java:848)
at org.springframework.beans.factory.support.DefaultListableBeanFactory.doResolveDependency(DefaultListableBeanFactory.java:790)
at org.springframework.beans.factory.support.DefaultListableBeanFactory.resolveDependency(DefaultListableBeanFactory.java:707)
at org.springframework.beans.factory.annotation.AutowiredAnnotationBeanPostProcessor$AutowiredFieldElement.inject(AutowiredAnnotationBeanPostProcessor.java:478)
... 40 common frames omitted
Caused by: org.springframework.beans.factory.BeanCreationException: Could not autowire field: private javax.validation.Validator org.springframework.data.neo4j.config.Neo4jConfiguration.validator; nested exception is org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'validator' defined in URL [bundleentry://164.fwk1495622108/META-INF/spring/module-context.xml]: Initialization of bean failed; nested exception is java.lang.TypeNotPresentException: Type javax.validation.spi.ValidationProvider not present
... 60 common frames omitted
Caused by: org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'validator' defined in URL [bundleentry://164.fwk1495622108/META-INF/spring/module-context.xml]: Initialization of bean failed; nested exception is java.lang.TypeNotPresentException: Type javax.validation.spi.ValidationProvider not present
at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.doCreateBean(AbstractAutowireCapableBeanFactory.java:527)
... 62 common frames omitted
Caused by: java.lang.TypeNotPresentException: Type javax.validation.spi.ValidationProvider not present
at sun.reflect.generics.factory.CoreReflectionFactory.makeNamedType(CoreReflectionFactory.java:117)
at sun.reflect.generics.visitor.Reifier.visitClassTypeSignature(Reifier.java:125)
at sun.reflect.generics.tree.ClassTypeSignature.accept(ClassTypeSignature.java:49)
at sun.reflect.generics.reflectiveObjects.WildcardTypeImpl.getUpperBounds(WildcardTypeImpl.java:130)
at com.sun.beans.TypeResolver.resolve(TypeResolver.java:327)
at com.sun.beans.TypeResolver.resolve(TypeResolver.java:362)
at com.sun.beans.TypeResolver.resolve(TypeResolver.java:321)
at com.sun.beans.TypeResolver.resolve(TypeResolver.java:172)
at com.sun.beans.TypeResolver.resolveInClass(TypeResolver.java:93)
at java.beans.FeatureDescriptor.getParameterTypes(FeatureDescriptor.java:387)
at java.beans.MethodDescriptor.setMethod(MethodDescriptor.java:114)
at java.beans.MethodDescriptor.<init>(MethodDescriptor.java:72)
at java.beans.MethodDescriptor.<init>(MethodDescriptor.java:56)
at java.beans.Introspector.getTargetMethodInfo(Introspector.java:1130)
at java.beans.Introspector.getBeanInfo(Introspector.java:414)
at java.beans.Introspector.getBeanInfo(Introspector.java:161)
at org.springframework.beans.CachedIntrospectionResults.<init>(CachedIntrospectionResults.java:224)
at org.springframework.beans.CachedIntrospectionResults.forClass(CachedIntrospectionResults.java:149)
at org.springframework.beans.BeanWrapperImpl.getCachedIntrospectionResults(BeanWrapperImpl.java:324)
at org.springframework.beans.BeanWrapperImpl.getPropertyDescriptors(BeanWrapperImpl.java:331)
at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.filterPropertyDescriptorsForDependencyCheck(AbstractAutowireCapableBeanFactory.java:1242)
at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.populateBean(AbstractAutowireCapableBeanFactory.java:1101)
... 71 common frames omitted
Caused by: org.eclipse.virgo.kernel.osgi.framework.ExtendedClassNotFoundException: javax.validation.spi.ValidationProvider in KernelBundleClassLoader: [bundle=org.springframework.context_3.1.0.RELEASE]
at org.eclipse.virgo.kernel.userregion.internal.equinox.KernelBundleClassLoader.loadClass(KernelBundleClassLoader.java:139)
at java.lang.ClassLoader.loadClass(ClassLoader.java:356)
at java.lang.Class.forName0(Native Method)
at java.lang.Class.forName(Class.java:264)
at sun.reflect.generics.factory.CoreReflectionFactory.makeNamedType(CoreReflectionFactory.java:114)
... 94 common frames omitted
Caused by: java.lang.ClassNotFoundException: javax.validation.spi.ValidationProvider
at org.eclipse.osgi.internal.loader.BundleLoader.findClassInternal(BundleLoader.java:501)
at org.eclipse.osgi.internal.loader.BundleLoader.findClass(BundleLoader.java:421)
at org.eclipse.osgi.internal.loader.BundleLoader.findClass(BundleLoader.java:412)
at org.eclipse.osgi.internal.baseadaptor.DefaultClassLoader.loadClass(DefaultClassLoader.java:107)
at org.eclipse.virgo.kernel.userregion.internal.equinox.KernelBundleClassLoader.loadClass(KernelBundleClassLoader.java:135)
... 98 common frames omitted
The class javax.validation.spi.ValidationProvider is available as shown in the console:
osgi> clhas javax.validation.spi.ValidationProvider
Bundles containing [javax/validation/spi/ValidationProvider]
84 com.springsource.javax.validation
/javax/validation/spi/ValidationProvider.class
Any clues why this class cannot be loaded in Virgo 3.6?
James
FUDForum. Page generated in 0.34086 seconds
