Home » Eclipse Projects » Dynamic Languages Toolkit (DLTK) » execute arbitrary scripts
execute arbitrary scripts [message #2630] Tue, 15 May 2007 11:00 Go to next message
Originally posted by: jgangemi.yahoo.com
hello all -
after an extended hiatus, i have resumed work on the perl
implementation that i was previously working on.
i'm looking for a way to execute arbititrary scripts to perform
actions - this would be akind to looking up the interpreter library
path. i see that i can get the InterpreterInstallType from the
ScriptRuntime (to get the correct interpreter location) and then i
could use Debug.exec in order to execute the script, but was wondering
if there was a more 'official' way.
thx!
-jae
Re: execute arbitrary scripts [message #2658 is a reply to message #2630] Wed, 16 May 2007 01:24 Go to previous messageGo to next message
Originally posted by: mikhail.kalugin.xored.com
You can fetch IInterpreterRunner from IInterpreterInstall object and
than use run() method. It requires launch configuration and so on. So
it's not a very comfort way. But there is no other official way, except
fetching IInterpreterInstall and launching using DebugPlugin.exec().
Mikhail Kalugin
Jae Gangemi wrote:
> hello all -
> i'm looking for a way to execute arbititrary scripts to perform actions
> - this would be akind to looking up the interpreter library path. i see
> that i can get the InterpreterInstallType from the ScriptRuntime (to get
> the correct interpreter location) and then i could use Debug.exec in
> order to execute the script, but was wondering if there was a more
> 'official' way.
> thx!
> -jae
Re: execute arbitrary scripts [message #2687 is a reply to message #2658] Wed, 16 May 2007 09:30 Go to previous message
yeah - the latter way seems best since i'm not interested in having
the user execute the script - it would be invoked by an action, etc to
perform some other type of action (format code using external script,
etc).
i'll keep the implementation generic and submit a patch once i get
things working so others may benefit.
thanks!
-jae
On 2007-05-16 01:24:01 -0400, Mikhail Kalugin <mikhail.kalugin@xored.com> said:
Previous Topic:Editor: Double Quoting
Next Topic:DBGp Debug Commands and Encoding.
Current Time: Sat Jul 12 01:59:01 EDT 2025
Powered by FUDForum. Page generated in 0.04460 seconds
