Home » Modeling » OCL » How to retrieve a AbstractConstraintProvider Object.
How to retrieve a AbstractConstraintProvider Object. [message #30494] Tue, 26 June 2007 09:22 Go to next message
Originally posted by: firstname.name.gmail.com
I am going "further" in my OCL/UML validation. I can successfully parse
constraints and make multi-status reports. I am happy with that, but I would
like to be able to evaluate rules defined in a file.
I worked around the OCLConstraintProvider.
My main problem is that ocl file name is "hard-coded" by means of a plugin value
and in turn, I do not know how I may delete/add new ocl rules. I have tried to
deal with that by retrieving the OCLConstraintProvider object, in the
BatchValidationDelegate Class with the IBatchValidator validator to reinitialize
datas. But I didn't manage to get this object.
Anyway It seems to be not really a nice way to reinitialize values. So my
question is to know what is the best way (if there is one) to do that.
thanks.
F. Lagarde
Re: How to retrieve a AbstractConstraintProvider Object. [message #30668 is a reply to message #30494] Tue, 26 June 2007 10:56 Go to previous message
Hi, François,
If you don't want the OCL file name to be hard-coded, it doesn't have to be.
The OCLConstraintProvider in the example is just that: an example. You
can define a provider that finds OCL files in a user's workspace next to
his UML models, if that is what you need.
Are you trying to react to a user's edits in an OCL file? Perhaps you need
to track, for each constraint that your provider defines (via the
constraint descriptor, probably), the OCL file that it came from. Then,
when the users changes that file, you can invalidate all of the descriptors
that originated from it and purge the constraint objects, too.
Note that constraints can be removed from the EMF Validation Framework by
using the ConstraintRegistry::unregister(IConstraintDescriptor) API.
The EMF Validation Framework provides no means by which a client can
directly access its constraint providers.
HTH,
Christian
François Lagarde wrote:
> Hello,
> would like to be able to evaluate rules defined in a file.
> value and in turn, I do not know how I may delete/add new ocl rules. I
> have tried to deal with that by retrieving the OCLConstraintProvider
> object, in the BatchValidationDelegate Class with the IBatchValidator
> validator to reinitialize datas. But I didn't manage to get this object.
> thanks.
Previous Topic:OCL Interpreter Example
Next Topic:OCL query
Current Time: Wed Jul 16 16:25:40 EDT 2025
Powered by FUDForum. Page generated in 0.24966 seconds
