Home » Eclipse Projects » Eclipse Platform » Starting plugin on Eclipse startup
Starting plugin on Eclipse startup [message #305337] Thu, 29 June 2006 15:49 Go to next message
Hi.
Is there a way to mark that a specific plugin should be started (means:
the plugin.start will be called) when Eclipse is started, and not only
when first plugin operation is triggered?
I want refreshPluginActions to run when eclipse is started, thus my
plugin's actions will enable/disable correctly.
Currently, they are refreshed only after first plugin operation.
Thanks!
Hana
Re: Starting plugin on Eclipse startup [message #305340 is a reply to message #305337] Thu, 29 June 2006 19:04 Go to previous messageGo to next message
Hana,
I'm not sure there is a way, but I'm quite sure you should be strongly
discouraged from doing this. If all plugins did this activation on
startup thing, startup would take a very very long time...
Hana wrote:
> Hi.
> (means: the plugin.start will be called) when Eclipse is started, and
> not only when first plugin operation is triggered? I want
> refreshPluginActions to run when eclipse is started, thus my plugin's
> Thanks!
> Hana
Re: Starting plugin on Eclipse startup [message #305345 is a reply to message #305340] Fri, 30 June 2006 01:16 Go to previous message
Originally posted by: lars.nospam.org
You can achive this by using the extensionpoint org.eclipse.ui.startup
But like Ed says, if all plug-ins are activated early the overal Eclipse
start-up will be a slow
/Lars
"Ed Merks" <merks@ca.ibm.com> skrev i meddelandet
news:e81mb3$g2d$1@utils.eclipse.org...
> Hana,
> Hana wrote:
>> Hi.
>> when first plugin operation is triggered? I want refreshPluginActions to
>> run when eclipse is started, thus my plugin's actions will enable/disable
>> correctly.
>> Thanks!
>> Hana
Previous Topic:Ant SCP not working in eclipse 3.1.2
Next Topic:Is it possible to aggregate update sites?
Current Time: Sun Oct 26 06:58:11 EDT 2025
Powered by FUDForum. Page generated in 0.05282 seconds
