Home » Archived » DSDP - Mobile Tools for Java (MTJ) » On-device debugging
On-device debugging [message #30737] Fri, 29 May 2009 08:40 Go to next message
Originally posted by: news.s237965939.online.de
I wrote a multimedia program which implements MIDI playback. I create a
midi-stream in memory and pass it to the built-in player. That works
perfectly on the emulator, on my Sony/Ericsson and on some Nokias I've
tried. But not on all Nokias and not on Motorola V3i (the only Motorola
yet I could try). I have exception handling on all the function calls
which I suspect to fail but unfortunately the exception messages are
rather meaningless (like 'device error'), so I cant figure out what's
going really wrong there.
Of course I've only tried devices supporting CLDC-1.1/MIDP-2.0. And
those support polyphonic ringtones which means to me that they support
midi playback.
I'm not sure but I think I've heared that on-device debugging is
possible on some Motorola cell phones. I can perhaps get a second hand
V3i and it would be great if someone could point me out how to do
on-device debugging. There must be a a piece of software running on the
device itself and another piece on the front end (Eclipse). That seems
to be the only way to find out what's really going wrong.
TIA,
Hans
Re: On-device debugging [message #30807 is a reply to message #30737] Fri, 29 May 2009 10:36 Go to previous messageGo to next message
Hello Hans,
MTJ provides a framework for on device debugging but the motorola specific
mechanism is implemented by the motodev studio for java
me( http://developer.motorola.com/docstools/motodevstudio/javame /) this
application uses MTJ within it.
Take a look at it and see if it helps...
David Marques
Re: On-device debugging [message #30842 is a reply to message #30807] Fri, 29 May 2009 13:08 Go to previous messageGo to next message
David Marques schrieb:
> Hello Hans,
> specific mechanism is implemented by the motodev studio for java
Thanks David,
the problem is that I don't own a Moto yet, but I found that I've an SDK
installed for Sony/Ericsson on-device-debugging. I'm happy to be an
owner of a SE but although I seem to have the latest version installed
my device (K770i) is missing in my list. I don't have trouble with my
software on that device but it would be interesting for learning anyway.
regards,
Hans
Re: On-device debugging [message #30877 is a reply to message #30842] Sun, 31 May 2009 12:00 Go to previous message
I've found out that it works alright with the JP-7 mdel. Thanks for
reading. But anyway, I don't have problems with this phone, but still
need debugging for Nokia and Motorola.
Hans
Re: On-device debugging [message #573680 is a reply to message #30737] Fri, 29 May 2009 10:36 Go to previous message
Hello Hans,
David Marques
Re: On-device debugging [message #573727 is a reply to message #30807] Fri, 29 May 2009 13:08 Go to previous message
> Hello Hans,
Thanks David,
regards,
Hans
Re: On-device debugging [message #573793 is a reply to message #30842] Sun, 31 May 2009 12:00 Go to previous message
Hans
Previous Topic:On-device debugging
Next Topic:Problems with obfusctaion
Current Time: Fri May 09 23:42:52 EDT 2025
Powered by FUDForum. Page generated in 0.02352 seconds
