Home » Newcomers » Newcomers » Version tool or something
Version tool or something [message #99680] |
Mon, 05 September 2005 19:06  |
Originally posted by: vicenrico.gmail.com
Hello all!!
Is there any way ( or plugin), to control the version of a program??
I mean,, i´m building a program and i wanna know how can i control the
version of the program , for example, something that when i add a
functionality of the program , increase the version number of the program.
Until now i do this by myself, and i want to know if there any tool for
that!!
Thanks!!
Re: Version tool or something [message #99683 is a reply to message #99680] |
Mon, 05 September 2005 20:10   |
Originally posted by: bboyes.systronix.com
On Mon, 05 Sep 2005 17:06:48 -0600, Vicente <vicenrico@gmail.com> wrote:=
> Hello all!!
> I mean,, i=C2=B4m building a program and i wanna know how can i contro=
l the =
> version of the program , for example, something that when i add a =
> functionality of the program , increase the version number of the =
> program.
> Until now i do this by myself, and i want to know if there any tool fo=
r =
> that!!
> Thanks!!\
Use CVS which has great integration with Eclipse.
Bruce
Using Opera's revolutionary e-mail client: http://www.opera.com/mail/
Re: Version tool or something [message #99740 is a reply to message #99683] |
Tue, 06 September 2005 08:04   |
>> Hello all!!
>> the version of the program , for example, something that when i add
>> a functionality of the program , increase the version number of the
>> program.
>> for that!!
>> Thanks!!\
> Bruce
Thanks,but can you tell me how can i use Eclipse CVS into localhost???
I do the connection but i receive a connection error..."Could not
connect t...",etc...
Which parameters i need to configure..???
Mines are=
-localhost
-Repository path
-user vicente
-connection pserve
-use default port
I don´t know really how working with CVS in local
Re: Version tool or something [message #99753 is a reply to message #99740] |
Tue, 06 September 2005 08:50   |
>>> Hello all!!
>>> the program.
>>> for that!!
>>> Thanks!!\
>> Bruce
> Mines are=
> -localhost
> -Repository path
> -user vicente
> -connection pserve
> -use default port
Before you can start using it you'll have to install CVS on your machine.
Dani
Re: Version tool or something [message #99767 is a reply to message #99753] |
Tue, 06 September 2005 10:10   |
>>>> Hello all!!
>>>> the program.
>>>> for that!!
>>>> Thanks!!\
>>> Bruce
>> Mines are=
>> -localhost
>> -Repository path
>> -user vicente
>> -connection pserve
>> -use default port
> Dani
Ok, Thanks!!!
Which is better, CVSNT???? or Tortoise CVS??
I know tortoise is a client where cvsnt is a server, but in tortoise´s
internet page says there are a way of function like a server for a local
use only. Do you know which is better for use with eclipse..??
Re: Version tool or something [message #99849 is a reply to message #99767] |
Tue, 06 September 2005 12:14   |
>>>> wrote:
>>>>> Hello all!!
>>>>> add a functionality of the program , increase the version number
>>>>> of the program.
>>>>> tool for that!!
>>>>> Thanks!!\
>>>> Bruce
>>> Mines are=
>>> -localhost
>>> -Repository path
>>> -user vicente
>>> -connection pserve
>>> -use default port
>> machine.
>> Dani
> Ok, Thanks!!!
> local use only. Do you know which is better for use with eclipse..??
You need the server (cvsnt) since Eclipe will act as client.
Dani
Re: Version tool or something [message #100021 is a reply to message #99683] |
Wed, 07 September 2005 03:29   |
Originally posted by: mr.smith.vous.etes.dans.la.matrice.com
On Mon, 05 Sep 2005 18:10:40 -0600
> > Hello all!!
> > program.
> > that!!
> > Thanks!!\
> Bruce
Can you explain how CVS will help?
CVS can tag an entire release but the tag must me given manually.
The automatic tagging of the files is not usable for one version-tag for the program (1 file will be 1.1 and another 2.4).
Re: Version tool or something [message #100145 is a reply to message #100021] |
Wed, 07 September 2005 12:29   |
>>>Hello all!!
>>>program.
>>>that!!
>>>Thanks!!\
>>Bruce
Well,really, i tried CVS but cannot connect to server (CVSNT) and i left
out.
Now i tested subversion who has more features than CVS and i like a lot
For using subversion into eclipse i use Subclipse plugin
Into the question of automatic tagging, i do with subversion/subclipse
and this mark one version for all program not as cvs than mark every
file with his proper version. I mean, if you do commit , the version
number increments all the files, and not only the modified..
Current Time: Thu Sep 04 05:46:23 EDT 2025
Powered by FUDForum. Page generated in 0.48339 seconds
