Home » Eclipse Projects » Eclipse Platform » MessageConsole + Hyperlinks
MessageConsole + Hyperlinks [message #304254] Mon, 05 June 2006 05:37 Go to next message
I am trying to add hyperlinks to my console (a la Java exception
reporting) so that I can navigate from errors to the source line/column
of my programs. I use messageConsole.newMessageStream() to get my debug
and error message streams and print messages to the console using their
..print() and .println() methods. However, when I try to add a hyperlink
using the addHyperlink method, I get a BadLocationException. I have
inspected the messageConsole.getDocument().getLength() and it is
constantly 0 (and that is the reason of the exception) although I have
printed messages using the print-println methods before... Any ideas or
examples?
In case it helps I am using Eclipse 3.1.0 under WinXP.
Dimitrios
Re: MessageConsole + Hyperlinks [message #304309 is a reply to message #304254] Mon, 05 June 2006 11:11 Go to previous messageGo to next message
Dimitrios Kolovos wrote:
> examples?
> Cheers,
> Dimitrios
The asynchronous nature of the console make this more difficult that it
seems it should be because writing to the console doesn't mean that the
text is actually in the document yet. You can get around this by using a
pattern matcher.
From ProcessConsole.java:
private class ConsoleLogFilePatternMatcher implements
IPatternMatchListener {
String fFilePath;
public ConsoleLogFilePatternMatcher(String filePath) {
fFilePath = escape(filePath);
private String escape(String path) {
StringBuffer buffer = new StringBuffer(path);
int index = buffer.indexOf("\\"); //$NON-NLS-1$
while (index >= 0) {
buffer.insert(index, '\\');
index = buffer.indexOf("\\", index+2); //$NON-NLS-1$
return buffer.toString();
public String getPattern() {
return fFilePath;
public void matchFound(PatternMatchEvent event) {
try {
addHyperlink(new ConsoleLogFileHyperlink(fFilePath),
event.getOffset(), event.getLength());
removePatternMatchListener(this);
} catch (BadLocationException e) {
public int getCompilerFlags() {
return 0;
public String getLineQualifier() {
return null;
public void connect(TextConsole console) {
public void disconnect() {
Re: MessageConsole + Hyperlinks [message #304346 is a reply to message #304309] Mon, 05 June 2006 18:51 Go to previous message
Hi Kevin,
I tried that and it worked :)
Dimitrios
> pattern matcher.
Previous Topic:remote debug, connection refused
Next Topic:why eclipse often occupy more than 95% cpu?
Current Time: Tue Jul 22 09:05:13 EDT 2025
Powered by FUDForum. Page generated in 0.06078 seconds
