Home » Modeling » TMF (Xtext) » Context dependent auto activation of content assist
Context dependent auto activation of content assist [message #999492] Sat, 12 January 2013 03:35 Go to next message
Hi!
I want to do the following:
If the user calls content assist (e.g. CTRL+SPACE) and chooses a String to be entered, then I want that dependent of the EObject (model object) behind this string, the content assist is automatically reactivated in order to propose further strings.
Example: You have qualified names "a.b", but in the content assist you only show first "a", then "." and afterwards "b" if the user repeatedly calls CA manually.
Sure one could solve this by calling CA manually on "a", then press "." and the do the default auto activation dependent on the string "." entered (there are some posts and blogs about it on the web, how to do it). But how can I solve it without even pressing "." manually?
So far, I found out, that I can call
sourceViewer.doOperation(ISourceViewer.CONTENTASSIST_PROPOSALS)
in order to activate CA manually (where sourceViewer is of type XtextSourceViewer).
I tried this call by configuring an IAutoEditStrategy for an AutoEditStrategyProvider. But the AutoEditStrategyProvider is only invoked, when I edit the document. So: Where do I have to hook in, when I just navigate in the document, or even better: after a chosen string is inserted by the CA automatically?
Re: Context dependent auto activation of content assist [message #1000186 is a reply to message #999492] Mon, 14 January 2013 02:59 Go to previous message
Hi Alex,
please search this newsgroup for COMPLETION_AUTO_ACTIVATION_CHARS.
They are used to automatically trigger content assist for certain input
events.
Sebastian
Looking for professional support for Xtext, Xtend or Eclipse Modeling?
Am 12.01.13 09:35, schrieb Alex G:
> Hi!
> calls CA manually.
> XtextSourceViewer).
Previous Topic:Using images from other plugins in LabelProvider
Next Topic:Parser optymization
Current Time: Thu Jul 24 22:45:59 EDT 2025
Powered by FUDForum. Page generated in 0.06820 seconds
