Home » Eclipse Projects » Remote Application Platform (RAP) » Theme of RAP
Theme of RAP [message #99480] Wed, 23 July 2008 00:03 Go to next message
Originally posted by: dnise.hotmail.com
Hi All:
For the moment I'm not sure I can set background color for action or
ViewPart title in rap.I glimpsed the "Theme.properties" and "Theme.css"
file. I didn't find the example of that I mentioned above.Now Rap has
changed lots of appearance than before.
I appreciate for any helps and ideas.
Re: Theme of RAP [message #99511 is a reply to message #99480] Wed, 23 July 2008 05:33 Go to previous messageGo to next message
Originally posted by: fappel.innoopract.com
the theming available in the theme.css adjust RWT-widget properties and
look & feel. What you are asking for are appearances settings of the
higher level workbench components.
For changing the active selected color of a viewpart tab
programmatically, you could use the following code:
IWorkbench workbench = PlatformUI.getWorkbench();
ITheme currentTheme = workbench.getThemeManager().getCurrentTheme();
currentTheme.getColorRegistry().put(
IWorkbenchThemeConstants.ACTIVE_TAB_BG_START,
new RGB( 255, 0, 0 ));
So you see that there is no low level widget API involved - this is all
done on the higher level workbench API.
This may looks a little confusing, but the Workbench Thememanager
approach is provided by RCP, while the low-level CSS styling mechanism
is RWT (RAP Widget Toolkit) specific. The CSS styling mechansim can be
used to allow a more 'webish' look and feel for each widget type.
The workbench also allows to provide themes declaratively. I think its
the Themes (org.eclipse.ui.themes) extionsion-point documentation which
should provide for more information.
Ciao
Frank
-----Ursprüngliche Nachricht-----
Von: dnise [mailto:dnise@hotmail.com]
Bereitgestellt: Mittwoch, 23. Juli 2008 06:03
Bereitgestellt in: eclipse.technology.rap
Unterhaltung: Theme of RAP
Betreff: Theme of RAP
Hi All:
action or
Re: Theme of RAP [message #99624 is a reply to message #99511] Wed, 23 July 2008 23:33 Go to previous messageGo to next message
Frank Appel wrote:
> programmatically
Hi Frank:
Thanks for your reply. For the moment I can complete to set the background
color for ViewPart Tab Header.But I have an other problem about this. I am
sure there is a brown line in Perspective when I add ViewPart in it
except using "Layout.addStandaloneView(..)". I'll show codes for you as
follow
// has no brown line,because it use StandaloneView.
layout.addStandaloneView(TopViewPart.ID, false, IPageLayout.TOP,
0.05f,editorArea);
//has brown line
IFolderLayout all =
layout.createFolder(Perspective.SPACE,IPageLayout.LEFT, 0.35f, editorArea);
all.addView(ConceptViewPart.ID);
For sure you can understand me clearly,I also attach a picture to you.
best regards
Re: Theme of RAP [message #99633 is a reply to message #99511] Thu, 24 July 2008 00:50 Go to previous messageGo to next message
--nextPart1417952.ZOWBGmjNM5
Content-Type: text/plain; charset=utf-8
Content-Transfer-Encoding: 8Bit
Sorry,I forgot attache the picture.Now added
Content-Type: image/png; name="viewpart.png"
Content-Disposition: attachment; filename="viewpart.png"
iVBORw0KGgoAAAANSUhEUgAABaAAAAOECAYAAABXTZbSAAAABmJLR0QA/wD/ AP+gvaeTAAAACXBI
WXMAAAsTAAALEwEAmpwYAAAAB3RJTUUH2AcYAxI1OTWdKwAAIABJREFUeNrs 3Xd4U9X/B/B3VpPu
TcseLXuVUVpKGWULIsgQ+IFMQVHZCIKoX0FAlKGoIENQthNBUYbsUVahLVBG 2aUDuvdufn+kiU2b
pjdNUih9v57Hx+bm3nPOPedzb9oPJ+eKvg9+qgQRERERERERERFRJTe6hTO2 X4t/ZnVW9fp1ETMs
iYiIiIiIiIiIiMgcmIAmIiIiIiIiIiIiIrOQsguIiIiIiIiIiIiIKtaE1q56 398cEmu+ulu5ACJR
qXVMaO0KKJXYHBpndF2cAU1ERERERERERERUwfQlmM2ZfAYAiEQAlKpEdDGq xLiycB/jMQFNRERE
RERERERE9AzoSjSbPfmsqUMEiERaSWjNrGyl6drBBDQRERERERERERHRM1I0 0VsRyecSdRUmoSe0
dFa9NtHSG2plrgGtznoXP/nStuvTvZ4dqlnJsDssXufr8hjZ3BlSsQhSsQgF SiWSs/NxOz4LYXGZ
Jfb1rm6NltWscPVpBi5Gp5d4f3QLF0jFqqnlOfkFSMzKx53ELIQnZPFKICIi IiIiIiIiIrOoyMRz
8XontHQGxGLVkhsmTj4DFTwDup69HFYycamvy8NSKoZMLIIIgEQkgpNCCt+a Nmhdzapk/Q5yrf8X
ZyERQSwCxCJAIRWjuo0MnWvbwsvNilcBERERERERERERvXjE5k0RS1+UftoS GguZWISGTgr41LBB
Y2cFQp5maN53sZTC1kICALC1kMDZUor4zDzdZYXEQi4Vo5mLJbzcrNDE2RLB TzIYjERERERERERE
RC8IzXrHpXhWs5KfSR8oCx86WLgchylnQZssvW0vl6BHPTuMbuGCsS1d0M/D AW7WMoPK8HCUY0gT
J4xr5YphTZ3QxNlS8LFKJZCTr8SNwqU3rGQSrffVs54jUnIAAPVLmQUNAEoA WXkFCClMOiukXCqb
iIiIiIiIiIjoRaIvwVzVks+bQ+NKrAltKmJDGlT0v6IcFBIMaOiIuvZyWEhE kIhFcLeR4SUDktB1
7OXoWscO9nIJxCLVLGW/WjbwcFQIOxERIBOL0NRFlbROyc7Xer+evRwFSuBc ZBqUStXr0ohEgFwi
QqvCpTeKl0VERERERERERESVn65Ec5VJPiuVJdZ8LnruZc0QF8okS3C0r24D C4kIF6LScCs+C0oA
DRzk8K9ti3bu1vj7blKZZbRyVSWOg59kIPRpBpq7WqKduzWau1ribmLZDwEc 10q7Q648+e8hg06W
UtjJJYhOy0VqTj6eZuTCzVoGJ0spEnQswzG+WFnXYrn8BhERERERERER0Yto c0isJtlaFZLPKqol
N0pLwKv6Q2mSmqSGDERRRTPg1W1Us5w71LBBhxo2Wvu5WgmrwtlStd+12Azk FSgRFpeJdu7WcFRI
BB1foFTNggaAs49TcT8pW/Nefc3yG6ptj1Jy4GYtQ317uc4EdIESKFAqkZSV j7C4TNwRkAAnIiIi
IiIiIiKiyqnqJJ7V5xtXYf1hkhnQ6sSvLnlCE+WFZRQU7q9ZG0Tg8T+ExqJl NSt4V7eGm7UFbsb/
lzRWL7dRPEFez0GOoJh0nWURERERERERERERkXFMkoBOyMyDq5VMM/M4O19/ 1lgkUi0xUvS1uoym
LpYIi81Ec1fV+ssJWXmC23HtaQZq2VrAw1GOB8lyPEzOhqNCCnu57lnU9nIJ HBVSJBpQBxERERER
ERERET2frsVmYnQLZ2y/Fl8h9Y1u4YxrsZmsXw+TJKCDn2SgV317+NWyhV8t W832rLwC7Lz+38lm
5xVALhXD3VqG6LRcrdfXYjMRUFcG7+rW8K5urdVpQikBnIpIwaBGTvCrZYOY 9FzN8hvX4zJxPjJN
s69vTRs0c7FEfQc5EmOYgCYiIiIiIiIiIqrsgp+onuU2uoVzhdR3LTZTUyfr 180kCeiIlBwcupeM
1m5WcLGUQlK4JoeFRKy137FHqehWxxYejgpEp+VqvT4dkQoLSSpaVbOCtUyC tJx8hD7N0FrLWYi0
nAIERqaiax07+NW0gaNCdYrhCdrrOIcnZKGZiyXq2ctxWccyHERERERERERE RFT5BD/JKDMpyvor
juj74KdKhiURERERERERERERmZqYXUBERERERERERERE5sAENBERERERERER ERGZBRPQRERERERE
RERERGQWTEATERERERERERERkVkwAU1EREREREREREREZsEENBERERERERER ERGZhdTqSRR7gYiI
iIiIiIiIiIhMjjOgiYiIiIiIiIiIiMgsmIAmIiIiIiIiIiIiIrNgApqIiIiI iIiIiIiIzIIJaCIi
IiIiIiIiIiIyCyagiYiIiIiIiIiIiMgsmIAmIiIiIiIiIiIiIrNgApqIiIiI iIiIiIiIzIIJaCIi
IjNIS0lmJ7CviYiIiIiIqjwpu4BeFCP7eAnab9fBYK391a+f53N6lm2sDP1k ivOqLOcptJ3lOR9j
+sDU/VfZ427b+hU4sv9X/LDvnMnLjo2JxLSx/eHs6o5vth8odb8Z4wfgSVQE Pl//K+a+ObTC+lPX
vVgkEsHKxhaejVti0IiJaNKybaXoayIiIiIiIjIeZ0ATERGZ2N+/b0d2dpZZ ynZ1rwnPxi0QHxuD
8BuhOve5H34DT6IiULueJ2rX83zm/aFUKpGemoKQS2eweO4k3LgaVCn6moiI iIiIiIzHGdD0wig+
s+9FmLn7os06Zl/zfMg0Onbrizu3ruHcyUNo2LRVifcDTx4CAPh16/vM4qFo nQUFBUhKiMWP6z7H
hdNH8Ou27/Dh5xs5kERERERERFUAE9BU5WVmpGPzN0tx8cxRKBSW8At4CSPG T4WFXKHZJ+5pNLZv
WIXQoEAolQXw8vbHmLfeg6Ozq2YfdcL7wy82YdWiWajboLEmwSLkeF2KJ9Fz crLx05avEXj8IFJS
EuFSrTq69ByAQSMmQiyR6C3r4pmjOLB3F+6H30BOdhYcnFzg7ReA4eOnQmFp VWY/JSXE4aslc3H3
9nXU92yKMW/NgUfjFoLOPzryIXZsXI1rV85DJBKhRRsfjJ48G27VayHwxEGs WToPvl16Y/oHn2vK
uxR4HCv/NwPTFixHx659NNs/mjkW4WEhmDZ/OdYsmwcA+PTrHdixcTXu3LwK uVwB3y69MGrybCgU
loLjoLQlOYSUbej4GnPOQuNW1z/A3A4Lwc5Nq3Hn1jXY2NihY7e+GD7u3RLj L+SaKG+cGHM96Iuj
4uMoZNxuh4Xgx7XL8fDebTi7umHQyDewYfUnRl9zRZegGNnHS2sMhJyDEL5d e2P7hpU4f+pfjJ48
GyKRSOv9cycOAlAlqkuLB33jYIoYLUosFsPJxQ3j312AC6eP4O7Nqwbfn3Td Y8JCLpba10RERERE
RPR80JmAri5PYs/QC6OseP5u2UxcuHABAJCdlYl/9uyAAhmYPn06ACAlJQXT Zk1EbGys5phzJw8h
8v4NbNy4EQqFdlJu94blSE9NQd0aLqguTzL4eH3nsOrbVfh73z7N9idREfhl 61oolKmYOHFiqccf
PHgQq5Yt09oWHxuDA3t3oSAzHgsWLCizDeuXz8HNa6rkzu2wYCyZNwmbN29G 9erV9Z5/bGwsPpn5
BpKT/3tI2KWzx3DvZgg2btyIvv4t8Z2FBa5dPgtXSRykUtVt6erZvwEAoWf/ weDePgCAzMxM3Lt1
DTKZDH07t8SawlNaMvcNZGZmAgByc7Lx7/5foRBlYc6cOQbHR/HXZZVdnvE1 xTmXFbfFz+fhw4dY
Mm8ScnJyAADJSQk48MdOpMU9wqeffmrQNWFMnBjaX+r2lxVHzs7OBo1bdHQ0 PlvwlmafpzGRmuSz
Ka45U5yD3jJrWKBVq1YICQlB4t2zaN68uea9mzdvIvZJFJo2bQqvejYAkkq0 paxxMEWM6rr3KuQp
AACxWKR539D7U9F7TFgIf38hIiIiIiJ6nkRnO5TYJjVkZyJDVJcnPRdxVFYb YhNT8cWG3+DiVgM/
bV6DA3t34fiJ03jtrY8BADu3/YDY2Fi08+2KN2Z8BLFYjM1rluD86X+x9dcD GDBsnFZ5rrU8sXDV
dlhYyBGdbfjx+s7h0OF/AQCfrPoBDRo1x6Vzx/HVp+9h/z8H0W/07FKP/2Hb TgDAhHcXoGvvVyAS
iRF+IwSL507C6TOBgsYpKS0La37cD4lUii8/fQ/hN0KxecceTJi6QO/5b9n2 HZKTk9GwWWvM+OBz
KJXAl4tn486ta1j/4y8Y/877aNnOD0GBx3Ey+CGatmyHvNxcnD4TCJFIhMDA c3iYooCFXIGQy2HI
z89Hq3Z+SJbU0NRZq34jTJmzCI7O1bBv92bs2bURJ06exqipnxocH8Vfl1V2 ucZX4mD0OZcVt8XP
58efvkZOTg46+PfAW7MXIeTSGXy1ZC7Oni05/kLLLk+cGNpf6rYJiSNDxu3H 3euRmZkJzyYtMfPD
FcjPz8eXi+fgXniY0dfcroPBWjOOo7NRrnMoS7suLyMkJAT7/w2Ek2cnzfY/ D58BALTv0r/U+BYy
DsbGaNG68/PzEBP5CDs2rQYANGreVvO+ofenoveYMTOW6exrIiIiIiIieja5 QF34EEKq8iZO/QC1
6npAobDE4NFvAgCSEuM07wedOwEAmDDtAzg4OsPO3hFjprwHALhw+kiJ8l4Z Ng4WFvJyH6+PpaU1
ANVDty6eOYp2Pl2x62Awvt1xSO9xq77fi50HrqBB4+Y4ffRv7Ni0Clu+/QwA kJGeKqju8W+/D1f3
mnByccPrb6naH3o5sMzzD710FgAw5s05cHJxg7OrG8ZMmQsACL54GgDg498T AHDl/CkAwNUr55CR
noouvV5BdnYWgi+qEmrXC79u792pe4m2Va9ZFwqFJQa8Ng4AkJaabJL4KKvs 8o6vsedcVtwWFxas
Kmfo61NgaWUN3y69setgMHb8E2TwNWFMnJS3v4TEkSHjdvXKeVV5U+bCycUN rm41MLawPFNcc6Y4
h7L4dO4JsViCc6cPQ6lUAlA97O/cycMQiUTw7dq71GOFjIOxMTqyj5fmv9H9 2mPOpMG4cv4UpDIZ
ho2ZUu77U/F7DBERERERET3fuAY0VXl16jfS/Gxrp5ppp07mAEBsTCQA4J3/ K5nMiYp4UGJb9dr1
tF4berw+I9+Yjh0bVuH86X9x/vS/cHGrgWkLlqNhk5Z6j0uMj8UXH0/D/fAb 5e6n+g2baX6u20DV
Z3FPo8s8/7jY6MJjGmu21fNoAkD1NXsAaOvbBRKpFFcunML/vTEDF07/C6lM htfGvYNT//6F86cO
o4N/D4SFXIRIJEI7365addSu56n52dLKusQYGqOssss7vsaec1lxW1x83BPV +NSqa/Q1YUyclLe/
hMSRQeP2JEpVRtHyGjY12TVninMoi529I1q06YDQoECE3whFo2atEX4jFPGx MWjaqj2cnKuVeqyQ
cTA2RosSiyWwtXdAo6atMXDEBK11wQ29PxW/xxARERERERlrRO/W2H0ohB1h JkxAU5Uns7DQ+36B
sqDU9zIz0kpsKz4zz9Dj9enc42V07vEywkIv4bsVHyH2SRQ+nTsJU95bDN/O vUo97oe1n+F++A24
1aiN9h27oXY9T3g0boH3Jg8RXHfxh5wBgEQiLfP8dSUulcX6xNrGDi28fBBy 6QyeREXg0tnjaNqy
HZycq6Fxcy9cPn8SyUkJuBcehsbN28DOwUn7RiaTme8mWUbZ5R1fY8+5rLgt 0c6CfJNdE8bESXn7
S0gcGTJu+fl5Zr3mTHEOQvh164vQoECcO3kIjZq1xrmTqpnZnQL6Gh23xsao 0AcCGnp/4uxnIiIi
IiKiyoUJaKIyOLu44WlMJNbuPAxHZ9cKP16XZq3aY+k3u7Dvlx/w589bsO6L D/Umw0IKv/q/aPWP
miRRxIM7BtX5+NFdzWzNe7dV6+S6utUo8ziXatXxJCoCD+7d0swafXD3lqZv 1Hw690TIpTPY9/MW
pKUmw8vbHwDQxqczblwNwq9b10JZUIAO/j1emPioyHN2dK6GuCdReBL1GDXr 1Ddbf5QVJ+XtL6Fx
JJSrWw3ERD7Cw3u34FlY3qN7t012zVXEOQCqZS82rfkU508dxujJs3H+1GFI JFL4+PcySdxWRIya
4v5EREREREREzy+uAU1UhtbtVQ/3+v7rJUiMj0VWVib+2P09Rvbxwv9mjTP7 8UW9Nbw7RvbxQuCJ
g1BYWqFZq/YAACtrG73HqWelhlw6i5ycbNwPv4Fvli8wqO4f136OxPhYxD6J wo/rlgMAvLw7CT7/
betXICHuCeJjn2Dbd18AAFq27ajZr13HbhCJxTh1ZH9h2apEV1ufLgCAI//8 DgBo7xfwwsRHRZ6z
Olb+2LUJ2VmZuHD6iGZ93pzsLJP1R1lxUt7+EhpHQqn7evuGlUiIf4qEuCfY tn6lya45tdSUJLOd
g6odtmjdvhMS4p7i4L7dSIh7ipZtfWFjZ2+SuK2IGDXF/al4XxMREREREVUl B/f8Iei/iiqnOINn
QH/6/RFALIVSJAEkFoDYApDIALEFlFI5RBILQCyDUiQFxBJ81M/mhRjIvLxc SKWyKnMu65fN0Pz8
5vwvBb/3Iho0ciLOnTqMoMDjCAo8rtkuEosxbMzbZj++qHZ+ATj6929Ys3Se 1vauvV7Re1z7jgE4
fXQ/1n6xEGu/WFiufrC0tsbb//ffrEo7e0e8PGxcmccNHD4egccPIDwsBO+M 6qPZbmvviCGFD7hT
l9esZTtcD7mIau41UaNwndeadRqgmntNPI2JRD3PJoJmXVeW+KjIc37ltfEI PHEQp4/ux+mj+zXb
3WvWgYVcYbL+KCtOyttfQuNIqAHDxuLk4T9x63qwznWQjb3mrG1skZ6WipkT XsGmX0+a5RzU/Lr1
RVDgcfy2bZ3qdRnLbxgyDhURo8ben3T1NaB6CCIgfCkQIiIiIiKiymzLuo/1 vj9+yieCyvluzft6
339r2mcGt83gGdAF1X3w2uTReP2tUZj09muYPnUIFswchCVzXsaauX2xaUEv 7PwwAHs+6SKovPAb
oVj03kSMfcUHG79cpPOhZs+D96e8pvU68tF9vDOqNwoKtNfRVCqVmDamH+6H h2n++DUF9UzFkX28
MLp/e8x/ZwTu37lhknMpzbFjx3Ds2DGthPP6ZTM026sKJxc3LFr9I7w7dYel lTUkUik8G7fAvMXf
oLlXB7MfX9T/TZyOLj0HwM7eESKxGI5Orug/dAyGjH5L73Hj3pkH3669IZcr IJNZwKNxC0xbsNyg
uidN/wgNm7WGVCZDs9be+GjFZjg4Ogs6/09W/4i2Pl0gV1hCLlegXcdu+HTN 9hJf/e/QuSeA/2ZZ
qrXx6QxAtdzAixYfFXXONevUx4Jl36FBo+aQSKSwsrZFu47dMG/xNybtj7Li pLz9ZUgcCR23BcvW
wbNJS0hlMri41cCEqR8A0F4/urzX3Kv/NxkKSyuIIDLbOai19e0KC7kC6Wmp kFnI0b5jgEnj1twx
auz9SVdfExERERFR5ZCekY7b98PL/b4p6hDq9v1wpGekm7UMU9RhrLemfab3 v/IQ7ToYXOKpSNXl
SYjOdtB5gGoGtAQQSVUznSVy1QxoiRyQWEApkUEkkkEpkQEi/TOgH9y5ic8W voMJUxegdTs/JMbH
YtOaT+HdqTv6vDLiubogRvbxKjGLatGciRg4YoLmq8wAcO3KeezevAaffr3D bPXn5+Xh2ME9OPL3
b1j27W6TnEtx6kSzWkCAKqFRfJu+GdD64oiI6HmTlBCHKSN7wsnVDd9uP8gO ISIiIiIiMpOMjHSk
ZaQiKycNd+4/RPdOPQx63xR1FDWid2vsPhSit7yjZ47As35dKCxsYGNlCysr a4PbVFYZ5a1D6LIY
fV4dVGY5QmZAl1ZOablAg5fgWNg7HK2GrxO0b+hPUwCUPkts70+bMXzcu+hQ GADuNetg8syP8dv2
7zT7pCYn4etl83Dj6mU0bdkW0xZ8rlnbcmQfL4ycOB2H9v2EpMQ4TF/wuWYm VkzkI6z8ZCYS42Mx
Zc4itOvYDQCQnpaCNcvex42QS2jaqh2mL/gcVja2mvKmf/A5Nn65CHXqN8LM D1fAzsFJM5O5eOK2
Z/+hOH5wr1YC+vjBP9BzwGsl9i+t3pnjB2D+0nWoVr0WHty5ifnvjMCiL7ei YdNWiImKwGcL3saX
P/yp1W8SqRSdew7Aj2s/12y7c/MqNn+zDBH3w2FjZ48R46eha+9XNO14bew7 OHv8AB4/vKvzXIp7
c/6XCAgI0CSci894Liv5TET0PBv3ii+ys7Pwztwl6NC5J9JTU7B1vWo9Zo9G zdlBREREREREZpCT
k4W7D+/B3tEWtWvXgpVlPTyIiBT8vinqKC+pVIrmLVogIzMTERGP8TDyITzq NoCFhcJkZZS3jrIS
y89auR9C6GJR9n9luXE1SPMVXrVq7jUxZc5izesdm1bBp0tv/LA3EN7+PbBj 4yqt/ZMT47Fy0x5M
X/A5vlo6V7N91/dfoUe/IXhv0RqtB0vt+v4rjH5jJrb8cRYBfQfj5x+/1Sov NCgQ63YdgV9AX+za
vEZ1TGGitnjCtkPnnrgdFoL0tBQAQEZ6GsJCL8Gva8n1N0urt7W3P65eOQ8A uBZ8HnK5AteCLwAA
Qi6dQWtvvxJl5eZk48j+X1HXo7Fm23crP8KgEROwec9pDB/3LratX6F1jJOL GxZ/ta3Uc9FFnYQu
jslnIqrs1MtKfPv5Bxg7wAdv/18vnDtxCDKZBV4dOYkdREREREREZEIZGem4 fPUKgmPjIG/QCNU8
myAlV4nr9x8jLi6+zPdNUYex4uLicf3+Y6TkKlHNswnkDRohODYOl69eQYbA ZTPKKsMUdTyPDJ4B
nZ0vNWhfuZ7301KTYWvnqLeMKxdOY+yUeZBIpegU0A+/btWefT141GTIFZbw 7tQd+Xl5mu03rgVh
0syPYGNrrzWDOCjwBMa/uwASiQQd/Htg2/oVGPfO+1rlWcjl6BTQD79v36C/ 86QydAroi7PHDqDX
gNdw5tjf8O3SGxbykmddWr1e3p1w/OBe9Og3BNeDL+KlwaNxPfgCXh35BkIu nkHP/kM1ZahnYstk
Fqjn2QRvzvqf5r0VG/dofu7c42WsX/U/rfq9O3WHwtKKdzwiIgBvTP8QTi5u CDx+AHFPYyBXWKJJ
izYYNuZt1G/YlB1ERERERERkIo8e3cPBs2eQ2Lw7XGXV4RyXgVsPo5GZEI/E +HhEhYUhPjW91Pfj
Hjwyug4hZZQl/MEjJEpD4OjsDEsnZ+RaOyJeVgOxECFo3+/o49cJdeo0MKqM mIiHSJTaG1XH88jg
BHRWjmpqsxgARIBIqfo/ACgLV5MWif7bV18C2s7eESlJCVoPX1IqlUhPS4GN rWqZjbSUJFgWrndi
aWWF1JRkrTKsbex0lp2emqLzvZTkBIzu107zWizWngTu7Or2X12pSWX2R/d+ Q/HNZ/PRa8BrOHFw
L96et0TnfqXV26yVNzZ+uQi5uTl4cPcmps7/DFNf74uM9DTcDgvB9A/+W2ZD 36zllOREHP7rZzy6
F44Hd2+WeN/K2sbg4Ci+DrTasWPHOAuaiCo1Cws5RoyfihHjp7IziIiIiIiI zKhOnQZ4VWGFI6eO
49y5bMTJXSAFkJ/0FLmJcaiWk4IpY3vpeT/WBHXEGn0eUVFRCI7LhczRBRKH asgD4JIdB18nOXp0
7wWXau5Gl7H4q1UIO3fZqDqeRwYnoDNyCtckEUGVeFY/dL5oIhqqJHR6tgL2 espq2rIdgi+cQsBL
gzXbwm+EYt0XC7F6i2rWso2tPbKzsyCXK5CZng4bOztB7bS0skFmeppmfWc1 a1s7rNv5LyRS3aee
kpQIe0dnZKSnwcHRpcx63GvUhpWVNc6dPAyFlTVq1Kqnc7/S6rWQy1G7XkP8 +9cv8GjcAlbWNqjn
0QT7ft6Ceh6NIVdYCjrfzxe+i7a+XRHQZxBc3GvgvUmDjQqMsh5CyCQ0ERER EREREREJ4VLNHcOH
jED3mEicOXcGgfci8MjCBmhQD6LonDLfN0UdxhLZ2wPV6yE3OQHV426iY4Pa 6OTbE67uNU1Whinq
eB4ZnIBOy1LNgJaKoco0q6lfF0lIp+fI9ZbVb/BofP7RNNg7uaBlGx9ERz7E xi8Xod+Q1zX7tG7f
CVfOn4S3X3ecPXEAXu39BbWzcXMvnD/9L2rV9cC3yz/QLMPRxrszHj+6h1p1 PXDy8D4cO7AHi77c
qjlu389bMGLCNJw5+g/a+/23/rFYLEZqchJs7Us+ybFH/6H4/uslmDj1g1Lb o69eL+9O+H3nBgx7
/W0AQIs2Pti7+3sMGf2W4HF5/OgeJk77AG7Va2vWri6NvnPRpWiiueiDCYmI iIiIiIiIiIRyda+J
QYNeg19MJC4FX8TRJ0+QJCsQ/L4p6iivNFkBahYkoLunG9p7vYxq5UgKl1WG Keow1lvTPjN5mQYn
oNPVM6CB/5LNaqLCTSJAKQLSs/UnoD0at8DkGR9h95avseqTmbBzcEK/waPR 6+XXNPuMnjwLXy2Z
i7WfL0TT1u3x7tylgto58o0ZWPnxdKSlpeDt9z7VbB81eRa+WfY+wq4GoUbt +pg2X7tTnVzcMHlY
N7Tw6oC35/63nEYbny54Z1RvbP3rQom62vt1xx+7v0d7v+6ltkdfvV7e/vhx 3edo1b4jAFUC+ucf
v0Wr9n7Cg2P2Inzz2QKkpiZh0Ig39O6r71znykqoAAAgAElEQVSKUs96LjrL ubQHExIRERERERER
EQlRzb0m+vWtiY4Jcbh27bLB75uiDkONbeeDFi3awtHJxWxlmKIOY/R5dZBZ yhXtOhisLL6xujwJ
0dm6Z8cGnjiKN+fPRCNr1ZrP6oRz0dnQysK1oed8uBq+XbtXmuAf2cdL7zrL ZBh9cURERERERERE
RPQ8GNG7NXYfCmFHGKm0XKDBM6Bz8qT4evHXAveWsueJiIiIiIiIiIiIqiiD M8Rde3R5YTuDs5+J
iIiIiIiIiIiITEfMLiAiIiIiIiIiIiIic2ACmoiIiIiIiIiIiKosrv9sXkxA ExEREREREREREZFZ
8CmBZFbV5UnsBCIiIiIiIiIioiqKCWgym+hsB3YCERERERERERFRFVDaRFQu wUFERERERERERERE
ZsEENBERERERERERERGZBRPQRERERERERERERGQWTEATERERERERERERkVkw AU1ERERERERERERE
ZsEENBERERERERERERGZBRPQRERERERERERERGQWUnYBERERERERERERPSvT 7zBF+Tz6yjPPJOVI
GShEFa8gPRlia3t2BDGuiYh4zyMiIiKqUkpLag5LvM7OeY784tjcZGWZNGv8 5O3mHB16ZkQiEQBA
qVRW6LGGlj179mysX78eaWlpz6xNFT0WZ8+exfz58xEUFIS8vDw0atQIoaGh L9Q5v2hjaK64rsr9
+yLHA69TxkFVo+ueV5G/SzCOiIiIqLJyW8skc1XEactEFWzVqlVV7pyHDRuG qKgozevY2FgGAuOa
iIj3PCIiIiKiKoAJaCIzUygUmplKVUXxGVnq5PO9e/dQr1495OfnMzBesDEm 9hkRr3Fe40RERERE
uojZBVTVXLhwAX5+frCwsIC/vz+io6N17hceHo5BgwbB1tYWdnZ2ePXVV3Hv 3j2tfUQiEUQiES5d
uoSAgABYWVnBxcUFU6ZMQXp6OgCgadOmaN68uWb/osca+oftm2++CWdnZ3zy yScmbefPP/8MkUiE
4cOHax23b98+iEQi/Pzzz1rbO3XqBJFIhJ9++klnW9X1FT/PBg0aQCwWQyo1 7t++AgMD0blzZ8jl
cri7u2PGjBklln74448/0L17dzg4OMDCwgJ169bF9OnTS3xduqzxM7YdAJCa mooxY8bA1tYW7u7u
mDlzJjIzM83a3sDAQHh7e8PCwgIeHh74/vvvtcZF7dGjR3jttdfg4OAAOzs7 DB8+vNRrQsgYC4lr
If0mJK6NvW5PnDgBZ2dndO/eXdB56tuelZWF2bNno2bNmpDL5WjYsCEWL16s 9Y8txY8xx3gWJ6Rd
hvZbYmIievXqBblcjuHDhyMvLw83btxA+/btIZfL0a1bN0RERJgkzkwdL0Lv /0LaK7RvSxMTE4Ou
XbvCysoK/v7+uHjxIgDg1q1bkEgk8PT0LFHW7du3IRKJ4OHhUWbMxsXFISAg ABYWFvD29kZgYKDg
60BofwqJS331GHLfMzTujInXstpV2j1P1zVpqs+r0hgbL0REREREFUG062Bw ieka1eVJiM52MKig
6XekXAOanm0wC1gP8e7du/Dy8tL6oy4gIADHjh3TOjYyMhJt2rQpsVSEu7s7 rly5And3d606bW1t
kZqaqrXvpEmTsGHDBowZMwZSqRSbN28u8YepvrYWPZ/8/HxMmDABW7duxaRJ k7Bu3TpIJBKTtXPV
qlVwdXWFQqFAbGysJkE8ZswYbNu2DcOGDdMkodPT0+Ho6AixWIzY2FjY2trq bbuuBFlp5y1kDG/e
vIm2bduWSOAOGjQIe/bsAQBs3boVY8eO1Xn866+/jq1btwoeP2PaoS6/b9++ OHDggNZ+7777Lr7+
+muztPfBgwdo1apViX2K939CQgK8vLxKJF8aN26My5cvw8rKSlB8GhLXQvrN 0Lgu73Xbtm1bXLly
BePGjcPmzZsNisni26dMmYLvvvuuxPELFy7E4sWLdR5j6vHURUi7DO23YcOG 4ZdfftHst3LlSqxd
uxZ3797VbBs4cCD++OMPo+PMlPEi9P4vtL1C+lZfTBWtWx0HISEhqF+/PgYP How9e/Zg165dGDFi
hFZfz5kzB9OnT8eXX36pt/yhQ4fi119/1Wy3trZGcHAwPD099V4HQvtTaFyW Vo+h9z1D4668xwlp
V2n3vOLXuDk+r3TVZUy8EBEREVU0t7XXdT6EcPodKR9C+Jz5xbF5qQ+MLE1p OWXOgKYqZdWqVUhL
S4O/vz+ioqLw8OFDnX88f/bZZ4iNjYWfnx8eP36MiIgI+Pj4ICYmBkuWLCmx f8uWLXH79m2kpaVh
4cKFAKD1x6U6uVU0UST0q7p5eXkYNWoUtm7dioULF2LDhg2QSCQmbaeNjQ36 9OmDpKQknD17FgCQ
k5ODP//8E2KxGH///bfmD+jTp08jNzcXPXv21Jl81pccUyqVRn9FefXq1cjM zMSQIUOQkpKiSYz/
9ddfmn2WLl0KAFi7di0yMjKQlZWlSfT8+eefBo2fMe1Qi42NxfXr15GWloZp 06YBAH7//XeztXf1
6tVITU2Fr68vHj9+jAcPHqB9+/Ylylm+fDkiIiLwyiuvICYmBrGxsRg6dChu 3bqFb7/9VvCYGBLX
QvrN0Lgu73FNmjRBRkZGqclnQ+zYsQMAcObMGWRnZ2sSXj/88EOZx5pqPMvb LkP7LScnBwkJCfj+
++8BAAsWLECHDh2QnJyM9evXAwCOHz9ukjgzZbwIvf8Lba8xYw4AycnJuH// Ph4/foyOHTsiNTUV
K1asAADMmzdPc25Fqe8HAwYMKLP827dv486dO5ry09PTsXr16jKvA6H9aWhc Fq/H0PueoXFX3uOE
tEvoPc8cn1e6mCJeiIiIiIjMiTOg6cUJZgGzZ5s0aYJbt27hwoUL8Pb2BqBK qHbu3Fnr2EaNGiE8
PBznz59Hhw4dAADnzp1Dx44d4eHhgTt37mjVGRQUhLZt2wJQLbdgZ2cHsVis 86vYQp9cr95v0KBB
+OOPP/Dll19i+vTpWvuYsp3btm3DmDFjMHfuXCxfvhx///03+vfvj/Hjx2PL li347bffMHjwYLz/
/vtYvnw5Nm3ahIkTJwoaC0PPWd9+6nO+du2aZmkTXZRKJYKCghAcHIzQ0FAc PXoU169fh0gkQkFB
QbnHz5B2qMsvGm/x8fFwcXEpUb4p29u8eXOEhYXh3Llz8PHxAQCcPXsWnTp1 0urfZs2a4caNG4iM
jESNGjUAqGaT1qpVC76+viW+sm+KMRbSb4bGdXmv2+DgYLRu3bpcMVl8e82a NREVFYWhQ4di6NCh
GDRoEORyuaA+M9V46iKkXYb229WrV9GiRQtkZGTA2toagGp2cYMGDZCZmamZ IWyKODNlvAi9/wtt
r5C+1RdTZ86cgZ+fHwDg/Pnz8PX1haenJ8LDwwEA3bp1w4kTJ7B//37069cP iYmJqFatGqysrBAX
FweZTKa3/KNHjyIgIECr/EaNGuHWrVt6rwOh/Sk0LvVdb4bc9wyNu/IeZ2i7 ih5X2j3JlJ9Xpd1z
yxsvRERERBWNM6ArD1POgGYCml4YQhJgVlZWyMzMRFZWliZRUPSPUvWxCoUC 2dnZWvtlZ2dDoVDA
wsIC2dnZWnVmZ2fDwsJCUFsMTcaq/e9//8PHH3+stc2U7UxKSoKbmxsaNWqE q1evYuLEidixYwfu
3buHunXrYtiwYdi5cyd8fHxw6dIlxMTEwNXV1aTJSUPGMCcnp9Q/qKOjozFg wAAEBQWV+sd+ecfP
kHaoyyk6PrrKN3V7ra2tNTPp1PVmZWXB0tJSaz9LS0tkZWXprNPBwQGJiYmC x0roGAvpN0PjurzX
bWZmJhQKRblisvj27du3Y86cOXjy5AkAoF69eti9e7cmMaevz0w1nroIaZcx 9xH1tvz8fIjFYp3t
NybOTBkvQu//QtsrpG+F3hfU41m0vf/88w/69esHf39/nDp1Cjt37sSoUaO0 lkTSV35GRoYmRtT9
YWlpiYyMDL3XgdD+FBqXpdVjzH1PSNyV9zhD26UvAW2Oz6vSXpc3XoiIiIgq mqkT0KKsWEjiL0CU
GQNABKWlO/JdO0Jp4VjmsbLbqm/E5TZ60yT7IT8LkrhzEKU9gqggCxDLUWDp jgKXDoLaYyqC21sG
LsFBVE661iPW9UA8XQkd9SwkXYomj0xt/vz5sLW1xdKlS3Hjxg2ztdPBwQE9 evTAtWvXcPfuXezd
uxddunRBjRo10KlTJ/z11194+vQpgoKC4O/vX2ry2dyEPOBr6tSpCAoKgqen J2bPno0tW7bg+vXr
Jh0/oQ8aA1DmrEhTtzcvT9gHhL5YSUlJeWbjZ2hcl/e4spLPpZWtTsAVNXr0 aMTExOD48eOoX78+
Hjx4gO7du2utwWvu8dRFSLtMcR9RJ/NMHWemjBeh93+h7TVmzIW056WXXkKr Vq1w+vRpBAYGGryc
gnqppqLnVHRbadeB0P40NC6L12OK+56+uCvvcYa2q6I/r0pjbLwQERERVcoc T04CpI/3AXmZyK07
HHl1XoUoJwXSR3uB3NQyj89t9KbRSVqt38FjjkGcfAsF1Xsi13Mi8t26QJz2 AJKog1V+rJiApiql
bt26AIArV65otl29erXEfnXq1AGg+sqwmvrnWrVqVWibly5dikWLFiEnJweT J0/WSg6Yup1DhgwB
oFoDNT4+Hv369QMA9O/fH6mpqfj444+Rn5+PwYMHP7MxVH8lvugDpIo7eFB1 cz979ixWrFiBcePG
Gb32dHnaIZSp21uvXj0AQEhIiGZbaGhoif3UMRIVFaVZn1v9nyEJdlP3W3nj 2hzXrTpJWDTxqOue
oda1a1dcunQJ8+bNQ0ZGRqkPFzPHeOqjr13mvt8ZE2emjBeh939D21veMQ8L C9P8fOnSJa2xVps7
dy4AYM2aNThw4AAkEonmvlyWojGiPmcPD48yjxPan8bGZUXcp5/1/biiP6+M iRciIiKiykgSHwQU
5CHfxQeQ2UBp4Yj8ah2BgmxIEy4DUM0GVs8ILv5a6z1lASRPz0J25wfIwjdB 8vhPIFfHhJncVEjv
74Ts7jaIir0vzohU/ZAZA0CMApv6yG30JvLqjShSxxlI72yB7O4PkDw9AygL l1zLSYY0Yh9kd76H
LHwjpA9+gSj9sVY7pZH7IX20R3B7RekRkD7aA9m9HRCnP3qmY8UENFUp/fv3 BwBMnz4dERERiIqK
wqxZs0rs17dvXwDArFmzEBkZicePH2PmzJkAgF69ehnVBnVCKz4+XvAxU6dO hZeXF06fPq15aJI5
2jlw4EBIJBJs374dgGpGFQC8/PLLAICNGzcCUK1L/ax069YNALBkyRJkZGTg 999/h0gkgkgk0jwo
Ud3HBw4cQFZWFi5fvoxRo0ZVeDsMjQlTtVc9brNnz0ZUVBQiIyP1xvmUKVMQ HR2N9PR0LFu2DCKR
SLMurqnjWki/lTeuzXHdVqtWDQCwadMmpKen4/r163j77bdL7Ofu7g6RSISf f/4ZNjY2mvO0t7c3
OtaEjqcuQtplzvudsXFmyngx9P5fVnuNHfPp06cjOjoaDx8+1Kzvrx5rteHD h6Nu3br46aefkJSU
hI4dO8LZ2VlQ+TNmzEBUVBQiIiI0/aHuAyHjVVZ/GhOXFXWfNuYzuqx2Cbnn VfTnlTHxQkRERFQZ
iTKiVT9Yumm2FVi6q35QJ4MFksRfhDjpKvJcfZFX+xWIM6IgjT6ivVNuCqQR e4GCXOTVHgClzE7r
baXcWVOW9NFvEGdEadeREARx0jUUuHZEvqsfxEnXIC5MlEuij6DAvjlyPcYj r/arEOUkQPLkuNbx
BfbNkF/zJcHtFac/QL6rH5CXBsnTs892rLgGNL0wNx4Ba9A+ffoULVu2xNOn TzXbXn75Zc0T6dXH
RkZGwsvLC3FxcVrHu7q6IiQkBNWrV9dbp762ODk5ITExEU5OTnr/cC1exvnz 5+Hn5wdbW1uEhYWh
Ro0aZmlnjx49cPToUTRo0EBr1paHhwfu3buHtm3blrpWZWnlmnIN6Js3b6Jt 27YlkrxFH671+uuv
a5LoupTVLlO1Q2j5pm5vZGQkWrRogaSkJL3lRUZGok2bNoiNjdX+UJRIcPjw Yc0DzISMldC4FtJv
5Y1rY68HXd566y2tf/QBgHfffRfffPONVhlvvvkmNmzYUOL4+fPnY+nSpQZd F+UdT12EtMuYfhOy
zZg4M2W8GHL/F9JeIX2r79opWjeg+seO0NBQuLm5ae3/9ddfY9q0aQCAzz77 DPPmzRN0H23bti0u
X76s2e7m5obQ0FDNP6qUFn9C+1NoXJZWjzH3PSHbynuc0HbpuucVL8ucn1el 9au+eDHk3kdERERk
LqZcA1oWvgFQKkssoyG7vR4QiZHbcFKJ9ZCLvi76s/Tedojy0pHnOR5KsUXJ 8gBAagPkpSHfrSsK
7JuUbFBuMqSRByHK+e85N0rreshz7wxIrDR15HqMBUQSyO5shlJmh7z6I1W/ r2U9hSjtLsRpjyHK
SQBEIuQ2nPxfOz3HAWLVEp9C2pvrOQEQSVX9VNgfhuAa0ETlVK1aNRw7dgyd O3eGTCZDx44dSySX
AKBmzZo4c+YMBgwYABsbG1hbW2PgwIE4f/685o/v8lq4cCFsbW11rv+pj4+P DyZPnozk5GS8++67
ZmunehmO4jPx1DPnXn311Wc6hk2aNMGhQ4fg7e0NmUwGBwcHDBw4EPv379f6 A3z48OGwtraGQqFA
hw4d8NNPP1V4O4QydXtr1qyJQ4cOwdfXF3K5HPXq1cO6desAaK9HXbNmTZw9 exaDBw+GnZ0dLCws
4OPjg/379+tNChoT10L6rbxxbY7rYeXKlZgyZQqcnZ1hbW2Nt99+GytXriyx 3/LlyzF27FhUq1YN
EokENWrUwJw5c0o8ONSc46mLkHaZ835nbJyZMl4Muf8Laa+xY75hwwb4+flB LpcjICAAJ06cKJF8
BoDx48dr1jE2ZD3fX3/9FV5eXpDL5XjppZdw6tQpTfK5rPES0p/GxGVF3afL Q2i7hNzznsXnVXnj
hYiIiKhSEhc+ZyT/v4eIi5SFy+aJSj7/BHr+IV6Ur3pYt1IkK72+fNWDBUWp 4brfl9kjr+5Q5Ffz
g1Kqeti5KP0BpFH/atUhu/sjZHc2q7blpalOJTEU0kd7IM5ORL5bF93tFVkY 1l6xDFD/vqoseKZD
xRnQRERVQExMDKpXr47atWvj0aNH7BCOJ1US+/fvx8svv4wmTZqUeBCtzl/s nuEsV8Zl5YsXIiIi
oopmyhnQ0qjDEKXdQ16NXlDaNIAk6hCUtg0giT4CpaU78moP/G+WdMNJQEE2 ZHe3Aih9BnSuxzhA
oj2hQr1ffq3+EGVEQZxwBXm1X4HSUs+EnYI8SJKuQhx3ARBLkes58b86PCeo ksNF67izWbW0h+d4
KCHSJKiLt1Nz7gLaq2vWtyE4A5qIiEplY2MDkUiEHTt2ICsrC9HR0ZgxYwYA wNvbmx3E8aRKIDU1
FTExMfjkk08AAHPmzGFcUqWNFyIiIiJzyHduC6VIAmnsOdWSFXInSArXQS6w b6baSWoLQLW8hSTh
SqllKe08AQDitPsQZz1RPfRP/cC/QgVWtVBg31S1X/ylEmVIH/wC2e31EKfc BURiFMhdVGUXJqoL
7FQPBRen3oYoU1WH5PGfqn3Uy2hkJUCcXPZEAiHtfZ5IGa5ERC+WIUOGYOvW rRg9ejRGjx6t2a5Q
KPDBBx+wgzieVAnY2f33QBMvLy+MHTuWcUmVNl6IiIiIzEEpd0Z+nYEQx16A 9NEfAJRQWroB2YlQ
Fs4wznftCMnTk5DGHEN+9e5A4lWdZeU7ewP5eRDHBgLKfCitaiLPrWvJOmW2 KLCuC3H6QxRkRmvN
gs6r2QfS2EBInp6C5MkRQKxAgV0j5Lv6AgAKnDsABfmQxF4ElHmqhLZ7N007 pU9OQRp1AAW29cs8
d6HtfV5wCQ4iohdMVlYWFi9ejN27d+PRo0ewtraGv78/Fi1ahLZt27KDOJ5U CdSuXRvx8fEICAjA
+vXrUatWLWG/2FXQEhyMyxcjXoiIiIgqmimX4CiNOCMKoqTryK/Rix1uBFMu wcEENBERERERERER
EZldRSSgyTS4BjQRERERERERERERPfeYgCYiIiIiIiIiIiIis2ACmoiIiIiI iIiIiIjMggloIiIi
IiIiIiIiIjILqSkLc1vLxcKJiIiIiIiIiIiISMVkCWhDn4pIRERERERERERE RC82KbuAiIiIiIiI
iIiInqVfHJuzE15QTEATERERERERERHRM8OVFV5sfAghEREREREREREREZkF E9BERERERERERERE
ZBZMQBMRERERERERERGRWTABTURERERERERERERmwQQ0EREREREREREREWmM 6N3aZGVJTdmwe5f/
5egQERERERERERERVVLDR4wwaXlSUzewQdueHCUiIiIiqpRaW4oRklnAjiAi IiKiSvv7bNPOLY0q
4+6DSJO2iUtwEBEREREREREREZFZMAFNRERERERERERERGYhZRcQET2/zu+Y BZ9RqzQ/FyUSS9DQ
fwwca7dkRxERERFRhf+eWhr1769EREQAE9BERJVK0V/mEyOu4u6Z7fDoNJpJ aCIiIiJ6Zr+XFp00
QUREVBwT0ERElZRj7Zbw6DQa4ae3osPIL9ghRERERPTcyMvJwJ0z25Eacwe2 bh5o6D8GEgtLAKqE
da3WLyH+wRW0enkuzu+YhfreQxBx9QAAoH6HYZBILHD33G7kZafzW39ERJUc 14AmIqrEHGu3hLIg
nx1BRERERM+ViCv7UbfNALQfvgyuHr54HPKP1vsWlg5o3me65nV6cgy8Bn6A +t5D8Tj0INISHqP1
gPlo6D8G4ae3skOJiCoxJqCJiIiIiIiIyKQSH1+Hws4NIrEETnVaIeHxNa33 neq0hEQm17yu3bIP
JFIFHGu1RGZSNNyb+EMik3PCBRHRC4BLcBARERERERGRSeVlp+LCrjma1yKR SOt9iUyh/VpurdpP
rJonJ5Eq2IlERC8IJqCJjJCWkgwbO3uT7UfPbowqq8SIqxCJJRxoxgn7kONO JooJWDqyI4iITEAi
t0LbV/8n+HfV4glqIiJ6cTABTS+MkX28AAC7DgZXSH3b1q/Akf2/4od95wze T2hbK/KcKrr/nqcx
Mve5Fy9f/VofIW1JjLiKu2e2o6H/mGcWUy9C3AiNE1P2h5D9KlPfmrIPK0Ob TXUNmyt2ymv/b9tw
OywYMz9cWe4yVi2ahcbN26D/kNcr7b3gyuELL/RnIxFRRXGs3gyZyU9gae+O 2HsXEXv3nNaaz0RE
VHUwAU1UTn//vt2k+9GzG6PK5PyOWZqfRWIJnwjOOGEfctxN4vL5k/h9xwas 2Pi7UeWMe+d9zHlj
MKrXqou2Pl0YE0REVVjtdgNw9/Q2pDy9B4VdNTT0f52dQkRURTEBTfQcq8gZ V1V5dtezOnch9fqM
WqXzZ2IsEcfbVJIS47H2i4UYOHw8HJ1djSrLybkaBgwbi7VfLMTKTX/A3sGJ Y0xEVAXo+j1VJrdB
kx5TBO1v6GsiIqpcmICmKiUnJxs/bfkagccPIiUlES7VqqNLzwEYNGIixJL/ 1iaLexqN7RtWITQo
EEplAby8/THmrfc0f5gX/fr1yD5epf6BWtZ+mRnp2PzNUlw8cxQKhSX8Al7C iPFTYSFXaB2vPk5o
+9WiIx9i1oSBcK9RB6u37Cvx/vSx/fE0JhILl2/Ap/Mml/hjW18/BJ44iDVL 58G3S29M/+BzzTGX
Ao9j5f9mYNqC5ejYtY9m+0czxyI8LATT5i/HmmXzAADrfz6GLz99D7evB6Nu g0YY+/Y8NGrWWquN
F88cxYG9u3A//AZysrPg4OQCb78ADB8/FQpLK61++vCLTVi1aBbqNmiMsJCL gsZIVz+rX3/69Q7s
2Lgad25ehVyugG+XXhg1eTYUCssKjdvoyIfYsXE1rl05D5FIhBZtfDB68my4 Va+l97g7N69i63df
4N7tMHg0boEZC7/QuV9Z8V5aH3/4+UaDzkPfWCbEPcWcSa/C1b0mVn+/Vyue ox8/xKyJA1HNvSa+
+nG/4D4p7avzRbcLuZaNvY6EjsOL3IdF3Q4Lwc5Nq3Hn1jXY2NihY7e+GD7u Xb3XszrWhMSqkPuG
vjYLreNFuoZ3blqNvNxc9Hx5mEnuWb1fGY69u7/Hzo2rMeW9xWXu/7zFRLMu rUp8HpTn8+F2WAh+
XLscD+/dhrOrGwaNfAMbVn+i85oiIiIiInqRMQFNVcq2777Av/t/1bx+EhWB X7auRV5uLl4b9w4A
1QOIPp41DgmxTzT7nTt5CA/v3cKyb3dDbsLk41dL3kPIpbMAgOysTPyzZwfy 8/Mx/p33y93+oqrX
rIvmXh1wPfgCboeFaCV3b18PxtOYSNSq64HmXh1KHFtWP7Tp0BkymQVCgwKR n58HiUR1Ozl/6nDh
///VJKCzsjJx79Z1SGUyeHXw15S3ec0S3Ai9BAC4Fx6Gpe+/ic/W/Qz3mnUA ACcP/4l1Kz7Uald8
bAwO7N2FtLQUvDN3iXb/rF+B9NQUuLrVMMn4fDp3ErIyMwAAuTnZ+Hf/rygo KMCkGR9VWMwmxD3B
xzPHITU5UbPt0tljCL8Ris/W/gQHJxedxz2JisCn8yYjOyuzMBESjG+WLzB4 nIvHe3n7WMhYtu8Y
gItnj+LcqcPw69ZXs1/QuRMAgLa+XY3qk/Iy5joSOg4veh+qRT66j0/nTUZu TjYAIDkpAQf+2Im4
p9GY/fFqvbEmNFYNvW8Ycz28CNdwTOQjnD6yHx279YWVta1Jxtnaxg5tfLvg 1NH9ePX/Jmnu6ZUx
Jsr7+RAbE4llC6Zo9nkaE6lJPhMREYy7jlsAACAASURBVBERVTVidgFVJaeP /g0A+GTVD9j210VM
L5xNduLwXs0++37egoTYJ2jn2xXrdh/B+p+Pwce/J6IfP8ShP38CoD1zSd8s prL2S0lOxBcbfsOW
vYHoO3AkAODi6SNGtb849Yy2U//+qbX91FHVLMg+A0foPK6sflBYWqFVez9k pKfidlgIACAvNxeX
z52ESCRC8IVTyMnOAgDcunYF+fl5aNnGF5ZW1po6oiMf4sstf+LbHQfRsGkr ZGdnaa3B+cfuTQCA
Ce8uwI/7zmHrnxc0s94unztZos01atfHj3+ex1uzPxE8RvrUrt8QqzbvxZa9 gXh15CTV+Jw5arJ4
HNnHS+d/Re39aQtSkxPRsFlrfLvjIL7ZfhCejVsgOTEee3ZtKrXs/b9tQ3ZW Jho398LanYfx9bZ/
kJWRbvA46+tjQwgZywHDxxee82atYy8XJk/bFSZPy9sn5blGjb2OhI5DVehD APh7z3bk5mSjg38P
bN5zRvPtibKuZ0NiVUg/ldZmQ6+HF+EaPnF4H5RKJVq162jSz9vW7fygLCjA ycN/VrqYCDsZavTn
w9+/b0dWZgY8m7TEtzsOYs3Wv9GgYTP+IkZEREREVZLJZ0C3tmROm54tfTFo a2WNrMwMnNm7A9bd
emF8t+54s7f2H5ofXFAlalbO/RDVXFRf4W00cx4CTv+La2ePYuGYCeWKeV37 fTbnQ7Rs0hAA0PiN
KTiwdxeSEuNK7Kt+LaT9xTXv3gM71jrjwolDWDFrPixkMuTm5eLiyUOwtbHF lP4DYFWkPnVdQvph
aPdeCAo8jsig0xjRwRsngi8gIz0Vr740EHv+2YukkLPo1bUn/r2umuX8arce Wuf2yfR58PGoCwBw
mj4XI98ajdvB5zX7HNn5J5RKJa7fCsPNU//g1t3bOH/5AgAgIz21RD/NeX0C mthblvu+VHy/ZTPn
o5lnfQBAi7ETsGfXRqSlJpf7Pleedty6rJohv3jaXLSqXR0A4DxjHkZOeR03 Lp0uNVbCQ1T9tGja
XLSs5QYAcJg+F6+/O87gcTZFHwsZy9ZtWmNf63a4FBKEpOAz6NqxM5JTU3A7 LBjWVtZ4rUN7yKTi
cvdJWW3Wdw7lvY6EjoOQeKjsfQgAd0NVS+N8MOkdNHS2hW+fvnizT1+d+xaP NaGxauh9o+hrQ6+H
F+EaXhZ8HgDQt3kzNDLh73CKli2wHsDdkPNobTm1UsWEkNgu6/MhvLBfF8+Y h9aacX8fo94Zw9+X
iYiIiKjK4RIcVKXMnjITX3y7AodOHMahE4dRw70GVv7vc7Ru1kqzz+PoSABA t8E9Sxx//9F9k7an
sUcjzc8O9g4AAKVSaVT7S1zkUimG9B+M9ds24viZ4+jdrRdOnTuN5JRkjBn2 OqwK19gsTkg/BPh1
hUwqxYlzpzB7ykwcPnEYMpkM0ydNxb5Df+Hg8cP/z96dh1lRnnnjv5vupiGs R8KugOCCGtEhUUBE
wQmJIgR3ktctxrhL3IjG5R3HTNzmhzqvZnMdd8UYHaMkblFnFBQVXBE1SkSa LQgHWRuku35/EHpo
uhuqu09FwM/nuvqSPlX11FN3PVV9+uvTdWL4gd+OV994NYqKiuKg/YfW/IV+ j//t92479Y2IiPl/
m1/92sLPFsYZPxsb7334Xqp67rhDr4Ken51671z971Z/n7m9qfPTUGlm2c1d MC8iIvrutOv/1mrn
3WrVamPz/r7dhmNs9112a9R5LkSN057LHx/7o3j9ralx6723xYGDhsSLr7wY lZWVsf++g6O0pLRJ
NWnSD8tGXkdpz8NXoYbr2l73qIReO/Rs8PWcdqw29L7RlOthW7iGZ/59nS6d uhT0XK9vb3M/N7f0
MdHYnw9z5s+t8bOtKdc+AABs7QoeQHf5xvaqypdqU2Pw1G+cHqeef3pMmjQp zjrrrPj000/jR+ed
Er/+9a9j9OjRtX6B3NjyFctrtZ92zNe1Xo/+vVOtu/77NP2vy1k/HRu33Htb /GnS03HC2SfFM9c9
F0VFRXHOz86NLjvWva80degSEQcOHRrPPvtsrGr1RTz/8n/H4MGDo9/Q/jFg wID4nykvRnHnspj+
wXsxcODA2H3/mkF5tz17RPPmzSMiYtWqdc85LSktqe7DRSdeGu99+F7suOOO MWLEiNhtt92if//+
sd9++9VZp57f7NOk+9LG6/X4px0Lep9r7NiJiOi8R/coKyurUasoKqq3zWbF zWptt2bNmkad50LU
OO25POYbP4gb7/xVTHvnjfh05dx4Zfq62ZGHjTm81j7S1qTzHt2jqKgoIiJW r17d6PPRmOso7XlI
M262hRpWJVXr1ttj+ygtLd3kuhuPtbRjtaH3jQ2/z+r+vyVfwyv//oziPvvu GsV1fJhtY3WsrKxu
f1N12tLHRGN/PlRWVdY6fxUVFd4vAwDwD5HP5+O3v/5lo7c/5tgfFbQ/BQ+g c7mcs8yXKs0YHDly
ZOy3337x7//+73HttdfGWWedFT/84Q8jImKHHXaImTNnxty5c6Nr164FG/N1 rVffthu/vvH3m+p/
fe2NGDEinnrqqfjwww/jqaeeihEjRkT//v3r3XfaOnz/+9+PZ599Nn77299G Pp+P0aNHRy6Xi8MO
OywmT54cN9xwQ1RVVcWYMWNqHcfs2bPjW9/6VkREzJgxIyIidtppp+r1nn/+ +YiImDJlSnTsuO7P
q6dPn566Tk09R01tr7Ht1whcevaMjz76KGbNmhUDBgyIiIj333+/+hzV12av Xr1ixowZ8cknn8TA
gQMjImLq1KmNPs9NrUlDzuUll1wSxx13XNx5553x3HPPRXFxcRx99NHV66St SVFRUSRJEsXFxdGu
XbuIiHj99dcbfT4acx2lPQ9par4t1LB79+7xySefxOLFi6Nv374NGmtpx2pT 7htZ3P+39Gu4bdu2
sWTJkigrK4s2bQrzIYQREcuWLYuIiHbt2m2yTlvimEgztjd3L9xxxx3jww8/ jE8//TT23XfdB5S+
+uqr3i8DAJC5fD5f/X7zoosvjSRJ/verqmrdfyOJtV+s/fvrVdXLly1dGvfe e0/B++QBdHyldOnS
JYqKiuKhhx6K1q1bx9ChQ6t/QV7v4IPXPXvyjDPOiHnz5sWKFSvi6quvjqKi ohgyZEj1eutnAy5a
tGiT+0y7XqH6X5/TTz891q5dGwMHDoyKiooYO3bsJtdPW4fRo0dHcXFx3Hvv ug8PPOSQQyJiXUge
EXHrres+6Omwww6rtY9zzz035s6dG7Nnz47zzjsvIiIOPfTQWrV78skno6Ki IqZNmxbHHnts6noV
svZflvXn4fzzz485c+ZEeXl5da2GDx9e73br63jOOefE7NmzY+7cuXH++ec3 +jw3VUPO5ZgxY6Jn
z54xYcKEWLJkSQwaNCg6dOjQ4Jp06tQpIiJuu+22WLFiRUyfPj3OPPPMJo2T hl5Hac/DV6WG6+9Z
V155ZaxcuTIeeeSRKCoqiqKiov+dFdzEe1LaOtXV5yyuhy39Gt5tt3WPhfjk k08Keu9a39769rem
MbF48eImH//6n4UXXHBBzJ07N+bMmdPoax+AiC/WVioCQCNVVVVFZWVlVK5d G2vXro0vvvgivliz
JioqVsWqVStj5cqVsXLFilixfHl2nXjgqTeTjb9eeOGFpK7XN/d15dXjE/iy REQSEZtc59RTT61e
b8Oviy++uHqd8vLypGPHjrXWKS4uTp577rnq9XK5XBIRyXbbbbfJfda1Xn19 3fj1jb9P0//6VFZW
Jj169EgiItlll12SqqqqTe47bR2SJEkOOuigJCKS3r1713i9d+/eSUQk/fv3 r3Nf/fv3r9F2586d
kwULFlSvd9xxx9V5vJurU0PPUdr20oyxhra/ZOmq5ICjflNrm/f+siD57nG3 Jbvu/y9J87LWtY69
tKx1suuQf00OP+WuZNq7c6pfX79d3wOuSJq3aFNjm5EjRzb6PG+uJps7R2nP 5Xo33nhj9bJrrrmm
xrLy8vLk61//eq02OnbsmMydO7d6vdNOO63WOmeffXatfaYdJ425jhYsWJB0 6tRps+chzbjZGmu4
8XozZsxIWrZsWavNXXbZZbNjLe1YTVunuvrc1OuhLmlr3dix09Q+X3755UlE JLfffnuqe17a126/
/fYkIpIrrrhik/XZEsdE+/btm/zzoby8PGnfvn3q67VQP28A/tF2Hfr/1fjq 950bkv8z9v5k5qeL
aqyTtq36jDjxDsUGSGnx4sVJkiTJVb/4eVJZWZmsWbMmqaioSFatXJmsWL48 WbZ0abL08yXJwr8t
SBbMn5fMmzsnmVs+Oyn/dFby6Sd/Ta76xc+Tj/5aniRJ0uBsuL5M2QxovlKu vfbaOPHEE6NTp05R
XFwc3bp1i3HjxsXll19evU737t1j8uTJccQRR0Tbtm2jefPmMWDAgJg4cWIM Gzaser3LLrss2rRp
Uz1jqj5p1ytU/+vTrFmzOOWUUyIi4qyzztpsf9LWISLiyCOPrDHja731M/gO P/zwOvfx8MMPx957
7x1lZWVxyCGHxIsvvlg94zIi4qabbooxY8ZEq1atokWLFrHvvvvGhAkTUter kLXPwvyFy+Lknz4c
Cz6r/X8Z75jwWowZtVe89ef/Gz+9/Jboveu+0bp162jVqlX06TsgfjH+3njr 2Utj6KA+ce8j02pt
9+Yzl8QFl/46uvfcPUpLS2PQoEFx8803N+k8N0VDz+VJJ51U/XzwUaNG1erz pEmTYtSoUdU1GT16
dEyZMqXGn+Ffd911ccYZZ0SHDh2iVatWceaZZ8Z1113XpHHS0OuoU6dO8fzz z8eQIUM2eR6+KjXs
27dvPP3007HPPvtEaWlptG/fPkaPHh0TJ07c7PGnHatp61RXn7O4HtLWurFj p6l9PuGEE6K4uDj+
+Mc/FvT+NnHixCgpKdnk46G2hjHRWN27d4+nn346Bg4cGGVlZdGrV6/4zW9+ ExFR/UxogG3F+8+P
q/566ZEzYuA/9YiLr32yxvKm+njWIoUG2IoVPfDUm7U+waVr2ZKYt7p9gxub Oe3ZuORnF6gqsOkb
z99/ud/UB0h9FQw+4tfxk5MGx+XXP1PrjfkhJ9wR99/0g8i1axlzFyyNUy76 fUy886QmLduaTJw4
MUaOHBl9+/atfj44akg2fvSjH8X9998fc+bMqfGolsb67LPPYvvtt48TTjgh brnllq2uHhs+M6+Q
5s+fH127do0ddtghPv30UwMP2Cb0HTa+1vvYitVrY5+RN8U7z5xXa50lS1fF Ty7/Q3w487M484RB
cdUvn6te1nfY+LjuspHxbzf+OZavXB03/MuoGD5k5+g7bHx124UIswG2devf z1595b/FRRdfGpWV
lVFVVRVJVVX14zjmzP40OnTsGEmS1FhWVVUV9957Txxz7I+iT6/u8eDTbzVo 3/VlymZAA3xJHr31
hBgzaq86ly34bFm0bb1ultzXt2sVc+Z/3uRlW4Nly5bF/Pnz44orroiIiHHj /JKhhmTt6quvjlat
WsWNN95YkPZuuummaNOmTfziF7/4yta0devWUVRUFPfdd19UVFTEvHnz4txz z42IiH322cegA7ZZ
X6ytjIeeeDu+sWvnOpffcNtLceCA3vHCQ6fFR598Vmv5+x//LV546NS44V9G xXk/f3zda38PnYXP
AE2XJEm88/ab8fZbb8THH/3lHzYxsETpAb4cnTq0rndZRcXaKC5e9/8IS0uK Y82ayiYv2xq0bdu2
+t977713nHjiiQaKGpKxzp07x+233x4nnnhinHHGGdGlS5dGtzV//vz4j//4 j7jnnntqPFLpq+bI
I4+Mu+++O4477rg47rjjql9v0aJFXHrppQYdsE3ZcIZy89LiGNi/R4y/7NA6 133h5Y/j8Tt+GC3K
SuLMEwbFQ0+8XWP5j3+wb7QoK43hQ3aOtWurFBeggJIkibffeiPyixfFrrvt HnPKZ0dERM9eO2a+
bzOgAbZAZWUlUVm57k332srKaNGipMnLtgbbb799tGzZMkaMGBGPP/54lJT4 /6RqyD/CYYcdFpde
emmMHTu2Se2MHTs2Lr300vje9773la7nzTffHJdcckn07t07SkpKol27dnHo oYfGpEmTon///gYc
sE15//lx8d5zF8RNPx8dPbq1j/GXjYzuXdrVue5n+ZXRpnWLiIjoWMdkjHZt WigoQEbefmNqLFv6
efzz8O/GTjvvEt/ad0As/XxJzPrrzMz37bdS4B/uq/7s5zS6dmoTi5esio4d WsWi/Mro0rFNk5dt
DWbPnu3kqyFfkgsvvLDJbfzud79TyFg30/nKK6+MK6+8UjGAr4RmRUUxfMjO sXDxirj035+Mm34+
us71cu1axrLlFdG2TYtYlF+hcAD/QJ27dou9vvmtqFy77pnQzZoVx557/VOs WbMmmpeVRcWqVdn9
nFB+gC3PXrt3i9//6Z1YVfFFPDzxndhjl85NXgYAAFn6P6P3juUrVsczL/6l zuX/PHin+P2f3o3V
a9bGzfdNSd1ucbOiyH++SoEBmqBL125RVVlVY1JgcXFxlJWVxZrVqzPdtwAa YAv0/VF7xSNPvhv7
jLopnvjzjPjRmH2avAwAALL283Hfjf+4/aWoWP1FrWXn/Xj/eG7yxzHkyN9E t05t42stS1O1eeDA
3nHg0b9VXICtVNEDT71Z62/hu5YtiXmr2ze4sZnTno1LfnaBqgIAsFXK5/OR y+UUAiBDa9dWxaNP
TY8n/jwj7rr+GAUByOD97NVX/ltcdPGlUVm57pEbSVVVVP39K0mqYvXq1f/7 /QbL7r33njjm2B9F
n17d48Gn32rQvuvLlD0DGgAAAMjcRVf/MZ5/eWasWvVF9NutS1x90SGKApCh LeUzuATQAAAAQOau
vXiEIgD8A/37NVdtEf0QQAMAAAAAbEO6d+0Se/bbK0qbN4/i4uLU27025ZWC 98WHEAIAAAAAkImC
z4DO5/OqCgDAVsv7WQAAvJ8tHDOgAQAAAADIRMFnQOdyOVUFAGCrlM/nvZ8F AMD72QIyAxoAAAAA
gEwIoAG+RJ8vq4gDj/5trddnfPS3OPj422PP4TfEEafeHW9Mn5tq2Wtvl8fI k+6Mbwy/Pg4/5e74
6JPPFBkAgAYbffJd8cBjb9Z47YHH3ozRJ9/VpHb7DhvfqGUAbL0E0ABfkvkL l8XJP304Fny2vNay
Oya8FmNG7RWvTxwbQwf1iXsfmZZq2c+u/lNccMqQeP2Jn8QhQ3eNi699UqEB AGiwD2YujP986PVY
ueqLiIhYueqLuOX+V+ODmQsz2+f7z49TeIBtkAAa4Ety5Gn3xNGH7lnnsnc/ WBCHfXePKGteEkeN
2DPe/3hhqmV/fuCUGLZfn2hRVhInHNU/Znz0N4UGAKBR9tq9a7z29uyIiHjt 7dmx9+5dayx/a8a8
OPK0e2LP4TfEkKN+E48++W71slnl+Rh50p2x7/d+Gc9N/rjGdhP//H4MHP2r +Mbw6+OZF/9S/fqG
M6D7Dhsftz7wagwbc3Ot9ZYuq4gfX/hw9PvODXHyTx+OpctXO1kAWzABNMCX 5NFbT4gxo/aqc9mC
z5ZF29ZlERHx9e1axZz5n6datqH85xXRu8d2Cg0AQKN8q9/28cq0TyMi4pVp n8a3+m1fY/kl1z4Z
px07IF6fODbOPXn/uPrXL1QvG3/L/8SYUf3it1cdHtf86vka273/8d/ihYdO jRv+ZVSc9/PH693/
ovyK+ONdP6q13vhb/icuPH1oTPvjOXH0oXvG/7vjJScLYAsmgAb4knTq0Lre ZRUVa6O4eN0turSk
ONasqUy1bEN/eOa9GPvDwQoNAECjfHODAHrKG59G/z2711g+8c6T4jsH7BJl zUti9PA9Yumyiupl
r79dHt8bvnv0/0b3ePq+H9fY7sc/2DdalJXG8CE7x9q1VfXu/8zjB0XLFrXX e27yx9Gn53ZRUtIs
hh+wS/z5pY+cLIAtWIkSAGx5yspKorKyKoqLm8Xayspo0aIk1bL1Ppz5WSz5 fFUMH7KzYgIA0Ch9
enSIBZ8tj1nl+SifvzR27dOxxvLFS1bGA394Kz74eGHM+MuCGsuWLquItq1b 1NluuzYtUu2/bT3r
5ZesjD2+fX3198XNipwsgC2YABpgC9S1U5tYvGRVdOzQKhblV0aXjm1SLYuI mPe3ZXHPI1Pj/57z
bYUEAKDRiooi/mmPbnHz/VNir926RrOimkHvaRc/EsMG9YkjR3wjuncZHCN/ +J/Vy1q1KotlK1ZX
PzqukNq2aREvPnxGlJT4o26ArYG7NcAWaK/du8Xv//ROrKr4Ih6e+E7ssUvn VMtee7s8rrjhmbh0
7EHRvLRYIQEAaJJv9ds+nnh2Rq3nP0dEfPTJojhwYO/4pz26x72PTKuxrP83 usfT//NhvDl9bnzn
2NsK2qcDB/SOj2YtisrKqnj4j+/E98++34kC2IKZAQ2wBfr+qL3ip1dNjF/e NTm279Iubrh8VKpl
P/3FxJi/cFnsffD/q37t/efHKSgAAI3yzX7dY80XlbWe/xwRcfVFB8e4X0yM JUtXxWnHDqyxbNxp
B8SZlz4aS5etjmsuPqSgfbrwjANj3C8mxqtvzY7ePbaL6//vSCcKYAtW9MBT byYbv9i1bEnMW92+
wY3NnPZsXPKzC1QVAICtUj6fj1wupxAAAGzV72fvvuPW2LPfXlHavHkUF6f/ C+nXprwSgw8aEX16
dY8Hn36rQfuuL1P2CA4AAAAAADIhgAYAAAAAIBMCaLZ5ixcvVgSAr9B90n0f YxAAALYcAmi2aRdc
cEH06NGjxmtFRUVRVFS0Rfd7a+jj1tjXphzX1nycW1Lft7Y6Nra/W9Nx1nWf /DJrWdd6s2bNiquu
uiq++93vRocOHaJdu3bRv3//+Nd//dfI5/NfyvFsS+Plk08+iaKioujZs+cm 19t5552jqKgopk+f
vsWO8S3h3r21vvcAAICslBS6wY1/EYQv0/XXX1/vuNwaxurWdD1tq9f+xse1 NR/nltT3ra2Oje3v
1nCcm7pPfpm1XL/eSy+9FMccc0xUVFTUWP7GG2/EG2+8Ebfffns8+eST0a1b ty/leLaF8dKuXbv4
5je/GVOnTo2nn3469tlnn1rrvPXWW/HRRx/F7rvvXl3rLXmMN/Xe3ZTj2trf ewAAsPXb0t53mgEN
W6DFixf7813nBIiIiy++OCoqKuLQQw+NSZMmxYIFC6K8vDwmTpwY/fr1i/Ly 8rjiiisUqomOOOKI
iIh47LHH6lz+X//1XzXW21ruie7dAACwBXjgqTeTjb9eeOGFpK7XN/d15dXj E9hSRESNr41fX7p0
aXL88ccnrVu3Tjp37pyce+65ycqVK2u0MWvWrOToo49O2rVrl7Rp0yY55phj krlz59a5nxdeeCHZ
brvtkmHDhjVo+031fb1Vq1Yl559/ftKtW7ekefPmyU477ZT8/Oc/T9auXZuq nddeey0ZOnRo0rJl
y6RDhw7J6aefnixfvrzGuh9++GEyevTopHXr1kmbNm2Sww47LPn4449T93Xe vHnJAQcckLRs2TIZ
PHhw8uqrr6au06b2PWHChCQikmOOOaZGe4899lgSEcmECRNqvL7ffvslEZE8 +OCDDTr+zZ2D+r5P
03Zjx8GGClGHQo/5QtS1Ies09rpIW/8pU6YkgwYNSkpLS5PBgwcnc+fOTdXf tMfw6KOPJsOGDUva
tWuXlJaWJj169Eh+8pOfJMuWLUvef//9pFmzZkmfPn1q9f+DDz5IIiLp3bt3 g67XNHWs7z5Zn00d
Q2NqmWa9kpKS6vG7sQ8//DCJiCSXy232eNL0vSFjO+0xNmS/Db0nF/I+NGfO nKRZs2ZJjx49kqqq
qlq13nHHHZOIqO5DXX3e1D6acg+rT5pzUN/3TfmZPXny5GT//fdPmjdvnnTu 3Dk555xzqs/n5t57
NPRaBwCAxrrr9luSaa9NSd55643kvXffTv111+23JB/9tTxJkqTB2XB9mbIA mm3W5n4JPPjgg2ut
c/bZZ1evt2jRomSHHXaotc6uu+6arFixolZ7/fv3T4qKipKTTjqpQdunCa9O P/30Wu1ERHLZZZel
aqdNmza1tj3llFOq1ysvL086duxYa50uXbok8+bNS7WPYcOG1di2TZs2ycyZ Mzdbp83te9myZUmL
Fi2S9u3bJ1988UV1e8cff3wSEcnRRx9d/dry5cuT0tLSpKysLFm6dGnq429K AL25tpsyDjZUiDoU
eswXoq5NCaDTXBdpj+mjjz5KWrduXWOdDcd0UwPou+66q86+RkRy/PHHJ0mS JIcffngSEckDDzxQ
o63x48cnEZGcc845DbpeCx1ApzmGhtQy7Xrrg8jbbrut0ff9tH1PO7bT9r2h +23oPbnQ96EDDzww
iYhk8uTJNer66quvJhGRDBgwoN4+b24fTbmH1SXtOajv+8b+zJ4xY0bSsmXL Wusddthhqd57NORa
BwCAbSWA9ggOtlnrft+r/e/1Fi5cGNOnT4/ly5fHT37yk4iIeOSRR6qXX3vt tTF79uz43ve+F/Pn
z4+FCxfGUUcdFR988EH86le/qtVe3759Y+XKlXHHHXc0avtNue+++yIiYtKk SbF69er43e9+FxER
d955Z6rt99xzz/jwww9j+fLlcdlll0VExKOPPlq9/JprromFCxfGfvvtF+Xl 5TF79uwYMGBAzJ8/
P6688spU+/j888/jr3/9a5SXl8egQYNi2bJlMX78+M3WaXP7bt26dXz3u9+N JUuWxOTJkyMiYs2a
NfH4449Hs2bN4o9//GOsWrUqItY9K/aLL76Ib3/729GmTZvUx98Um2u7UOOg EHUo9JjPsq6Fui7S
HtP1118fy5cvj/333z/mzp0bs2bNimXLlhWsr1dddVVERPz617+OlStXRkVF RTz//PMREfH4449H
RMRFF11UfU1saP3yUaNGFex6YgYogAAAIABJREFUTXufbOgxNKSWade77bbb onPnzvHjH/84evXq
FSeffHLceuut8d5776U+nrR9Tzu20/a9oftt7D25UPeh73//+xER1dfSehMm TKixvC6b20ch7mGN
GT/1aezP7BtuuCFWrVoVRx55ZCxdujQeeuihiIh44oknUl9Taa91AADYZpgB zVdhFnRdr234iIjP
PvssiYikWbNm1a/ttttuSUQkc+bMqTErLSKSgQMH1mrvzTffrLGftNun6Xe3 bt2SiEiOOuqo5MEH
H0wqKioadPxTp06tfm39jNgNj3XnnXdOIiKZMmVK9Wsvv/xyEhFJnz59Uu1j 0qRJ1a+98sorSUQk
O+2002brlGbfd999dxIRyYUXXpgkSZJMnDgxiYjkpJNOSiIi+f3vf58kSZJc dNFFNWZKpj3+psyA
3lzbTRkHG2tqHQo95gtR14as05jrIu0x7brrrrVq9OKLLxb0ERxVVVXJa6+9 ltx6663J2LFjkz32
2COJiKSoqKjWDNSJEycmSZIkixcvTkpKSpK2bdsma9asadD1mraODTnGNMeQ tpYNqfns2bOT8847
L+nVq1eN2aW9e/dO7r777lTjJ03f047thvS9Iftt6D250PehhQsXJiUlJckO O+xQ/RiOqqqqpEeP
HkmzZs1qbL9xn9Pso7H3sLqkPQf1fd/Yn9nrz827777bqPceDbnWAQCgKbak GdBFDzz1Zq3pGV3L
lsS81e0bHGbPnPZsXPKzC6T6bDGKiopqzUJa/1pFRUWUlZXVu27Lli2joqKi znbbt29f/Ymi67db
tWpVtGjRonqdtNun6fe9994b48aNiwULFkRERK9eveLBBx+MAQMGpDr+1atX R/Pmzettv0WLFrF6
9eoaNVm9enW0aNEimjdvHqtXr97sPjbctqKiIlq2bFlj2/rqlGbfS5Ysic6d O8cuu+wS77zzTpx8
8slx3333xcyZM6Nnz55x9NFHx/333x8DBgyI119/PebPnx8dO3ZMffxpzkF9 32+u7aaMg401tQ6F
HvOFqGtD1mnMdZH2mL72ta/FqlWratRo5cqV0apVq832N80xzJs3L0aNGhVT p06tc/316/3pT3+K
ESNGxP777x8vvvhi3H///XHsscfG0UcfXT3TMu31mraOac5JQ44hbS0bU/Mk SeKZZ56JCRMmxKpV
q+KDDz6IadOmxS9/+cs466yz6j2etH1PO7bT9r2h+23oPTmL+9DBBx8cTz31 VEyePDkGDRoUL7/8
cuy3334xdOjQ6tnbjd1HY+9hdUl7Duob7439mb1+v2vWrInS0tIGv/doyLUO AABNcfcdt8ae/faK
0ubNo7i4OPV2r015JQYfNCL69OoeDz79VoP2WV+m7BEcfGVtGMTVpaqqqt5l S5curfXahr/INmb7
TTnuuONi/vz58cILL8SOO+4Yn3zySRx00EHx8MMPp9p+w2BiUyFI2v5v6hfu DZWUlGy2Tmn23b59
+/jnf/7nePfdd+Pjjz+Oxx57LA444IDo1q1bDB48OJ544on429/+FlOnTo39 99+/VmCxueNvis21
Xchx0NQ6FHrMZ1nXjcdGXf8TJM11kfaY0o7fxho7dmxMnTo1dtppp7jgggvi P//zP2P69Om11jvk
kEOiX79+8dJLL8XLL79c55/kN/R63VwdC30MaWvZmJoXFRXFd77znbj99tvj /vvvjz/84Q8RUftR
Bo3te9qxnbbvDd1vY89xIe9D6x+zsT4EXf/fH/zgB03eR1PvYU0dP4X4mV1Z WVmQe0Kaax0AALYV
Amiox/bbbx8REXPnzo0kSWp8pfkFtKnb1+XAAw+M119/PS666KJYuXJlnHji iQU51h49ekRExJtv
vln92vp/rz+Ozdnweayvv/56RKybkVqofR955JERse45nYsWLYoRI0ZERMSh hx4ay5Yti8svvzwq
KyvjiCOO2KbG0cayrEMWY7Yx1gdLG4Y+77zzTqOui7TH1LNnz4iIeOONN1Lt s6GeeuqpiIiYPHly
jB8/Pn74wx/WO+P4wgsvjIiIG2+8MZ588skoLi6uPs8NuWYaWsdCHUPaWqZd r3379lFUVBQzZsyo
tSyXy0XEuuebF6r+aaTte2P3W4h7cmOv7cMPPzzKysri4Ycfjqqqqnj44Yej tLQ0jjrqqILso1D3
sEJfs2n7361bt4iI+Pjjj5t8X9jctQ4AANsKATTbtPUBzKJFixq87cEHHxwR EWeccUbMmzcvVqxY
EVdffXUUFRXFkCFDMt9+Q126dImioqJ46KGHonXr1jF06NCIiGjXrl1B6rS+ r+eff37MmTMnysvL
47zzzouIiOHDh6dq45xzzol58+bFrFmz4pxzzomIdTO8CrXv0aNHR3Fxcdx7 77012h45cmRERNx6
660REXHYYYdtUWOwkOMg6zoUuq+N1alTp4hY9+FzK1asiOnTp8eZZ57ZqOsi 7TEdeuih1eN49uzZ
MXfu3Dj//PMLfi968skno6KiIqZNmxbHHntsneuOGTMmevbsGRMmTIglS5bE oEGDokOHDg2+ZtLW
Me19Mu0xpK1lQ9c76qij4oknnojPP/881q5dG3/5y1+qj2fw4MGbPJ6G1D+N tH1v7H4LcU9u7LXd
rl27OPjgg6O8vDx++ctfRnl5eQwfPjy22267guyjUPewQl+zafu//j5z5ZVX xsqVK+ORRx6JoqKi
KCoqqv4QxbTX1OaudQAA2Gb4EEK2ZblcLomIZLvttmvwB3OVl5cnHTt2rPGB VxGRFBcXJ88999xm
20u7fZoPMDr11FNrtRMRycUXX1yQD3MrLy9Pvv71r9dqv2PHjsncuXNT7WPk yJE1tu3UqVMyf/78
VHVKu++DDjqo+oPHNtS7d+8kIpL+/fs36vjT1C5SfnBbY8dRQ2RVh6aO+WjC Bwxu6LTTTqvVh7PP
PrtR10XaY1qwYEHSqVOnGutsOKYbauPtjjvuuDr7Wl/7N954Y/Wya665plHX TNo61nWfbMoxpK1l
2vXmzJlT68MHN/xq27ZtjQ+Uq+t40vY97dhO2/fG7jftOc7qPvTAAw8kEVFd y3vuuaeg+2joPawu
ac9B2nOctv8zZsxIWrZsWWu9XXbZpVHvPTZ1rTf2/gMAAEmyZX0IoRnQbNMu u+yyaNOmTZ3Pityc
7t27x+TJk+OII46Itm3bRvPmzWPAgAExceLEGDZsWObbb+jaa6+NE088MTp1 6hTFxcXRrVu3GDdu
XFx++eUFqVP37t1j0qRJMWrUqGjdunW0atUqRo8eHVOmTImuXbumauOWW26J /fbbL8rKymLYsGHx
3//939G5c+eC7nv9n25vPLN6/Uy4ww8/fIsbg4UcB1nXIYu+NsZ1110XZ5xx RnTo0CFatWoVZ555
Zlx33XWNui7SHlOnTp3i+eefjyFDhkRpaWkMGjQobr755oId00033RRjxoyJ Vq1aRYsWLWLfffeN
CRMm1Lv+SSedVP1c342fCZv2mklbx7T3ybTHkLaWadfr1q1bTJs2LS677LLo 169ffO1rX4vS0tLo
2bNnnHrqqTFt2rTYa6+9Nnk8Da3/5qTte2P3W4h7clOu7VGjRsXXvva1yOfz 0bJlyxg9enRB91GI
e1ihr9m0/e/bt288/fTTsc8++0RpaWm0b98+Ro8eHRMnTmzUe49NXesAALCt KHrgqTdrPYywvk8s
3JyZ056NS352gaoCQBNMnDgxRo4cGX379q3z2ceAax0AADbl7jtujT377RWl zZtHcXFx6u1em/JK
DD5oRPTp1T0efPqtBu2zvky5xOkAgC3DsmXLYsWKFXHFFVdERMS4ceMUBVzr AACwVRNAA8AWom3b
ttX/3nvvvePEE09UFHCtAwDAVs0zoAFgC7H99ttHy5YtY8SIEfH4449HSYn/ TwyudQAA2Lp5twsA
W4jZs2crArjWAQBgm2IGNAAAAAAAmSj4DOh8Pq+qAAAAAACYAQ0AAAAAQDYK PgM6l8upKgAAAAAA
ZkADAAAAAJANATQAAAAAAJkQQAMAAAAAkAkBNAAAAAAAmRBAAwAAAACQCQE0 AAAAAACZEEADAAAA
AJAJATQAAAAAAJkQQAMAAAAAkAkBNAAAAAAAmRBAAwAAAACQCQE0AAAAAACZ EEADAAAAAJAJATQA
AAAAAJkQQAMAAAAAkImSQjeYz+dVFQAAAAAAM6ABAAAAAMhGwWdA53I5VQUA AAAAwAxoAAAAAACy
IYAGAAAAACATAmgAAAAAADIhgAYAAAAAIBMCaAAAAAAAMiGABgAAAAAgEwJo AAAAAAAyIYAGAAAA
ACATAmgAAAAAADIhgAYAAAAAIBMCaAAAAAAAMiGABgAAAAAgEwJoAAAAAAAy IYAGAAAAACATAmgA
AAAAADJRUugG8/m8qgIAAAAAYAY0AAAAAADZKPgM6Fwup6oAAAAAAJgBDQAA AABANgTQAAAAAABk
QgANAAAAAEAmBNAAAAAAAGRCAA0AAAAAQCYE0AAAAAAAZEIADQAAAABAJgTQ AAAAAABkQgANAAAA
AEAmBNAAAAAAAGRCAA0AAAAAQCYE0AAAAAAAZEIADQAAAABAJgTQAAAAAABk QgANAAAAAEAmSgrd
YD6fV1UAAAAAAMyABgAAAAAgGwWfAZ3L5VQVAAAAAAAzoAEAAAAAyIYAGgAA AACATAigAQAAAADI
hAAaAAAAAIBMCKABAAAAAMiEABoAAAAAgEwIoAEAAAAAyIQAGgAAAACATAig AQAAAADIhAAaAAAA
AIBMCKABAAAAAMiEABoAAAAAgEwIoAEAAAAAyIQAGgAAAACATAigAQAAAADI REmhG8zn86oKAAAA
AIAZ0AAAAAAAZKPgM6BzuZyqAgAAAABgBjQAAAAAANkQQAMAAAAAkAkBNAAA AAAAmRBAAwAAAACQ
CQE0AAAAAACZEEADAAAAAJAJATQAAAAAAJkQQAMAAAAAkAkBNAAAAAAAmRBA AwAAAACQCQE0AAAA
AACZEEADAAAAAJAJATQAAAAAAJkQQAMAAAAAkAkBNAAAAAAAmSgpdIP5fF5V AQAAAAAwAxoAAAAA
gGwUfAZ0LpdTVQAAAAAAzIAGAAAAACAbAmgAAAAAADIhgAYAAAAAIBMCaAAA AAAAMiGABgAAAAAg
EwJoAAAAAAAyIYAGAAAAACATAmgAAAAAADIhgAYAAAAAIBMCaAAAAAAAMiGA BgAAAAAgEwJoAAAA
AAAyIYAGAAAAACATAmgAAAAAADIhgAYAAAAAIBMlhW4wn8+rKgAAAAAAZkAD AAAAAJCNgs+AzuVy
qgoAAAAAgBnQAAAAAABkQwANAAAAAEAmBNAAAAAAAGRCAA0AAAAAQCYE0AAA AAAAZEIADQAAAABA
JgTQAAAAAABkQgANAAAAAEAmBNAAAAAAAGRCAA0AAAAAQCYE0AAAAAAAZEIA DQAAAABAJgTQAAAA
AABkQgANAAAAAEAmBNAAAAAAAGSipNAN5vN5VQUAAAAAwAxoAAAAAACyUfAZ 0LlcTlUBAAAAADAD
GgAAAACAbAigAQAAAADIhAAaAAAAAIBMCKABAAAAAMiEABoAAAAAgEwIoAEA AAAAyIQAGgAAAACA
TAigAQAAAADIhAAaAAAAAIBMCKABAAAAAMiEABoAAAAAgEwIoAEAAAAAyIQA GgAAAACATAigAQAA
AADIhAAaAAAAAIBMlBS6wXw+r6oAAAAAAJgBDQAAAABANgo+AzqXy6kqAAAA AABmQAMAAAAAkA0B
NAAAAAAAmRBAAwAAAACQCQE0AAAAAACZEEADAAAAAJAJATQAAAAAAJkQQAMA AAAAkAkBNAAAAAAA
mRBAAwAAAACQCQE0AAAAAACZEEADAAAAAJAJATQAAAAAAJkQQAMAAAAAkAkB NAAAAAAAmRBAAwAA
AACQiZJCN5jP51UVAAAAAAAzoAEAAAAAyEbBZ0DncjlVBQAAAADADGgAAAAA ALIhgAYAAAAAIBMC
aAAAAAAAMiGABgAAAAAgEwJoAAAAAAAyIYAGAAAAACATAmgAAAAAADIhgAYA AAAAIBMCaAAAAAAA
MiGABgAAAAAgEwJoAAAAAAAyIYAGAAAAACATAmgAAAAAADIhgAYAAAAAIBMC aAAAAAAAMlFS6Abz
+byqAgAAAABgBjQAAAAAANko+AzoXC6nqgAAAAAAmAENAAAAAEA2BNAAAAAA AGRCAA0AAAAAQCYE
0AAAAAAAZEIADQAAAABAJgTQAAAAAABkQgANAAAAAEAmBNAAAAAAAGRCAA0A AAAAQCYE0AAAAAAA
ZEIADQAAAABAJgTQAAAAAABkQgANAAAAAEAmBNAAAAAAAGRCAA0AAAAAQCZK Ct1gPp9XVQAAAAAA
zIAGAAAAACAbBZ8BncvlVBUAAAAAADOgAQAAAADIhgAaAAAAAIBMCKABAAAA AMiEABoAAAAAgEwI
oAEAAAAAyIQAGgAAAACATAigAQAAAADIhAAaAAAAAIBMCKABAAAAAMiEABoA AAAAgEwIoAEAAAAA
yIQAGgAAAACATAigAQAAAADIhAAaAAAAAIBMCKABAAAAAMhESaEbzOfzqgoA AAAAgBnQAAAAAABk
o+AzoHO5nKoCAAAAAGAGNAAAAAAA2RBAAwAAAACQCQE0AAAAAACZEEADAAAA AJAJATQAAAAAAJkQ
QAMAAAAAkAkBNAAAAAAAmRBAAwAAAACQCQE0AAAAAACZEEADAAAAAJAJATQA AAAAAJkQQAMAAAAA
kAkBNAAAAAAAmRBAAwAAAACQCQE0AAAAAACZKCl0g/l8XlUBAAAAADADGgAA AACAbBR8BnQul1NV
AAAAAADMgAYAAAAAIBsCaAAAAAAAMiGABgAAAAAgEwJoAAAAAAAyIYAGAAAA ACATAmgAAAAAADIh
gAYAAAAAIBMCaAAAAAAAMiGABgAAAAAgEwJoAAAAAAAyIYAGAAAAACATAmgA AAAAADIhgAYAAAAA
IBMCaAAAAAAAMiGABgAAAAAgEyWFbjCfz6sqAAAAAABmQAMAAAAAkI2Cz4DO 5XKqCgAAAACAGdAA
AAAAAGRDAA0AAAAAQCYE0AAAAAAAZEIADQAAAABAJgTQAAAAAABkQgANAAAA AEAmBNAAAAAAAGRC
AA0AAAAAQCYE0AAAAAAAZEIADQAAAABAJgTQAAAAAABkQgANAAAAAEAmBNAA AAAAAGRCAA0AAAAA
QCYE0AAAAAAAZKKk0A3m83lVBQAAAADADGgAAAAAALJR8BnQuVxOVQEAAAAA MAMaAAAAAIBsCKAB
AAAAAMiEABoAAAAAgEwIoAEAAAAAyIQAGgAAAACATAigAQAAAADIhAAaAAAA AIBMCKABAAAAAMiE
ABoAAAAAgEwIoAEAAAAAyIQAGgAAAACATAigAQAAAADIhAAaAAAAAIBMCKAB AAAAAMiEABoAAAAA
gEyUFLrBfD6vqgAAAAAAmAENAAAAAEA2Cj4DOpfLqSoAAAAAAGZAAwAAAACQ DQE0AAAAAACZEEAD
AAAAAJAJATQAAAAAAJkQQAMAAAAAkAkBNAAAAAAAmRBAAwAAAACQCQE0AAAA AACZEEADAAAAAJAJ
ATQAAAAAAJkQQAMAAAAAkAkBNAAAAAAAmRBAAwAAAACQCQE0AAAAAACZEEAD AAAAAJCJkkI3mM/n
VRUAAAAAADOgAQAAAADIRsFnQOdyOVUFAAAAAMAMaAAAAAAAsiGABgAAAAAg EwJoAAAAAAAyIYAG
AAAAACATAmgAAAAAADIhgAYAAAAAIBMCaAAAAAAAMiGABgAAAAAgEwJoAAAA AAAyIYAGAAAAACAT
AmgAAAAAADIhgAYAAAAAIBMCaAAAAAAAMiGABgAAAAAgEwJoAAAAAAAyUVLo BvP5vKoCAAAAAGAG
NAAAAAAA2Sj4DOhcLqeqAAAAAACYAQ0AAAAAQDYE0AAAAAAAZEIADQAAAABA JgTQAAAAAABkQgAN
AAAAAEAmBNAAAAAAAGRCAA0AAAAAQCYE0AAAAAAAZEIADQAAAABAJgTQAAAA AABkQgANAAAAAEAm
BNAAAAD8/+zdd5hV1b0//s/MOVPoDL1KE4NSxoZgFAlGxIIpN7Hk642Jib+r Kfd6VYyiX703xkSj
RpPfTaKJiSli9Bp/pmLBihUsVE1QiiBdwTMz1GFmzvn9gYwMZRxgNs7g6/U8 8wxn7b3W3uezT/Ks
vLNmHQCARAigAQAAAABIhAAaAAAAAIBECKABAAAAAEhEurEHzGQyqgoAAAAA gBXQAAAAAAAko9FX
QJeUlKgqAAAAAABWQAMAAAAAkAwBNAAAAAAAiRBAAwAAAACQCAE0AAAAAACJ EEADAAAAAJAIATQA
AAAAAIkQQAMAAAAAkAgBNAAAAAAAiRBAAwAAAACQCAE0AAAAAACJEEADAAAA AJAIATQAAAAAAIkQ
QAMAAAAAkAgBNAAAAAAAiRBAAwAAAACQiHRjD5jJZFQVAAAAAOAjsnzlqli+ clWTuJe0xwEAAAAA
cGC5YuLVkcvlPvjJZrf+jlxUV1W/356tPb6uoiImTbq70e+j0QPokpISTxcA AAAA4COWzWYjm81G
7v3f2Ww2crlsVFZW7nQsKfaABgAAAAAgEQJoAAAAAAASIYAGAAAAADiArVyx PKqqttRpq66uijXv
vpP4tQXQAAAAAAAHsHdXr4qXpr0Q1dVVERFRVVUVs2fOiI0bNkRhUVGi104r PwAAAADAgWvo4UfG
nNkz44XnnokuXbvGqhUronPXbjFk2OFRXpZJ9NpWQAMAAAAAHMDy8vJiyNDS 6NipcyxasCC6du8R
w0qPiIqK8sSvbQU0AAAAAMABLi8vLw4bPDQ6deoUPXodFOv2Q/gcYQU0AAAA AMDHQl5eXnTp2i02
rF+3364pgAYAAAAAIBECaAAAAAAAEiGABgAAAAA4wORyuSZxH76EEAAAAADg AHPTjT9oEvfR6AH0
Dd//3l737dm9m08GAAAAAPCxt3zlqr3uO/Hqa/a678LFyxv1fSSyAvqKiVfv 0fm5XC5uuvEHMXRY
qU8WAAAAAPCxt3zlqr3OWZuSRALoXC4X2Wx2j/sVFBb6ZAEAAAAAxN7nrE1J kwqgU6mUTxUAAAAA
QBwYAXR+UoXJZbM7/WRramLWKy/FyuXLdjoGAAAAAMAHdsxZVyxbGrNffTmy NTW7zF+bYs6aTACd
zUZ2h5+ampqYNfPVKK8oj249eux0HAAAAACAD+yYs3bo2DHKK8pjzuyZUVNT s1PGmv3YBNDvLw3f
PnyePWtGvLd2TZzwqROjprpGAA0AAAAAUI8dc9ZUKh3DRxwba9e8G6/Nnb3L ELqpSSaAjlzkctna
n+VL345lby+JXr0Per8oNXWO53ICaAAAAACA7e2Ys+Zy2UilUtGla9dY8tai eGf1yiafsybyJYTV
VdVRWVlZ+7pj585xUN9+sXzZ0ujeo0fk5/uyQQAAAACA+uyYs0ZEVFVVxaoV K6LfgIOjR6+DYsP6
dU36PSQSQO/q2xn79R8QERGzZrwaQ0uPiFRKCA0AAAAAsDs75qzV1VUxe+aM 6Ny1WwwZWhrrKsqb
/HtIKIDe9X4jffr2iyVvLYotW7ZEUVGRTxAAAAAAwG7smLO+t3ZtdOzYKYYM OzzKy8uaxXtIbAV0
bjcbXvfp2y8Ki4piyw5LxwEAAAAA+MCOOWvHjp2ie4+eUV6WaTbvYb9twbG9 zZs2+fQAAAAAANRj
Vzlrc8tWEwmg11VU+HQAAAAAAOyDAyFnTSSAnjTp7r3q9/L0aT5VAAAAAACx 9zlrU9LoAfRZ537N
JwMAAAAA4COycPHyJnMvjRpAX3XlZZ4uAAAAAAAR0cgB9H1TZqsoAAAAAAAR EZGvBAAAAAAAJEEA
DQAAAABAIgTQAAAAAAAkQgANAAAAAEAiBNAAAAAAACRCAA0AAAAAQCIE0AAA AAAAJEIADQAAAABA
IgTQAAAAAAAkQgANAAAAAEAiBNAAAAAAACQivbsD3YvKVAcAAAAAgL22ywB6 ZWV7lQEAAAAAYJ/Y
ggMAAAAAgEQIoAEAAAAASMQut+Cw/zMAAAAAAHtiV1s7p/fkZGgquheV+YwC AAAAQBOxu0XNtuAA
AAAAACARAmgAAAAAABIhgAYAAAAAIBECaAAAAAAAEpFWAgAAAACA5unRP/25 QeeN+/zn9ss4O9rj
APr6Xz8RkZ+OXF4qIlUYkV8YkSqIyC+MXLoo8lKFEfkFkctLR+Sn4trTWh8Q DzKXrYm8/FSzG7sp
1ukXN/xn7b8vnPjjBh8DAAAAAHb2m9v/q97j53/juw0a547/98p6j1/0Hzfu 8b3tcQCd7T4izvns
oVGYyo/igrxoWZCKVkX50aogP1oXpqJVUSpaFuRFcUFefP67z3/oeOvXLIm3 Z/09Nqx9Ozr1PSp6
Dhkbha1KmtxDnPvQzTFs/M4PYPo9l8aIc2/dZZ/6jtU39qbyd2Lek7fH4Z+7 NvLy8mrbc7lczP7L
92PgCV+J1x6+rUFjN8T0ey6t/XdefipatO8W/UecHa069Gq0Ou3oqaeeioiI MWPG1AbNv7jhP+u0
AwAAAAD7z94EzB9mjwPo/JXT4/5fvhKRl9660jlVtHUFdKooIlUYuVRB5OUV RC5VEJFX/0rYje8t
jzefuSv6Dv9CtO8+KLZsqoiF0+6Lkt5Do9shxzep4m8qf2eP+zQ0IN5x7Bbt ukRx605RseqNaNd9
UG17xer5UVDUKlp16N1o4fOO95rL1sS7C6fHoun/G0NPvSzxOj311FO1YfO2 8BkAAAAAaLiGrnD+
ME1iBfT/PXl+DDv79gadO+d/vxERF+32+PLXn4hew06LDr2HRUREcZtO0W/E 2bF87iO151Rv3hAL
nv99VLyzKNp26R8HH/+VSBe1jIitK3d7HzE+Vr/xXFRtXhcDjz8vSnoPjYiI zevWxJtT74qqTRXR
/9hzoqTXkK3jbdkYC54SiZ4wAAAgAElEQVSfFOtWLYg2XQfEwOPPi1Rhi9rx Bo46LxZNuz9alvSI
Q0Z9NdLFrWtXCDd0RfM225+fWTo35j/3+4jIRYt23aLv0f8Sbbr03+3YXQYe G+8seKlOAP3uwpei
yyeO2+n83b2n2X/9QQw68cIoat0xNr63POY+/KMYPO7iaN2pT2xetybeePKX UfrZq+rcc15+Kjr2
Hx6LX/lTbdv6NUti8csPxsayFZEuahW9S0+PzgOG195Hr9JTY+3imbGpfFWD 6nThxB/HmDFjagPn
HYPn7VdFAwAAAAC7t6d7Mu9v+XvbsVPhh/98mHXvLoySXofWaStu3SEGHPt/ al+/Peuv0aHP4TH8
7Buj5KBh8faMv9Y5v2rTuig948oYePx57we8Wy2d+ffoMnBkHPKpr8fbr/51 u/bJ0eeIM+Los2+I
zgNGxrLZD9cZr3zlG3Hkv3w3OvY9It6eNTkiPlgdvC+rjuc/9/voc/TnYvg5 N0fPIWNj0bT76h27
w0GlsX7N4qjesjEiImqqNse61Qui40FH7DT27t5Tux6HRvmqN7e+r9VvRipV EOWr5kdERNnKedGu
5yd2GitXUxXvzn8hWpb0rG1bNO3e6DHkxBh+1g+id+mp8faMv9TpU9iifQwe d/Ee1WlbCL0j4TMA
AAAAHDj2OICurEk32rnVlRsjXVj/lxRmlv8zOvY5MvLyU9Gp71FRtvwfdY73 HDo28tOFUdJ7aOSy
NbXtFe8ujE79jo42nfvVWeWbWfZ6FLftGnn5qehw0LB4b9lrdccbcnLkpwve v9Y/G63QbbsOiPKV
b0TFqvnRrudhUfqZq+o9f+v7PSLeWzwzIiLWLH41OvQ5PPLTBTvXaDfvqX2P QVG+cmsAXbFqQXQ9
dHRUrN4aQJcvnxftu32wunr6PZfG9HsujVfuvzrWLpkV/UeeXXts2Pgro0Pv 0shLFUSnfkfXhuLb
dDhoaKQKivynCQAAAACoY4+34Ni8ZevS5vyIiLyIvNzW3xERudzW39u+N2/z lsKoL5YsKGoVVZXr
o7BF29q2XC4XNVWbIl24dZuNmsoNteFmqqAoqio31H0D75+3o5rKjZEqaLFT e3Xlunjp3gm1r7f/
kr+IiMJW7WuvVb1lQ6MVesBx/xoLnvldvPH0nZGXn4rDxn4rWnXoXW+fzgcf GwuenxRdDjku1ix4
Kfofd+4uz9vde2rb5eB4a/r9kc1Wx4bM8jj4+C/HzD9dFzVVm2P9msUxcNR5 tX3qW7VcVbk+Vr/5
QmzKrIwNmWU7HU8VFO9xPbb/wsHtbdsT2ipoAAAAAGj+9jiA3rhla9iYzout wfO2/Hb7IDq2htAb
KoujXT1jtek6IMqX/yM6Hzyytm39miWx6MU/1K4QThe2ipqaqkilCqJmy+ZI F7ds0H2mClpEtmpz
7f7Ote1FLePIz/935OXv+gsSqzatj4IWbaJ6y6YoKG7TaIUuKGodh479VuRq qmLNW6/GG0/9Oo78
wn/X26e4TadIFxTF2iWzI7+wOFq07bLr97qb95SfLogW7brHO2++EK07HhSp guJoVdIzVrz+ZLQs
6RH56cIG3fubT94Z7XsNji4DjomC1qfE3L//cJ9qsWP4vOOXEAqhAQAAAODA sMcB9PrNW0PLdH5s
TZq32fZ6u0B6w5b6t2XoPmh0zHv6V5Fu0TbadxsYm9a9G29Nvz+6HTq69px2 PQZF+fLXo6TX0Fi7
ZGa0735og+6zTee+sfbtOdGyfbdY+Pw9tdtwlHQ/LDaVr44W7brFu4tejncX TovB4y6u7bfiH09G
7yNOj7Vvzaz9QsOIrauKqzdviHRxq70q9Ny//zB6DhsXJb2GRbqoVZ3V1fWN 3WXgJ+Otlx+IfsO/
uNux63tP7XsOiuWvPRa9h54SERFtux8SK197PHq+/7ohNlasjr49vxjFrTvV 7ou9O3tap+2D5u2/
mBAAAAAA2L8u+o8bG33MPQ6gN2xbAR3xQdi8Td77TXkRubyIDZX1B9CtOh4U /UecFUtnTY75Fauj
oKh1dDt0dHQdeFztOX2O/EzMf/Z3sfD5P0SbbgfHwcee26D77HXEGTF/6q+j esvGGPDJD77UsPdR
Z8TC5+6OincWRXHbLjHw+C/X6VfYsn3MeOCaaNt1YAz45AfXat9zcMz803dj +Jdu2ula0++5dKe2
Hbe06DfynFg07d6Y/+zdkZefHwOPP69BY5f0GhrLX388SnoN3e17re89te9x WCx55c/RtsfWLxxs
1+2QWDb74WjX4xMNfub9R34pFj5/T1Rt2RA9B59U77n1vZftbVv1vP0q5919 MSEAAAAAkKxxn/9c
IuPm3fvorNyOjd2LymJlZftddnhx6pNx4cRL4pBWW/d83hY4b78aOvf+3tAT rrktRo4+sdkUefo9
l9a7FzJNR32fUQAAAABg/9pdXrfHK6C3VKfjf773Pw08O63yAAAAAAAfU3uc EI/+9AkHbDGsfgYA
AAAAaDz5SgAAAAAAQBIE0AAAAAAAJEIADQAAAABAInxLIM1W96IyRQAAAACA JkwATbO0srK9IgAA
AABAE7G7xaK24AAAAAAAIBECaAAAAAAAEiGABgAAAAAgEQJoAAAAAAASIYAG AAAAACARAmgAAAAA
ABIhgAYAAAAAIBECaAAAAAAAEiGABgAAAAAgEQJoAAAAAAASIYAGAAAAACAR AmgAAAAAAGqdc3Jp
o42VbswbWzTjcU8HAAAAAKCZOvuccxp1vHRj32D/I0/ylAAAaJZKW+TH7E1Z hQAAoNnOZw8dNXSf
xli4eHmj3pMtOAAAAAAASIQAGgAAAACARKSVAKBxTb/n0hhx7q0KAQDAAT3n 3R1zYQC2J4AGAAAA
9sj2IbMFGADURwANsB+tX7MkFr/8YGwsWxHpolbRu/T06DxgeO3EvfcR42P1 G89F1eZ1MfD486Kk
99BdTuq3f13fmNWVG2P+M7+JjeUro+eQk2PJq3+u7Ve9ZWMseH5SrFu1INp0 HRADjz8vUoUtPCQA
APZZfXPN6fdcGr1KT421i2fGsPHfien3XBr9hn8hls59JCIi+h1zZqRShbFw 2n1RXbmhzrwYgOZH
AA2wHy2adm/0Kj01SnocFmsWz4i3Z/ylNiyOiKjatC5Kz7gyyle+EfOf+30c 86Wb92nMpbMnR7ue
h8UnxvxbLHn1z3X6LZ05OfoccUYUt+0S7y19LZbNfjj6DP8XDwkAgH32YXPN whbtY/C4i2tfbyhf
FYd/9uooX/FGLJvzaHTsc0SUnjExKla92eB5MQBNky8hBNiPho2/Mjr0Lo28 VEF06nd0VG/ZWOd4
z6FjIz9dGCW9h0YuW7PPY5Yt/0d0OXhE5KcLoufQsXX6ZZa9HsVtu0Zefio6 HDQs3lv2mgcEAECj
+LC5ZoeDhkaqoKj2de+h4yKVLo6SXkNjU9nK6Dbo+EgVFO3RvBiApskKaID9 qKpyfax+84XYlFkZ
GzLLdv4v5cKWjTpm1eZ1kSrY+qeOBS3a1TlWXbkuXrp3Qu3rvLw8DwgAgEbx YXPNVEFx3ddFrbae
l791nVwqXayIAAcIATTAfvTmk3dG+16Do8uAY6Kg9Skx9+8/3PPJ/OYNDR4z Xdg6aqo2RbqwZVRt
XrfDJL9lHPn5/468/JQHAwBAo9rTuabFEAAHLltwAOxHGytWR/ueh0brzn1j 9RvPNrhfXn4qMkvn
Rk1NVSx//bEGj1nSe3CsWfhS5GqqYuVrj9c91v2w2FS+OnLZbLyzYHq8/uhP PCAAABqFuSYA21gB
DZCA6fdculPbiHNvjf4jvxQLn78nqrZsiJ6DT2rweAOPPy/mP/f7SKWLovfh p9U5Vt+YvUtPjzef
/U0se+2x6DH4pLr77B11Rix87u6oeGdRFLftEgOP/7IHBwBAozDXBGCbvHsf nZXbsbF7UVmsrGy/
x4MtmvF49D/yJFUFaGJy2ZpYs+jlWLN4Rhx60jcVBGA3Slvkx+xNWYUAAKDZ zmcPHTV0n8ZYuHh5
DOjbM+6bMnuP+u0uU7YCGuAAtvCFP0TZ8n9ETXVltO50UPQf+SVFAQAAAPYb ATTAAWzAJ/+PIgAA
AAAfGV9CCAAAAABAIhp9BXRpC5k2AADNl/ksAAA0HrNrAAAAAAAS0egroLsN 6aWqAAAAAAAfgUwm
E3f8/Kd73f+sc7/WqPfT6AF0SUmJpwwAQLOdrJvPAgBwIMxnr5h4deRyuQ9+ stmtvyMX1VXV77dn
a4+vq6iISZPubvR7SnssAAAAAAAHnmw2G9lsNnLv/85ms5HLZaOysnKnY0kR QAPsB4PG3BLznppQ
b/vbK8riuh8/Hq/MWR5FhakYN/qQuPKbY6Jli4Ldjrkr28YbNOaWuO6yk+Os 8cMadC8AALA7f3/i
nzHh+snxo/87Pk7/9KDdzknT6fy47dozYuyogXXan3t5cdx0x9Px1tuZ6H9Q h5j47TEx8oiDdjlO
QToVgw7uHN+9dGwcNrBrg+a+ADRdAmiAJuLy6yfHqWMGxU+/97mo3FIdd9w9 LW664+n470vG7rbP
h024H5g8N8YcOyA6d2ylwAAA7LVHp74ZJx1/cDwy9Y06AfSOc9LHnp0fl3// obj56tNqQ+i581bF
VT98JG648pQ4elivmD5zaVz2vb/HXbecGZ/o33mncTZXVscfJ8+Jy7//UEz+ 7fkNnvsC0DTlKwFA
0zBv4btx1vhhUVyUjnZtimPCRaPj0alv7tOYl190Qlz/P08oLgAAe23T5qqY PmtpXHPxSTF95tux
ubJqt+eOHTUwbr76tLjkur/Vtv3yD9Pjsn87IY47um8UFabjhBH94ltf+WT8 8g/TdzlGcVE6zj6j
NFa/u07xARpZLpeL5UuXRi6X22/XFEADNBGjjukbN/9iajz48Gux6O33IpWf Fy/++Vv7NObw0t7R
rk1xPP7cAgUGAGCvTJ22KI44rEd07dQ6Sg/rEVOnvVXv+WNHDYzq6g/2Ep0x d3kcf0zfOud8+riD
46VZS3fZf0tVTTzw0Ny46MsjFR+gEeVyuZg7Z1bMmT0zFi6Yv99CaFtwADQR 118+Lm771XNxz59n
xjW3PBoH9SyJH10zPg4b2GW3fXa1F96Of5p4+UWj4/zL/hgjjugdbVoVKTQA AHtkyjPz48TjBkTE
1uB4yjNvxrjRhzS4f9m6zdG+bYs6bZ1KWkamfFO9c9uJ3xqzx3NfAHYtl8vF nNkzI/Pe2vjEoYfF
8mVb/0/APn37JX5tATTAflCQTkVNNhep/LzatpqabBSkU7Wv27dtEd+9dOt+ zxXrK+O+v8yKK298
KP7666/WmWxvP8luyIS7TauiuPDcEXHzHVPjustO9jAAAGiwyi3V8fS0hfHQ U/Piv259LCIiWrUs
jMot1VFU2LBIoX3b4li3vm4IXVaxcyi9bW5bVV0TL7y6JK65eUp85YtH7dHc F4BdmzPz1VhXUR6f
HjsuampqonuPHjFrxqux5K1FiYfQtuAA2A8GHdw5lq8sr9O2ZHlZHHbIB6ub j/nMT2Pjpq376bVt
XRRfPevoWLKsrHayve1nb4wdNTDKKjbHy3OWeRgAADTYcy8vjmGDuteZjw75 RLd4/pUlu+3z2LPz
I53+IG44prR3PD1tUZ1znnpxYQwf1muX/QvSqTjuqL5RVrHJAwBoJF2794gT xnw6amqykc1mIz8/
FUNLj4juPXtFYVGyfy0tgAbYDy65YFRc95PHY8myTNTUZOPtFWXxo18+ExMu HF17zimjD4m77n85
1mY2xubKqvjVvS/F8NJejXYP1/zHp+Pm26d6GAAANNijU9+Ms84YVqftzNOH xqNT39jl+Y89Oz8u
//5Dcdu1Z9S2XfivI+PHv3ouXnh1Se3q5p/c9Vz8P/9nxC7HqKquiT/8ZVYc OaSnBwDQSLp17xHZ
mmydfZ9TqVQUFRXFlsrKRK9tCw6A/eCTR/WJtZmN8ZVL74931qyPLp1ax+UX ja6z6uPKb46JG372
ZJz2lbuickt1HHtUn7jhilPrHXdP9sHr3LFVfPH0oTFn3koPBACAD1VVXROz Xl8R3//OuDrtY0cN
jJ/8+rmoqq7ZaU6aTufHbdeeEWNHDfxgzjqgc9xw5alxw8+ejIVL3ouD+3SM m646fafvOtk2TlFh
OkoP6x7XTxi313NfAJqOvHsfnbXT1x12LyqLlZXt93iwRTMej6uuvExVAQBo ljKZTJSUlCgEAADN
ej57w/e/F1dMvDpqamoim81GLrt1641sNhu5XDYqKys/eL3dsUmT7o6zzv1a DOjbM+6bMnuPrr27
TNkWHAAAAAAAB5jtt9v4KNmCAwAAAADgAHPTjT9oEvchgAYAAAAAOID07N4t hg4rjYLCwkilUg3u
9/L0aY1+L7bgAAAAAAAgEY2+AjqTyagqAADNlvksAADms43HCmgAAAAAABLR 6CugS0pKVBUAgGYp
k8mYzwIAYD7biKyABgAAABJXVV2jCAAfQwJogCZm0Jhbdvmz/fH7/z5nl/0A AGB/zVWHjr0tzvzG
pPjH/NX1nr/N5y74/R7PXc1xAZq/tBIAND3znppQ7/EHJs+NMccOiM4dWykW AAAfyVx1c2V1/HHy
nLj8+w/F5N+e/6Hz2oVL1jZ4vgvAgcMKaIBm6PKLTojr/+cJhQAA4CNTXJSO s88ojdXvrqttGzTm
lrj97mkx/vzf1r6u73dExGPPzo8hY2+NwSfdGp+74Hfxypxlda4z+Yl5MfKz P4shY2+Nx56dr/AA
zYwAGqAZGl7aO9q1KY7Hn1ugGAAAfCS2VNXEAw/NjYu+PLJOe7fOreP+n59b p23biuddrXy+5Lq/
xdXfPjHmTLkkvvHlY+Oqmx6p23fhO/H0/f8Wt117Rlxy3d8UHqCZsQUHQBO0 q73udpysX37R6Dj/
sj/GiCN6R5tWRYoGAMBHMled+K0xdV6fNGpgtGxR0ODxjjm8dzz/yuLo07Mk Ro/sF+NGH1Ln+AVf
OiaKiwpi7KiBUV2d9QAAmhkBNEAT1JA98dq0KooLzx0RN98xNa677GRFAwBg v85Vq6pr4oVXl8Q1
N0+Jr3zxqDrz1D1xy9Wnx8X/9de4cOKDkU7nx6SfnBODD+lae7xdm2JFB2jG bMEB0IyNHTUwyio2
x8s77JMHAABJK0in4rij+kZZxaZ9GqdD+5Zx90/OiVcm/3tc9e0T48KJDyou wAFEAA3QzF3zH5+O
m2+fqhAAAOxXVdU18Ye/zIojh/Rs0Pmp/LzIlO8cVo//6m/i4affiHQqP9q3 Ld7nQBuApsUWHABN
UEP2gN6mc8dW8cXTh8aceSsVDgCA/TZXLSpMR+lh3eP6CeMa1G/0yP4x+sw7 Ys6US+q0X3/5uLj6
5kfjsuv+HvmpvLjt2jMUGeAAknfvo7NyOzZ2LyqLlZXt93iwRTMej6uuvExV AQBoljKZTJSUlCgE
AADNej77+7vujKHDSqOgsDBSqVSD+788fVocd+JpMaBvz7hvyuw9uvbuMmVb cAAAAAAAkAgBNAAA
AAAAiRBAAwAAAACQCAE0AAAAAACJSDf2gJlMRlUBAGi2zGcBADCfbTxWQAMA AAAAkIhGXwFdUlKi
qgAANEuZTMZ8FgAA89lGZAU0AAAAAACJSCsBQPIGjbllp7Z5T01QGAAAmrVZ r6+IH935bMydtzI+
M/awuOhfR0aPrm0VBoBaAmiA/UTgDADAgeQf89+Jb13z5/jvS8bG8cP7xjtr 1sdVP3wkxo4aGOd+
/ggFAiAibMEB8JEbNOaWuP3uaTH+/N9GRMTsf66ML1x4dwwde1uM+uLt8adH Xqtz7p33vhRjzv5F
DBl7azz27PzaY0uWZWL8+b+NYz7z03jyhYW17RXrNscF33kghp18W3z98gei Yn2logMAsM/u/MP0
uOSCUTF21MBoUVwQfXqVxPWXj4u5b6yqPSdTvim+NuGPMXTsbfG1CX+MsopN Hzp/ra8PAM2PABqg
CejWuXXc//NzIyLiqh8+EheeOyJemfzv8Z9fPz5u+PnTdc5dm9kQD/3ua3Hb tWfEJdf9rbb9ll8+
E2efMSzu+MHn48afPVWn/TsXfSpmPHRxnHn60PjJXc8pOAAA++yl2UvjUyP7 12nr1b1d3HjlqbWv
b7pjapzyqU/EzIcvjrGjBsZNd0z90PlrfX0AaH4E0AD7yaAxt9T+7OikUQOj ZYuCiIiY/Nvz4+QT
DomiwnR8duzgqFi3uc653/zysdGiuCDGjhoY1dXZ2vZX5iyLz4w9LI4c0jOm 3HNBbfuTLyyMAX06
RDqdH2NPOCSeeG6BhwEAwD4rX7c5Stq1qPecZ6YtitNOHBTpdH6MP+nQePrF RR86f62vDwDNjz2g
AfaT+vaAbtOqqPbf75VtjHv/OjveWPhu/HP+6p3ObdumeJdjVKzbHG1b73ws U7YxBp90a+3rVH6e
hwEAwD7r0K5lrC3bGF06tq5ty+UiKtZvjnbvz1nLKjZF65aFERHRqmVhlJVv +tD5a319AGh+rIAG
aGIunPhg5EXEF04bErff8C8N7teqVVGs27Dz/s5t2xTHa49dGvOemhDznpoQ rz9xmSIDALDPhpf2
iqnT3qrTNusfK+LMb0yqfd2ubYvYXFkVERHrN2yJdm2LP3T+Wl8fAJofATRA E7Ng8doYPbJ/HDG4
Z0x6cEaD+x05pGdMeebNmPX6ijj53F/Vto8e0T8WLFkbNTXZeOChuXHOt/+g yAAA7LOvnHlU/PhX
z8bTLy6Myi3V8caid+OaW6bE+WceXXvOqGP6xlMvLorq6mw89OS8OGFEvw+d v9bXB4DmxxYcAE3M
DVecEhOunxxlFZviwnNHNrjfhAtPiG9e/aeoWFcZN0784ItfvvON0THh+snx 0uyl0f+gDnHrNeMV
GQCAfTZsUPf43uXj4tZfPRsLr/lLdGzfMr565lHxpc8evt1c9FNxyXf/Flf8 4KE45vDecfPVpzdg
/rr7PgA0P3n3Pjort2Nj96KyWFnZfo8HWzTj8bjqSn/aDQBA85TJZKKkpEQh AABo1vPZ3991Zwwd
VhoFhYWRSqUa3P/l6dPiuBNPiwF9e8Z9U2bv0bV3lynbggMAAAAAgEQIoAEA AAAASIQAGgAAAACA
RAigAQAAAABIRLqxB8xkMqoKAECzZT4LAID5bOOxAhoAAAAAgEQ0+grokpIS VQUAoFnKZDLmswAA
mM82IiugAQAAAABIhAAaIAFvryiLC77zQBx+yk9ixGd+Gtf+aEps3FSV6DUH jbmlUc8DAODjZdbr
K+LL//m/cfgpP45rfzQlVqyuUBQA9pkAGiABl18/OY4f3i+m/eVbMeWeC6JV i8K46Y6nE73mvKcm
KDwAAHvlH/PfiW9d8+c47wtHxot//lZ8/ezhcdUPH4l7/jRTcQDYJwJogATM W/hunDV+WBQXpaNd
m+KYcNHoeHTqm7XHB425JR5++o0YPv5/4l8vvi/Wlm2sPTb7nyvjCxfeHUPH 3hajvnh7/OmR1+r0
u/Pel2LM2b+IIWNvjceenV/n2DaPPTs/hoy9NQafdGt87oLfxStzltW5v8lP zIuRn/3ZTmMAAPDx
dOcfpsclF4yKsaMGRovigujTqySuv3xczH1jVe05mfJN8bUJf4yhY2+Lr034 Y5RVbGrQPHXJskyM
P/+3ccxnfhpPvrBwn8erWLc5LvjOAzHs5Nvi65c/EBXrK+v0u/3uaTH+/N96 qABNhAAaIAGjjukb
N/9iajz48Gux6O33IpWfFy/++Vt1znn+5cXx7P/3jTj9xEFx6y+frW2/6oeP xIXnjohXJv97/OfX
j48bfv50nX5rMxviod99LW679oy45Lq/7fL6l1z3t7j62yfGnCmXxDe+fGxc ddMjdY7PW/hOPH3/
v9U7BgAAHx8vzV4anxrZv05br+7t4sYrT619fdMdU+OUT30iZj58cYwdNTBu umNqg+apt/zymTj7
jGFxxw8+Hzf+7KlGGe87F30qZjx0cZx5+tD4yV3P1enXrXPruP/n53qoAE2E ABogAddfPi6y2Vzc
8+eZccb5v4lTz7sr/jH/nTrnfPO8Y6O4KB3jTzo0pk5fVNs++bfnx8knHBJF hen47NjBUbFuc91+
Xz42WhQXxNhRA6O6OrvL6x9zeO94/pXFMX3G2zF6ZL+YMumCOscv+NIxUVxU /xgAAHx8lK/bHCXt
WtR7zjPTFsVpJw6KdDo/xp90aDz94qIGzVNfmbMsPjP2sDhySM+Ycs8F+zze ky8sjAF9OkQ6nR9j
TzgknnhuQZ1+J40aGC1bFHioAE1EWgkAGl/7ti3iu5eOjYiIivWVcd9fZsWV Nz4Uf/31V2vP6dal
TUREtGpZWOfPDd8r2xj3/nV2vLHw3fjn/NU7jd22TfGHXv+Wq0+Pi//rr3Hh xAcjnc6PST85JwYf
0rX2eLsGjAEAwMdHh3YtY23ZxujSsXVtWy4XUbF+c+3csaxiU7RuWfjBHLZ8 U4PmqRXrNkfb1jsf
29vxMmUbY/BJt9a+TuXn1TneplWRBwrQhFgBDZCAYz7z09i4qWrrxLl1UXz1 rKNjybKyHSbOWyfY
69dXRucOrWrbL5z4YORFxBdOGxK33/Ave/c/INq3jLt/ck68Mvnf46pvnxgX TnzQQwEAYLeGl/aK
qdPeqtM26x8r4sxvTKp93a5ti9hcuXWOu37DlmjXtmGLGlq1Kop1Gyp3at/b 8dq2KY7XHrs05j01
IeY9NSFef+IyDxCgCRNAAyTglNGHxF33vxxrMxtjc2VV/Orel2J4aa8659x5 7/TYUlUTf3vin/Hp
4wfWti9YvDZGj+wfRwzuGZMenLFX1x//1d/Ew0+/EelUfrRvW1xnhTUAAOzo K2ceFT/+1bPx9IsL
o3JLdbyx6N245pYpcf6ZR9eeM+qYvvHUi4uiujobDz05L04Y0a9BYx85pGdM eebNmPX6ijj53F/t
83ijR/SPBUvWRqxr2AkAAAqISURBVE1NNh54aG6c8+0/eIAATZgtOAAScOU3 x8QNP3syTvvKXVG5
pTqOPapP3HDFqXXO6dq5TYz87E/j2CP7xA+vOq22/YYrTokJ10+OsopNceG5 I/fq+tdfPi6uvvnR
uOy6v0d+Ki9uu/YMDwUAgN0aNqh7fO/ycXHrr56Nhdf8JTq2bxlfPfOo+NJn D6895zvf+FRc8t2/
xRU/eCiOObx33Hz16Q0ae8KFJ8Q3r/5TVKyrjBsnnrrP433nG6NjwvWT46XZ S6P/QR3i1mvGe4AA
TVjevY/Oyu3Y2L2oLFZWtt/jwRbNeDyuutKfvgB8mEFjbol5T01QCIAmJpPJ RElJiUIAANCs57O/
v+vOGDqsNAoKCyOVSjW4/8vTp8VxJ54WA/r2jPumzN6ja+8uU7YFBwAAAAAA iRBAA3wErH4GAAAA
Pg4E0AAAAAAAJEIADQAAAABAItKNPWAmk1FVAACaLfNZAADMZxuPFdAAAAAA ACSi0VdAl5SUqCoA
AAAAAFZAAwAAAACQDAE0AAAAAACJEEADAAAAAJAIATQAAAAAAIkQQAMAAAAA kAgBNAAAAAAAiRBA
AwAAAACQCAE0AAAAAACJEEADAAAAAJAIATQAAAAAAIkQQAMAAAAAkAgBNAAA AAAAiRBAAwAAAACQ
CAE0AAAAAACJEEADAAAAAJCIdGMPmMlkVBUAAAAAACugAQAAAABIRqOvgC4p KVFVAAAAAACsgAYA
AAAAIBkCaAAAAAAAEiGABgAAAAAgEQJoAAAAAAASIYAGAAAAACARAmgAAAAA ABIhgAYAAAAAIBEC
aAAAAAAAEiGABgAAAAAgEQJoAAAAAAASIYAGAAAAACARAmgAAAAAABIhgAYA AAAAIBECaAAAAAAA
EiGABgAAAAAgEenGHjCTyagqAAAAAABWQAMAAAAAkIxGXwFdUlKiqgAAAAAA WAENAAAAAEAyBNAA
AAAAACRCAA0AAAAAQCIE0AAAAAAAJEIADQAAAABAIgTQAAAAAAAkQgANAAAA AEAiBNAAAAAAACRC
AA0AAAAAQCIE0AAAAAAAJEIADQAAAABAIgTQAAAAAAAkQgANAAAAAEAiBNAA AAAAACRCAA0AAAAA
QCLSjT1gJpNRVQAAAAAArIAGAAAAACAZjb4CuqSkRFUBAAAAALACGgAAAACA ZAigAQAAAABIhAAa
AAAAAIBECKABAAAAAEiEABoAAAAAgEQIoAEAAAAASIQAGgAAAACARAigAQAA AABIhAAaAAAAAIBE
CKABAAAAAEiEABoAAAAAgEQIoAEAAAAASIQAGgAAAACARAigAQAAAABIhAAa AAAAAIBEpBt7wEwm
o6oAAAAAAFgBDQAAAABAMhp9BXRJSYmqAgAAAABgBTQAAAAAAMkQQAMAAAAA kAgBNAAAAAAAiRBA
CAE0AAAAAACJEEADAAAAAJAIATQAAAAAAIkQQAMAAAAAkAgBNAAAAAAAiUg3 9oCZTEZVAQAAAACw
AhoAAAAAgGQ0+grokpISVQUAAAAAwApoAAAAAACSIYAGAAAAACARAmgAAAAA ABIhgAYAAAAAIBEC
EiGABgAAAAAgEQJoAAAAAAASIYAGAAAAACARAmgAAAAAABKRbuwBM5mMqgIA AAAAYAU0AAAAAADJ
aPQV0CUlJaoKAAAAAIAV0AAAAAAAJEMADQAAAABAIgTQAAAAAAAkQgANAAAA AEAiBNAAAAAAACRC
QCIE0AAAAAAAJCKtBAAAAAAAB47lK1fF8pWrmsS9CKABAAAAAA4wV0y8OnK5 3Ac/2ezW35GL6qrq
99uztcfXVVTEpEl3N/p9NHoAnclkPF0AAAAAgI9YNpuNbDYbufd/Z7PZyOWy UVlZudOxpNgDGgAA
AACARDT6CuiSkhJVBQAAAADACmgAAAAAgAPZyhXLo6pqS5226uqqWPPuO4lf WwANAAAAAHAAe3f1
qnhp2gtRXV0VERFVVVUxe+aM2LhhQxQWFSV67bTyAwAAAAAcuIYefmTMmT0z XnjumejStWusWrEi
OnftFkOGHR7lZZlEr20FNAAAAADAASwvLy+GDC2Njp06x6IFC6Jr9x4xrPSI qKgoT/zaVkADAAAA
ABzg8vLy4rDBQ6NTp07Ro9dBsW4/hM8RVkADAAAAAHws5OXlRZeu3WLD+nX7 7ZoCaAAAAAAAEiGA
BgAAAAAgEQJoAAAAAIADTC6XaxL34UsIAQAAAAAOMDfd+IMmcR+NHkDf8P3v 7XXfnt27+WQAAAAA
AB97y1eu2uu+E6++Zq/7Lly8vFHfRyIroK+YePUenZ/L5eKmG38QQ4eV+mQB AAAAAB97y1eu2uuc
tSlJJIDO5XKRzWb3uF9BYaFPFgAAAABA7H3O2pQ0qQA6lUr5VAEAAAAAxIER QOcnVZhcNrvTT7am
Jma98lKsXL5sp2MAAAAAAHxgx5x1xbKlMfvVlyN
Re: Theme of RAP [message #99884 is a reply to message #99624] Thu, 24 July 2008 09:56 Go to previous messageGo to next message
Originally posted by: fappel.innoopract.com
if I understand your problem description correctly the line belongs to
the CTabFolder that is used for implementation of the PartStack (So the
line doesn't belong to the view itself). The standalone view isn't
stacked so there is no CTabFolder. That's the explanation why there's no
line.
Ciao
Frank
-----Ursprüngliche Nachricht-----
Von: dnise [mailto:dnise@hotmail.com]
Bereitgestellt: Donnerstag, 24. Juli 2008 05:33
Bereitgestellt in: eclipse.technology.rap
Unterhaltung: Theme of RAP
Betreff: Re: Theme of RAP
Frank Appel wrote:
> programmatically
Hi Frank:
Thanks for your reply. For the moment I can complete to set the
background
color for ViewPart Tab Header.But I have an other problem about this. I
am
sure there is a brown line in Perspective when I add ViewPart in it
except using "Layout.addStandaloneView(..)". I'll show codes for you as
follow
// has no brown line,because it use StandaloneView.
layout.addStandaloneView(TopViewPart.ID, false,
IPageLayout.TOP,
0.05f,editorArea);
//has brown line
IFolderLayout all =
layout.createFolder(Perspective.SPACE,IPageLayout.LEFT, 0.35f,
editorArea);
all.addView(ConceptViewPart.ID);
For sure you can understand me clearly,I also attach a picture
to you.
best regards
Re: Theme of RAP [message #100016 is a reply to message #99884] Thu, 24 July 2008 23:28 Go to previous messageGo to next message
Originally posted by: dnise.hotmail.com
Hi Frank:
Thanks for your reply first.
Is there any other way to change the color of viewpart border? Or should I
define a new Workbench?
Re: Theme of RAP [message #100030 is a reply to message #99511] Thu, 24 July 2008 23:52 Go to previous messageGo to next message
Frank,
> This may looks a little confusing, but the Workbench Thememanager
> approach is provided by RCP, while the low-level CSS styling mechanism
> is RWT (RAP Widget Toolkit) specific. The CSS styling mechansim can be
> used to allow a more 'webish' look and feel for each widget type.
Can I use the aformentioned CSS styling mechanism to change the border of
some widgets created via FormToolkit? For instance table or combo widget
to achive more 'flat' look.
Setya
Re: Theme of RAP [message #100139 is a reply to message #100016] Fri, 25 July 2008 06:38 Go to previous messageGo to next message
it is possible to remove the outer border of the CTabFolder using the
CSS Theming mechanism. But unfortunately it is not yet possible to
change it's color.
Ciao
Frank
Bereitgestellt: Freitag, 25. Juli 2008 05:29
Hi Frank:
Or should I
Re: Theme of RAP [message #100152 is a reply to message #100030] Fri, 25 July 2008 06:41 Go to previous messageGo to next message
it should be as long as the FormToolkit factories methods don't set some
properties like font, color etc. programmatically. Setting properties
programmatically override css settings.
Ciao
Frank
Von: Setya [mailto:jsetya@gmail.com]
Bereitgestellt: Freitag, 25. Juli 2008 05:52
Frank,
of
Setya
Re: Theme of RAP [message #100179 is a reply to message #100016] Fri, 25 July 2008 06:46 Go to previous message
Originally posted by: rsternberg.innoopract.com
dnise wrote:
> Hi Frank:
The CTabFolder border color (#cecece) color is still hardcoded in the
file BordersBase.js. Please feel free to file an enhancement request in
our bugzilla to make it themeable.
Not sure what you mean by "define a new workbench", but I don't see any
way to change this color except from patching RWT code.
Best Regards, Ralf
Previous Topic:Alternating Row-Colors in tables
Next Topic:Banner image & custom presentations
Current Time: Tue Sep 23 18:36:29 EDT 2025
Powered by FUDForum. Page generated in 0.06064 seconds
