Home » Archived » Jubula » How to use default value in a local data set
How to use default value in a local data set [message #1000251] Mon, 14 January 2013 06:05 Go to next message
Could you please advise how to use default value in a local data set.
Say, I have a keyword that fills some person record:
_keyword_fill_person
It takes several parameters:
=FirstName
=Second_Name
=Address
etc, the list can be big enough
All the parameters have default value
I want to test some place in the application that concerns field FirstName of the record from above. First I need to setup this data.
So I use keyword '_keyword_fill_person' and want to pass different parameter '=FirstName' expecting that all other parameters would take default value unless I specify them exactly. However, when I start creating set for parameter '=FirstName' I'm forced to enter all other parameters. Can I avoid that?
Alex
Re: How to use default value in a local data set [message #1000650 is a reply to message #1000251] Tue, 15 January 2013 02:06 Go to previous messageGo to next message
The way that referenced (default) and local data works is on an all-or-nothing basis. That means that as soon as you change one parameter, the whole data set is considered "local" and is no longer affected by changes in the referenced test case. You can switch the data back to their referenced values in the "Data Source" combo box in the properties view.
Nevertheless, if you reference the Test Case with default values, then you should be able to change one value without having to reenter the other data - I can't quite read from your post whether that is what you are describing.
If I've misunderstood, let me know Smile
Alex
Re: How to use default value in a local data set [message #1000811 is a reply to message #1000650] Tue, 15 January 2013 08:10 Go to previous message
Hi Alex,
I' better describe my expectations in pictures Smile
Here is defined test case with default values specified:
index.php/fa/12972/0/
I add it to test suite:
index.php/fa/12973/0/
Here are default values being set as expected:
index.php/fa/12974/0/
I need to call this case severeal times for various values of parameter FIRST_NAME.
So I define values for the parameter:
index.php/fa/12975/0/
Now I expect to have data set with values I entered for FIRST_VALUE and all other values propagated from default settings. However other values are empty:
index.php/fa/12976/0/
So, I need to manually enter missing values that is quite uncomfortable.
Eg: to repeat case with 10 parameters 10 times for only one of paraemters I will need to fill 81 more absolutelly unnesseccary for current scenario fields.
Alex.
  • Attachment: ref_case.PNG
    (Size: 13.17KB, Downloaded 612 times)
  • Attachment: test_suite.PNG
    (Size: 3.18KB, Downloaded 543 times)
  • Attachment: def_values.PNG
    (Size: 19.59KB, Downloaded 605 times)
  • Attachment: f_name.PNG
    (Size: 7.35KB, Downloaded 591 times)
  • Attachment: problem.PNG
    (Size: 9.21KB, Downloaded 600 times)
[Updated on: Tue, 15 January 2013 08:11] by Moderator
Previous Topic:Title: Problem in Tree Table (RCP) of a Property View (RCP)
Next Topic:Null pointer exception on keyword update
Current Time: Sat Jul 19 02:05:04 EDT 2025
Powered by FUDForum. Page generated in 0.08295 seconds
