Home » Eclipse Projects » Eclipse Platform » How to select editor based on content instead of file extension
How to select editor based on content instead of file extension [message #305902] Sun, 16 July 2006 05:40 Go to next message
Originally posted by: lmmw66-remove-this.telenet.be
Hi All,
I've written a plug-in that has a multi-page editor that handles special c
source files. The first line in those source files indicate whether my editor
can handle them. If my editor can not handle them I would like the
framework to open the cdt editor.
I associated my editor to the .c and .h extension; the problem is that
the eclipse framework now sends all .c and .h files to my editor, also
those that I can not handle. Is there a possibility to let the eclipse
framework decide on what editor to instantiate based on the content of the
file instead of its file extension?
ludwig
Re: How to select editor based on content instead of file extension [message #305938 is a reply to message #305902] Mon, 17 July 2006 05:02 Go to previous messageGo to next message
Originally posted by: tom_eicher.ch.ibm.com
Ludwig,
you can contribute to the org.eclipse.core.runtime.contentTypes
extension point. You would probably declare your own special-c-file
content type as subtype of C files, and contribute a describer that
recognizes your special c-files.
-tom
> ludwig
Re: How to select editor based on content instead of file extension [message #306000 is a reply to message #305938] Mon, 17 July 2006 16:31 Go to previous messageGo to next message
Thanks for the info Tom. However for some reason I can't get it working ;-(
My describer class never gets called by the framework.
This is the relevant part of my plugin.xml
<extension
point="org.eclipse.ui.editors">
<editor
class="org.eclipse.odt.ui.editors.OOCEditor"
default="false"
extensions="ooc,xml,c,h"
icon="icons/files/ooc_file.gif"
id="org.eclipse.odt.editors.OOCEditor"
name="OOC Editor">
<contentTypeBinding contentTypeId="ooc-source"/>
</editor>
</extension>
<extension
point="org.eclipse.core.runtime.contentTypes">
<content-type
base-type="org.eclipse.core.runtime.text"
file-extensions="c,h,ooc,xml"
id="ooc-source"
name="ooc-source"
priority="normal">
<describer class="org.eclipse.odt.ui.editors.OOCDescriber"/>
</content-type>
</extension>
When I open any .c,.h file, my OOCEditor is created. The OOCDescriber
class is never called. Any idea?
Thanks a lot,
ludwig
On Mon, 17 Jul 2006 11:02:27 +0200, Tom Eicher wrote:
> Ludwig,
> -tom
>> Thanks,
>> ludwig
Re: How to select editor based on content instead of file extension [message #306012 is a reply to message #306000] Tue, 18 July 2006 02:59 Go to previous messageGo to next message
> <extension
> <editor
> default="false"
> name="OOC Editor">
> </editor>
> </extension>
> <extension
> <content-type
> id="ooc-source"
> name="ooc-source"
> priority="normal">
> </content-type>
> </extension>
Start your target using -clean and if this doesn't help check the .log
for problems. Next, try with priority="high". In addition you might want
to use the existing BinarySignatureDescriber instead of witting a new
one. Take a look at the JDT Core plugin.xml how this can be done.
Dani
>Thanks a lot,
>ludwig
>>Ludwig,
>>-tom
>>>Thanks,
>>>ludwig
Re: How to select editor based on content instead of file extension [message #306034 is a reply to message #306012] Tue, 18 July 2006 14:49 Go to previous message
>> <extension
>> <editor
>> default="false"
>> name="OOC Editor">
>> </editor>
>> </extension>
>> <extension
>> <content-type
>> id="ooc-source"
>> name="ooc-source"
>> priority="normal">
>> </content-type>
>> </extension>
> Dani
>>Thanks a lot,
>>ludwig
>>>Ludwig,
>>>-tom
>>>>Thanks,
>>>>ludwig
The -clean option does the trick! Thanks a lot! Help was highly
appreciated.
ludwig
Previous Topic:cvs synchonization error
Next Topic:Disappearing Help
Current Time: Fri Jul 18 22:08:24 EDT 2025
Powered by FUDForum. Page generated in 0.05364 seconds
