Home » Eclipse Projects » DSDP - Target Management » Support for some kind of sync in TM
Support for some kind of sync in TM [message #30673] Sat, 10 January 2009 11:13 Go to next message
Hi dev,
I want to ask you one question, is planned some kink of
synchronization in feature ?
Because there is only one option and it's "Overwrite existing resources without warnings",
sync would be great feature
thank you for reactions
Re: Support for some kind of sync in TM [message #30779 is a reply to message #30673] Mon, 12 January 2009 08:09 Go to previous messageGo to next message
Hello sNOP,
integration of RSE with Platform Team/Synchronization has already been
implemented by a Student for the Google Summer of Code programme this
year, and it's just about to be integrated into the RSE codebase:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=185925
it will be in with RSE 3.1m5.
Martin Oberhuber, Senior Member of Technical Staff, Wind River
Target Management Project Lead, DSDP PMC Member
http://www.eclipse.org/dsdp/tm
sNop wrote:
> Hi dev,
Re: Support for some kind of sync in TM [message #30919 is a reply to message #30779] Mon, 12 January 2009 11:11 Go to previous message
Martin Oberhuber napsal(a):
> Hello sNOP,
great thank you
Re: Support for some kind of sync in TM [message #578405 is a reply to message #30673] Mon, 12 January 2009 08:09 Go to previous message
Hello sNOP,
sNop wrote:
> Hi dev,
Re: Support for some kind of sync in TM [message #578490 is a reply to message #30779] Mon, 12 January 2009 11:11 Go to previous message
> Hello sNOP,
great thank you
Previous Topic:Problem with RSE
Next Topic:Re: Publishing in new PDT?
Current Time: Fri Sep 05 15:18:18 EDT 2025
Powered by FUDForum. Page generated in 0.07277 seconds
